I am new at this website. I think it's great that everyone sharing their ideas regarding vehical.
I just got a new 2003 LE. It's much nicer than my old 95 PF. For Nissan Pathfinder, it has come a longways.
One Problem I am experiencing is a noise coming from engine JUST AROUND 2,900 RMP to 3,100. Have not had a chance to bring it to the service department yet. It sounds like crakling noice as you are in too high of a gear in stickshif. Has Anyone experienced this problem? If you did what was the problem and the solution?
He should be able to provide you with the correct part number for your oxigen sensors (the ones before and after the catalytic converter) then you could search here for your part or some other web site. http://www.nissanpartswholesale.com/oxygen_sensor.html for the part.
Has anyone had any luck with Nissan in getting their "satellite-ready" radio correctly modified? I was on the message board several months ago about this. I had bought an '03 Pathfinder LE and purchased the "satellite-ready" radio option. The radio was to have had a satellite tuner installed when the dealer got them. After many months of zip response or help from Nissan, they finally said they weren't going to install them (they said quality control problems) and I was out of luck unless I wanted to get an FM modulator, which I don't. I would like to hold out for true digital satellite sound. Has anyone else with this problem had it resolved? Thanks in advance for your response.
I have a 99 3.3 lit. pathfinder. I am having problems with the 02 sensors like a lot of people do with these models. I was wondering whick set of sensors go bad is it the ones before the catalylic converter or the ones after it. thanks
i just bought a 95 SE sport, It is exactly what I was looking for except that the spare tire is mounted inside the cargo area. It kills the cargo space. Last week I had to take out the spare tire mount completely to fit something in. Its a terrible design, it definitely has the room to haul, but not with the tire mount in place. Has anyone tried to attach a pathfinder swing away from the junk yard? Any problems with that? Is there an after market solution? I've spent the last week trying to find a solution and have seen nothing relating to my car. Any help or direction would be greatly appreciated. thanks in advance.
There may be aftermarket solutions for your model year. Try http://www.4x4parts.com. If you don't see the part listed anywhere on their site, give them a call and they should be able to point you in the right direction.
The steering lock of my 99.5 LE 4x4 decided not to budge forcing me to get a wheel lift tow to the nearest dealer today afternoon. Since the truck was with the dealer, I have also asked the shop to read the engine computer to tell me the reason for the persistent but intermittent Check Engine Light problem I have been having.
What do you think should be the cost (diagnostic time) for the Check Engine Light issue? My gut feeling is that it should not be more than 30 minutes of work to plug into the computer, download the records and then look up the appropriate books. Any thoughts on this?
BTW, this was the third time in the past six months that the steering lock got stuck. On the two earlier occasions, I was able to solve the problem without taking it to the shop (use shift release to release tranny from P, rocking the steering wheel while turning the key etc.). However, this time it would not budge though I tried multiple times, including an overnight rest.
The dealer has given me an estimate of 3 hours of diagnostic for both the problems which to me looks on the steeper side!
The dealer has given me a quote of $500 for changing the ignition lock (the part alone lists at around $150, though can be had for 25% less). I am stuck with them since the car is not drivable right now. They will also rekey the new lock so that I can use my current key. I guess I could have saved some money taking it to an independent shop .
I am glad I did not ask them to run the diagnosis for the check engine light!
daqman: Try Ebay. Also if the car is totalled and insured, the insurance company will deduct the salvage value of the vehicle from your claim if you keep the vehicle.
Have a 2001 PF GLE with 27,000 miles. Been a great vehicle except for something terribly annoying...the belt keeps slipping. Have been to the dealer numerous times and have had the belt changed TWICE...thats 3 belts in 27,000 Miles!!! Sometimes it squeals when the wheel is turned hard, sometimes for not apparent reason at all. Dealer cannot reproduce the problem. Could the pulleys be glazed? Could something be seizing?? HELP!!! Next closest dealer is 150 miles away.
I have a 2002 Pathfinder LE with one nagging problem.When i accelerate on a hill,hit a bump,or make a sharp turn,the interior lights will flicker along with the door ajar light.It only seems to do this when the temperature goes below 40 degrees.It is more annoying than anything else.Does anyone have any idea what can be causing this?
beaulier,It is possible your idler pulley is bent,misaligned,or the bolt that tightens and loosens your drive belt on the idler pulley is stripped.Your idler pulley is what tightens and loosens your drive belt.
Also check that the groves in the pulleys are clean right down to the sharp inside. Any gunk in there will hold the belt a little out and it will have a lot less grip. "V" Belts are designed to get most of their grip on the sides of the "V"s, and this includes the multi v type. You can try a "belt dressing" (available from auto parts places), which lubricates the belt so it sinks into the "V" easier and further. It runs cooler and lasts longer as well.
It sounds like the door ajar problem is caused by one of the door switches. Try wiggling each one in turn. Either one is broken or has a connection problem. They are on the door posts (you will see a rubber boot). They should just pop out for inspection.
Just washed mine and had a closer look. To get the door light switch out you have to remove a screw. No big deal, just correcting what I thought was a "pop out" switch.
After checking on pathstar1's alternative, consider that the door is not aligned properly. I've had this problem on other vehicles where the door needed to be adjusted on the hinges. It was making poor contact with the switch, so body flexing (turns, bumps, etc.) caused the switch to open briefly.
If this is the case, you can sometimes find the offending door by determining if a sharp left or right turn causes problems (if it only happens on sharp left turns, it is likely a right door, etc.). Either that, or alternately tape closed all switches but one and drive around until you discover which one flickers...be sure to consider the hatch.
can someone please clarify. how do i get into 4x4 mode from a standstill and as well as straight driving. manual seems a little confusing. if neccessary please post all details including using reverse. so far heard different things from everyone under the sun. oh i have a 2000 se.thanks in advance.
I've checked the four passenger door switches and they do not seem to be the culprit.I've opened each door and pressed my finger over each door switch and wiggled the switch while pressing it and the interior light would not come on.I suspect the rear hatch switch has something to do with this since it does it most when I accelerate going up hill. This problem has "Cannot duplicate" written all over it since it only does this in cold weather.It is a major hassle leaving the truck at the dealer since I work alot alot of hours.But I definetly want to get this taken care of before the the warrenty expires.BTW I owened a 2001 Ford explorer sport before the Pathfinder so you can imagin my dread going back to the dealer.But I still love my Pathfinder a million times over the Explorer!!!!
Most recent Pathfinders and other SUVs are "shift-on-the-fly" style 4 wheel drive systems. (That means you don't have to get out and manually "lock" the hubs of the front wheels.) They have a short "lever" next to the automatic transmission selector or manual gear shift. This short lever is used for the 4 wheel drive control. In normal 2 wheel drive, it is pushed all the way forward. To shift into 4x4 mode, pull it back one position ("click"). This is 4x4 "Hi" mode. You can shift into 4x4 Hi at any speed <50mph. 90% of people never have to use any other mode. The next position back is neutral. Used only when the truck is being towed. The furthest back position is 4x4 "Lo". The vehicle MUST BE STOPPED to shift into 4x4Lo. It should only be used for severe traction conditions -- i.e., "off-road" -- I can't think of too many conditions where the average driver wold ever have to use 4x4Lo. If conditions are bad enough where you would have to use it on the street, stay home!
If you have an SUV other than a Pathfinder, or have a "pushbutton" 4x4 selector, obviously these instructions may be incorrect -- Check your manual!
Note to Golgo31: If you really aren't sure how to use the 4x4 system, I'm sure the dealer or your mechanic would be happy to give you a short lesson. And I'd recommend it.
My 01 Pathy has been running through way too much gas lately and the idle between 1500-1800 makes the car shudder and hickup. Also, check engine light came on twice in the last month. I've got 69K on it so the first time I brought it in for the light they said it was an 8 trip ago light for the ignition coils, but they rarely do them in a Pathfinder, so they reset it and charged me $72 and sent me on my way. Well it went off again over the weekend, then turned itself off but I had it checked yesterday just in case and was told this time it really was the coils...not one ...all 6 bad. The estimate for this repair was $720. I told them to order parts as they had nothing there so I've got a 1-2 week window before I have to pony up the dough. Has anyone else had this issue? This seems excessive...all 6 bad at once?
I own a 2003 SE 4WD with about 1800 miles on it. For the past 300 miles the top of the steering wheel cowling has been rattling persistently on all road surfaces except the smoothest surfaces. This is very annoying, especially in a nearly new vehicle, and makes the structure feel cheap - don't want to think this way because I love everything else about the vehicle so far.
If I push on the top of the steering wheel the rattling stops, so it seems that if it is possible to put adhesive on the bottom aspect of cowling and affix it to the underlying structure this would solve the problem...not sure if this is possible or wise to attempt however.
Has anybody had luck getting rattles removed by the dealers under warranty? Especially similar steering wheel rattles??
Did you try to tighten the screws around the steering wheel cowling?Sometimes the noise can be something as simple as a loose screw.When I bought my Pathfinder I had a rattle at highway speeds around the front passenger side fender.It turned out to be a loose screw that connected the front mud flap to the wheel well.To make a long story short I tightened the screw,the noise stopped,and it saved me a trip to the dealer.
I too am having the same problem with the interior light. the dealer put in a new switch last night, but on the way home, during turns, the thing went on. I took it right back. I am going to call them this morning and have them check the alignment on the rear hatch door. My truck also makes a lot of noise around 3K. It sounds like the motor is going to seize up. The loaner maxima I am driving is buttery smooth and quiet all the way to redline :-)
I haven't gotten a chance to get my truck back to the dealer yet.The interior/door ajar light comes on very sporaticly.Seems to be at it's worse when the temps go below 35 degrees. Please let me know if the dealer corrects the problem.When I get around to leaving the truck at the dealer I'm going to wait for a serious cold snap.
I just purchased a 2003 pathfinder se 4x4 that's the same problem described by bd70. The rear liftgate tends to bounce back when I attempt to close it. While the liftgate appears to be secure when you push on it you can feel some play and the interior light stays lit. This is extremely annoying and I'll it back to the dealership for servicing.
dmcmd, When I returned to the dealer for service after I posted that message, I complained about the liftgate not closing, thinking that it was a problem with the latch. The service rep explained to me that the seals on the doors are very tight and it was his experience that sometimes this would cause either the doors or rear hatch to fail to close securely if you didn't slam them shut and all of the other doors/hatch were closed. I guess, having a brand-new Pathy, I was afraid to hurt it by slamming the rear hatch. Since then, I don't hold back when I close it, and I haven't had the same problems since. I know its a bit unnerving to manhandle your brand-new Pathy that you probably already love, but trust me, you won't hurt it and it works. If not, maybe your problem is a real one which you should take up with the service department while its still under warranty. If however, you are taking it easy closing the rear hatch, just give it a bit more of a slam. I hope this helps. It got me down a little to see that my new truck was having these sorts of problems. Now I'm at ease with it. Good luck.
I was working on a friends 92 PF 3.0 tonight. All the symptoms pointed to a slipped timing belt, but when I removed the covers and checked, the marks lined up. What didn't look right was the crank gear key way was about 30 degrees counter clockwise from the balancer key way. After removing the crank gear I found that the half moon key had indeed sheared and in doing so took out a piece of the crank almost the size of the key.
Does anyone PLEASE have any suggestions on how to repair this, short of replacing the crank or engine?
That's a pretty technical question for the folks around here, most of whom own 2001 and newer Pathfinders. Check out my profile for some links to helpful sites for your Pathfinder.
I have been having the same problem with my 2001 Pathfinder. The diagnostics computer doesn't detect the problem in two trips to the shop. "Songokuh", Did you ever find out what the problem was?
Has anyone had any issues with their transmission slipping? I have a 02 Pathfinder LE with 30,000 miles and the transmission has been slipping. The dealership told me that it was due to it being cold and the transmission fluid was thick and once it warmed up the slipping stops. I thought this sounded ridiculous. They told me there were no metal shavings in the fluid and that everything seemed to be OK. Any suggestions.
My 01 Pathfinder does this between 1500 and 1800 rpm. The check engine light had gone on three times, twice I took it to the dealer. Also, driving 65-70 on highway it felt like it was going to stall or was out of gas, but wasn't. Took it to dlr and they said that the coils were bad. Not just ne but all 6....for a repair total of $720+. Crazy. Anyway, traded truck for Honda Pilot 2 days ago. Not spending that kind of money to fix my 01 Path with 70K miles on it. Probably just the beginning of repairs...Good Luck
Is any other 2004 Armada owner having trouble with their climate-controlled heating system? I purchased the first Armada from Dow Lewis Motors in Yuba City, CA, on Oct 22. Shortly thereafter, I discovered that the heater did not respond to temperature settings. Except when set full on (90 degrees), the systems tends to discharge cool air.
I've had the car back in for repairs on five occasions. They have replaced several parts, but so far, none have fixed the problem.
Hi, I get a 98 Pathfinder with 63k this year back in May. long story in a few words: I like so much how they drive but ever since I bought notice a front noise clunk, I take it to the service in June, August, September, October, November and now because the same noise. On the Service they just toll me that they change all the possible parts related with the noise (struts, mounts, rotors, even the pads which now are screaming because they put after market pads). This noise occurs on low speed over hard or soft surfaces. what should I do?
Sysamin1 you wrote "My 01 Pathy has been running through way too much gas lately and the idle between 1500-1800 makes the car shudder and hickup". I have just started to experience this problem yesterday have you found out what may be causing this problem. I have a 2000 path SE and it only has 52 K I was wondering is anyone else in here has experienced this problem Im hoping its nothing major. I have not seen the check engine light go on but my car started to hickup and shudder and it started about 30 minutes after filling up my gas tank.. to Sysadmin as for your check engine light issue I was reading through all the messages on this site and there are a lot of the same concerns as yours regarding the "check engine light" does any one know what could be causing the car to hickuo and shudder ?
Sysamin1 you wrote "My 01 Pathy has been running through way too much gas lately and the idle between 1500-1800 makes the car shudder and hickup". I have just started to experience this problem yesterday have you found out what may be causing this problem. I have a 2000 path SE and it only has 52 K I was wondering is anyone else in here has experienced this problem Im hoping its nothing major. I have not seen the check engine light go on but my car started to hickup and shudder and it started about 30 minutes after filling up my gas tank.. to Sysadmin as for your check engine light issue I was reading through all the messages on this site and there are a lot of the same concerns as yours regarding the "check engine light" does any one know what could be causing the car to hickup and shudder ?
On my 2001 LE, when it is cold (first 5 minutes or so), it can flare quite badly between 1/2 and sometimes between 2/3. I've had the dealer test it a few times and they say this is a normal characteristic. I'm not too concerned as it goes away upon warming up (and my complaint is now officially on the dealer computer if something happens later).
Has anyone exprerienced a somewhat loud wrapping noise comming from the engine upon a cold start?? This noise seems to be just @ cold start as it dissapates when the engine has heated up. All fan belts/compressor belts have been replaced recently. 01 Pathy LE.....
I own a 2001 Pathfinder SE and I am having problems with the factory installed Bose 6 disc CD changer. The CD player either does not play or it will play about a half a song and then stop. Is this a common problem with the Bose system? Is it covered under a Nissan extended warranty? I reviewed some old posts and it looks like numerous people have had problems with the CD changer. I called my local Nissan service manager and he told me that he, “did not know of any major problems with the Bose CD changer.” Do you think he is telling the truth?
I've seen renderings and they look hot! Anyone know anything about the new design of the 05 Pathfinder? When are the new models usually released to the dealers? Ive hedged on buying a current one b/c they are so damn boring looking, but the new ones look really great.............
Well, my 2001 LE remote has been intermittant for the last year (several button press' needed sometimes). It died completely yesterday. Sooo, all those with remotes that were new in 2000 or so, be prepared to buy a new battery for the remote (CR2025).
I'll tell you, the problems with this vehicle are never ending ;-) (NOT!!!).
I was on the way to the parents on Christmas eve and had 3 CD's in my changer (none of them CD-R/ RW's, etc.) I was using the all shuffle mode and came across a song that I didn't want to hear. I hit the next button on the steering wheel controls, heard a little noise from the CD changer. Then the ERR2 message popped up and now I can't play, eject, or do anything. CD changer says WAIT makes some noise and then just freezes.
From other posts I see that this basically means this has to be replaced. FYI, I have an '01 that I bought in July of '00.
A question I have is whether anyone has just replaced the factory unit with an aftermarket ($350 for this crappy changer seems crazy). Also, can the steering wheel stereo controls be retained with an aftermarket unit? Doubtful on this but I would really hate to lose the controls.
Just bought two at Radio Shack (I can get them wholesale too, but I like getting my batteries from Radio Shack because they are almost always fresh as they sell so many). They are around $5 each.
I changed the battery a few minutes ago. Those remotes are really well made. I thought the "buttons" would be carbon on PCB pads, but they are actual switches on the PCB. Very nice. Nice job waterproofing too.
For those worried about the code being lost, I'm pretty sure the remotes are hard coded (can't be changed). The vehicle has a memory space in which your dealer can enter up to four remotes (he needs the remotes to do this). So changing the battery in the remote has no effect (other than making a dead remote work again ;-).
There is a Technical Service Bulletin for that transmission flare up b/w 1st and 2nd gear. WWW.ALLDATA.COM. Dealer serviceable free of charge. Check with your dealer and bring up TSB with them.
Getting ready to replace the original Bridestones on my Pathfinder. Everyone seems to agree that the Bridgestones are not up to par for this vehicle but no one has recommended any other tire.
Anyone have a recommendation for a replacement for the 17" tire.
Not that many brands and models to choose from that fit the 17" rim.
Check out Goodyear Fortera HL Edition (mine, just bought, very nice quiet ride, great traction, 2001 LE 2WD, 25570R16), Yoko Geolander GO51, and Bridgestone Dueler AT Revos (if you need extra off road traction).
Does anyone have any suggestions on when to replace your Automatic Transmission fluid, gasket and filter for a 2001 LE 2WD Pathy with 40K miles? The owner's manual just states to inspect every 15K miles. So when should you replace it since preventative maintenance is so vital to the life of the Tranny? I do not use my Pathy for towing. Mainly a commuter vehicle in hot south Texas weather.
I change the ATF, gasket and filter out every 30K on all other cars I have driven. Does Nissan expect it's ATF fluid to last a lifetime? Same goes for the Fuel Filter....except they recommend to change that when you car stalls on acceleration.
fishingguy1
Let me see how much they charge for fixing the lock.
Otherwise put them on Ebay or in your local paper.
Help?
Any thoughts on how to attack this thing?
Is anyone else having similar problems?
