Brakes - both front rotors were glazed. "Excessive wear" the dealership said. I baby my Ax pretty much and I have a funny suspicion that it is due to the "soft" suspension setting allowing the momentum of the vehicle on a stop to exert even more weight/force on the front brakes causing excessive wear. You know it wasn't my driving that caused it when the dealer just slaps on two new rotors without even blinking. No more pulsating on regular or hard stops.
Driver's seat - well, they had to tighten up some anchor bolts again to try to resolve the squeaking problem. Seems to have worked.
Towing - very dissatisfied with the towing. Tranny hunts a lot between overdrive and 3rd and even second on moderately rolling to average sloped highway.
Campaign - CMUNIZ - I can't tell a difference either in the roof rail or anywhere inside.
Slip Yoke - had them lube the slip yoke per this online club and I still have the clunk at a stop or on restart.
-mike
-mike
http://www.fourwheeler.com/roadtests/50258/
Some cool pics of the Ax on fairly rough ground.
I thought the mainland US was the only place they were to be found? Someone must have really wanted one.
I think it is funny and sort of sad that I have only seen one other Axiom around where I live, but all the way down in
St. Thomas, one goes driving right by.
Axiom 4200lbs
Pilot 4400lbs
Volvo XC90 4500lbs
(All 4WD)
Unit body vehicles with complicated, not much articulation suspension components = heavy.
Does anyone know if aftermarket speakers or an amp will improve the sound or if it's the stereo itself?
Any suggestions on speakers would be a big help.
Ithan
-mike
Thanks for any help. I am going nuts over this.
They aren't FWD SEDANS!!!!!
Jees if you want a quiet SMVs, go get a Hondah or MDX or Highlander!!!!!
-mike
Can you tell us what part of the transfer case actually failed? Just curious.
Can you describe the noise better?
As far as loud engine at cold starts - it is weird, but the fan actually kicks in if it is warm outside or when the humidity is high regardless of the fact that the engine is dead cold. Mine usually switches off after about 15 seconds, when it realizes the engine is cold. The fan is driven by a belt, but its speed is regulated by an electrostatic clutch. The fan rotates at fairly low rpm until the clutch engages as a result of hotter engine temp. or turning on the A/C. It is a rather old design, which should be replaced by an electric motor.
Another question: I noticed that the AC on Axiom is not powerful enough to lower the inside temperature quickly. In fact, the coming out of the blower air is not that cold as on the other vehicles. Is this just a weak A/C, or there is a problem on my Axiom (low pressure in A/C line)?
Thanks again
Last year I spent 5 weeks out in the desert north of Barstow working on a NASA project. The average temperature was 106°F. The Axiom worked just fine in auto mode, I had the thermostat set at 75°F, but started out in 65°F just to cool things off first. Driving through the deep desert on dirt roads for 100 miles in 106°F: No complaints.
Didn't anyone tell you that you're supposed to read them all before posting?? JUST KIDDING!
Reading all 1680 posts would take the better part of a day even with a high speed connection. It's best to just look at what's been posted recently when joining in.
The spoiler involved drilling three 5/16" holes in the lift-gate, the middle was cake because it came through where the brake light is installed and therefore only involved drilling the outer skin, the other 2 outside holes involved drilling a clearance hole (5/8") through the inner skin for the screws to fit through. Once all of the plastic dress panels were re-fitted no screw heads were visible. Sweet. $260.00 painted http://www.customautotrim.com.
I did one more thing, I fitted a '4WD' emblem, the red one from a Vehicross, $10.00 new from the dealer onto the rear hatch.
My next project is to fit my drivers seat 1" riser brackets, they're designed but need to be fabricated. I'm also toying with a design for a combined front skid/dress plate, maybe one for the rear.
I'd love to put that spare tire somewhere else.
I am impressed - I think you deserve a free Krispy Kreme at the very least!
-mike
I don't know anything about the 2003 Axioms.
My engine sounds smooth and strong, even at start-up.
-mike
When I start my Ax up the electric fan is non-operative. I'm not sure if it is interlocked to the AC operation command or to a temperature high setpoint of the coolant. Verification is an easy test. I'll perform a functional analysis on my Ax. Although, Paisan, I'm sure you're right.
Also, perhaps operation of this fan is in the Owner's Manual?
-mike
I purchased a 2002 Axiom two weeks ago which was a dealer demo with 700 miles on it. I was very surprised after some driving how shaky and unsettled the suspension behaved. Vibration etc even on smooth roads. After the first week I returned to the dealer for some promised work on the car and was given another 2002 Axiom with 90 miles on it as a loaner. This ride quality on this Axiom was VERY different than mine. None of the shaking, suspension dampened the bumps well without being overly harsh etc. If I hadn't driven both of these in the same day one after another (twice) I wouldn't have believed they were the same vehicle. I have since read some discussions here and believe the intelligent suspension system has some inherent problems Isuzu isn't willing to admit to. Any help?
Does anyone know what the shocks do if the computer is detached? Is there some "default" mode they would be set at? It would be interesting to see how the vehicle behaves under those circumstances.
It seems like they are handing you a bunch of crap...they have to be able to test the vehicle to see what the problem is...
One other thing, is there any way to see if the "demo" vehicle has been altered in any way...maybe they have modified the suspension somehow...I know that's "reaching"...but It seems like you are getting the short end of the stick...especially if the difference is as noticeable as you say...
Let's not use the term 'weak suspension', of all of the 'hybrids' I believe that the Ax probably has the strongest suspension (and the most articulation), and the one you'd want anywhere tricky off the asphalt. How about 'truck-like ride'? The Ax sure is an anachronism. Looks like a wagon but rides like a truck, and for all their efforts Isuzu can't disquise this fact. I've learned to live with it, after all my Ax rides better than my friend's Mini Cooper, or my other friend's Tundra with the sport shocks (and man, does it rattle and squeak!).
From my experience just driving into work everyday I must confess that some mornings I notice the bumps more than others, I'm not sure if it's weather or my imagination, and I don't have the measuring equipment to quantify it.
I would sure like to drive an Ax with a set of new well tuned non ISC shocks, just for comparison. Expensive experiment.
Another thing is that I don't think the ISC shocks are very durable. I have had one shock already replaced and another seems to be going bad. I plan on replacing the shocks with Rancho 9000x sometime late this summer. At least one poster here has responded with very positive results from replacing the ISC shocks with the ranchos.
As I recall, another poster did unhook the ISC computer by disconnecting each shock individually. I believe he said the shocks essentially went to an extremely stiff setting.
-mike
-mike
I was just quoting what the media and advertisements say.
Sorento
Axiom
Montero Sport
All are TRUCKs that have AWD + Low Range + Full Frames....
-mike
The vibration I'm experiencing feels like the shocks not dampening even the smallest road irregularities. Other adjustable suspensions function on the premise of the shock absorber rod being moved up or down to place it in a different valving position and therefore changing the response of the shock to the road.
If I had to take a guess I would say the actuators moving the rod of the shock aren't working or in sync with the shock and I'm primarily riding on an improper valve area.
-mike
I love the truck, well built, solid and power. Oh, and I love the looks.
Now to the bad: The rear suspension absoltely sucks, does a horrible job of smoothing out the bumps (whether in sport or comfort mode) I spoke with the dealer, and Isuzu, not much help. But the dealer advised to maybe seek the help of a performance shop to possibly replace shocks with better ones. Other people have complained to them about the poor rebound control. I called Calmini performance in Cali, basically the the Axiom is a Rodeo with a real nice skin. But, when it came time to what to do about the ISC system, everyone shied away from an aswer, even the Isuzu cars north east manager, Eric. But one thing I did notice under the truck is that the front shocks (work great) have top mounted actuators, while the rears seem to share a remote actuator of some sort that has a hose connecting to the side body of the shocks. So basically, this weekend I am going to take a shot and replace the rear shocks with Monroe sensatrac's. They are only $50 a piece so if it doesn't work I can return. Does anyone have any advice they woul like to share?
