Visitor Agreement.
http://www.accessatlanta.com/partners/wsbtv/consumer/rendevous0823.html
All-in-all, our RDV's been doing fine. We have a laundry list of small items for the dealer to fix next time in. The most major item is the oil leak in the AWD unit. They've already worked on it twice... Oh well. Regards to fedlawman & the gang here.
I'm concerned because this sounds like a potential design/safety defect -- and I think it should be fixed if it is. My RDV is a $35,000 vehicle and I expect it to be as safe as possible. If that means Buick has to fix the tranny so it doesn't do this and it saves even one life -- I'm all for it.
By the way, how do you leave the radio on with the keys removed? Doesn't the radio turn off as soon as the driver door is opened? Thanks.
I agree that it would be great if this vulnerable aspect were corrected, but I doubt that Buick would do a recall for this, especially if most cars function in the same way. I believe someone who posted above said their other make of car functions in a similar manner.
As for the radio thing... what I've done on only a few occasions, is where the kids have handed the keys to me out the window, and then rolled-up the window w/ the doors locked while I did a quick run into a curbside store where I can watch them while I'm gone for a few minutes. I would definitely not recommend this for young children. Hope this helps.
They said the transmission had 2 quarts too much trans fluid in it and that likely caused the problem. It is an intersting problem since that means it came with at least 2 qts too much fluid from the manufacturing line. If that happens often Buick is loosing a lot of money! But I doubt if that was really the problem.
Locks - they claimed to find "foreign debris" in the ignition switch. They cleaned and lubricated it and said all should be fine. So in less than a week why has it happened two times already?
I don't have a lot of confidence in the mechanics at this point.
I have also noticed my CD/tape radio looses a minute each week. So the next time I feel like taking it in I will have that on my list, along with the locks...
I was told in the spring that Buick Engineering knew of the problem and would have a fix available by the end of the summer. I haven't had an opportunity to take my RDV in to the dealer to see if the fix is available now.
I have since switched the locks to open when I shift into park.
Try removing the key more slowly and see if that's the problem.
Now that I think about it, I'll have to see if the mirror malfunctions during the same "session" that the door locks malfunction.
Click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click, click...well, you get the idea.
I may go in for BCM #2 next oil change.
I am just wondering if anyone has the same symptom. This is my first car doing ABS checking like that.
As for the sun visor, yes it does move back into a vertical position and is therefore useless to me. I just wear really good sunglasses and don't worry about it. It is a minor flaw that is made up by the other benefits of this vehicle.
For the sun visor. Mine stays in the position. My car was manufactured in June so GM must have it fixed.
I will stop by today to check it out.
After reading of this possible SUV defect in the 2002 Buick Rendezvous, I called
the Buick Rendezvous owners line. They could not confirm this issue and referred
me to my selling dealer. The service manager had the problem checked out and the
answer was found on page 2-29 of my owner's manual, and confirms that the vehicle
is working properly. The first click is the B(accessory) position which allows you to
use things like the radio and windshield wipers. The manual further states
"ACCESSORY if you must have your vehicle in motion while the engine is off(for
example, if your vehicle is being pushed or towed)."
If Kim Ruiz's child placed the key in the B position, then this would explain what
happened. The vehicle can only come out of gear when the keys are in the ignition,
and any time the keys are in the ignition adult supervision is of course
recommended.
Please forward this to Clark Howard to add to his investigation. I enjoy his program
and learn many valuable tips from his work.
Sincerely,
Stan
Here is the link to the orginal report.
Walt
I know a lot of people like DRLs, however I do not. I hope I don't start a debate over their usefulness (or lack thereof). I simply want to use the resources of other Rendezvous owners to find a way to disable those found on my vehicle.
I hope that somebody out there knows how, and if so, would please share this info with me.
When I find an aftermarket brand I will post the part number.
How can I 'turn off' DRLs?
This is the current discussion in A&A:
Daytime Running Lights (DRLs)
Care to share?
My suggestion would be to try other Buick dealers which may still have the charcoal filters in their inventories. The Pontiac Aztek and the three GM minivans (Venture/Montana/Shillouette) share many parts with our Rendezvous. Perhaps their cabin filters would fit?
I've never had a DRL-equipped vehicle before. I have, however, driven in front of DRL-equipped cars and frequently find myself flipping my rearview mirror up to lessen the glare (from the brights) which always seems to be aimed right into my mirror. I guess I just don't want to be the guy who is annoying the driver in front of me with my bright DRLs. And they are pretty bright on the Rendezvous.
Why not use the lowbeams like VW does, or the amber lights like GM does on the minivans, Corvette, Intrigue, etc. They are much less distracting to other drivers, IMO. I guess my biggest beef with DRLs are the cars which use the brights at a lower intensity.
I see a lot of people driving around at night without taillights on. When I pass them, their DRLs are on. The reason seems to be is that their car has DRLs and they think their headlights are on, so they don't turn them on, which leaves the taillights off. I don't think that is very safe.
If the vehicle is more visible to oncoming traffic, then wouldn't logic follow that it is more noticeable to police officers? As an admitted speeder, the last thing I want in a speed trap is to be more visible.
I am just annoyed that I don't at least have a choice in whether I can turn them on or off.
If they are an added "safety feature", why won't my insurance agent discount my rates for having a DRL-equipped vehicle?
If studies show that DRLs make vehicles more noticeable, and if all vehicles have them, how do you NOW stand out to other drivers? What's next, DRHs (Daytime Running Horns)? The horn would constantly blare when the vehicle is in gear, so oncoming traffic can not only see you, but hear you as well.
I know many people like DRLs, and that's fine. Many of us do not, however, and would prefer not to have them. I'm not asking for them to be outlawed, I just wish I had an easy way to disable mine instead of jumping through hoops to figure it out.
Thanks to the person who posted the www.lightsout.org suggestion. They are presently working to help me find a way to get this done.
Just my $.02
I would comment that--at least in the case of my RDV--the headlights/taillights come on automatically, so even though the DRL's are on during the day, as soon as the sensor determines it's time for regular lights, the headlights *and* the taillights turn on. I wasn't sure if you realized this from your comment about people thinking their taillights were on since the headlights appeared to be, even though it is actually the DRL's.
Anyone have this happen to them. Any idea on the cost of the repair? Can I get a warranty fix for something like this?
Tracy
Anyone know if that's good advice or not? I'd sure like to figure out what cupping is caused by so as to stop it in the first place.
Tracy
To answer the Driver door wind problem Yes I have had that problem
as noted in my posting earlier this year.
The wind caught my drivers door as I opened it and almost
tore the door off the car. After checking with the dealership about covering
it under the warranty they said no so I was out $197.00 at the
local body shop. Again a month later the same problem.
I took it to the same dealership and asked why a restraint strap was
not installed on the door.
Another $197.00 at the same body shop. Than 2 weeks ago the same thing
happened after the dealership had welded the hinge to the pillar frame.
There is a problem and I have been watching this board to see how
many other people have this same problem.
Needless to say we traded for our old standby a 2003 Buick Lesabre with a door
restraint strap. Buick did reimburse me for the body shop repairs.
I too am somewhat concerned with the door hinges being damaged. Just over this weekend, I paralleled parked on a slanted street and when my gf opened the door, it went flying outwards due to the slant. She's usually good about holding onto the door.
Now, I had wanted a Daewoo (sp?) in the past, and the wind caught that door with a large gust. One hinge broke! the other stretched to point of 1 inch opening when the door closed. Thank goodness I put it on our VISA and declined coverage....damage: $800.
Hope this isn't going to be a recurrent problem on the RDV. Our Nissan Sentra SE-R had production problems with sagging hinges (door too heavy) that caused a lot of wind noises at 30K
e-mail address so it makes it impossible to answer them on a personal basis.
Yes I did get reimbursed for the door hinges that were bent twice from Buick. After the third time they welded the hinge and the wind got it again and that is why we traded back
to the LeSabre. I called a complaint into a consumer hot line provided by
the Buick dealer and also wrote to the President of Buick than they agreed to reimburse me for the damaged hinges.
It took 2 months to receive the check.
