-mike
It was as if the center differential wouldn't disengage. I don't have to do this, everytime, I have made more of a habit of it to prevent any damage. Maybe the computer sensors need adjustment? Never had any real issues with it.
-mike
I have a Yakima rack installed on my Axiom - IMHO Yakima are better than Thule, a little more elegant, with tons of accessories.
I originally ordered a track system but couldn't bring myself to drill the roof, a lot of it had to do with the fact that the tracks need to be parallel but the Axiom roof seams are not. A mismatch which bugged me. No doubt the official factory roof rack probably has a way of solving the non-parallel problem.
I admit that I can't slide my crossbars but I genrally only use the basket. If you don't like the "temporary" idea I would recommend the factory roof rack. you can get it from http://www.partscheap.com/axioma.htm for $288.00.
If you are interested in the Yakima rack see message #313.
I have seen the Yakima rack and have considered it. I mainly carry skis and bikes and think that I would prefer having the rack futher back on the roof than where the Yakima would mount. Do you have noticeable windnoise with your rack system? I have the same concerns you mentioned about the dealer installed rack. I have seen one Axiom drive by that had the dealer installed rack. It looked fine but I couldn't tell how it was mounted on top. I actually wonder if they remove the chrome and black strips on the roof and place the rails there. The funny thing was that the other driver was just as shocked as I was to see another Axiom on the road. It is the only one I have seen since I bought mine. I am still surprised that these things aren't selling very well.
I'm sure that the roof strips would be removed and that screws would be used to mount the factory rack, how else could it carry real weight? Mounting it at the seams is an excellent idea, lots of rigidity there.
The Yakima rack mounts about where the roofline is at its highest, so it looks okay, I think it would look a little weird if was mounted towards the back.
My original advice still stands...if you want a permanent rack get the factory one.
I'm not sure where you live but here in LA there are very few Axioms, and even fewer 4x4 versions - I had a hell of a time finding a 4x4. I feel kinda special.
I think I read that the new concept supercharged Axiom has a recessed roof rack, so it does make sense to mount rails at the seams. I believe they also said it had a touch screen nav system, I would love to see that as an aftermarket upgrade.
I tried getting some information from my dealer about the dealer installed rack, but they were useless, they didn't even bother calling me back with a quote like they said they would. They didn't seem to informed about their rack at all.
I went to Sport Rack Outfitters who sell all sorts of racks on Saturday, they said the rails would not need to be mounted parallel and could follow the seams just fine. I will probably go there to have them installed and see if they can mount their rails in the seams, I wonder how hard it is to remove the chrome strips.
Anyway... I realize the Axiom is controversial and may not be selling that well. I think if it were advertised a bit, it'd probably really take off. My friends really like it.
Here's my question. The back and sides are pure style. BUT... The front of the vehicle is butt-ugly. The lights should be twice as big and the small grill between the lights should've been extended lower. It also needed a real bumper on the front if for nothing more than looks.
So the question is this... Is there anything aftermarket to maybe fill in the big vents and make it more flush and appealing?
Overall, I think I'm going to really grow to like it. I've read good reviews and bad reviews. But compared to my Explorer, it's a step up in luxury. I don't care if it really is a "Rodeo in a tuxedo." Not everyone drives off-road and in the woods. Some of us just want a nice commute to and from work.
-mike
I just mocked up your recommendation to put big round driving lights under the regular lights.
I wonder if driving lights are illegal anywhere and I'd be asked to turn them off? It'd be nice just to wire them in with the regular lights so one switch turns them both on if that's possible. I'd hate to drill for a toggle switch. And then I guess it has to be wired into the fuse box. Sounds like a pain.
Check out this mock-up. What do you think? I know it's crude, but it gets the point across. I also wouldn't want them very deep so they stick way out. I'm not even sure what's available.
http://www.geocities.com/shawnph1970/axiomproofofcconcept.bmp
-mike
The look of the front is growing on me. I even like the tan interior a lot, unlike some folks. I was thinking of getting the "nose guard" to keep off the lovebugs (used to be called a "bra"). Does anyone have one of those?
tidester
SUVs
-mike
PS: Corrected to be more PC for our host
Gas Cap loose
Poor fuel (not poor grade, just a bad batch)
Sensors
If it is the gas cap, it will re-set itself after it hits 1/4 of a tank IIRC. My bet is that it is either the EGR valve or the TPS (Throttle Position Sensor) we've seen a few CELs thrown due to those 2 items on Troopers.
-mike
If it is from bad gas, how quickly would that cause the CEL to come on? I have used a half tank since my last fuel up. This is the first time that I went to that station and it was definitely cheaper than other stations.
-mike
I called the dealer service department and they pretty much came to the same conclusion you did. They said that here in California with all of the additives, sometimes a bad batch can occur and cause the CEL to come on. He said drive it around as long as the engine seems to be running OK to see if it resets, and bring it in next week if it doesn't. I will top it off on the way home with a more expensive grade, hopefully this will work. I doubt it is the gas cap, I drove about a 120 miles since my last fill up. Thanks for the advice.
-mike
-mike
Secondly, I had to take my Axiom in for a trans re-lubricant so to speak. I have a 2WD and the it would lurch taking off - either stand still or rolling stop and was starting to "hit" pretty hard from 3rd to 4th. They said the factory did not lube the trans well enough and that the vent hole was improperly sized causing it to clog up.
Any thoughts on the second but really need help on the first.
Darin
2nd: These trannys are pretty hard shifting to begin with, that is what allows them to last 200K+. A smooth shifting tranny basically puts more wear on the torque converter because a smooth shift basically is the torque converter slipping to allow smooth transitions. It could be a clogged vent hole but I'd have to see it first hand to know if it was normal or not.
-mike
Oh, the steering problem. I had to get my alignment adjusted twice already. No pot holes and haven't touched a curb yet. I also have not gone off roading, except in chem/refinery plants that are pretty muched paved anyway.
Thanks again
Also, I just found out that the rear seat backs have two positions, it seems like the rattle isn't as bad in the more reclined position. Definitely makes the rear seats more comfortable as well.
-mike
IMO the mechanism does allow for a small amount of play, otherwise it would be a really tight fit which would make it difficult to engage into a locked position. Have you tried putting a little grease on the latch mechanism? If you look hard enough, you should be able to see it. On the Trooper we have these pull-up buttons on top of the seats, next to the head-rests. I believe it just pulls up a rod which engages/disengages the mechanism.
Let us know what you find out!
Normally I don't hear anything unless I hit a large pothole, then I can hear the seats rattle. I would like to fix this since it is the only rattle the Axiom has, but haven't had much luck yet. I tried to put a rubber tubing around the U-bolt so the locking mechanism would have a tighter fit, but it didn't help at all. I will fiddle with it more this weekend.
The trooper ones don't attach to the pillars at all, only the floor.
-mike
-mike
First off, anyone who is looking for a new 4WD and does not take the Axiom for a test is making a BIG mistake. This truck is AMAZING! Strong V6 w/230hp, TOD w/4LO, Limited slip differential, Intelligent suspension control, all on a real truck frame. Let's not forget the 17in alloy wheels, 6-disc CD changer, automatic climate control, auto-dimming rear view mirror, you want more?, go for a test drive. Oh yeah, does 0% financing and 10 year powertrain sound enticing?
No, I'm not a salesman but that's my pitch.
The only thing I don't understand, like has been mentioned before, is why Isuzu can't sell more of these by coming up with an ad plan that works.
Can't complain though, I got mine and so far it's the only one I have seen on the road.
k2rm (or anyone who can help) you mentioned in post#526 that you had a hitch installed. Do you know which brand? Hidden Hitch, Draw Tite, dealer... I contacted Hidden and they told me that their Rodeo model will work but "it does not look very well installed" their words not mine. I was told it sticks out beyond the rear bumper. I found the Draw Tite for $100 which seems decent and is Axiom specific.
Next, pitt4, are you still looking for mats? I found Husky liners that are custom fit for the Axiom. I didn't buy them, yet, still looking around. They are not cheap, $70 front, $70 rear but I guess custom costs a little if you want it.
http://www.suvxccessory.com/xccessory/2002-isuzu-axiom-liners-mats.html
Well that's it for now. Thanks for any help!
Welcome to the Isuzu fold by the way. Be sure to check out http://isuzu-suvs.com and send me Axiom pics for the owner's gallery!
-mike
I got my towing package from my dealer. The first Axiom I test drove had the dealer installed towing package and it looked really nice. It is designed so it curves around the spare tire so only the hitch receiver sticks out. When I bought mine, I just had them load one in the cargo area and installed it myself. It only took 6 bolts to install and maybe 20 minutes, very easy. You just need someone to help you hold it up while you bolt it to the frame. I think I paid $250 uninstalled for it. I knew I could have found an aftermarket one for less, but I liked the design of the Isuzu one.
Good luck
k2rm does you hitch look like this one?
http://www.draw-tite.com/index2.asp?page=prodsearch&searchtext=axiom
I agree, the rounded tube design looks great on the Axiom. There was one at the dealer with a hitch but I couldn't see any brand markings or stickers.
My friend has a 01 Rodeo and I helped him put a Hidden Hitch on it, looks nice. Since the Rodeo and Axiom share the same frame I was hoping the same hitch would work, my only concern is any difference in the rear bumber size.
Thanks again.
