Oil Filters, whose is best, and Why?
However, ask Amsoil, many of their filters have duplicate uses and they usually have a larger filter with the same thread and bypass settings that you can use. I fact, my chart says the SDF 20 and the SDF 36 will both work. The 20 is slightly larger and the 36 much longer so it depends on your clearances.
I have since put over 1500 miles on the new oil and filter change, and in that milage have used absolutely no measurable amount of oil.
I'm still curious, what with this being a forum on oil filters, if anyone has seen the bypass on a filter not allow the oil to fill the filter until after a period of time such as this seems to have been. I can't figure any other place for 1/2 quart of oil to suddenly disappear. It happened only once, so there is obviously no oil using problem with the engine itself.
Quote Old Post:
#2424 of 2440 Stuck Bypass? by fwatson Jul 14, 2003 (7:01 am)
I had a curious occurance. About 3000 miles after changing the oil and filter on my '01 Mazda Millenia P, I took a 150 mile trip. Before leaving, as usual I checked the oil level and all was fine.
The trip went fine, but when I checked the oil before returning home it was down halfway between the add and full marks. I headed home and bought a quart of oil about 75 miles down the road, and it still showed about midway on the stick. Added the oil to the full mark and went on home. Next morning oil level checked full.
I have since changed oil and filter again and after about 500 miles there has been no drop in the oil level.
It may seem strange, but all I can come up with is a stuck bypass in the filter that finally closed allowing the filter to fill. Does that seem sensible to you filter guru's?
There has never been any sign of oil on the engine or underneath the car, and the tailpipe is clean and dry. I haven't seen any even minute sign of oil smoke from it.
The filter was the same, SuperTech, which I have run for years on all my cars with no previous incident of any kind.
They look just as small as my 2002 MazdaP5 filters but Mobil cross reference is stating that my car should use M1-108.
M1-103 is designed to be used in variety of Toyota 1.8L engines (Corolla, Celica, MR2, Matrix, Pontiac Vibe) can I safely use those in my Protege?
Right now I'm using PureOne from a 2.5l V6 Mazdas or Bosch equivalent.
What should I do?
What's a better choice?
