Revka
Hatchbacks & Station Wagons Boards
Matrix XR (automatic)
Sport Package
Sport Plus Package
All Weather Package
Cruise Control
ABS Brakes
Side Airbags
Navigation System
Dave
(SF Bay Area)
Please someone fill me in how good/bad it is
I drove the XR auto yesterday to get an idea what the base was like. Im probably going to put the $500 down to hold it.. because its still not made yet. If you stomp on the gass will it hit 7000 and hold long enough to get in the power band?
If you had to say how fast it was 0-60 what would be your guess?
The XR felt like about 10sec
My Focus blows the doors off that. Its a 5 speed anyhow.
I want to know that this XRS auto can at least smoke my old Focus, or its going to be hard to win me over. Everything else about the car is much better.. I just want the speed also!!!
I have driven the XR auto extensively and the XRS auto briefly, and IMHO, if you are definitely going with an auto, you do not really get the extra power from the XRS engine. Now, if you are thinking of a manual, it is a totally different story.
Thanks for correcting it out there.
>17" wheels and P215/55zr Firestone tires
>4 wheel disc
>4 wheel ABS
>full ground effects pkg
>fog lights
other than that I think the suspension is the same...
XRS 6spd with 5200km
I would suggest that Toyota increase the displacement of the engine from 1.8 to 2.0 liters, which should provide a wider torque curve at lower engine revs. That way, the Matrix won't feel "flat footed" accelerating from stoplights.
Only one thing.
Our tires are 50 not 55
BTW
Got tint already and half of my decals.
I did put them last night and I'll try to finish tonight. After all I'll post some pics.
XRS 3300 km
If you think manual is hard to get, try getting ABS on a 2WD XR or base Matrix.
I'm glad to see that there are many others who have trouble reading the odo and outside temp display. THe reason is due to the very low contrast level between the numbers and the background. With sunglasses, it is impossible to read the numbers in the daytime. Nightime is much better due to the lower level of ambient light. Now why did they make the contrast so poor on that area of the display? THe rest of the panel is usually legible day and night.
The one minor problem I had has now been resolved. One of the clip assemblies that holds up the tonneau cover was missing entirely, and another was missing a bolt. My dealer ordered them for me (under warranty, of course) and I just installed it yesterday. Other than that, I've had no rattles, no squeaks, no other problems so far (knock on wood!).
Microrepair: what grade of gasoline do you put in? The manual lists the minimum grade is regular-87, and that's what I've been putting in. I used to have a Honda Civic that I started putting premium in when I first got it, and my mileage gradually dropped over time. My mechanic later told me that you should use the lowest octane that the mfr recommends (unless it starts pinging, but it's a new car, so that won't be a problem). If that's not the problem, you might try switching brands of gasoline, and if that doesn't work, I think you need to take this in for service.
As the car gets older (at least several years later), though, carbon build-up inside the engine will increase compression pressures, leading to the need for higher octane gas. The advise I've heard is to use the lowest grade gas that results in no engine "pinging."
We've been putting in regular 87 octane, mostly one brand so maybe we should try a different brand first. The O/D is definitely in the right position, unless the indicator light is wired up backwards. No, no, I've checked the RPM's and it is in O/D all the time..! We've also been running the AC most of the time in the last month since it's been pretty sticky here in eastern Mass.. But again, we used to do that with the big Chrysler too...!!
I just bought a Cosmic Blue Matrix XR 4WD. Really like it a lot. It has enough power for me. In Minnesota, I need traction not power...
It has FE, CL, EJ, AW, CF, C1, & EF. List price was $20,020. Invoice was $18,260. I paid $18,600. I think I did good.
I am happy to be part of Matrix gang...
DVD9
My wife and I have been searching for a car to replace her '93 Tercel. I drive it to work, so I needed something I could fit into (I'm 6' 5".) Anyway, I used to own an '87 Nova hatchback, so I wanted something with good utility. We looked at the Focus, but weren't thrilled with it (a bit small for me...) So we looked at the Matrix, test drove a XRS (only one they had to test) and decided to order the most stripped-down base model available.
We live in Minnesota, so all of the cars are delivered with the "cold weather package" (+$250) which has the rear wiper, heavy-duty battery, and HD alternator. We agreed to a price of $15,500 for the car (they were actuall advertised at "from $14,850" in the paper, but the dealer said "NONE of them are that cheap!" and were told it would be in in about three weeks. Well, two months later they called back and said the car we ordered would still be a couple of months, but that they had a slightly better equipped 5-speed model (power windows, locks, cruise, mats and remote control for the locks) in cosmic blue for $600 more. Sticker was about $16,800, and we got it for $16,100.
They tried to sell us the extended warranty (7yrs/75,000 miles for $1,200) and rustproofing ($599). We declined both, and had the car undercoated/rustproofed and mud flaps installed through a company called Dealer Automotive Services for $207.
The car has been great. I fit into it without any problems, the headroom is phenomonal, even in the back seat. (I was wearing this huge 10-gallon coyboy hat sitting in the back seat and didn't touch the ceiling!) Lots of cargo space, and the plastic cargo area is great for toting around the dog!
I've now put about 500 miles on the car (trying to stay within the 55 mph break-in recommendation) and got 31.2 MPG on the first tank.
Great tires (Eagle RS-A's), although when I picked up the car, the dealer told me that "because the tires are an odd size, you may want to buy one and keep it in the car" !!!???
Gauges are fine. They take a bit of getting used to, but are easy to see, and look great at nite.
The radio is great (remember, this is a base model), but the display on the radio heats up and is actually hot to the touch!
All in all, I think this will be a great car!
Will you give me phone # and address for Dealer Auto. Services? What kind of warranty do you get from them? I am interested in the undercoat and mudflaps for my new Matrix. I also live in Minnesota so the undercoat is good for the car.
DVD9
Dealer Automotive Services Inc
1102 South 5th Street Hopkins MN 55343
(952) 933-3575
I think they're nation-wide, so you might find one closer to you if you live outside of the Twin Cities.
BTW the mud flaps are not the custom molded Toyota flaps, but they look good anyway, and they were only about $20 installed...
I've got a buddy who works at DAS, so I may have gotten a better deal than you'll get on the undercoat! The warranty is a lifetime warranty against rust-through from the underside of the car -- they ask that you bring the car in after 7 years for inspection and any touch-up.
And while I'm posting, has anyone actually purchased/installed/used the Yakima Rack for the Martix yet? What do you think?
Does anyone have advise or ideas an a modest upgrade? I don't need sub woofers or multiple CD machines. I.E. Should just the speakers be added/replaced..and/or the unit itself? Any brands or methods recommended. Thanks..
But will going above 55 during the break-in period on occasion do any lasting damage? Has anyone heard anything about that?
I doubt that going above 55 will do any lasting damage (as long as the speeds were varied and the RPMs were within a reasonable range). What is just as important is that you appropriately maintain the vehicle. Follow the manufacturer's recommended oil change schedule. Happy 4th of July and enjoy your Matrix.
Just posted new pics of my XRS in pictures section.
Have a look and tell me if you like it or not?
Is anyone experiencing the same delivery problem I have with Toyota?
I placed my order for a XRS back in the late Feb and have no sight of it still. All that I have been told is that it's in the production state but I got that about 2 months after I placed my order and another 2 months has passed by since. It's really frustrated and this is the reply I got from Toyota:
Dear Sir,
Thank you for your recent correspondence. We are sorry to learn of this situation and we understand that waiting for a new vehicle can be a great inconvenience.
We would like to mention that demand for the 2003 Matrix is much greater than anticipated, and as such, the delivery time may be longer than for other vehicles. Although we are unable to speed up the delivery cycle, we truly apologize for any inconvenience that this may be causing. A copy of your correspondence has been forwarded to our Product Planning department for their information and future consideration.
Thank you again for taking the time to contact us and for allowing us the opportunity to comment.
Sincerely,
Michael Hollinger
Toyota Canada Inc.
I'm in Vancouver, British Columbia and I have checked with other dealers here and it's the same story. Does anyone here work for Toyota, who could please tell me just HOW MUCH LOOOOOOOOOOOOOGER till I could be part of this club???
A Matrix Wannabee
Try a dealer down here. Boch has 45 per their ads, IRA has the same.
The problem you face is that XR's are being built in fairly small numbers. Nobody at Toyota is held accountable for meeting YOUR order.
It obviously doesn't take 4 months to build a Matrix. Their aren't any parts on your car that aren't on some other combination of cars, so they could build it if they wanted to.
The wait is just baloney. People aren't really getting 'custom' built cars, they are getting in a line waiting for the particular combination of colors and options to built as a matter of course at Toyota. The richest variety of XR's in the U.S. that I have found is in the Southeast.
Naturally, that's where Toyota sends 2wd XR 5 spd's with ABS, since the ABS is totally irrelevant there.
I shopped somewhere else and 'ordered' a MiniCooper. Very similar money, predictable wait and very cool car.
I just ordered a digital camera and it should be in next week. When I get that I will share some pictures as well. I installed the mini-receiver hitch from Toyota and I can provide a picture of that if anyone is interested.
Where did you get your small TRD stickers? I really like them...
