The crankshaft sensor monitors the relationship between valves and pistons in the engine to maintain the variable valve timing. It is also measures the engine's speed by calculating revolutions per minute. The crankshaft sensor is in effect a catcher in a baseball game, calling the game so the pitcher (the engine) can fire the appropriate function, or pitch,
Symptoms of Problems
When a crankshaft sensor has failed or is failing, certain timing problems will arise in engine function. The engine may start normally in some cases, but will cut off after a few minutes (or seconds) of operation. More than likely the engine will be unable to start at all. Since the crankshaft sensor is responsible for engine timing, the driver may experience engine backfire or irregular rpm function, if the vehicle starts at all.
Read more: Bad Crank Sensor Symptoms | eHow.com http://www.ehow.com/about_5860665_bad-crank-sensor-symptoms.html#ixzz0ywHTDgEL
http://www-odi.nhtsa.dot.gov/recalls/results.cfm?rcl_id=10V426000&searchtype=qui- - cksearch&summary=true&refurl=rss
I find it curious that they say it happened on the assembly line during a particular month, yet they are recalling all US-made Sonata made from Dec 2009 to Sept 2010.
Is there anything that other people consider really important right now? I actually have driven the car since January 2008 (it was new then), which should tell you how little i drive it. I also don't tend to drive during rush hour. What do you all think? Just to be safe in terms of my warranty, should anything be done?
Upon returning four days later just for grins tried it and magically it started. Stupid me I did not take my rental car to work the next morning I took the new car. Well late as it always is I went to depart work and bingo no start! :mad:
Called Hyundai 800 number (is this a new car?) and had car towed. Dealer Service Manager called and was great said it was most likely the brake interlock start switch and would have it ready next day. :sick:
I had to depart on another trip said no problem, no hurry see you after the weekend on Monday when I get back. Monday I picked the vehicle up and Dealer Service Manager said thank goodness I didn't pick up the car that next day because it wasn't the brake switch. They had to trouble shoot the system and it took the day. They checked battery, OK at 14.4 Vs, brake switch light switch, OK, and checked ground wires and found them OK. The issue for the no start problem was they found the 40AMP fuse for the ECM lose causing the failure. They removed the 40AMP fuse assembly for the ECM & adjusted the male pins on fuse and the car started right up. All systems checked fine and problem solved.
I have only drove the car twice since the problem was solved. It was to the airport and back. The other night returning from my trip I walked to the car looking good it did but was wary it would not start. It started! So far so good but only three weeks into the new ride.
Love the car but until I get a few more starts.... completed ...... I push that button with my eyes closed and fingers crossed. A month plus into it and so far so good.. :shades:
I have a 2006 Sonata V6 with 40,500 miles. Since a month ago, it gives a rattling noise from beneath the right-side doors. The noise does not start until the car running at normal speed (30-60 mph) for at least 15 minutes. It is a constant mild metallic noise that sounds like some nuts got loosened up and vibrating. The weird part is that it does not happen every time I drive. It only happens once or twice a week. I cannot reproduce the noise or predict when it comes out.
Can anyone point me in the right direction what it might be?
I don't think the noise is from the front wheel or rear wheel. The noise sounds like it's sometimes from right beneath the right-side front door, sometimes right beneath the right-side rear door. :confuse:
Thanks in advance.
Might also inspect the underside of the car to see if a part is loose, e.g. part of the exhaust system.
Personally I run regular oil until the engine warranty expires then go with synthetic and 50% longer change intervals.
I should note that this has been occuring ever since about 92,000 miles. So I have driven just fine up to this point.. but thought a little help from the pro's might be good since I dont know much about cars!
The only other rattle I can think of like this would be noisy valves, which are adjustable, but they usually "tick" rhythmically and the noise doesn't disappear in a few seconds.
Hey, I love that car and I have 87K now. I paid the $1300 to have this fixed out of my pocket (got same price from 2 dealers) and expect to have it for another 100K.
The have to pull the engine out of the car, it's a big job but they did it right I admit. I thought for sure they would forget a vac hose or something but smooth as silk. With your mileage, I would have them replace the spark plugs while the engine is out. Might be some cost savings for you.
1. What does the dealer charge for installing new spark plugs? I'm sure someone has had it done.
2. Has anyone had a non-Hyundai dealer do it? It's border line one of those things that I almost feel better about the dealer doing it as they've done 20 of them to every 1 an indy has done.
While driving the car yesterday, it just shut off. I saw & smelled some smoke come through the heating vents. Upon opening the hood, dead center directly in front of the bumper, there is a 3-4 in wide by 5-6 in deep round cylinder type part that looks like it connects to the exhaust was smoking. The car starts but has some type of rattling sound now. Just had the oil changed 10 days ago at Hyuandi dealership along with full service check, found no problems. Any ideas about what it could be and how much it may cost me to repair it?
We have a 2006 Kia Optima at around 68K miles. I am thinking of at least having a drain&refill for the transmission fluid.
Kia, like Hyundai specifies SPIII ATF. Is that a must? Redline claims its D4 ATF can be used where SPIII is required.
Has anyone had experiences with Redline D4 or any other ATF on the one hand and with SPIII on the other?
Should I just have a drain&refill done or should I get a flush?
This only takes about 25 to 30 minutes to complete. If you're more comfortable paying a mechanic to do this, they should not charge you more than $100. It's only about $30 for the fluid, plus 1/2 hr labor. There is no filter to change, only the transmission fluid.
Our Kia Optima is 2006 (earlier model, probably similar to 2004-2005 Sonata) with 4 sp auto transmission.
At first I wanted to buy Redline D4 and use it for drain/refill. On their website they say it is also compatible with SPIII. Not on the bottles though.
But Kia/Hyundai say only SPIII should be used. What is it that makes this ATF so special? Can it be because it includes extra additives to protect the transmission or its viscosity is different?
I do not want to take a risk by using D4, however if SPIII is just a repackaged general-use ATF I would rather use a better quality fluid.
What is the size of the drain plug? What tools do I need for the service?
I have another unrelated question about the car. Last few months it started being a little noisier than it was when we first got it. I use only synthetic oil like M1 5W-30 or Pennzoil Platinum 5W-30 with good quality filters. But I can hear clattering or clacking rather from under the hood when the window is down. Similar to a diesel.I hope I am not exagerating it.
Last fall the dealer had to replace the oxygen sensor because of check engine light. The light has not come on since then.
I have not had the timing belt replaced yet. Other accessory belt was a little squeaky during winter if that is relevant.
A 1" socket fits the drain bolt on my 2007 Sonata (5 speed AT). A 25mm might even fit a little better, although the 1" works fine without deforming the bolt head. Not sure if the older 4 speed AT has the same size drain bolt but I assume they would be the same size. I think a drain and fill on yours would be about 4 or 4.5 quarts.
About the noise, it can be caused by colder weather or by using a non OEM oil filter. Stick with the OEM filter. They are good quality. Also synthetic oils are usually thinner than conventional oils of the same weight, which can make an engine run noisier. Maybe try a High Mileage oil which are usually a little thicker. That might make it run a little quieter. I really wouldn't worry about the noise unless it becomes loud. Check your oil level every couple weeks to make sure the oil level stays near the full mark.
Do the prices look good? Also I need to do the 45,000 mile service and it would cost around 400.00. Is the price fine?
They had a special at $200 per axle, and they just sent me a coupon for $169 per axle (after I had already done it :sick: ). So to me $260 sounds high. $130 for flush sounds about right, but I wouldn't do it until you need to change the front pads too. Or you are feeling a lot of give in your brake pedal.
P.S. I'm surprised your fronts aren't worn out as well.
