I have change the Service valve/high sensor/accumulator and the compressor
What else can I do???
!!!!Does anyone have a solution for this problem!!!!
It's very annoying specially in a hot place like this one (central america)
HELP!!Help!!
I like the ability to flash at tractor/trailers to let them know it's safe to change lanes!
I have also had a problem with the stability system light being on ever since I bought the truck in 2007. Does anyone have any idea what the problem may be, or is there anyone experiencing the same issues? I am concerned that this will be a pretty expensive fix. The truck has already been in the shop 3x in the last year. The wheel bearings have been replaced, as well as the wheel speed censor, so unfortunately that was the not the problem. Any advise or assistance would be greatly appreciated, Thanks!
Jaxon
Please feel free to email me at govinl@uwgb.edu.
Thank You
Let's keep the discussion here so everyone will benefit.
SUVs and Smart Shopper
How can I get information on what I should really be paying? 33k.
Scott
feel free to ask me.
The Escalade is still under warranty. I know that brakes would not normally be covered under warranty but when this happens to soon might they be covered?
A chugging noise comes from the front axel area when making a gentle turn. The similiar sound as a 4 wheel on hard surface with the hubs locked. Does not always happen. And I can't make it happen with a really sharp turn.
Our service garage says "Oh, The diffrentials and transfere case fluids need changing" $375.00 and we still have the same problem. I'm hesitant to take the car back to them without knowing more about the system myself!
I know the car has an automatic stability system but I don't know how it works or if that has anything to do with it.. Any suggestions would be appreciated.
Andrew
Disconnect the lamp electrical connector from the lamp assembly.
Remove the nuts from the back of the bracket.
Remove the lamp assembly from the bracket.
Remove the 4 lens screws.
Remove the lens.
Remove the gasket.
Remove the bulb.
We took it to Bergstrom automotive and they said the bearing hub is broken & needed to be replaced or else accidents may occur in the near future. Cost us $650ish just for the part and another 1k for labor.
I think your problem is the same as our's. Good luck.
It has 164,585 miles on it, and, besides tires, I've only had to replace the battery (two months ago) and had new front brakes/rotors installed (I live on a steep hill and use low gear) two years ago. The "Service Engine Soon" light came on and, when diagnosed, battery replacement was indicated. Put new battery; problem resolved.
Now, light is on again, and indication is one O2 sensor needs replacement. I used 85 octane gasoline when I drove to Minnesota three weeks ago (I live in Calif.) with an octane booster, as I've done in the past. Would that have affected sensor ? And, would that indicate that the other three sensors are bad, also ? How does the diagnostic meter know which sensor needs replacement ?
If I do the work myself, how do I know if it is three wire or four wire, as there is a myriad O2 sensors for the 6.0L Cadillac engine ? Even 1 & 2 wire.
I have an 02 EXT and I'm having a problem with my front end shaking with I turn sharp to the left. It feels as if though the wheel is slipping. I've had this problem before back in 07 and had it fixed but lost the paperwork so I forgot what they fixed. Would anyone know anything about this? I'm hoping to narrow the problem down so I can possibly buy the parts and fix myself.
