Ford Ranger Maintenance and Repair
in Ford
your Ford Ranger Problems. Good luck and thanks for your participation. ;-)
Pocahontas
Pickups Message Board
Pocahontas
There was alot of slack in the drive train. It did feel like the ujoints were starting to go. The only other problem was odd front tire wear.
I had the inertia switch replaced in September.
I had the fuel pump replaced 2 weeks ago. The mechanic dropped the tank, tested the power wires to the pump, and was getting FULL and PROPER voltage. The pump would not work. He replaced the pump. Then 2 days ago, I couldn't get the truck started for the life of me.
The next morning, as I was arranging to have it towed, i tried to start it and it started on the FIRST TRY!!!! What the hell is happening.
e-mail me at igloomaster@yahoo.com.
I'm bringing the truck back to the mechanic next Monday to have him look over all the wiring and see if he can find out why this problem is happening. I don't know a damn thing about electronics/fuses in cars.
my 1994 Ford Ranger 2.3l is at the garage right now.
The mechanic just called and said the "relay" was rattling, and showed signs of overheating, so he replaced it.
Hopefully this will solve the problem of intermittent fuel pump failure.
I virtually guarantee that it's the switch on the passenger side door. I had a Dodge Intrepid - same problem. Turned out the little plunger switch was not quite long enough, so I drove a screw into the end of it, effectively lengthening the switch by the thickness of the screwhead. Worked for 100,000 miles afterwards...
I am looking at a 1999 Ranger king cab 4X4 for 15,900 with 33,000 miles. 4.0 litre engine, auto transmission. Does this sound high to you?
Have there been any problems with this truck?Anything problem areas I should look for/at/on this vehicle?
Also, the truck has 245/75R16 tires on it. Can you install bigger tires on stock rims? What is a bigger (taller) size for these? How big before needing a lift? What is a good lift kit for these for under $500-600?
Thanks in advance.
Open hood
lock doors and close.
unhook and rehookup battery.
open with key to reset?
Been told it will fixit but have not tried it yet!
Thanks in advance for any and all advice of this problem.
The light went back on after about 25 miles. We replaced the gas cap and brought it back in. He turned the light off again and drove it for a while. The light just went on again.
Has anyone else had this problem? Thanks in advance for any help.
If the check engine light is coming back, a sensor is not sending correct readings to the computer. And there is something that needs fixed.
P.S. To 'turn the check engine light off' all he did was unhook the battery cable for a few minutes.
I took it to a mechanic that was recommended. We have always bought new cars and taken them to the dealership for service. Have people has better luck with private mechanics or dealerships?
I run at 65-70 mph to/from work five days a week and still the thing pings. Ford dealers (two) say that they can do no more. Every time I pull a hill at 65 mph, it pings.
Any help?
What I read is a huge percentage of 3L Rangers, across most years from early 90's to current, ping.
There is little to be done to help except run higher octane gasoline. Ford has something called a 'SPROT' (or something like that) connector that can be changed. What I think it basically does is retard the timing. Which will reduce the power of the truck, and I've seen people write it does not always help with pingin.
Pinging seems to be a horrible design feature of the 3L motor......
Ford factory engineering know of the problem/complaint, and they have no fix! Our dealership's customer service manager confirmed this, and felt it would be best if the vehicle was returned as a "Lemon".
Last weekend Ford, and the dealership took back our 2000 Taurus SE (FFV-Vulcan 3.0) due to 14 months of repeated shop visits for engine ping. The final straw was when they finally changed the processor (computer), and the ping was even worse. We now have a 2001 Taurus SES, with the basic 3.0 Vulcan (no FFV). Ford and our dealer really came through for us with an exceptional offer to rectify the "Lemon" we owned.
We also own a 1996 Ranger XLT, 4.0 2x4 (78,000 miles). It has been a great truck!
Good Luck!
1 of 2 Anyone else have a Ranger with Spark Knock? by supercab2 Apr 26, 2001 (02:08 pm)
I have been living with this for 3 years. Ford Motor Company cannot come up with a fix for my 1998 XLT 3.0 liter V6. The truck does have automatic transmission. I have decided that it's time to switch back to Toyota. Anyone ever have spark Knock with a Toyota? I'm growing more and more frustrated each year that I own this truck. I like everything else on the truck except this stupid knock problem. Ford does not treat all customers the same!!!!!
