I think that code is for an evaporative leak. I had the same problem and was told to replace the fuel cap with a new one. I thought that was ridiculous so I have found that if you put the cap back on and turn it several times and stop between clicks the light will stay off. You have to disconnect the battery to make the light go out. I hate this car so much that I won't replace fuel cap until trade in time.
I got a few problems. Maybe all related.
The oil pressure gauge keeps going up and down, depending on rpms. High rpms, high pressure and vice versa. It only does it when engine is hot though. I checked the oil. I am loosing (burning) some, maybe half a quart per 500 miles. But it has 104k miles. So that is not that strange. I opened the oil spout. At hot engine temp, there is very light smoke from the heat coming out. Is that normal?
Also, when I get out of the car after parking, there is a slight odor like that of warm, slightly burnt rubber. Could it be related?
Does anybody know what my problems are?
Should I even worry with 104k miles?
Thanks so much in advance.
I own the JGC and 4runner. I worry about the jeep often, no worries about the 4runner. I won't buy any more jeeps after this.
The dealer said, he only seen this once and that I should ignore this message because they don't know what causes the car to signal this...Well it's a pain in the >>>> to hear this all the time.
I have question other dealer's but they all say it could cost me up to $700.00 to find the problem?
Does anybody know what could cause this?
Before everyone starts saying bad things, I know that the JGC has had it's share of problems such as brakes, electrical etc.....but what vehicle does not have problems. I mean, I honestly have never seen a JGC broke down on the side of the road and I see many running on the road so how bad can it be?
Your input and recommendations on if this is a good deal would be appreciated.
1) when I step on and off the accelerator at exactly 50 mph, I hear a ticking noise somewhere near the accelerator. I don't hear the ticking noise from accelerator at lower speed. I step on and I hear "tick" and then step off and hear "tick". Tick~tick
2) When I turn on the ac and step on accelerator, I hear this very low frequency chainsaw noise for like 2 seconds. It sounds like "Cheeeeee"
If anyone had the same problems, plz tell me how to fix..
Thx..
Any advice assistance is appreciated.
Good Luck
Mike
Any ideas?
Mark
I can tell you that you should get the sound checked with the transmission. That could very well be the sensor switch I believe mostly the 5 speed transmissions have this. I am familar since I just purchased 1 1/2 weeks ago my 2004 JGC Limited V8(90 miles). I did experience a problem with the transmission within one week of owning.. I received a rough sound and then power just stopped couldn't move jeep. Be advised if this happens put key to off position and in park this actually resets the vehicle to allow you to get to the dealer for service. I am having the switch replaced. I have heard by other owners they too have had the same problem, the dealer that i drove to for service claims it doesn't happen often, but i found 2 people. I would get this checked could very well be your problem . Good luck!!
Sometimes with Alloy wheels, if you don't get the nuts to the same torque, you may get clicking from the loose ones. I've personally experienced this with my alloy wheels, but not with any of my steel wheels, so I can't claim it has the same effect.
your wheel, and plastic hubcab, should not be compressing when turning, that seems to me a pure fabrication, and a sign of a lazy/poor dealer.
The dealer should at least loosen and re-tighten all the nuts on the wheel where the noise is present to eliminate this potential cause.
i also had radio problems(took it back 1 time) and ac problems (took it back 2 times) can i excerise the lemon law? This car only has 7k on it. Please help!!!
Squeeking could be a loose belt. When you put a car in gear the rpms typically drop and there is a strain on the engine, so that could be a loose alternator belt or power steering belt?
Do you mind telling me about yout 95JGC? I actually had a '93 JGC Ltd. 150K+ on it before I traded it for the 2004. It was fine except for the expansive leak fixes that I didn't want to deal with. Let me know thanks!
Does anyone know of any recalls or bulletins for the 04 and brake problems? I like the vehicle overall, (though not as much as the 02 Montero Sport XLS it replaces) but I'm concerned with the rotors as it seems the only last about 3-4k before needing some type of service....Any help is greatly appreciated!!!
When did you start having problems? If they had turned them 4 times before replacing and the first time was BEFORE the brake warranty expired at 12,000 miles, I would point that out as existing under the original warranty and the turning did not fix... Give me back my $50!!!!
I had the problems with a '99 and '00 Grand Cherokee. On the '00 I fixed it by getting replacments at Autozone for less than $100. Very warp resistant...even after extreme overheating because the un-greased caliper pins hung the pads against the rotors...they warped while very hot, but that went away once they cooled down. I greased the caliper pins a couple of times after that. Still had the aftermarket rotors when I traded it in with about 66,000 miles (45,000 on the aftermarket rotors).
When they replaced the rotors in 5/04, I actually didn't pay the 50.00 co-pay as the dealer elected not to charge me. I have an appt. 10/6 again bringing it back in for the rotors warping again, along with a constantly squeaking center console and driver's seat.
I just don't know what to do about the rotors, as I'm growing tired of having them turned every 2-4k!!!!!
The maximum care pkg pretty much covers EVERYTHING on my GC with the exception of the following:
* Maintenance services and items used in such services
* Glass, plastic lenses
* Body and paint items, including soft trim
* Snow plows, winches and trailer hitches
* Wear items such as manual clutch assembly, brake pads, shoes, rotors, drums and belts
So it's almost like having bumper to bumper for 6yrs
Note that it does exclude wear items such as brake pads and rotors, so this might not help on that type of problem...if your 5 Star dealer sticks up for you, they will be covered by DC, if they let you down as my 5 Star Jeep dealer did, DC will not cover you... one reason my wife is driving an Envoy instead of a Jeep.
My Jeep has 40,000 miles on it, and is without question, the most trouble-some, poorly engineered vehicle I've ever owned. I can't wait to get back into a Honda.
There must be a switch or sensor somewhere, has anyone else experienced this and know what/where it might be?
I am considering buying a 1996 JGC 4WD (manufacture date 04/96) with around 90K miles from a friend. He has been pretty happy with the Jeep and never had to do anything except the regular maintenance.
I have read a lot of reviews here and get the feel that a lot of people are equally divided between those who love their JGC and those who hate it.
I have always liked the JGC but am just a little skeptical based on its reliability records.
It seems some year models have been absolutely trouble free while some have had lots of problems.
I would really appreciate if anyone could share their experience with this year model. Any tips, suggestions, things to look out for....will be really appreciated. I need to make a decision in the next 2 days.
According to MSN Auto an occasional problem on this vehicle (1996 JGC) is failure of the Four Wheel Drive (4WD) Viscous Coupling and failure of the Air Conditioning (A/C) Evaporator Core.
Thanks for all the help !!!!!!
The original shocks and tires seemed to make the Jeep feel like it was wandering on rougher roads. The Bilstein's were about $80 each and the Yokes were $74 from Tire Rack.
