Do it yourself brakes..???!!!!!
I hear about guys who change or do their own brakes. Now, I know that is cheaper than going to your local dealer and having them do it. But dont you need to have your rotors resurfaced after any brake pad replacement? I currently need to get my pads replaced, but if all it requires is replacing the pads, then whats the deal? I can then take the car and have rotors resurfaced after I change the pads! Its only about thirty bucks for that.
for resurfacing rotors and drums when
doing a brake job, it's been my
experience that it really isn't necessary unless they've been damaged by metal to
metal contact caused not replacing worn
out shoes and pads in a timely fashion.
Minor surface imperfections can be
ignored. If glazing is present it can be
removed with emery cloth. Other details
are more important when doing a brake
job, such as properly lubricating guide
pins and other surfaces, checking wheel
cylinders and hoses for leakage and
taking proper corrective action, and
flushing out and replacing old brake
fluid every three years. Some
manufacturers have specific
recommendations for their cars, and these should be adhered to.
The front end of a car is usually more
sensitive to various problems than the
back, so if steering wheel shake or other oddness is experienced when braking,
double check the front brake, suspension, and steering components.
Jim
If a shop does the brake job, they will turn the rotors or replace them. The reason for that, is if there is a problem and they have to get reimbursed for warranty from the brake pad seller, if the rotors are not turned or replaced, then they are out the warranty.
If you do the work yourself, then not turning the rotors, forget that lifetime warranty on the brake pads.
Nope, nuh uh.
Samne system, the brake fluid runs thru the ABS controller, whether it is working or not. If a problem arises, the ABS controller defaults to a standard setup and you have no ABS braking.
When it is working properly, the controller controls the barake fluid to the brakes.
One thing when doing brakes on ABS controlled brakes, if you compress the caliper piston and push the fluid back up the system, you take a chance on damaging the ABS modulator. Contamination from the claipers can be pushed back up into the ABS system and damage it.
Didn't say it will, just that it can.
Something to think about.
What can i use old brake fluid for?
dave
I have a brake lathe at home, so I can do them, but use it mainly for pickup drums and flywheels.
The machine shops are trying to make ends meet, they charge for everything now. Waste disposal and all that.
You can buy great quality brake parts and tools at places like "a-1brakes.com" and the Eastwood Company. Also Wrenchead.com and CarParts.com have all kinds of stuff.
Brakes are pretty easy to do and can save you a ton of money. But it does pay to buy the best quality pads and shoes. A similar event happpened to me as what was described in post #15. I went to Bendix brake parts and was very happy.
Oh, before I forget, to "break the glaze" on drums and rotors, 3M sells all kinds of abrasive pads to do the job. Check them out a MMM.com and click on "automotive products" then "abrasives". Your best off using a good drill with an eccentric shank so the pad will grind in an orbital manner. Don't think of using your disc sander as it's too big and fast.
0patience, you have my envy and sympathy. Oregon is a beautiful state, but not inexpensive.
No problems with the abs system...in fact I never even noticed it. I never resurfaced the rear rotors, was'nt worth it in my opinion.
There is one thing I'm unclear about and that is bleeding the brake lines. I would like to replace the brake fluid..but I'm unsure about how and where to bleed the system.
Can anyone give some guidance on how to do this?
Rob
on the back of the brake assembly (crawl underneath and get an eye full of old dirt and grease), above the axle, there is a fitting that looks pretty much like a greasing zerk. It screws in. You attach a clean hose on the top of the fitting by pushing (use a clear one so you can see if you have bubbles, or if the brake fluid is anything but clear.) off-color fluid (rust red in any shade) should be fully flushed, there is water in there rusting your brake system. the free end has to be below the level of a jar with some clean, new brake fluid in the bottom, this to prevent screwing up and sucking air into the system.
you should clean up the area with some alcohol-type brake parts cleaner and dry it before getting the wrench out and backing the fluid fitting out just enough to break the usual rust and road crud. stop there. this fitting being tight or loose is the valve to open the fluid passage or shutting it down. if you break this fitting off, you are Stuck Outta Luck.. it's tow time and if they can't back the fitting out, you have to replace the whole brake frame for the wheel. if you have to use penetrating solvent to get it loose, do so... BUT... once there is ANY movement on moderate wrench pressure, STOP and clean all traces off with alcohol-type brake cleaner, dry the area, etc. any oils and brake fluid don't mix, it rots all the seals.
shade-tree style, having previously insured the car isn't going to move over you without a nuclear war breaking out, next step is to get a buddy who is smart enough to put the brake pedal to the floor when you command, and even more rare, let it up ONLY when you command that. if the pedal comes up before you shut the fluid drain fitting, you suck air into the system. then it doesn't work.
insure the fluid resivoir is full, and never let it get below halfway down, with clean, new brake fluid of the proper DOT rating. anything that was opened and resealed is full of water and will rust the system, pour it in the recycle bucket now. I had two quarts worth when I redid a car a few years ago standing by, and used almost all of it.
NOW you are ready. back the fitting off a bit, have your buddy BRAKE. back it off until fluid flows into the jar. when the flow basically stops, the pedal should be all the way down. turn the fitting clockwise to shut the "valve." have your buddy let up on the pedal slowly... if fluid moves back into the brake assembly from the hose and jug, crank the fitting tighter to prevent it.
repeat until fluid is clear (if you are flushing rusty old crud out of the system) or until there has been no expelled air bubbles for two additional pushes. OK, that's a little paranoid, but these are brakes... don't cheat. if nothing else works on a car, the brakes MUST work properly, or you are a weapon, not a driver.
move on to next wheel.
repeat until all wheels done.
I found I had to replenish the fluid in the resivoir every couple of pushes or so. if you have a third buddy lollygagging around, have them replenish fluid, close the cap, and announce when he is adding and when he has finished, so you don't run the master cylinder dry and suck air into everything, meaning you will have to start all bloody over and go for quite a while.
break out the refreshments when you have successfully test-driven down the alley to a firm pedal and not gone through the garage at the end of the alley.
... or have it done for you....
Attach a see through 3/8 clear hose on the bleeder screw and open it push the piston in fluid will expel out of the bleeder and through the clear hose into a jar or apparatus to catch the fluid, by the way apply a little anti-sieze to the brake bleeder for easier removal at a latter date close bleeder screw
Replace pads and lubricate contact areas and caliper pins back of pads with synthetic grease or anti-seize.
If one does not have ABS the same procedure with exception of clamping brake hose.
Bleeding the two front calipers may be a good idea at this time. I've always have had great success with a one man bleeder made by CAL-VAN tools have two of them they contain 2 ball bearings that act as a two way check valve with a spring, used for last 10yrs never had a problem always a great solid pedal.
Pepboys sells a one man bleeder yet has only one ball bearing, it was succesful too.
Unless someone showed me some hands on work that I can learn from watching.
Another thing you made me realize is...the lack of precaution I take when working underneath my car. God forbid an earthquake ever started underneath me (Never thought of that). I would of been a squashed duck for sure the couple of times I've worked underneath there with just a simple floor jack and no other support >:O
Thanks for the advice
spyder98
No. It is NOT an acceptable practice to clamp the brake hose with any tool.
It is a dangerous practice and can damage the brake hose, causing premature failure.
Clamping or crimping the brake hoses can cause the inner lining of the brake hose to seperate from the hose, collapsing it, cuaisng either no braking to the front or locking the front up.
On older hoses, this can cause quick failure of the area where the clamp was installed.
One acceptable procedure is to open the bleeder valve, attach a hose to a recovery pan or container, then compress the piston into the caliper slowly, allowing the fluid to go out of the caliper thru the bleeder and hose. with the hose full of fluid, no air should back into the caliper. Once the pads are replace, it is a good idea to bleed the system, regardless.
The preferred method of bleeding the system is with a pressure bleeder.
Putting on front pads is incredibly easy on most cars, a bit more involved on others. Get a factory manual (most accurate, but high dollar) or a chilton's (cheaper but very useful). These can show you, with photos/diagrams, how to do it.
Even w book, dismantle one side at a time, so you have a model of how to get the d*#% thing back together! Make sure you keep an eye on fluid level when pushing in piston for new pads.
Rear shoes (drum brakes) are a bit more tricky sometimes, but usually do-able if you have any mechanical aptitude whatsoever. Some models' drums/shoes call for special tools, although you can often improvise.
I've never had a car w rear discs, I assume they are similar to front.
I've never had any problem not turning rotors; only if brake pedal "pulses" or obviously if you see problems is it really necessary, in my experience.
I usually clean everything w brake parts spray, lube what manual says to lube, take care not to lube what manual says not to lube.
Save lots of $ doing it yourself.
After several instances over the years of ridiculous b.s., outright incompetence, and attempted rip-offs from various dealers/repair shops/garages, I do anything & everything myself that I possibly can, including brakes. An old cliche, but I've found it to be true: if you want it done right, do it yourself!
if you can tie it down and make it solid enough to bounce on and wrestle against, it ought to be safe to work on... but I think the line from the chilton manual is probably the best advice in the book...
if you're not sure about your abilities or the safety of the job, leave it to a professional.
now, if I'd just paid attention a few years ago and not tried to take off that water pump myself...
Wish I was smart enough to know that when tried fixing a sticky throttle cable on my old CRX. "Bad Idea"...I took a screwdriver head and began tinkering around the throttle body area. Sure enough...a minute later my check engine light turned on and never shut off again. Along with the annoying 1 second hesitation my car developed while applying throttle.
Not even a honda specialist knew how to fix the problem :-/
then there was the time when......oh nevermind
(I have replaced pads before!!!)
I need to change them. I dont think that it is worth paying $300 for replacing the front brakes is really worth when I know that I can do the same thing except for resurfacing the rotors.
No wonder there are so many rear end collisions....the warped rotors and hard [no stop] cheap pads, water contaiminated ages old black brake fluid which boils before the stop is complete.
Almost as scarey as a 6500# SUV behind you [30 feet] that takes at least 45 feet longer to stop than my car.
Please for my sake be careful when you do your own brakes.
Brakes are one thing I don't cheap out on. I do the labor myself and buy the best pads/rotors/hardware you can get.
Cheers,
TB
These are your BRAKES we are discussing!
I'm all for saving money BUT, if you don't know what you are doing or lack the necessary tools and equipment, leave this important job to a pro!
Also, as someone else said, changing your brake fluid is very important since the stuff absorbs water. It will turn to steam during a hard stop and you will have no brakes!
I've been working on "stuff" and fixing and tinkering bikes, motorcycles, small engines, boats, cars & trucks since I was a young kid; its hard to comprehend that there are a LOT of people out there (male and female) who are clueless and intimidated by even the simplest of tasks.
I'm no master mechanic, and although I'm a big fan of all the high-tech, gee-whiz gadgets & computers, I haven't a clue how to work on most of it. But a lot of the basic maint. stuff is still do-able. and surprisingly, quite simple.
Unless you have a trustworthy, competent, honest mechanic/technician (of which there are many, you just have to find one), IMO its a way more dangerous gamble to have the "discount brake & muffler" shop, with a kid with 3 weeks experience making $5 or 6/hour, work on your brakes or change oil, than to just carefully do it yourself.
Jim
And thanks, JEBER for the great support for we home-tuners! JULUS-- I hope you will strongly consider getting a book on that Lincoln. It really, really helps.
I had a toyota one a few years back that was real useful, I've never had a nissan manual........
(please don't kill the messenger)
I know it's a moot point, since non-power brakes are probably a thing of the past now even in the cheapest of cars, but I'm just wonderin'
Jim
