Visitor Agreement.
Lots of factors affect what you can do in towing, especially with vehicles that have transfer cases and torque-splitting or limited slip differentials. Proper lubrication is one of them.
In any case, I'd say the 4Runner is an impractical choice to tow behind another vehicle, unless it's entirely on a trailer.
However, for automatic transmission, you cannot tow faster than 30 MPH or farther then 50 miles. If the vehicle must be towed farther or faster, "disconnect the rear drive shaft at the rear differential to avoid damaging the transmission", and the transmission must be placed in Neutral.
Thus, this is how we have been towing our 87 manual tranny 4Runner behind a 40' RV for years.
My question relates to the difference between a 2004 V6 4WD "Multi-Mode" model versus a 2004 V8 4WD "Full-Time" model. It appears that neither model can be towed with all 4 wheels on the ground. Jeep has been capable of this trait for years, as their patented 4 wheel "freewheeling" system is a huge advantage for towing behind an RV (however, Jeeps have their own issues.........another subject, another day)
So, before we leap into buying a new 4Runner, I just want to know going into the purchase what my options are........1) towable with 4 wheels on the ground.......2) towable with 2 wheels on the ground via dolly...........or 3) NOT TOWABLE. I do not have access to 2004 O&M manual to review.
I currently have a 98 TLC with the Locking rear diff option, I am looking at a 02 or newer model with the TRACS / VSC options and I want to know the pluses and minus of the 2 systems. I have been very happy with my 98, and have used the locking rear diff to get my TLC (and boat in tow) out of some sticky situations.
My questions are specific to mud and snow since I do live in the upper Midwest and am off road quite a bit. Will the new system send power to more than just 2 wheels if I am in a very slippery situation? In my 98 I can lock up the center and rear diff and get at least 3 wheels to get some power.
However, I think I accidentally hit the locking switch with my knee and drove for maybe ten minutes like this. I was driving on residential steets (no faster than 30 to 40 mph). I realized the center diff. was locked when taking a 90 degree turn at about 20 miles per hour. I heard a thump noise once as I was turning. I didn't hear it again after completing the turn. I then realized that the center diff. was locked and immediately unlocked it. I also heard another thump when the system disengaged. My question is did I do any damage? and if so, how would I know? I am thinking I should go to the dealership and explain situation and have them check out the car for any damage. Does that seem necessary? Lastly, is it normal to hear a thump when system disengages?
Needless to say I will be more careful in the future. I appreciate any feedback on whether I should be worried about any damage or not.
http://img33.photobucket.com/albums/v98/bp3959/
I described this in some detail in a post around the turn of the year; I think it was in the main 4Runner discussion. I experimented quite a bit and think I learned some about how the system is designed to function. Perhaps that post will be of some use.
For definition: ATRAC = 4-wheel traction control. VSC = stability control to prevent oversteer and understeer.
So, if you're gonna play in mud or snow, or want to go up a muddy hill, then i would lock the center differential. ATRAC will then manage side-to-side power transfers by pulsing the brakes to spinning wheels. Engine power is not affected. Here's a key...if you want to power thru something or up a hill, be aggressive with the gas pedal! Don't worry about all the noises and flashing lights, just gradually press down on the gas pedal. ATRAC decreases it's intervention as RPMs go up.
I see a lot of owners just giving up when they hear the noises (of ATRAC working) or too scared to use the gas pedal. Use it...but in a gradual way! Always, LOCK THE CENTER DIFFERENTIAL. If you don't then your car won't move anyway because VSC cuts engine power.
Hope this helps.
This was prior to having the 99 Landcruiser, which made it up fine this year in full time mode, no diffs locked.
TLC/4runner/Sequoia center diff is LOCKABLE. When you LOCK the center diff, you disable VSC/dethrottling fx...4-wheel traction control is ALWAYS on!
And if you re-read my post you will see I was only talking about the LC, etc, FULL-TIME mode, and almost everyone is now using brake modulation for engine torque apportioning in full-time mode.
And just what led you to believe the RX and HL didn't have a center diff'l??
Doesn't the RAV 4 have this same system?
Subaru is an example of a Full-Time AWD system.
I'm not trying to be confrontational with this statement.
The 04 RX330 uses brake modulation at the front to force engine torque to the rear. Remove the ABS pump and it always remains simply a FWD vehicle.
By that measure I would call the Rav4, Hl, RX, Sequoia, LC, etc, Full-time systems ON-DEMAND.
Sounds like real full-time AWD a la Subaru to me. ??
And 5% rear and 95% front doesn't qualify?
Put any of these on a lift and in gear and the tires will turn but at a rate determined by the front final drive ratio vs the rear, and they are different.
A more reasonable test would be to chain it to a good solid tree (damn good commercial, that!) and watch which tires actually exhibit torque application, but again, with Trac disabled.
And you might have to disable the Trac system.
We have a Outback wagon and it's been great. My only gripe is that it could be wider and have about three inches more of leg room.
On TLC100, center diff is LOCKABLE. In normal city driving, it is open. Power is routed 50/50.
Don't forget that TLC100 has ATRAC...4-wheel traction control system. This can effectively brake the wheel with the least traction to avoid all power going to it.
The rear differential on RAV4 AWD may or may not be a limited slip, depending on the options on the particular vehicle. I need to check this last statement in regard to '04 RAV4. I know it's correct for '01 thru '03 RAV4 AWD, but the option of a limited slip rear diffy may have been eliminated from the RAV4 for '04.
None of this changes the fact that the RAV4 AWD is full time AWD, or full time 4WD without low range gearing, depending upon your preference of terms.
I know that like the RX, the VC was eliminated in the HL in favor of Trac brake modulation, but does anyone know if the same thing was done with the Rav4?
Assuming your Rav4 shares the HL/RX AWD system and rear suspension clearance restrictions.
The manual does show that Landcruisers without the rear electronic locker do come with the clutch-type LSD, which can and will wear out without any indication, as Cliffy1 talked about at the beginning of this thread.
I would think the newer 100 series (2000 and up) would not need LSD's or lockers because of the traction control systems, although this could limit off road capability.
Awesome vehicle. Full-time 4wd definately better than my old 98 JGC w/Quadra-tracII (at least on snow). Unfortunatly, wife's (family) car and I rarely get to drive it.
Rear lockers are still offered in TLC's and they are still available for most any kind of trucks. Not many trucks come with the option of lockers....ever...thats a fact, TLC's are one of the few SUV's that are available with stock lockers even back in 94' when I got mine and there was no such thing as trac. Braking systems will not replace lockers as long as I off road....(well until I can get my TLC fixed after my sister who was staying with me for a while rolled it over)
