tidester, "Volvo XC90 SUV" #930, 3 Jan 2003 9:19 pm
-mike
-mike
is now stuck in the far back position, which is fine for me, since that is where it usually
is. However, my wife can't drive the vehicle in bad weather now. Does anyone have any
idea how much it will cost to replace, or where to get the parts? This is the second
electrical item to fail. I shoulda got the extended warranty.
had to be replaced. My service guy gave me a 10% discount, so I ticked in under
$500. For comparison, the seat place in town would have been about $60 less, but
would have taken longer. The parts were $270. What a rip.
1.Are the newer models user friendly as far as basic maintenance like oil changing etc?
2.Is there anything I should be aware of to look out for or problems that people are having with the newer models?
3.The oil appears virgin, but I plan to use Mobil one Synthetic when I change it. Any body have any luck with accessories to help improve gas mileage a bit besides using synthetic oil?
4.Can any one recommend a web site or store that sells a good Kayak carrier for the roof and a rear hitch cargo hauler?
Thanks in advance for your help!
The first major problem I had involves the "DTE system" not working. i.e., twice - when the tank showed I had 1/8 of a tank - I RAN OUT OF GAS. The "DTE" system did not engage, the yellow gas-low light did not work. Just.. all of a sudden the DTE went to a flashing "---" and the car died. Twice. That's apparently fixed now.
The other problem was the right front brake - the caliper got stuck in a closed (or open?) position and wore the brake pad out and almost damaged the rotor. The brakes had been squeaking, I'm glad I brought it in when I did. Both were warranty issues but a pain in the you-know-what. I love driving my "pathy" but honestly if the Honda Pilot had fit into the garage, we would have gotten that instead!
I've just bought a 1998 Pathfinder and I just discovered a goofy problem the previous ower decided not to tell me about. Some times when I first start the truck in the morning, it will be running just fine then you put in gear and it just dies, and it will do it over like 5 or 6 time in a row then it will be just fine for the rest of the day. Has anyone else had a problem like this?
Jake
The last time it did this the check engine light came on during the trip.
Any ideas?
Hope It Helps - Jo In Texas
i'm having an issue with wiring/relays... can you please provide to me the instructions for locating the relay box? specifically for the turn signals/flashers?
thank you thakn you thank you thank you!!!
SUVs and Smart Shopper
my code says:
P0158 Rear O2S, Bank 2
i think it is:
part # 226A1-4W011
can i reset with this procedure?:
reset procedure after replacement:
http://www.nissanhelp.com/Ownership/Common/codes3.htm
thanks in advance!!!
also, to reset the error code, can i just unplug the battery for 10 minutes after i put in the universal sensor?
thanks!!!
also, about the reprogramming, i have 91k miles and the dealer told me it's $330 to reprogram the thing. so, i'm thinking the old sensor lated quite a while, how long til the new one blows out?
also my BOTH of the catalytic converters rusted out! and it's only a 2002! i cna have universals welded in a meineke for $total but the friggin' warranty should be 8 years!!!! but i got too many miles.
you think i'm ok not to reprogram? and also, is the universal easier and just cut and solder underneath the car, and seal with shrink tubing or electrical tape?
thanks for all your thoughts!
i'll hook it up and do the battery disconnect for 10 mins, and then if all is well i'll pass inspection ASAP!!!
been driving for 4 months with "rejected!" for this one reason alone. luckily no tix yet!!! LOL
the dealer won't ECM for free due to 91k miles... it's a scam!
not sure if you even still own this Pathfinder, but did you ever figure out what the problem was? Just bought a used 98 Pathfinder and it's doing exactly the same thing you describe.
OK
I trust my mechanic and when i asked him if I should have the work done to stop the oil loss he said not to bother since body rot is the number one cause of death where I live. He said just keep feeding it oil.
Any ideas if this is a simple switch or something that I can easily replace? Hate to have to bring it to the dealer and spend a lot of money to fix.
Basically i'm down to this i've checked everything i can think of and when it came down to simple spark plugs its sparking but i noticed that i can pull the 4 and 6 plug and it has no effect on the engine it's still idling rough and not rougher. i can't even go up a hill with this thing without it dropping down to 1st to get up the hill. i smell light gas odor on the plugs when i pull them back out but i'm lost at this point (and yes the distributor order is correct i've checked that) on that note i have also switched the 4 and 6 plug and this doesn't do anything either help im lost. btw its a 93 pathfinder 3.o sev6
:mad:
I just bought a used pathfinder 20001 se, with 60k miles on it. Nearly Everything works fine, as it is still under extended warranty.
There is one thing which is driving me crazy. If I am driving at low speed at 40 mph and let go of accelerator, then if I slightly tap the accelerator instead of pressing it down hard as I just want to increase the speed slightly, it makes at lound whirring noise at 1500 rpm and 45-50 mph. If I keep the accelerator pressed hard, then it does not happen as it shifts from 2-3-4.
When it is whirring, I think the response goes down also.
I am thinking it is a timing belt or transmission issue.
Before I got the car, the dealer had installed a new transfer case, harness wiring.
Any help on this would be appreciated as do not trust the dealer to much to really take an effort to replicate the problem in the workshop.
Khurram
Khurram
Service Bulletin Num : 00053
Date of Bulletin: JUN 19, 2000 View Document
Component: POWER TRAIN: AUTOMATIC TRANSMISSION
Summary: SOME APPLIED VEHICLES MAY EXHIBIT A CHIRP NOISE AS THE AUTOMATIC TRANSMISSION SHIFTS FROM 2ND TO 3RD GEAR, PARTICULARLY WHEN ACCELERATING THE VEHICLE WITH ONLY 1/8 THROTTLE APPLIED, THE NOISE MAY BE COMING FROM THE HIGH CLUTCH ASSEMBLY DURING OPERATION.
Now the Nissan service center says the squealing is from a broken power steering pump and that it is not the same problem as all of the previous squealing. They further state that it will not be covered by the warranty since this was not the problem initially and the car is out of the warranty period.
My question is: is it possible that this was the underlying problem initially? Is it reasonable to think that a similair squeal recurring over the course of 2 years is the same issue or is this two distinct problems? How would I differentiate? And how do I know that the fuel pump was even checked during any of these other visits.
Haven't seen you post anything more on Bose Clarion CD changer issue. How did it get resolved? I have the same problem. Did you make a deal with Nissan not to post any more comments about this issue if they took care of you?
