Oldsmobile Intrigue: Problems & Solutions
Anyone agree or disagree with me?
Racer68
Regarding the steering, many of us have had vibration through the steering wheel or creaking and groaning but I have not heard of the steering tightening up so much that you can barely turn it. It sounds like maybe the car cutoff or there was a temporary loss of power steering. On another place on the internet, it was suggested it could be a problem with the power steering high pressure hose being restricted. You may also want the mechanic to look at the crankshat position sensor as well. It may not send a code. Some here on the forum have replaced it before it causes too much trouble.
Trac, ABS and SES light: That seems to be a common problem with the Intrigue. On another forum, a poster suggested it could be the wheel sensors or a bad wheel bearing. Since your mechanic checked the wheel sensor already, I would have him look at the wheel bearings.
subprman: I will tell you i am not a mechanic or automotively inclined. Most of this informtion I have gained from reading this forum religiously for the past 4 years as well as another one. Your problems are not uncommon. If anything I have posted above is incorrect or wrong, someone please correct me. I don't want to give you bad information but i also want you to get the car ready for your daughter. I can imagine how you must feel sending her off to college in a car you are not 100% sure about.
Good luck. And check your Car Space e-mail. I sent you a message.
The top end of the motor under the valve cover on one side (3 of the 6 cyl.)is very noisy and also bone dry. THREE mechanics later still no fix... Looking for a motor diagram to see how the oil gets pumped up to the double overhead cam. Also, the motor runs great, no skip....
2001 olds intrigue. 3.5 liter engine
Previously the dealer replaced the EGR valve and cleaned the fuel injectors. That seemed to resolve the problem but after a few thosand miles the same problem is reappearing.
Can you tell me how you made out with this problem or can anyone else shed light on this? Thanks.
I have a 1998 Intrigue. Lights go out and I can either hit the sleep bumps on the side of the road or flick the dim switch a couple times and they would come back on. Tonight neither worked but they came back on when I came to a complete stop. It's getting dangerous to drive at night - any advice would be appreciated!
Whining noise...wheel bearing?? Though usually it's a groaning noise.
Windows...think all that is on the driver door (had that worked on because the windows would not go down).
Cruise control....wonder if that falls under the heading of electrical.
I am no expert, obviously, but have had some of the same problems. If you haven't already, do a search for electrical, cruise, etc, on this forum...same problems others have had and really good advice. Good luck :shades:
I owned a 1999 that got totaled for 4 years and in that time I was in the shop countless times.
I have a 1998 Intrigue that has a squealing power steering pump. What is involved in the repair/replacement of the pump? How involved is the repair? Any special procedures involved?
dinoburb
~Tracy
The whinning noise may be you power-stearing pump or you may just need powerstearing fluid. Not sure about the AC vents.
HELP I like this car otherwise!
My apologies for any confusion and frustration!
