Honda Accord Quality Control Issues
Good point regarding the factory undercoating on the new Accords. Toyotas do have factory undercoating on all cars that they sell.
I think what I said was I have never personally heard a clunk in any Accord or Odyssey while backing up. I have no doubt backed up hundreds of these.
But 'm sure you think each and every one clunks.
As far as rust go's...I see, from time to time cars running around here with salt belt license plates. A lot of these are rust buckets.
I don't doubt that some Hondas may have an unusual rust problem. I just don't see it here and we do have a LOT of rain and salt air.
You think with all the knowledge isellhondas has regarding Hondas, he would comment in a constructive positive manner like Auburn does in the other Honda forum. Instead, every position he takes is defensive, negative and at times outright rude.
Isellhondas has a very aggressive arrogant attitude when he writes a response to a Honda question. I think it was MikeGold_1966 that said it best--"He is the resident gadfly" of this forum.
My only suggestion is to take the majority of isellhondas comments (no pun intended) with "a grain of salt".
You have to grin when isellhondas says something of note. I think the dude is probably ok but just gets carried away with his remarks.
I think in all fairness, Honda is a reliable brand but if I have to compare between Honda and Toyota, I will say that I will give the edge to Toyota in terms of reliability.
Although I do sell Hondas, I have no stake here. I have never used these forums in an attempt to drum up business. Quite the contrary.
I do try to calm the fears of people who come here, read negative postings and jump to the conclusion that all Hondas rust, clunk, squeak or go through brake pads every 10,000 miles.
If that makes me a "gadfly" or bad person, so be it.
Also, just my fyi: I have the Michellin X-One tires on my current car and they are absolutely the best tires I have ever had. Great road grip and handling!
As for the security issue previously mentioned, the '03 Accords now come with laser cut keys as well... (with the key)
Personally, I feel that the build quality of my '03 is much better than on my '00 Civic, the ride is smooth, and handling is great. Brakes are a bit touchy w/ the EBD, though. Overall, very nice car.
Funny, gotta have a new ride to keep it from getting stolen. One would think the newer the more enticing but no, it's the older ones that get taken. I'm a little bitter.
isell, what's the story with this chip embedded in the ignition key? And is this part of the car or an extra of some sort?
Anybody know of a good alarm system (short of a Rottweiler)?
It's supposted to be impossible to hotwire one of these. Impossible is a big word, I know, but from what I understand, the theft rate on these has gone way down.
It's still possible to tow one away but that tends to make a lot of noise and attract a lot of attention.
Car alarms...I don't like them but if you go that way be sure to stick with one of the name brands.
The way the chips actually works is kinda interesting. When you put the key in the ignition and turn the lock cylindar, the closed circuit(on) creates an electromagnetic field which engergizes the chip in the key. The chip then sends out an encrypted signal to an antennae in the ignition which is routed to the ECU. The ECU decodes the signal, and determines if it is a "authorized" key. If it is, the ECU allows the fuel delivery circuit(fuel injectors, etc) to be powered up. At least this is my understanding of it.
As for an alarm system, I usually go with about 200-300 for a system, and end up installing myself. Primary reason is because it is very expensive to have it set up the way I want it. I may just wait to see if Honda comes out with a plug-in module for the OE system, though since the OE is built into the key. I believe that on the '00-'02 you can add in a glassbreak sensor and shock sensor on top of the keyless entry.
bburton, yea, you'd think it was a budding metropolis. According to Sunday's news, there were 2 teens who "trained" about 18 of their friends to be car theives. The two were busted for operating a ring in the state capitol. Not sure what the PD is doing about the others.
of keys. Or they can look them up on their
computer system. But you can't just go to Ace
Hardware and get a key. They need a special
device to program the chip.
There are two add-ons that I know of which you can add to the Accord security system. On is the Siren kit which will bypass the car horn and will use a 98dB horn for the alarm. The other one is a Hood Switch Kit which will trigger the alarm if your hood is opened/broken into(this is probably a good add-on, since thieves can just open-up your hood and totally disable your alarm).
However, the factory security system already includes a hood switch so you wouldn't need a hood kit, even if one is available. You can test it. Just leave the hood ajar. The security system will not arm. The doors will lock, but the alarm will not set and the red LED on the door will not flash.
Storm11, unless your dealership is giving you a huge discount or you are one of the lucky few. Here in Toronto, its around $500, however, I am not sure if this price is for one key or for the whole set(i.e 2 owners key + 1 valet key).
150-300 dollars sounds way off!
I owned a 2000 Accord EX V6 sedan for three years. Although the transmission does have a hesitation or hard shift from 1st to 2nd, I did not experience the clunk when driving in reverse, ever - even though someone suggested that they all did it. I now own a 2003 EX V6 sedan and, contrary to popular belief, it does not, nor ever did, drift to the right. I love this car. It is a significantly more impressive car than the previous generation. Although I don't know Isells at all, it seems to me that his opinions are unbiased (as unbiased as anyone's can be since we all have biases)and insightful.
Respectfully,
WELCOME........
"contrary to popular belief, it does not, nor ever did, drift to the right." This is not belief. This is fact. Just cause you are lucky that yours doesn't does not mean it doesn't happen. It happened to me when I test drove a EX V6 here in Canada. Please do not make it sound like we just make these things up.
Thank you..
cheers...
Take Care
The transmission problem was also discussed here as something like a "perception" and not a widespread problem. Now we all know it to be the otherwise. If you think all the discussed topic here are trivial, then as aming said " you are the one of the lucky few" and I sincerely hope it can stay that way. Mdame, this kind of discussion is good for the consumer, think of it as your lifeline, a "Dear Abby" kind of a forum for your Accord.
Thanks for the discussion. Its invigorating.
I am very much flattered for giving you invigoration in your otherwise sorry life . However, since you think that this forum is full of trivial issues that you feel are not important, then my advise to you is to move on. Go to another forum, as this forum are for " honda accord quality control issues" nothing big or small (go ahead read the TITLE).
If you think that your dealership will accomodate all your car "small shortcomings", then,(ahem) you are one of the lucky few. However, read the previous postings and you will notice that the dealership most often ignore the customers concerns. Let me qoute you "there is a huge difference between a transmission problem and drifting", sorry mdames but both of these problems are the same...i.e they are "quality control issues" and having this discussion here in this forum will let accord owners know if these issues are common or not.
Thank you for dropping by...
Sincerely yours,
Mike
Trying to make up for lost time?
Temp gauge is off by 2-3 degrees and the service advisor told me that they don't have any device to check so he suggested that I should llisten to radio and see what's the difference and then they will adjust that to that difference.
Looks like Honda makes vehicles and most of them are good but if one of them has something wrong then GO FIGURE as their mechnics can't or will after tearing everything apart.
As for the mirror they have to check the whole wiring for the car to get to the problem (at least that's what they told me) and so they need it for a week.
I can't believe they need a week to figure out the wiring. Can you get them to exchange the car for another new one?
keep track on how long the car is in the shop. Maybe you can get a new one under a lemon clause or something.
Good luck..
Our store has a big time and temp sign in front of it. Once in awhile someone will drive by, compare the temp to the one in their car and actually call us to tell us ours is wrong!
Lots of things will affect the reading.
Seems like much ado about nothing!
At the radio station!
While it gives Joe Listener a pretty good idea of the temperature, I wouldn't call that accurate unless you were standing outside the studio (or wherever they get their weather data from...many times it's the local airport.) When I lived an hour away from and 1,000 feet of elevation up from Boston, I wouldn't trust WBZ's temp call to be accurate from where I was standing.
