2002 Odyssey EX
Haven't done that yet. Sick kids, blah, blah, blah. I'll certainly post if that turns out to be the magic bullet.
Something to remember....always check the fuses (or lack therof).
Did anyone ever installed GNET_RGB_HONDAACURA20 in there ody? I looked at there website and it sounds pretty good but I am not sure if true.
http://www.gnetcanada.com/navvideo-models-gnet_rgb_hondaacura20.asp?Car=Honda%20- Odyssey
Thanks :confuse:
Hi All,
I'm new to this- just got my Odyssey today! I want to add an
audio line input to the standard stereo. There is a button for
"Aux", which I gather is intended for a CD changer or cassette
deck. From what I've been able to glean from Google, they don't
give you a simple stereo line in, and I need some multi-pin
converter box to interface with the stereo. Looking through
some of the vendor's sites, I haven't seen any mention of 2007
models, and I'm also not clear if these work with the basic LX
stereo system... I don't have a CD changer, satellite radio, or
a DVD player.
Could someone point me in the right direction?
Once you get the connector, you can plug anything into it that you want to. I have a USA spec ipod gizmo that has the aux connecotr, and outputs for an ipod (dock port), and also a set of RCA plug inputs in case you want to use something else. So, I can use an XM roady or something like that.
Check out Crutchfield.com. They will tell you what works with your car, and show the range of options. If they don't have '07 listed, look at '06. It will give you your options, although you mind want to confirm with Honda that the plug did not change (very unlikely).
email: buynewcar@yahoo.com
We just bought a '07 ody EX. We want to have Nav with bluetooth installed. Looked at Z1 and several websites say it will not. Can you post send some pictures so we can see and show the installers?
AP
Yesterday I found a very innexpensive and easy way to connect our Ipod to our 05 Touring's stereo system. In the very back left armrest is a flip-open storage compartment that has auxilary inputs for audio and video, as well as 3 standard headphone jacks. I took a long (about 10' long) 3.5mm headphone extender chord that I happened to have laying around, as well as 3.5mm-headphone-jack-to-RCA-splitter, and connected that into the audio inputs in that compartment. I ran the chord out of the compartment, straight down and tucked it under the plastic at the edge of the carpet, then ran it under the plastic side door molding (by tucking it underneath), then underneath the carpet, and up to the center armreset between the two front seats and into the Ipod. If you turn the Ipod volume up to almost full volume, it's about the right input level. Turn the stereo on, hit the "Aux/DVD" button until is says "Aux", and viola - iPod on the stereo... You could get a holder for it if you wanted, but we'll probably just leave it loose in the center console. It's been a while since I bought that 10 foot extension for the headphone jack, but I'm guessing it's pretty inexpensive from a Radio Shack store. Same with the headphone-to-RCA splitter. My guess is less then $15 for both. Sounds great, and no more FM transmitter (yeay! I hated that thing).
The only work around I can think of is to rip the DVD's and re-record them with region 1.
stereo adapter
headphone 10ft extension
Thanks for your help!
Wonder if/when Honda will just add an aux plug to the Ody? Even the Civic (EX at least) comes with one. Will probably be standard on just about everything in the near future.
Dave
I usually put it on shuffle mode and tuck it away in the cubbie. If I don't like a song, a quick thumb to the channel up button on the steering wheel and it skips to the next one. I also adjust volume that way.
If you decide to pick a new artist or genre, just pull out the ipod and change it that way.
I've moved your post to the existing Odyssey Nav System topic, where you'll probably get a quick answer.
The XM radio expired in my Odyssey.
I had read that you can get a discounted price on some website?
Any thoughts?
I have an 04 Ody and am thinking about changing out te front speakers with something better. I am a bit of a klutz. Anybody here attempted that? How big a deal is it? What's the most likely obvious thing that I'll miss?
Many thanks....
The sattelite radio competition is fierce now between XM and Sirius. We let our Odyssey XM expire and watched the coupons start being mailed to us. 2 mos. after we let it expire they folded and sent a card stating 4.99 per month. Deal!
