I think there are 3 different speeds at which you can choose the locking speed (this is why the factory doesn't activate this feature). Dealers are supposed to activate this feature at your desired speed choice when they sell you the car. DO NOT pay the dealer anything, or feel that he did you a big favor, to do what he is supposed to do as part of selling the car.
Does anybody really want this feature activated, since the driver can control all Windows and doors? What if there is an emergency like falling in a lake/river, or trying to get out in an accident?
IMO Driver's controls are more than enough!
If Sen Kennedy should happen to be driving you , you should be able to open the doors from the inside even when they were automatically locked upon reaching the set speed.
The doors on my prior car automatically locked at 10 mph and could be opend from the inside. Some cars lock as soon as the car is put into gear.
I just got by Mail a "Sonata Quick Reference Guide" from Hyundai; and that is all it says! Period!
"Automatic Door Locking:
Your Hyundai is equipped with a feature that will automatically lock all the doors when driving above 25 mph. See your dealer to activate this feature."
It has nothing to do with Auto Manufaturers... It is the country's responsibility to prevent monopolistic practices.
Here in the US they used to require cars to be Serviced by dealers...but they outlawed that requirement; even though most people still take their cars there, to be stripped to the bones!
Hee-hee-hee - with my sardonic prose getting me in trouble with the mods, here, who else? Glad to see you stumbled into this site, Phil! (Miss the old days - remember those "light discussions" with ol' KIHO?)
I hope to get the brakes adjusted (or restore to its original condition), but I do not trust my dealer anymore. Could any one recommend high quality Hyundai Service around DC area? Thank you very much!
I only hope Hyundai has some high quality service center around.
Has anyone been experiencing unexpected readings from the OAT sensor? :confuse:
It seems on a least several occasions that the outside air temperature can be up to 10 degrees warmer than what is being reported at either airport at any time.
I drive very close to Midway Airport and yet I get readings that are almost always higher than reported on the radio, while near Midway.
I had snow fall on my car while the OAT sensor is reporting 40 degrees F. I also have installed an OAT sensor located just outside my apartment. Most times the car reports temperatures higher than reported by the OAT attached to the apartment. Sometimes 4 or 5 degrees higher, sometimes more.
I've got a 3000 mile oil change coming up in the next 500 miles and was thinking of having the OAT sensor tested for temperature reporting accuracy.
Is anybody else experiencing OAT sensor reading either higher or lower than what one might expect to see? :confuse:
drive, if you don't know what the temperature is?
I have an outside temperature gauge in my Honda CRV.
I have looked at it maybe three times in the year
I have owned the car.
Let us know if the service writer keeps a straight
face when you report this "problem". :-)
radio.
To answer your question, though, my readings are fine after about ten minutes of driving. It can be 10 degrees off one way or the other (usually warmer) when I first start the car.
Mention it when you go in. You paid for it so it should work.
Also as you said, "Mention it when you go in. You paid for it so it should work. " Sort of like automatic door locks, you paid for them, so they should work.
really need a thermometer to tell it's cold.
It seems I have been experiencing the same exact thing with my 06 Sonata LX. I hear a clicking sound similar to a water sprinkler. It happens under normal operating temperatures (engine). It is a very small noise, but my car only has 4000 miles. It comes and goes sporadically. It is not temperature because I'm in Texas at temperatures have ranged from the low 60s to the low 80s. I believe it started happening after my first oil change at 2700 miles because I did not hear anything before. At first I thought it was lifters too, but the oil was fine. I took it into the dealer to get looked at, and I'm still waiting for the diagnosis. Let me know what you find out.
I'd be interested to know if the reading is merely informational, or if it's an input to the auto temp control system.
And yes, I agree you should complain about it. Make them fix every little thing while your warranty is in effect. Brace yourself for all the things that are NOT covered.
I apologize for overlooking your reply to my message. Since I sent the posting I tried disconnecting the battery which was a response to another sonata owner with the same problem. My radio worked fine for about 2 weeks, then it started acting up again. I believe I will take your advice and let well enough alone until it stops working; then go from there. Thanks again for the response. Tom
I was able to do that a few years ago when I traded in a car 2 years before the extended warranty was up and got back a pro-rated refund.
All extended warranty contracts dont offer this option but it might be worth checking out. Good Luck!
I took it to the dealer and he checked the car out and stated that there was a small vapor leak caused by a loose gas cap. I still am not convinced that was all there was to it but the light is out for now and keeping my fingers crossed this does not become a nagging problem.
I glanced at the daily worksheet at the dealership and saw a high number of CEL warranty work being done on quite a few cars on that day alone.
Is anyone else out there having similar problems with their Sonatas? Thanks
