Acura Integra GSR Customizing and Modifying
http://home.earthlink.net/~cvlocas/wheels.html
Harry, have gone back and forth with Tirerack about the center caps. So far, they have offered a discount price of something like $26 for all four center caps. I'm not giving up yet, though .
Thanks in advance for any info!
In terms of goals...i was planning to up the power and handle and appearance a little. Im not planning on auto-x or street race, but i'd like a little more oomph. I plan to get the AEM CAI, probably an exhaust, a rear sway bar (probably comptech since i hear good things about it...but it's a little expensive...how's neuspeed?), and maybe a set of wheels later on. Then maybe some springs...but that's probably last cuz i think it'll look better a little lowered with bigger wheels...17in at most.
If you plan to put one in the lower part of the bumper (the "mouth" part), that's easy to do on your own. It most likely won't look as neat as a pre-made one from GrillCraft or a similar company, but it'll only take a few dollars and maybe 30 minutes to do. What most folks do is buy some wiring from a hardware store and cut it into the appropriate size. Then slip the piece into the slot, bend it around the inside edge of the bumper, and fasten it on with small screws or adhesive.
Note: Don't use the screen door material. Use something stiffer that will hold its shape better.
Doing it this way won't look as nice as buying a pre-made kit, but it's cheap and quick.
Mods-wise, the most popular basic mods are the ins and outs - intake, exhaust, header. Combined, they'll give you some so-so power increase, but only at the high end, and you'll most likely lose low-end power. If you want to lower the car, then I'd personally recommend looking into some adjustable coilovers (just my opinion).
As for looking too riceboyish...unfortunately, the majority of folks consider pretty much any modified import (especially an Integra with grill, exhaust, aftermarket body kit, and lowering springs) a [non-permissible content removed] car.
http://www.groupbuycenter.com/buy.asp?row_id=3171
I just named it off the top of my head. I like the OEM front lip best of all, but they are hard to find as Acura discountinued them a couple months ago. If you could get lucky and get one of those and then take your car to a body shop to have the black side skirts color-matched with your car, it would look great IMO. The "gutter-guard" mesh stuff has been done before. I don't like how it looks in many cases but you can always go to Home Depot and spend about $3 and play around with it on your grill. Suspension modifications are also a great thing because they enhance your handling over stock by a large margin and make your car look better as it is lowered. As hard-core performance is not your main goal, I would probably go with the Tokico Illumina Suspension kit (struts and springs $535 shipped). I would definitely not recommend getting just springs as they will wear out your stock struts fast and give you a bouncy ride and then you will have to replace the struts anyway. A Type R rear sway bar will cost you $100-$125 (with all the necessary hardware) and will take out a lot of the body roll. Exhaust is okay for sound and looks but don't expect too much hp from it. I personally think the stock exhaust looks fine on a GS-R. For wheels, look on tirerack.com to compare how several wheels look on your particular car. Then, get the Kosei K1 Racing wheels to be like the rest of us in this forum
thanks,
victor maniquiz
510-222-8313
BTW, no I haven't upgraded to coilovers yet. I 'm still on my old H&R OEs which is why I 've been getting my butt kicked by another '00 GSR with GC coilovers and lowered about 2-2.5". This GSR also has a Comptech 22mm sway & tie bar combo.
I 've been loosing by about .3sec. to this guy who in pretty much a novice and this is his first season! I 'm convinced his setup and handling much better than mine although the guy auto-xes religiously and drives around to 3 different states to different clubs (NY,NJ,PA) and has done at least 20 events or more he tells me, plus auto-x school!
Anyway, this past Sunday although I lost to him by .3sec. (I drove the hek out of my car and actually PAX'd the lowest I ever did), in the fun runs I managed to exactly match his time of 34.35 so now I 'm happy to know that my car (and myself) can be just as fast as his. I 'd probably do better in his car given my experience but this kid (23yrs old) seems to be a very good driver. When I watch him drive I 'm like wow, that looks fast, but now I know what I look like when I 'm out there. The guy complemented me too and said the same thing, that when he watches me he knows what he looks like..
I 'm very comfortable with the H&R & the Konis that I 'm reluctant to get coilovers but I know I 'll have to, to be more competitive. If I can loose or be matched by a first season driver (however exceptional this driver may be) there 's no doubt in my mind that coilovers is the way to go. I 'll most likely get them in early spring in probably 400-450lb flavor. This guy has the regular street kit which if I 'm not mistaken are 350F/280R or 380F/300R. I 'll probably go with 450F/400R minimum.
Oh, I fogot to mention that about 3-4 weeks ago I had FTD for the duration of the day runs for the first time in my life!! That was shortly lived because in the afternoon the temps warmed up and the other faster cars started getting traction and of course beat my times like they usually do.
That felt really good though..
'06 Civic LX coupe
'11 BMW 335i coupe xDrive
'13 Honda Accord sedan (wife's car)
Oh yeah, if you haven't already, be sure to check out the December issue of SCC b/c it has a sweet feature on some awesome handling cars...a "g-test" if you will. I enjoyed it.
I saw the new Z06 Vette 405hp a few weeks ago up closed & personal. The guy let me sit in it (not much room) Now that's sweet! The mags said they got 1.0g on the skidpad with its factory street tires. That car was VERY fast but its driver was so & so. You could tell it had great handling and traction just by the way it was turning or by the way its driver would straighten it out easily when he realized was going too fast into a turn or to avoid wiping out (auto-xing). At the end of the day one of the club officials who is also an Evolution School instructor drove it in the fun runs and got 2 secs faster than its owner. That was about 1 sec. faster than my best. BTW, he took it for 2 runs. He did better with the traction control off.
I 'm really interested in the upcoming SCCA issue. I want to see what kind of g's they pull with modded cars and what kind of suspension they use. Thanks for that info chem..
I remember about 2yrs ago, they took a '99 Civic Si and put GC coilovers, Illumina shocks I think, sway bar, tie bars, etc. and got 1.01g on street tires! I think they were using Dunlop SP9000.
'06 Civic LX coupe
'06 Civic LX coupe
Why don't you tell us what G's some of these cars pulled?
'06 Civic LX coupe
9 ITR .913g
8 del Sol .926g
7 Beetle .937g
6 Supra .948g
5 Cosworth .956g
4 Porsche 914-6 .985g
3 Supra 1.009g
2 Beetle (the insane one) 1.011g
1 RX-7 1.035
The slalom results were pretty close in the top part of the group with the ITR, more-modified Bug, one Supra, and the 914 all being within .1 mph (from 71.6mph to 71.7mph). The RX-7 got 72.4 mph .
The RX-7 is awesome. There are usually 2-3 of them that auto-x with me, lately I 've been doing slightly better than them or match them at worst. Of course all they have is adjustable shocks, but they 're very fast and nimble. I 'm very happy to keep up with them with my relatively soft suspension. I just got back from another auto-x event. An STS (modded on street tires) GSR with GC coilovers/konis & 22mm sway came close to my times (only .6 sec. away)! He had 400lb-F/350lb-R spring rates and lowered about 2.5" (a little too much drop for my taste). Really good handler. This car seemed like it rotated on a dime. Had the new Falken Azenis on as did many other cars. Everyone says that is a really good street tire and very sticky. My brother is buying them for his Type-R too. I hear they 're pretty inexpensive. This guy had faster times than at least 15 other cars with R tires. With the proper suspension setup street tires can work better than some cars with R tires and inferior suspension.
'06 Civic LX coupe
My Kumhos are starting to go and I can see a little bit of the steel belt on one spot but I have one more event this season and I 'm going. I want to run these tires to the ground anyway. This I think will be my 18th or 19th event this year but my problem is that I drive to the events on the Kumhos and don't ever take them off (too lazy). I could 've easily gotten another 5-6 events out of them if I didn't drive on them.
They don't grip like they used to anymore but I figure what the hek, I won't be racing for another 5mos so I gotta go
'06 Civic LX coupe
I think the rear Si and Integra brakes are the same. If you do decide to go that way, remeber you can use the Si or Teg hub/spindle, etc. but don't have to use factory rotors. Get Brembo ones, they 're cheaper!
BTW, my auto-x season is usually from the middle/end of March to the middle of November. We get a solid 6-7 mos so it's not bad. Now I 'm talking about 4-5 different clubs (2 of them SCCA). Some clubs start in May but run till Nov. Others start Mar-April but end in September, etc.
The only thing is, it's warm from May through August, but the other months can be cold and even get snow! It sucks for R tires. This weekend's forecast calls for high 40's to 50deg. To those with R tires, auto-xing in those temps, means it will feel almost like driving on ice! Very tricky and you have to restrain yourself so that you don't spin out or lose control of the car. November is definitely not my favorite month to race. You also have to work at the same time and freeze my butt off chasing cones that other cars knock down. The good thing is, not too many people usually show up in cold weather so there's time for more runs.
'06 Civic LX coupe
It was so slippery (for those of us with R tires), I wiped out 3 out of 4 runs. I didn't go off course or anything and didn't even hit 1 cones. Just slided sideways and came to a full stop on a 180deg u-turn like turn. So I only had 1 good run which was so & so (in the fun runs I did almost a second better) but still managed to get a 1st place trophy in my class (only 5-6 cars in my class this time). Plus my club, the one I 'm registered with, took the "challenge cup" because we had the most points out of all the other clubs. We had 11 1st place wins compared to 8 of another club. So for the 3d year in a row our club gets to keep the big shiny trophy (gotta give it to another club if we loose next year, it's just symbolic..). So my season ended well even though I had 1 good run. The GSR & the Kumhos served me well with at least 17 trophies this year. Got by butt kicked twice, both times by other GSRs with coilovers but I 'll be ready for them next year :-)
'06 Civic LX coupe
your back brakes dont need to be replaced because thats not where you need stopping power. when you hit your brakes the weight of the car pushes down and forward on the front brakes..so better front brakes mean better stopping.
A '98 Civic HB is very light and weighs a little over 2300lbs with A/C. All you need to do is upgrade the front brakes.
Brembo rotors cost me $26 or $28 each for the front (plus about $10-15 shipping for both). AXXIs pads are $35 for BOTH front including shipping! You 're talking about $100 for the whole setup with shipping!
You shouldn't need SS braided lines unless you do track events, road racing, etc.
If your rotors are in good shape, I 'd just replace the pads for now. You 'll notice a big difference. Just remember no matter what aftermarket pads you get, they 'll dust if they are any good. So rinse off the brake dust from your wheels once or twice a week.
The big brake AEM kit I think is way too expensive. It is NOT $500 for both sides. It's at least $400 PER side but comes with calipers & pads. You 'd also be adding more weight to the front wheels and that will have adverse effects on acceleration and handling.
I Know a guy who upgraded to Type-R brakes on his GSR. He said his car had slower acceleration and steering response got worse. It's the same as putting several pound heavier rims on your car.
Let me know if you want to know where I got the rotors. The pads you can get from the groupbuycenter. From Coximports. They always have sales on the Axxis. If you don't see it on the groupbuycenter give them a call. The price is always the same, $35 w/shipping for Civic.
'06 Civic LX coupe
Could be a combination of everything, Brembo rotors, pads, Goodridge SS lines, and fresh (Honda) brake fluid that were done at the same time. I know that the fluid & SS lines don't make any difference unless you 're racing on the track where you 're heating up your brakes & fluid really bad. Pads are supposed to be what make the biggest difference.
'06 Civic LX coupe
116C West Park Rd.
Dayton, OH 45459
Steve or Vinny
937-312-1532, 1533
I paid $28 ea. for the front GSR rotors & $24 for the rear. Shipping was $15-20 for all 4. Later I also bought 2 front '96-00 Civic Brembo rotors also from Colleti, $26 ea.
Paid $99.99 + $9 shipping (ripoff, the things weigh less than 1 lb) for Goodridge SS lines, the whole set. A&H & everyone else was $119-129.. too much. I can't remember who I bought them from, I 'll look for the receipt. They used to advertise on the groupbuycenter.. Let me look at my favorites folder.. I think I bookmarked it. Yep, I found them. Lightning Motorsports! $99.39 for all Acuras & Hondas. I remember it took me like half a day to find that price. URL: www.lightningmotorsports.com. Lightning's s+h charges are a little excessive but have really low prices. A&H that is one state away from me (in PA) wanted $11 to ship them, plus they were like $125. I don't order anything from them although many people on the East coast order from A&H. I think their prices are high as well as their shipping charges. Companies always make money on the shipping. I don't mind paying like $1-2 more than their cost on shipping because they have to pay for someone to package everything up & ship it out, but doubling the shipping charges, I have a problem with. You can go to ups.com, put in a vendor's address and your address, estimate the weight of the package, and it 'll give you the UPS shipping charges. Then you have a pretty good idea how much the vendor is trying to make on shipping..
'06 Civic LX coupe
See if you can find an MC at a junkyard from the same model year as your car. I 've also heard that the rebuilt ones from major parts stores are not bad either. Good luck!
I hate to admit it, but from now on I 'll bring mine in to the Acura dealer when it comes to bleeding brakes. They did a great job with mine.
'06 Civic LX coupe
'06 Civic LX coupe
One more thing -- A group of us in the Atlanta area are heading to a "dyno day" on Dec. 1st. I'll be dynoing my car for the first time. Care to venture a guess about what kinds of numbers I'll see? Too bad I don't have any dyno runs stock, so I guess I'll just guestimate my stock whp at around the standard 140ish. I'm hoping to see 155-160 with the mods I currently have (AEM CAI, JDM 4-1 header, Carsound hi-flo cat, and custom 2.5" stainless exhaust with Magnaflow resonator and muffler). Should be fun!
As far as consensus re: removing the belt to your power steering goes, I know a few guys that do this, but most of us leave it on because we daily drive our cars and taking it off would mean we have to work harder driving our cars around town,lol! There's one guy over at H-T.com with a '99 or '00 GSR and he's got the exact same set up as I do (except he uses a stock exhaust). He dyno'd his car and got ~160whp with the power steering connected and ~163 without it. So, there is a measurable improvement to be realized by taking it off, but it's such a small relative difference (~1.8%) it's hard to say what this would translate to on an autocross course.
Happy Turkey Day!
I know a guy with DCSports SS 4-1 header, Apexi (I think N1, 2.5") exhaust & AEM CAI on his '00 GSR. that put down 158whp & 119.6ft-lbs. This is on a '00 GSR with low miles, I think 10-12k mi. He doesn't auto-x, just visits sometimes and comes over & talks to me.
Now I know there are differences between '97 & '00. The exhaust & the intake manifold are different on the '00, even different than my '99, but differences should be very minor.
Since you have the free flow cat and most likely a better header and/or exhaust, I think 160 is very realistic. The only thing that might make a difference is mileage or the condition of the motor, valvetrain, etc.
Now the question that's been holding me back from getting a H&E, is that since I already have 152whp and 116.5ft-lbs with just the AEM, is another 6-7whp worth $1,000 + labor, for a good header & exhaust? Right now I can't bring my self to do it, unless my header or exhaust needed replacement. I have not seen anything that indicates that these 2 mods give the other person the upper hand in auto-x, because all of the Integras I go up against have them, and only the ones with coilovers & better suspension have managed to beat me. Even if they give the others a .1-.2sec advantage I seem to make it up on skill. So as it stands, I 'm not convinced or ready to spend over a grand on those, but what I have been thinking about lately, is a VAFC to lower the VTEC crossover. Now that should help me accelerate faster when exiting turns or on a low speed course where power early on and at lower RPMS counts a lot. Half the time or more, I 'm not in VTEC in 2nd gear or as soon as I hit VTEC I have to brake for a turn. It would be really nice to be able to get VTEC between 5-5.5K RPM. I can see my times easily dropping from such a mod. The downside of a VAFC is mucho tunning on the dyno and that means more $$. So that looks like it might be my next mod. I don't think it should kick me out of DSP. What does the book say CJ? I don't think it's a problem, come to think of it, I 've seen a CSP Civic Si with that mod.
'06 Civic LX coupe
'06 Civic LX coupe
As far as the VAFC kicking you out of DSP, I don't think it would. But my rulebook is at home and I'll have to double check on that for you. But basically, everything that's legal in ST is legal in SP, and the VAFC is legal in ST so that's why I think you'd be fine. Any way, if you'd like to move you VTEC x-over to 5-5.5K, you would be RAISING the x-over point, wouldn't you? I'm not sure if '97s are tuned differently than '00s, but right now I thought the GSR x-over is at about 4500 rpm. Now that I can hear it on my car, VTEC x-over happens at about 4600 rpm (as indicated by my tach) under WOT. Under 1/2 to 3/4 throttle, x-over is at about 5K. When I was driving home a few weeks ago from TN, I was able to play around with hearing the x-over on the freeway doing about 105mph by lifting or pressing the throttle to regulate the RPMs just above and below the x-over point (~4800-5000 rpm). That was pretty cool. So, please explain your thinking about having VTEC at 5-5.5.K. I'd like to hear what you know about that... Hope you had a good Thanksgiving.
Performance exhaust: $450
Listening to VTEC crossover on the freeway: PRICELESS
LOL...good stuff CJ. Sounds like I will keep my power steering on for the time being, thanks for the help guys. I am really curious what the SCCA handbook has to say concerning the future modification of my hatch. As much as I would like to modify my car to my liking, I don't want to get stuck in some "Outlaw" class just for one mod. Could you guys give me some insight on this matter? Like the organization of the classes, what mods most people have within the classes, and just the major distinctions between classes. Everything I've done has been bolt on, no crazy electronics, and haven't taken the head off for anything (hooray for SOHC power!). After I put the seats in and the Beaks reinforcement kit comes out for the ITR rear sway (of which I will then get), and then do the brakes (Brembos, AXXIS, and SS lines), I should be ready to roll. Of course, the other part of me says to autox first and then mod when I realize exactly what my car needs. Please tell me what you guys think and try your best at my "classes" question. Thanks.
