Well, probably the only parts I don't like about the A/T are 1) robs some power, 2) shifts too quickly from 1 to 2 when pulling out of corners (I'd like to delay the shift a little later that the AT decides, even with O/D off, which does delay shifts a bit). Other than that, I love the fact I don't have to dance a ditty every time I drive through stop-and-go traffic. And the Pro's AT is usually pretty good (there is that hard stumble when stomping on the accelerator just after a short stop...I've learned how to avoid it).
RE 15,000 mile checkup
I did my spark plugs at 15,000 also. They looked kinda nasty when I took them out, so I guess it was a good idea. Cost me less than $10 bucks, so why not?
Mazdafun: Thanks for the tip. Does anybody know how I can clean behind the vents without taking the car apart??
Hey, you have to admit, it's been a while since I've done anything stupid to my car. Maybe(????) I'm getting the hang of this ownership thing.
Going to paint the calipers shortly. Seriously considering the factory sport exhaust. I'm having a hrd time finding one installed. I want to hear it before I buy it. It won't do much for performance. I'm just buying it for a better sound.
what should I do???
Testing out (or learning) manual on a new CL-S 6 speed? LOL I don't want to be a jerk and ruin a clutch on a new car
Also, I would rather have both hands on the steering wheel in an emergency, not grabbing for another gear manually.
I suppose I'd better don fire-proof clothing now?
but to have an automatic just so you can do left foot braking? I think I'll learn heel-to-toe downshift instead, more fun!
Not a flame, alternator, just what I was taught.
I'm going to lunch now, but will gladly respond later to further barbs. Ha! I hope someone is on my side.
If you had to make a panic stop in a car with a manual, you could left foot brake if you thought that might give you an edge - thus saving that split second, and just letting the car stall. In normal driving, you wouldn't need that extra split second, so wouldn't need to left foot brake and could come to a stop with the right foot on the brake, the left operating the clutch. Just a thought.
There are small, battery-operated vacuums that come with a gooseneck attachement that might sneak between the blades in the vent.
I think you can also buy attachments for a can vac. You can get serious suction when you neck down the orifice like that. Watch you don't overload the motor though.
You could also make your own attachment. Depends on what it's worth to you.
And if suctioning the dirt off doesn't work, you could always use your vacuum to blow air instead of suctioning air to blast the dust off.
Sounds pretty kludgey to me. I'd stick with the beater manual, or better yet find a good friend with a manual who will teach you and let you practice until you get pretty good at it. That might not take as long as you think. Manuals these days, with their fancy sychros and relatively smooth shifters/clutches, are getting pretty easy to use IMO. There will be some intitial pain to learn, sure -stalling, bucking, etc., but it will pass quickly enough.
On the track, having a manual makes ALL the difference in the world. Not just for power, but having stability and immediate response out of a turn. You can achieve some of this with left foot braking, but the converter slips too much to get that launch out of the bends.
When driving the wife's MPV, I've tried it, but I'm so used to right foot braking I don't have near the sense of feel and control with my left foot. I have no idea how long it would take to get as good braking using my left foot as I do now with my right.
what do you mean, are you suggesting trading in for a manual? doesn't trading in will cost me more than just tax and DMV fees (aka vocus syndrome)? Please explain further!
I would also caution anyone from comparing the skill of an F1 driver to their own.
Well, except for me, of course. ;-)
Rbrooks, F1 cannot be compared to an auto in any street legal vehicle. Not only do the cars have more power than they can handle, the transmission does not use a torque converter but rather an automatic clutch; a HUGE difference.
When they make a true manumatic, I will humbly relinquish my rights to left leg flexors.
The manual function does hold the engine speed longer than the true automatic way does though, I noticed this when flooring the accelerator from a takeoff. So it does have some advantage over leaving it in true auto mode.
I find it encouraging, though, that Toyota has put a true manumatic on the MR2 Spyder, a car that I can actually afford. If it catches on, maybe they'll put it on other, more practical, cars.
You might have been able to get a better deal, but you can't change that now. Just enjoy the car!
Congrats on your new Pro!
I didn't know the MR2 offered that option. Me thinks me needs a test drive.
