Honda Odyssey Care and Maintenance
I'm one of those vehicle owners that put only about 4500 miles annually because I use public transportation in the NYC area. I've had my 2000 EX since August, but it has less than 2000 miles on it. Should I wait to hit the 3,750 mark to change the original engine oil formulation? It's got mix of 50/50 highway and suburban local miles. I think I should change in the spring, which would be about 8 months & 2,200 miles. Any opinions? It may be at the anniversary before I hit the 3750 mark.
The dealer is asking 6/84 I extended coverage for 1495( money back if not used). The power sliding door look like its going to break anytime. Is this door only covered in 3/36?
And How can you stop the auto door when closing?
Also, it is sometimes hard to decide whether mine falls under Normal or Severe driving conditions. The climate is mild in Seattle (40' - 90') year round, and we don't tow with the van or anything. So I think I may want to use a middle-of-the-road approach and perform maintenance every 5000 miles. If you look in the owner's manual, you would see that this approach would make the schedule line up nicely with Honda's schedule for more extensive maintenance (at 15000, 30000, 45000, etc.) Other times it's mostly oil and lube and tire rotation. What do you think?
While the car is off, push and _hold_ in your Trip meter button, then while still holding that button in... turn your ignition key to _On_ (not start). Wait until light goes out or you need a hair cut... which ever comes 1st. LOL, seriously it should go out in about 15 seconds or less.
We need help to cover a scratch today located in the center of the rear bumper of our 2001 GG Odyssey. The shape/size is a reverse "L" with 0.5 inch wide/0.75 inch tall (no dents).
I had attempted to change the oil on my 2000 Odyssey using the same ramps I have used on several other cars for the past 20 some odd years. The Odyssey's bumper hits the ramp before the tires do. Trying to jack up the van and using jackstands won't bring the van high enough (besides being a big pain in the butt!). Any suggestions, thanks.
You get them at stores like Pep Boys. Maybe $49 bucks for the pair. Pretty much indestructible.
Eric
2001 EX TW - Trans Cooler, Wheel Well Liners, Nose Guard, Steering Wheel Cover
KarenS
Owner's Clubs
What grade oil to use? The manual states 5W-30, however, the dealer (and other sources) state 5W-20 -- which noone seems to make except Honda. I didn't know Honda manufactured oil! The use of these oils is for the "average" car buyer, most likely a "midwest" climate with harsh winters and moderate summers. I've come up with this plan: use Mobile 1 synthetic 10-30. The 10-30 because of my extreme heat situation and Mobile because it does not have polymers or zinc in the mult-grades (and it is rated tops, behind Amsol, in several sources). So, is the 10-30 the way to go? or should/could I go with a single grade 30? (at least for the summer months) I want to stay within the parameters of the vehicle warranty.
I am a maintenance freak (there... I admitted it) and want to make sure the best oil is used. I will probably change at 5,000 miles regardless of what any source says. Hey, I'd rather "error" on the safe side and spend just a little more money each year -- it certainly won't hurt. I plan on keeping the Ody for a long time.
I would appreciate any experienced/professional advice.
My preference has been to change at the 3,750 interval, using name brand 5W-30 conventional (as opposed to synthetic) oil. My current vehicles are a 1957 Chevy Wagon (a toy) with 110,000 miles, 1988 Volvo 760 Turbo Sedan (spare car, for when van or pickup is in shop, or when my sister comes to town with her kids for a month. Used to be the primary Mom and Kids mobile) with 180,000 miles, 1991 GMC Pickup (my daily driver)with 160,000 miles and the 1999 Odyssey with 39,000 miles... So I bet I'll keep mine longer than you'll keep yours!
The climate in Colorado is definitely different than what you describe, so I'm neither experienced nor the proffesional you requested. But I'm opinionated, and that counts for something, doesn't it?
Hope this helps,
Rich
"I've have experience removing the EX roof rails. You will need a T30 Torx bit to remove them. And when you do remove them you'll notice that the roof molding (or the black plastic strips) are cut into 3 seperate pieces. So you would have to buy 2 replacement roof moldings for the left and right side of the roof. You could get them at Handa-Accessories.com for about $40 each.
-nemogira "
How do I access the area behind the holder to determine the problem?
Using dealer AA08 syntec (CASTROL SYN 5/30) at six months/ 6000 mile interval since first oil change.
No oil use, but the oil seems much more dirty than regular CASTROL oil changed at six month/ 6000 miles intervals on my 1994 Sable with 113,000 miles.
Is this sign of blow by? Is Syntec dirtier? Do I need better filter than the HO15400-poH-305 now used by the dealer?
This is my first experience with snytec. My earlier 1991 Accord used regular oil, stayed clean like the Sable.
We plan to keep the Ody for some years.
Any advice would be helpful. thanks, wdf1
KarenS
Owner's Clubs
The owners manual says to change it at 30K miles.
But it doesn't show where it is or how to get to
it. The dealer wants $38 for the filter, plus
1-2 hours labor.
I'm tempted to order the shop manual, hoping the
info is in there. But thought I'd ask here first,
in an effort to save a few bucks.
Carl
I know in Accords it is tough to do the first time since there is some brace that needs to be removed. I don't know the procedure, but 1-2 hours is quite a range. The dealer should have a book that lists the labor time for that job.
standard warranty of 3 yrs. or 36K miles from either a 3rd party or
Honda. There is a list of Honda dealers on the main Honda thread
on this web site that selling the Hondacare 7 yr/100K 0 deductible
for around $900.
the maintenance light will blink several times and stop, the maintenance light should
now be reset.
http://partscheap.com/
http://www.handaaccessories.com/
You got 23 MPG with 5W-20 synthetic oil. Whats your driving condition? What kind of MPG did you get prior to use synthetic 5W-20? I could get 23 MPG all freeway driving with non-synthetic oil
bjk
