Visitor Agreement.
In my case I was used to using a Fram PH8a "sized" filter, which as most folks know, is app the size of a oversized coffee mug. Needless to say I was skeptical but the oem compared the filtering material and needless to say I now use the new and smaller oem filter size. Again this is in a Toyota Landcruiser.
Two of the neatest things I have on my Corvette are an ambient outside temp gauge AND an oil temp gauge !!! In theory the great area and mass of metal does operate like a "heat sink". However in my Corvette, there is not much room to deviate from the PF-44 oil filter unless I do a complete filter reroute. Then of course you'd have to factor in the longer lines and the extra oil, in addition to the bigger filter and test it against a smaller filter...
________________
The Super Tech catalog calls for the ST2808 on the 2001 Hyundai Elantra.
The ST6607 could be used as a smaller alternate, however the correct filter
which we recommend is the ST2808.
The only air filter we have available for this application is the Champ
AF7999. For the nearest Champ distributor in your area, please contact our
Customer Service at (800) 851-3641.
If you have any other questions, feel free to contact us at any time.
Chad Garrett
Technical Service
Other than Kmart, are there any other outlets for either Penske or Castrol filters?
BTW, does anyone know anything about the current oil filters that Toyota sells for the 4 banger Camry? I've noticed that our local metro Phoenix KMarts now have no penske or castrol filters. It appears that if you want wix you have to go to NAPA and get out the money gun!
saw their internet ad on the filters
I use supertech and purolater filters but have used Toy if I go by the dealer (other side of town)
some do not like the thinner metal shell tho I have never had one fail.
either is prob OK
st is cheaper.
*post 1705
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html
Please give your thoughts.
I see there are magnets to place on the outside of oilfilters too. Anyone try them? If the metal stays loose in the filter and the antidrainback valve doesn't work it could be trouble. The magnet will hold the metal till filter change.
Seem like a good ideas to me anyways.
I emailed champlabs to find out if it is ok for my application.
Also, I picked up ST8A filters for my dad's 2000 Ford Ranger 4.0L at 1.97 each; The motorcraft F1A was 2.67 each; The size of both filters were identical and both made by champion labs. I bought three supertech ST8A good deal there.
From my observation, walmart auto dept has mostly fram stuff. they only carry fram air filters there too. With oil filters, it was about 70% fram..15% motorcraft..15% supertech. this is in Memphis, TN
Autozone here carries bosch, stp, fram, mobil 1 oil filters; Mobil1 filters are too high. Since I avoid fram, I've been using bosch at 5 bucks a pop from autozone looking for cheaper high quality alternatives. I've never been to advanced auto parts store. does anyone know which oil filter brands they carry? I went to advanced auto parts website and it only listed the services they do and what replacements parts they carry. no mention of oil or oil filters they carry.
oh, and I wish I picked up some wix filters from Kmart. We don't have that many kmarts here. I went to one last week and their filters were a mess. Very unorganized like someone went through all of them and no cross reference book was found. I'll have to do some research to find which wix filters apply to my 92 mits 1.5L engine.
On another note, when I was at walmart. they only two 5w30 valvoline maxlife oil bottles left at $1.97 each. this was around 12 noon. Everytime I look for this stuff they are always sold out. I looked for chevron supreme but walmart doesn't carry it. They carry Valvoline, Pennzoil, Quaker State, Castrol, Supertech oils.
oh and if everyone has any other suggestions on where else to get bargains post info please. Thanks
The ST6607 is the correct filter for the 1992 Mitsubishi Mirage 1.5L, based
on the information we received from Mitsubishi. The Supertech line is a
consolidated filter line, in order to keep less unused filters on the
shelves. Sometimes, that can cause a filter to be slightly shorter than
the original equipment filter. This is just a difference in manufacturing
and all filter warranties will remain in effect when these filters are
used. Please be assured that the ST6607 will work on this application with
no problems. However, the ST2808 can be used if provided there is enough
room and clearance to use this filter. The decision to do so will be under
your discression though, for we are basing our information from that of the
o.e.
Chad Garrett
Technical Assistance Representative
Champion Laboratories, Inc.
I'm still unsure whether or not to use the ST 6607; I'm going back to walmart to see how much difference there is with the ST 6607 and the ST 2808. If anyone has used ST 2808 instead of the ST 6607 filter, please post any results with it.
btw, I do have enough clearance for a bigger filter.
oh ya, I looked up oil filters at O'reilly auto parts online..they have a O'reilly microguard filter for 3.99. they have a wix filter for 5.49 a little too high for my tastes.
they are a supplier of wix oil filters. you can fax them a list of oil filters you need and they will quote you a price. Free shipping to 48 continental states and no sales tax. might be a good deal. They are based out of NY. anyone have any experience with this site?
Advance Auto Parts stores in my area carry Purolator PureOne filters. This is a well-regarded filter line. Advance sells most of the PureOnes for $5.99, I think. The Meijer stores in our area (basically, a Kmart/Wal-Mart plus a grocery store all in one) carry PureOne for $4.99 each. Meijer is in several states but I'm not sure if they are as far south as Memphis.
Im still unsure whether or not to use the ST 6607; Im going back to walmart to see how much difference there is with the ST 6607 and the ST 2808. If anyone has used ST 2808 instead of the ST 6607 filter, please post any results with it. btw, I do have enough clearance for a bigger filter
I have used a 2808 in place of the OEM filter on my V-6 Hyundai. Then I bought a 6607, stuck it alongside the 2808 and quickly returned the 6607 to Wally-World.
I had one spare OEM filter (it's even bigger than the 2808) and from now on, I'm gonna pay the price for the import OEM. It's about US$4.50 and twice the size of a 6607. Don't know if the inside of the OEM is ALL media (presently draining one to cut open), but as I have plenty of room around the engine, physical filter size is no problem. That and the appearance of the OEM filter. It is just SO much heavier and cleaner looking. Even comes with a plastic 'condom' over the open end to keep out any crud that may enter on the trip from the Motherland! =;-))
