Visitor Agreement.
For the horn check the fuse panel under the hood and see if you have blown fuse. Unless the steering wheel was taken apart, I can think why the connections would be off for the horn connection.
Let us know what you find.
1) Take out the UPPER glove box. Two screws, one on each side, and 2 hidden ones in the center (you have to pry off some fuzzy round plugs). After you get it out, you will see the receiver behind it. It is a plastic box with a pitiful stubby antenna to the right. remove the 2 screws holding it to the chassis. About a foot to the left you will see a round horizontal metal tube screwed to a vertical bracket. All you have to do is take a stranded wire (14 gauge or so) and loosen this screw and wrap one end around it and re-tighten. Run the wire over to the keyless receiver and scrape the rightmost screw hole. Re-install the keyless receiver with the two screws and wrap the other end of the wire below the rightmost screw so that it touches the grounding plate under the screw. Before you re-install your upper glovebox try it! My range went from a pitiful 5-10feet to over 50-60'. If anyone still has the 2002 Sedona this should help.
My dealer back in 2002 was no help when I took it in to him. Maybe you can get rid of this annoyance if you still have your van.
Good luck!
My 2004 Sedona with just 78,000 miles blew the motor because the Intake Manifold Valve (butterfly) dislodged itself and was completely ingested by the engine pistons"... and "all that remains were bits of metal shavings".
I found out that the 2002-2005 Sorento with same size engine (3.5, 6cyl.) has a recall: TSB#073/NHTSA ID#10025153 on exactly this same issue.
AUTOWORLD KIA (DEALER#7096963), East Meadow, New York claims this is not a "Power Train" Warrenty and/or Recall Issue even though we are original owners with impeccable maintainence records.
REPAIR QUOTE: $8,371.00 plus $35/day storage from June 18 (45 days and counting).
Any advice appreciated.
Tony
917-653-0888
