I guess I figured this was more of a high speed factor. As I am not a high speed driver (85-90 tops -- except for one 110 experiment) -- I didn't consider the temperature rating to be a serious factor and I don't expect it to become a problem for me down the road. But I am certainly no expert on tires...
Oh well, the good news is that when I drive my M, I seldom have to listen to her driving "advice".
Lynn
Well, I got a quote from the 5* body shop yesterday......$1517.00!! They have to replace the right front fender, take out 2 dents/gouges in the right front door, and they say that they have to sand and re-clearcoat the right back door and the hood to blend the paint so that it will look as it should. Here's hoping that they know what they're talking about. I have heard that metallic silver is difficult to match. This is the first time my M has been damaged....and it had to happen right in my own garage!!!
Lynn
http://albums.photopoint.com/j/AlbumIndex?u=1620463&a=12630411&f=0
Here's what Big Red's butt looks like with the dualies, spoiler, and removed lettering.
http://albums.photopoint.com/j/View?u=1620463&a=13138309&p=49828451&Sequence=0&res=high
I loved my Yokos on the Mark--they were very quiet and handled well--
http://homepage.mac.com/bugatti/jacob/interpretation/ChryslerAtlantic.html
http://www.ch70.chel.su/ccc/sport/chrysatlnext.html
Crossfire:
http://www.chrysler.com/experience/concept/
I believe Chrysler is going ahead with the Crossfire.
I pulled next to one and signalled the passenger (who was reading off some sort of checklist) but he wouldn't roll down the window. Both cars were white, with the side skirts which were also white. No front or rear extras, but the front fenders were quite flared. I didn't see the front of either car, but got a good look at the back. Strange looking dual exhaust; both sides had dual tips coming out of mufflers that clearly weren't production -- they were almost cube shaped. The exhaust was very low, the valence was only cut on the left side and both pairs of tips were completely below the valence.
They had some sort of big plastic tank in the back seat, a pretty large trailer hitch, and some contraptions hanging off the right side windows.
Neither car looked lowered, and the wheels were definitely not 18's.
Clearly these weren't Specials, but I don't quite know what to make of them. I'll be on the lookout for them again, but I rarely see these "test" vehicles more than once.
Igor
It feels like 34/35 to me, but I'll let you know when I check it.
(sorry, off the topic)
Ok and now for the Speed Limiter, it has to go. I was quite embarrased today while racing a Lincoln LS. I was pulling away from him (not realizing how fast we were going) when it kicked in
Anyone hear of anything besides the ASE chip that removes it ? I head about something from Kenne Bell ... dont know if it removes the limiter though...
Those pictures were very similar to what you just described - exhaust pipes sticking out lower than the valence. Actually my impression was that the whole rear was slapped on too high for the chassis.
I think those were supposed to be the 300N.
I will try to remember where I saw them.
Also interested in any info on the anti-foam that ajpiii talked about - sounds interesting.
bigmike5 -the "Special" uses the same emblem as the regular 300 but with the word "Special" on it so unless you look very close a picture would not show this. Also when you open the front doors the lower sill cladding has a metal plate with "Special" on it.
grunschev -what you saw was a mule. They take production bodies in use now and hide future engines ,trans under them to fool the public. As they are testing the mechanics off the vehicle they really dont care what body it has. So what you saw was a rear drive ,most likely V8 powered LX mule. I once saw the mules for the prowler , they used the prowler frame and powertrain but bodies from the Jeep Wrangler were used . Was the weirdest thing you ever saw.
Big Red's Wheel
The contact letter had some information on me, like that I have a 300M. I wonder if this is something that DC is doing. Hmmmm.
It's all lies I tell you!
Matches fine, don't worry! As long as they use the correct paint code, which is fixed to the inside door jam you won't have a problem.
Only makes me wonder why car manufacturers invite a lot of people intoa room and tell them a secret and then get all POed when someone leaks info.
By the way, the KDW in the tires' nomenclature means that they are rated for dry or wet roads. They also offer a KD version, which is strictly a dry road tire, and a KDWS, which is rated for use on dry roads, wet roads, or snow. Being from Texas, I'm not too worried about traction on snow covered roads.
These are also a directional tread design, so rotation is only front to rear.
I also received from Goodrich a Gtech Pro device, which they were offering with the purchase of 4 high performance tires. So far, I've only checked my 0-60 time with it. Over 5 runs, I averaged 7.64 seconds from 0-60. I was not using Autostick and my car's engine and exhaust are completely stock. I actually made these runs on my commute to and from work, starting from stoplights.
Lynn
Lflowers-Sorry to hear about your garage accident. With a teenage driver, my garage and the vehicle she drives are in grave danger Good luck with the paint job.
Silver
DO NOT USE:
Any cleaner that contains an acid (this will immediately react with and discolor the chromium surface).
Any oven cleaner.
Any abrasive metal cleaner.
Chrome polish unless it is buffed off immediately after application.
Any abrasive cleaning pad or brush.
A car wash that has carbide tipped wheel-cleaning brushes.
Personally, I use just a car wash shampoo and a wash mitt, followed every month or so with a coat of a polymer sealant (like Zaino, Meguiars, even Nu-Finish) for protection, which will last longer and protect the wheels much more than a wax. Also, be careful of tire cleaners, as they can sometimes stain this delicate chrome finish.
As mentioned with directional tires, they can only be rotated front/back and not side to side. But that's not entirely true... last month I rotated them side to side, it just required they be remounted on the wheels. Sure, it hurt to pay $60 for a rotation, but I figured since the tires cost $225 each, what the heck.
Igor
ps to 300Michael: Sorry, I don't even *own* a digital camera! I'm an old fashioned film guy.
I have a digital camera and some big pockets, but with my luck I'll forget to turn the flash off.
Crossfire, I think, is nice looking.
http://www.chrysler.com/experience/concept/feature9.html
It's described as having a supercharged 225 HP engine in this little sucker. Completely impractical for me for the next 18 years, but I like the looks of it. For other concepts just click on the little images at the top of the page. That CHRONOS is a tank!
