Visitor Agreement.
Also try to jack up front wheels, one at a time, and turn each wheel left and right to see if there is freeplay in steering.
Agree with jk27's advice to see another dealer.
The 3.4 engine is known to have a faulty intake manifold gasket design. I had the engine flushed with new Dex-Cool in year two to try and minimize the caustic nature of the coolant while still maintaining the factory warranty.
I just had a friend spend $800 to replace the gaskets on his 2001 Venture mini-van.
We decided to change out the Dex-Cool for a new green anti-freeze that is suitable for all engines.
Guess what, he saw the start of a minor leak on the upper right-hand side of the gasket! He added a container of Wynns Radiator Sealant to hopefully stop the leak and prevent the repair.
If you are still under warranty, have the gasket replaced with the new design that came out in 2003. I am just 60 days out of warranty and know that GM will do nothing to fix this.
This vehicle has been very good up to this point, but I am sure that it may be all downhill from here. I highly recommend the extended warranty if you have the 3.4 engine.
Hopefully the 3.6 VVT engine is better otherwise GM is going to lose a great number of customers to Toyota and Honda. This may be my last GM vehicle....
* Check engine light comes on at various times.
-- My service department looked at codes from the computer for this including "Loose gas cap" and "Emissions sensor problem" (of course that was not the real problem...)
* When using the left turn signal, the hazard flashers would come on in the back. Right turn signal was alright and this will not happen every time the signal is used.
-- My service department was clueless....
I recently had the vehicle in the shop to finally get the Engine Check light fixed. They kept it for a week and went over the complete electrical system.
They found that the Bulkhead connector for the wiring harness had filled with water and corroded. This was causing my odd electrical symptoms to occur. My vehicle is a 2003 RDV and the Bulkhead connector for my vehicle did not have a seal around this connector. That allowed the water to accumulate and short the connector every so often. I was told that newer models have a rubber gasket in the bulkhead connector and this is not a problem.
If you are having weird electrical problems you may want to have your service department check the Bulkhead connector for corrosion and standing water.
Since I have had this fixed my taillight problem has not re-occurred. I hope that this fix is the last for that problem.
1. I cannot set the keyless entry fob button to BOTH flash the lights and sound the horn - only the lights flash.
2. Sometimes the radio/CD player forgets where it was playing a CD - and sometimes it remembers - with no rhyme or reason.
3. Sometimes the backup warning gong sounds properly and sometimes it forgets to chime until I touch the car I'm parking in front of. Again - no pattern.
Now, I know these are minor complaints which are on my punch list for warranty attention when I bring it in for first oil change [only 3K miles so far].
Do these items ring any bells with any forum members?
2. Don't play my CD enough to know.
3. I've read that backup sensors are not 100% dependable. Their effectiveness is based on the height of the car or object behind you and it's shape. The more blunt the shape of the car behind you, the more likely the sensors will "see" it. Also, the speed with which you backup also makes a difference. The slower your speed, the more the sensor will "see". This is true for all the backup sensors for other vehicles.
Hopes this helps.
The latest - the automatic door-locking sometimes delays when I put the car in gear - and sometimes it doesn't.
Nextmoon - you're right about pressing the 'lock' button on the fob twice to sound the [wimpy] horn.
Do you mean low windshield wiper fluid sensor, if so my sensor has warned me a couple of times.
Oh, and my 2002 RDV CXL has a low windshield washer fluid light and it operates as it should. Wish I had the tire inflation sensors on my model
My air pressure light came on one time in the middle of a road trip. Needless to say, I slowed down a lot just in case. However, I found that the cure was to reset it with the two buttons on the dash. After I did that, no more problems. I might add, in almost 23,000 my RDV has been trouble free. Never even been back to the dealer. Knock on wood. About the horn. It's no good when you finally do find it. What a screw up that is. Good luck.
I've heard the tire inflation sensors need to be adjusted properly with each tire rotation/change. So it's an extra expense in addition to the regular cost. Can anyone with tire sensors confirm this?
My wife drove the car when it was fairly new and the bells went off. She didn't pay much attention. When the car was home, I started it and the bells went off before I moved it as a warning. I checked the tire pressures, found one at 28 instead of 33.
My wife had not mentioned the bells. Talked to my wife lovingly about the importance of the DIC with its bells and whistles!!!
If the wheels are rotated or the air pressures are adjusted, I use the reset button so that the computer will remap the rotation ratios of the tires from its antilock brake system.
Also, have you noticed the starter run on after engaging the key? The dealer told me it is supposed to do that. I said it sounds like the started has a problem. They said it is just the computer. It keeps cranking the starter until it recognizes the car is started.
The front tires heat up more and the difference between front and back rotation rate is affected by the temperature expanding the air. I've never had a problem with that. If cold resetting doesn't do it, reset after the car's been driven a few miles at moderate speeds.
Friends had a tire replaced on a new LeSabre in 2000 or so. The sensor would go off only when the car was going down a steep driveway. They took it back to the dealer finally. The Tire Discounters tire store had put on the wrong size front tire. 205 instead of 215, e.g. The tire had been ordered in and whoever did the final installation didn't check that it was the right size!!!
The system found the rotation rate was different enough only when the additional weight was on the front wheels changing the rotation rate due to tire crush.
As for the starter, mines stops after I let go of the key. Your starter doesn't sound like it's acting normally. Maybe try bringing your RDV to a different dealership to have it checked out if that's an option.
As to the low washer fluid, my book says like I have it. When I inquired at the dealer they had to contact GM. Finally I had an answer that the CX doesn't have the sensor and in later issues of the owners manual the wording is different on this sensor.
http://www.mygmlink.com/pdf/go2content/manual/US/en/buick/2k04ren- dezvousgtk.pdf
Do you have the buttons for the DIC control which is in one of your instrument clusters?
Page 6-15:
How to Reset the Change Engine Oil Message
If your vehicle does not have the optional Driver
Information Center (DIC), do the following:
1. With the ignition key in ON but the engine off,
fully push and release the accelerator pedal slowly
three times within five seconds.
2. Turn the key to OFF.
If the CHANGE ENGINE OIL message comes back
on, the engine oil life monitor has not reset. Repeat
the procedure.
If your vehicle has the optional DIC, do the following:
1. Turn the ignition to ON with the engine off.
2. Press the MODE button until the DIC reads OIL
LIFE LEFT/HOLD SET TO RESET.
3. Press and hold the SET button until 100%
is displayed.
You will hear three chimes and the CHANGE
ENGINE OIL message will go off. If the CHANGE
ENGINE OIL message comes back on, the monitor
has not reset. Repeat the procedure.
I guess I was looking in the wrong place- everything I read, including a response from someone else here, gave me info on the DIC, but not what you suggested. It worked!
No check engine lights. Sound occurs at any level of fuel.
Any one else have this issue and know exactly what the problem is? I like to have my facts straight BEFORE I go to the dealer for the song and dance.
PS Every one that thinks they are driving an American car look again. Yes, it is made in Mexico.
The company is an American company. The profits go to GM. At least the money doesn't end up in Japan or Germany as in some other car companies.
Is there really an "American car" still out there? I mean, assembled in America, with all parts from America, with American workers? I truly doubt it.
I remember purchasing a Mercury Tracer in 1988 and feeling good that it was an "American car". I discovered that it, too, was assembled in Mexico and that it had a Japanese (Mazda) engine. The only parts from the US were the seats.
Welcome to the global economy!
