-June 2024 Special Lease Deals-
I have changed the spark plugs on my 2000 4.7 V8, and have 'lost' the capacitor? (if it is a capacitor) that is attached to the rear right-hand coil (as facing the windscreen from the front).
When changing the spark-plugs (with coil-on-plug), there are 3 extra bits (with wiring) attached to the coils (2 on the right side, and 1 on the left when facing the windscreen). If the front cylinder on the right (facing the windscreen is No. 2), then I believe they are on No. 4 and No. 8 on the right.
My problem is that I have 'lost' the one on No. 8 down the back of the engine behing the throttle body/back of head/back of block) (it doesn't seem to be from the same part of the wiring harness as the coils) and I don't know where it comes out of the wiring harness.
It runs OK, and not having it connected to the earth on Coil No. 8 does not seem to cause a problem.
My questions are:
- What it is?
- What does it do?
- What is the problem with not having it fastened to the earth on the coil?
- Should I keep driving it?
- Where does connect to the wiring loom, so that I can 'fish it out' and reconnect it
Any help would be very much appreciated.
David.
Incidentally, the term is "ground" and not "earth."
Good luck!
On the 2000 4.7 V8 GC there ar no points (I believe) that's why I couldn't understand. On older cars that I've worked on, with a distributer (Dizzy), the capacitor is in the dizzy (I'm not up on these new cars with seperate coils and, I suppose, I crankshaft position sensor to control timing).
Whether it's Capacitor or Condensor, and Ground vs. Earth depends on which side of the atlantic you hail from.
Still looking for any help on how to 'fish it back out'
David.
I have been having the same problem for over a month and it is just rediculous. I have taken my car to several mechanics and they cannot figure it out. Have you had any luck with finding a solution?
Did your car ever die out shortly after turning it on?
:confuse:
The Problems is usually
Tire Balance
Bad Tire
Bad or Bent Trac Bar
Steering Stabilizer
Wheel Bearing
The Angle of your Axle
and anything else under it!!!
It Sucks it feels like being in a Paint Shaker and If I owned this when it first came out I would have Sued JEEP for a bad front end!!! Very Dangerous
I have Tranny Problems and I have had mind refilled and had numerous trips to the Mechanic to fix it and nothing solved yet I have had over 500.00 of sensors replaced
Brakes Twice
Tires
Alignment
Oil
:lemon:
4wd Full Time: When needing standard 4wd; dirt, snow, light mud, etc more traction!
4wd Part Time: Good for Deep Snow and Ice
The Difference is that the Gear Ratio for power from Front Tires to Rear Tires is diff and thats why you have two diff choices... Of 4wd Part time and Full Time
4wd LO: Use only when needed really slow gear ratio or going down steep slope or up a rough hill.... You can drive up to 35 mph in 4LO and it will shift through all three gears...
(To get in 4Lo You must PUT THE TRANS in Neutral and moving no more than 3mph and then with a quick pull it into 4LO) To get out of 4Lo( moving about 3mph and trans in neutral give a good push forward on the handle and that will get you out of 4Lo)
Logan
It is usually bad caster and camber angle in Axle... It could be shocks or even bad Tierod...
Very simple it looks like a Dirt Bike Shifter
However, it needs it, so here I am.
Joe
Does anyone know the trick for reconnecting the right side exahust header to the exhaust manifold? One of the two bolts/nuts is completely blind from the bottom, I cannot get one hand let alone two up there to hold the nut and get the bolt started, does not appear to be any access top side from within engine compartment either.
I had to drop the exhaust to replace the oil pan gasket, now I can't get the exhaust properly bolted back together, appreciate any ideas.
Brand new to this board. Looks like a great place to learn about Jeep problems.
The coolant low warning light on the overhead console keeps coming on at startup, but the coolant level is fine.
Anyone else have a problem like this? Any ideas of a fix?
Thanks in advance.
Kurt
The problem I have now is that my Check Engine light is on and my Jeep's RPMs dip down to almost 0 when I stop at a light or stop sign. It wobbles but doesn't cut off. Also when driving, I feel a slight drag and my RPMs jump a bit but not too much. I think it may be transmission related - possibly the Torque controls but not sure. Any ideas?
Also, any recommendations for finding a good mechanic?
I know I screwed up, but would appreciate any help you guys could give me!
My questions are:
- What it is?
- What does it do?
David.
I haven't used it much as I bought a 3rd car for my commute to work.
The other day I got in it and now it seems as if the passenger side vents
only blow outside air (changing the passenger side temp control doesn't
change the temp). Looks like that you changed the blender doors etc.
I understand you need to have the dash pulled apart etc...Did you do this yourself and if so how much of a pain was it? The dealer wants about 800 bucks to do this.
By the way I also have a 2004 Honda Accord that has about 22 K on it. It's been flawless. When my Jeep had about 22K I probably did the front roteors a few times already and had the passenger and driver side htd seat changed.
change the temp). From what I understand to resolve the issue it's something to do with either the blender doors, modules. Apparrently you need to remove the whole dash to get to these. Has anyone out there attempted this themselves?
If so how much of a pain was it? The dealer wants about 800 bucks to do this.
But that jumping, vibration, and shimming was very annoying. Is that common with the Quadra-Trac I system and does the Qudra-Trac II system do it as well?
1.) When I turn I hear a scrubbing noise like my tires are too large (they are factory) and I also hear a whining noise.
2.) For about two weeks I have been hearing a rattling noise when I press the gas pedal. It sounds like maybe I put bad gas in, but does anyone have any idea?
Help if you can...
go to hvac sub assembly replacement.
don't know if u got my last reply but l have the same problem so good luck and stay in touch.
2001 Grand Cherokee Lmtd.
Nlcarb
kyfdx, "BMW X3" #2211, 23 Oct 2005 5:51 pm
btw, ALL CAPS is hard to read and lots of people just skip over those posts.
I guess all I needed to do was write a post to get the creative juices flowing and I was able to solve the problem I created.
Thanks for your imput.
My blower motor will not cut off unless i remove the maxi fuse. I replaced the "resistor" but did not correct the problem.
when i replaced the resistor the it was extremely hot to the touch?
