I live in the city of Pgh.Pa. Cold now...wasn't when I bought my Sonata. My question is...when they make a car in the summer do they put in freezeless washer fluid because my resevior is full but nothing comes out. worked fine in the warm weather.
By the way, have any of you reading this post ever had a persistant tailgater? Whenever that happens to me, I get an uncontrollable urge to wash my windshield. For some inexplicable reason, these pests invariably back off a car length or two (or roar around me waving their middle finger in an appreciative salutation...). In either case I've never understood why...
can someone shed some light. thanks.
In the first year of ownership, small round dents were noticed in the rear doors that were totally unexplainable. Other car doors should not have been responsible as the car is never parked in locations where it can be damaged. It appears the metal is very soft. In the last few months vertical creases have appeared in the front doors and we know nothing could have caused these because the car has been stored in the garage and not driven. One of the creases in the front doors has a crease on the opposite side door in an identical location. It appears to be an imperfection or some mounting inside of the doors that is pulling on the metal.
We are planning on taking a picture of the damage and taking it into the dealer repair center although they have told us they have never heard of this problem.
Has anyone else seen this happen on their Sonata and if so, what was the result?
I think you got it backwards on checking the ATF in park. Actually, Hyundai recommends checking the ATF level with the vehicle in "Neutral" NOT in "Park." This is per TSB 03-40-019.
Now to the new problem. After fill up at gas station...aprox 20min later I noticed a strong odor (almost like burnt coffee} no smoke just odor. Stopped at my sisters for an hour in which it disipated. Continued on to my destination...got there with no odor but noticed gas trickling in rain water from my car. Stayed there for 2 hrs. Came out from visit and gas stopped trickling. Faint odor(burnt coffee) emanating from wheelwell on gas tank side. Rain washed all traces of gas away. Do you think I might of lost a seal at some point? When I got home there was no indication of a leak.
As to the "burnt coffe" odor, it was probably raw gasoline that had puked up through the filler neck. Areas still allowing MTBE as the oxygenator to retard smog emissions "enjoy" a particularly oboxious odor from gasoline. MTBE was just banned 4 days ago after a year long delay in California, and many other states still using MTBE either have plans to do so or are at least considering it. Nasty stuff. MTBE, VERY soluable in water, affects the odor and taste of drinking water pumped from wells when run-off leeches into the water table, triggers severe asthma attacks in susceptible people, and the EPA has published studies linking MTBA with cancer. MTBE's replacement oxygenator is ethanol (grain alcohol).
I figure it was probably frozen so I thought I would try it in the parking garage at work. It is much warmer in there. This time it went all the way up but it was making the same awful sound as it did that morning.
I will try again when the temperature warms up above freezing but I believe it got broke from the cold weather. Hopefully this is a warrantee item. It should be.
I also had the problem with the door locks that would lock by themselves the last straw with that is when my baby got locked in the car and I had to call a locksmith to break into my car on a NY summer day the nxt day I took the car back to the dealership and made them keep the car until they found the problem they called three days later and said they could'nt find a problem but I never had the problem again and there was no charge........hmmmmmmmmm
I don't know whether this is related to your phantom door locking, but on two occasions the doors on my 2003 Sonata unexpectedly locked up, too. I believe I traced the problem to the way my keys and alarm fob were oriented in my trouser pocket. I -think- one of the keys was pressing against the "Lock" button and when I moved a certain way, there was enough additional pressure to activate it. (Maybe something similar could happen in a handbag, too?) I've been careful to orient the keys to the opposite side of the alarm fob in my pocket and haven't had a recurrence. But, I'm still waiting for the other shoe to drop...
I bought an extended auto warranty once in my life. It was my first and last time. There are so many fine point gotchas that they rarely justify their cost. (If I were you, though, I'd carefully read the exclusions fine print of your extended warranty to make certain you're not being snowed. There've been cases where unscrupulous dealers lie that a given repair isn't covered, charge the car owner, and then double-dip against the warranty provider, too!) I'd be willing to bet that what you paid for your extended warranty would've covered most if not all the replacement cost of parts and labor for all four window regulators.
The windshield wipers have come loose a couple of times which that either don't work or crash into one another and get bent up. This happened to me yesterday again..
Another problem is when I am driving down the highway, all the sudden the car will jerk like it has came out of overdrive.. It only does this for a second.. But it is doing it more often.. Anyone else having that experience? Transmission shifts weird at times too. I used to own an Impala LS.. I will probably buy another one of those after I'm done with this car. Although, I spent less than 18,000 out the door so I can't complain too much. Also, somehow mice built a nest in the blower and Hyundia would not cover it under the warranty which I thought was cheap on there part.. That cost me 90 dollars..
I have a 2003 Sonata and the air flow controls drive me nuts too.. I talked to service about. That is the way there are and there is nothing you can do about it. I guess we live with it.
Good Luck,
Scott
sheba6, my former '96 Accord had fresh/recirculation buttons for its HVAC system, too. Hyundai seems to copy Honda on a lot of details. They probably figure since Hondas are so popular worldwide, if they mimic Honda on the details, it won't hurt their sales. One thing that annoys me about my Sonata's implimentation of these buttons is that the happy-merry Hyundai product planners insisted on programming them to revert to fresh air mode anytime the engine is shut off. On the Honda Accord I had, whichever button was active prior to engine shutdown maintained its status upon restart. I like to drive with the HVAC operating in recirculation mode since it minimizes my exposure to other cars and trucks' exhaust fumes. (Even in the recirculation mode, ALL cars intentionally bring in some fresh air, so passing out from lack of oxygen isn't really a factor.) I'm constantly having to remember to hit the danged button to shift back to recirculation mode whenever I restart the engine. Not a deal buster, mind you, but it's annoying that some ding-dong product planner 10,000 miles away presumes to control even a minimally significant aspect of my preferences. I just wish I could return the favor...
My wife cut her finger simply by opening the passenger side door; at first I didn;t believe her but when I ran my finger gently along the driver side inner door handle, I could feel the sharpness and almost cut my finger too.
Has anyone else had similar problems?
you wrote:
"Another problem is when I am driving down the highway, all the sudden the car will jerk like it has came out of overdrive.. It only does this for a second.. But it is doing it more often.. Anyone else having that experience?"
I have a 2003 Sonata V6 with 22000 km on it and it has been jerking on the highway like you described. This has happened about 4 times now. The dealer says there is nothing they can do about it if they can't reproduce it. If other people are having the same problems I would think Hyundai would fix it and put a tech note out instead of ignoring it. Please let me know if you resolve the issue.
Dave
Flat highway, and the original factory ATF, at proper level.
I have lived in semi-rural areas for about 20 years and I have never had mice get into the blower on any of my cars in the past. Also, I drive about 50K a year so it is not like my car sits for days on end. So, in my opinion, Hyundia should not had charged me for what I consider "a design defect". Btw, you are absolutely correct about the Hyundia following Honda in the A/C department as my Girl Friends 2001 Civic does the same thing.
Airbrush, My car does this Jerky thing just like yours.. Flat on the highway. ATF at proper level. I will let you know if I get it resolved.. It seems to be happening more often too. Thanks for your response.
http://www.thestar.com/NASApp/cs/ContentServer?pagename=thestar/L- ayout/Article_Type1&c=Article&cid=1074772867328&call_- pageid=968867497088&col=969048871196
Also, just something I've been curious about, are the +/- on the shifter supposed to be back lit like the P,R,N,D..? Mine aren't.
If you have less than 36000 miles they will replace your door handles under the bumper to bumper warrantee. My pass. door handle was peeling and the dealer replaced both the pass. and driver door handles and said they have had quite a few cars with the same problem.
There's another, less ominous cause for apparent "missing". However it involves the automatic transmission (and is normal). Hyundai has a TSB out about this. What happens, particualrly in colder weather, is that at steady highway speeds over flat terrain, the transmission may cool sufficiently that the temperature drop triggers a release of the torque convertor lockup*. When this happens, there'll be a modest surge in engine RPMs (~200-300 RPM) and a slight, but noticeable lurch in momentum. Since the fluid is now churning through the torque convertor, it'll heat back up to normal operating temperature and torque convertor lockup will re-occur, again with a noticeable lurch but, now, a drop in the engine RPMs. The same thing can also happen in hilly terrain as the torque convertor will disengage when pulling hard or on flat terrain when you accelerate to pass slower traffic.
*For reasons known only to the Hyundai's automatic transmission gnomes, torque convertor lockup only occurs once the ATF is warmed to normal operating temperature. There's a thermostatic sensor mounted in the transmission that monitors fluid temperature and feeds the info to the shift control computer. (may be related to avoiding transition "shock" since ATF is at its most viscous state ("thickest") when cold)
Yep, the +/- sportshift designators ARE supposed to be lit just like the regular automatic shift designators are when the headlights or parking lights are on.
Anyone hear of this before? Solution? Advice?
Is there another web site I can check for this problem.
I'm due for a "check-up" at the dealership, and I'll keep you posted.
Anyway, I remember reading discussion of a 'LubeGuard' trans fluid additive that may be helpful in eliminating the 2-3 shift flare that I have been unable, in multiple attempts, to have the dealer fix.
My question to the board members here, WHICH Lubeguard product do I need to add to the New OEM Hyundai fluid, Lubeguard RED or BLACK or GREEN or SILVER? Also, do I need the Protectant or the Supplement? If anyone has the part#, that would also be helpful to me.
I have given up on Hyundai ever fixing the 2-3 shift flare, and would try just about anything to rid myself of this problem. (I'd bite off the head of a live snake, if I know that would work!)
Thanks in advance for all answers.
Now, how long have you had the 2-3 flare? If you check the Technical Service Bulletins at Hyundai WebTech (http://www.hmaservice.com/webtech/default.asp), there are entries about the problem you described. Have you brought the 2-3 shift flare issue to the attention of your dealer's service department? (PLEASE forget telling the sales staff. They're clueless and couldn't care less, anyway.) Have they checked your car for transmission diagnostic fault codes? Even driven the car? If not, for goodness sake try another dealer! Something's wrong - these transmissions don't do that when everything's operating right and adjusted correctly. They're characteristically velvety-smooth shifters except maybe the first couple of 2-3 shifts may be abrupt when very cold.
Finally, these "New Generation" Hyundai automatics are among the latest adaptive learning "fuzzy-logic" trannies - they tailor themselves to your driving style.* They can be retaught if necessary by disconnecting the ground cable from the battery for about ten minutes to clear the Transmission Control Module's memory. But don't do this until a dealer checks for fault codes. (Those would be wiped, too.)
*Perhaps problematic when multiple drivers are involved - especially if the alternate driver has a lead foot...
Actually had the problem early on and tried 3 different dealer service depts before I found one that would even 'try' to do something with it. Seems they can't find any codes at fault, but every time they reset something, it works fine for about the next 100-150 miles and then goes back to the same 2-3 shift slippage pattern. I really LOVE the car but it is a inconvenience to continue to leave it at the dealer over and over again. They must be getting tired of it also, because the 3rd dealer also mentioned that since I have over 30,000 on the orig fluid, that since they cant find any fault codes that the next time I bring it in for this problem, and no fault codes are found, that I 'could' be charged for their diagnostic time! So much for Americas Best Warranty.
I am the ONLY driver and am NOT a leadfoot. Over my lifetime, I have driven in excess of over 600,000 miles overall, and have never had to have a auto trans 'adapt' to my driving.
The trans fluid has about 37,000 on it and I figured that since it has the drainplug, it didn't look too hard of a job to do. I know it is a large size socket, but I do have one of that size, so I figured I would give it a try. I will try disconnecting the battery for awhile to 'reset' the computer and see if that improves the situation.
The wifes Ford has a slight "juddering" vibration, that you speak of, so perhaps I will try some of the Lubeguard Red 'snake oil' and see if that does anything for her cars problem.
Thanks again.
As to your wife's Ford, check the owner's manual. This may be one of the Fords that -require- "Mercon V". If so, it may be time for a drain and refill. Now for the good news: Ford is alone among current mandatory proprietary fluid fills that has licensed the "Mercon V" formula to any and all blenders who request it. You can actually purchase Pennzoil, Quaker State, Castrol, etc. authorized "Mercon V" ATF at auto parts stores and departments. Shoot, I've even seen Wal*Mart's own house brand (SuperTech) "Mercon V" fluid for less than $2.50/qt. SP III is a Mitsubishi license. Hyundai/Kia hold a sub-license from Mitsubishi and their respective SP III fluids are blended and bottled in the U.S. by Chevron. However, Chevron is contractually prohibited from distributing the stuff outside Hyundai or Kia dealer channels. My local Kia dealer prices SP III about 79 cents/qt less than my Hyundai dealer, by the way.
I do have the proper socket and 1/2 inch breaker bars. I have seen no visible filter cartridge outside of the usual oil filter, but of course I was looking underneath and not on TOP, so thanks for the heads-up on this.
One issue that concerns me is the gasket. I did ask the dealer for the gasket for the trans plug and they said it is the same one as the oil drainplug. The head of the plug for the trans is soooooo much larger than the oil drainplug. Might this be so it is NOT mistaken by the lube-jockeys as being the oil drain, and the threaded diameter is in fact the same as the oil drainplug??? (Hence uses the same gasket.)
Also, would the TRANS drainplug loosen in the same direction (counterclockwise) as the OIL drainplug, or is this a reverse thread?
As far as the wifes Ford, there is no drainplug in the Fords trans pan, so I would not even attempt to do that job as it would be too messy to drop the pan. Her car already has a small trans leak, so there would be room to add the Lubeguard without trying to drain anything off.
Pans without drain plugs can be dealt with by loosening all the fasters but NOT removing them. Loosen the one on the lowest corner (depending on your work area's slope, if any) to within 2 or three threads of removal, and the others progressively less. A couple of moderate whacks with a soft hammer at several points on the pan will break the seal and allow the pan to drop at an angle only as far as the attaching bolts will allow. Keep a hand on the underside and only allow it to ease down to avoid spillage. Of course you also want to have a drain pan under the low corner of the pan, but it should drain without undue mess. What little remains in the pan afterword won't present much of a problem when you fully remove the bolts and drop the pan away completely. If you want to replace the filter, now's the time. Ford has more variations than Hunts has beans. Your best bet is to write down the car's VIN number and buy the proper filter from the dealer that's right for your wife's car. Some look nearly identical, but won't seal or operate correctly. If the pan was originally sealed with a semi-liquid room temperature vulcanizing compound, clean all traces of the original sealant off the pan flange and the tranny pan mating surface. If a cork or rubbery gasket was used, make certain all remnants are cleaned off both surfaces. Make sure the pan is squeaky-clean inside, too. There will probably be several magnets stuck to the pan's interior, too. Clean 'em and replace 'em, but don't lose 'em. Use a non-hardening sealant like "Permatex 2A" to apply a bead around the circumfrance of the pan OR a NEW factory replacement gasket, BUT NOT BOTH! to reinstall the pan. Don't overtorque the bolts - they're going into aluminum. Unless the owner's manual specifically states the use of "Mercon V" ATF, verify through a Ford dealer what the proper ATF is for your wife's car - the official recommendation may have changed since the car was built.
Whatever "wealth of knowledge" I have, I learned from my dad while I was growing up. No formal training, but I read a lot, too.
For this reason I cannot purchase another Hyundai with an automatic. I understand that the standard transmission on the V6 Sonata is a 5 speed manual. Does anyone own a Sonata with this combination, or has anyone driven a V6 Sonata with the 5 speed?
Assuming that the 5 speed works well with the V6, I think it may be a real challenge trying to find a dealer with a 5 speed V6 Sonata.
