1996-1998 is Gen 1
1999-2001 is Gen 1.5
2002- 2004 is Gen 2.
2005-2006 is Gen 2.5
2007-2009 is Gen 3
2010-2011 will be Gen 3.5.
there are subtle changes within Gens, e.g. from 1 to 1.5 the compression changed, so did the output and trim levels, Gen 2 to gen 2.5 included new AWD system (same as Gen 3) and drive by wire with VSC (same as Gen 3)
Gen 2.5 manual (mine) gets 26 mpg city, and 30 mpg on the highway.
As to OP, 2000 is a good model year if it is maintained well.
It needs to have the valves adjusted every 30,000 miles, like any B-series engine. Timing belt needs to be changed every 7 years or 100,000 miles, just like any B-series engine.
When did the shaking start?
OW
Good Luck
You can retrieve the code by registering your ownership in owner link in www.honda.com. what it needs is answer a few questions.
Re-read the Owner's Manual on starting procedures, i.e. dash lights going out before starting.
Re-read the Owner's Manual on immobilizer protection, i.e. blinking green key light.
If those two don't help, then you are probably not cranking it long enough.
Also is there a way to manually start the all-wheel drive mode? Say I want the vehilce to be operated under all-wheel drive mode no matter what the road condition is!~~~
Turn off VSA.
Put her in 1st.
And have fun
http://www.youtube.com/watch?v=q6qxbyUlRz4
This is how you know AWD works.
They have "Real Time" four wheel drive.
If slippage occurs, power is transferred to the rear wheels. It is seamless and the driver has no control over this.
It works like a charm too. I was thankful to have it during this past crappy winter!
Ditto. The traction is amazing and quite useful. Love it!
OW
Generally, ATF fluid in a Honda should be replaced every 30,000 miles with Honda ATF Z-1, only!!!!!
Honda recommends draining, refilling, driving 5 miles, draining, refilling, driving 5 miles, draining, refilling for 90% fluid replacement.
Anyone have a suggestion (other than electrical tape over the light, please)? Anyone ever solved this? Thanks.
Normal and Severe conditions are defined in the OWNER's MANUAL.
Ask PepBoys if their alternator cycles on and off electronically like the Honda one does. Chances are that it does not.
Honda Alternators, unlike most others, are not on all the time. They charge the battery to 100% and then cycle off until battery is discharged to about 85%. Then cycle on again.
One can observe this with a voltmeter while driving. The voltage will cycle between 14.3V (alternator on) and 12.0 V running off battery. this allows the vehicle to be more fuel eficcient by taking the load off the engine, and prolongs the life of the battery by not overcharging it when it does not need to be charged.
Since the computer sees alternator on all the time, it alerts the driver that alternator is not performing properly and is probably over charging the battery and will eventually lead to failure of most of the electronics components, including, but not limited to the on board computer.
Honda, unlike others, are not cars, they are machines. Check out Honda Azimo if you think you are just driving a car.
OW
THEN I would use good synthetic oil like Mobile 1 or AMSoil, and a good filter (mobile 1, Purolator Pure-One, AMSoil) every 5000 to 6000 miles.
If you said NO to at least two of the conditions above (like me), then I would stick to the usual 3000 mile interval, of course still using quality synthetic oil and a good filter.
If you continue to use conventional oil, I would never pass 3 months or 3000 miles whichever comes first, no matter what the conditions.
Anyone with the initiative can perform their own test.... change your oil and filter and check it, paying particular attention to the color and odor. Using a clean white napkin to wipe off the dipstick is a good way. Then repeat checking the color and odor weekly until the oil begins to get dark, and/or starts smelling like varnish. That is when you should change it, and the number of miles you have on it at that time should be your interval.
Using less expensive oil and fram filters, mine was getting bad at way less than 3000 miles. I now use only Mobile 1 Extended performance oil and Pure One filters, and I could go to maybe 3500 or 4000 miles, but I don't. 3000 is my limit.
The Dark Oil Myth
Are oil changes every 3,000 miles really needed?
I use dead dino in my minivan and have pushed the usual recommended 7,500 interval out to 11,000 miles at least once. It's a '99 and ~133,000 miles on it. Oil's a lot better than it used to be.
If you really want to know what shape your oil is in, pay the $20 for an analysis.
I have NOT seen proof that 3-5K mile oil changes extend the life of the engine. I HAVE however seen first hand proof that 10K mile changes with synthetic oil and a good filter does not impact the life of the engine.
My M.M. told me for oil change after first 5,000 miles, then 8,000 miles later and MM shows I still have 40% left. I think may be a change of acceleration habit, now I accelerate slower and off the gas pedal earlier.
So if you want all that junk floating around your engine for 5-7k miles, go ahead. I like my car.
You'll need a longer test to test oil consumption. You might have the dealer check your PCV valve, and also complain about oil consumption. Maybe there's a leak you can't see. At least the complaint will be recorded.
Generally, there's no cause for alarm here unless you continue testing and find that the oil consumption in miles per quart is slowly increasing as the miles pile up. An engine can use some oil and run forever, but when it drops to say one quart per 1000 miles, that really gets my attention, especially on a newer vehicle.
Next oil change, try to measure it very accurately. And make sure the dealer makes note of this on the repair order....and check the PCV system.
But they don't. Some people drive mostly on freeways and at moderate speeds and live in an area with a mild climate. For them, a longer interval between oil changes makes sense. Honda's system attempts to account for these differences. It makes sense to me.
Is there proof that "thicker is better"? Or is it just a personal preference?
Aren't you concerned that the switch to 5-30W will void Honda's warranty?
You should always use the thinest possible oil your vehicle's engine will use. I'ts because of the close tolerances in the new motors. The oil needs to get to all parts of the motor immediately upon starting and remain there at full pressure at all times.
The only vehicle I've had trouble with is an '01 Camry 4 cylinder. Started using oil at 60,000 miles. Treated it like my child, so it was doubly frustrating. It's got 135,000 now, and I'm going up (45 miles) after class this morning to check and probably add oil. My sister has it now. Cat converter hasn't gone yet, and it doesn't tick or knock. I changed the oil myself on that one, as it was easy enough for a fifth grader to do. But not the first few times.
I spent $10 on a raffle ticket two weeks ago. Prize is a CRV EX. Drawing in November. Just checking to see what I could be in for
And on the viscosity. I switched to 5w-30 early on but switched right back after mentioning it to a top-notch professional mechanic who has the same model CR-V. He says the engine's self-adjusting valves need the 5w-20.
Maybe that's what he meant by "self-adjusting".. :confuse:
