I'll post back when I get a resolution to this.
I will never buy another car with wheel covers.
Anyone else experiencing this problem?
I read reviews that this is a very quiet car but not to my experience. My wife's Camry drives much quiter on the same road. Is anyone else experiencing the same problem. Any solutions.
I have similar annoying vibrations with my 2003 Sonata when I have my foot on the brakes at a STOP sign or red light. The vibrations are so bad my whole body shakes. Can you give me any extra information about the missing compression ring so that I could try that solution.
Also did you get it fixed at the dealer, cause the ones here dont even want to try. They say that's the way the car is designed! Any help would be appreciated.
alore1
I am new to the forum and just posted the problems I am having with 2003 Sonata. Very similar vibrations when my foot is on the brakes and I am stopped at a red light, it reduces when I put it to neutral. The vibrations are so bad that my whole body starts to shake. The dealership have been no help at all.
Please advise me on what to do next. How did you go about the BBB. Has it been of any help? Has anyone thought of filing a class action law suit? If so, I would be glad to be on it.
alore
They dealership also said that they have seen a few cars now that exibited the same problem/correction as mine.
Just thought somebody might find this tidbit of data worth something. Cheers. 230 miles on new car now.
Usually rotors can be resurfaced once... which means when it is due for a new brake job it will need new rotors!
I hope you have it down in writing describing what they did... and that, they will replace your rotors at no cost when it is time!
About Rust on my Rotors. My Car has 350 miles, and a ton of rust on the rotors. Is this necessarily bad?. Doesn't look good, yet the Brakes seem great.
No the rust isn't a problem per se but it can make some noise upon braking. Yeah I'm not sure about the quality of the leather but I know just about all leather shows more wear and tear than cloth seats. So I wouldn't expect the Sonata leather to be worse or better than most cars. It's funny I have grey leather in my LX and I wanted tan. The grass is always greener!
Thanks in advance for your help.
Your Warranty and Service requirements start from the day of purchase. However there is no doubt in my mind, that I'm driving a brand new Car with old Oil!
And don't just assume you can get away with the 6 Month/7500 intervals. I have yet to live in any area of the United states that doesn't qualify for the 3 Month/3750 intervals. See the Book and your Dealer for details.
6 MONTHS from the Date you bought it - not Manufactured!
So you have until July 2006 or 7,500 miles whichever comes first!
If this is what is causing all our vibration problems, we will have to build a statue in your honor, or in the very least, name a holiday after you.
Hope you get your oil problem fixed - don't have any problems with that. If I hear something, I'll let you know.
THANKS, AGAIN!
Pat
Hopefully message #965 from kburke2 about the missing compression ring will be of help to all of us.
Good luck!
Pat
Pat
Rear suspension noise - a squeak, creak or rattle noise - occurs mostly over bumps or rough roads
Loose or bent rear shock absorbers
Damaged spring or spring mounts
Damaged or worn control arm bushings
Go to detailed test B.
See page SS-12.
If anyone has had this fixed by their dealer, please let me know.
Pat
What state do you live in? I am in Illinois. I have the same problem but was not so lucky with the service dealership as you were. My dealership did not do anything to my car. Just kept giving it back to me saying that is how the car is suppose to be. Mine did the same as yours, at first bought the vibration was less, mostly noticable in the steering wheel but grow worse over time. I have been unsuccessful in all of my attempts to get someone to fix it. Please let me know your progress, I will not give up until I get this car fixed.
Its a horrible substitute for the new car smell.
If the paint got chipped by a flying rock or something.
If the "spot" is caused by a flying rock: IT IS NOT COVERED... and it is pretty easy to tell!
It falls under Insurance : Collision.
The 7 year /100k rustproof warranty is good only if caused by the weather/elements/salt... but not collision!
I don't understand what you mean by your questions...
Determined? the cause of the spot? if yes- It is easy to tell ( a lot of tell tale signs); if it is an object that hit it or if it is a paint failure.
Can' claim what under any circumstances?
No idea what you mean!
I don't buy cars to often (replacing '92 Accord with 194,000 miles) so would like advice on what to look/look out for to determine which specific car to get?
When test-driving, I'm usually careful going around the block.
I would love to do an interstate drive, but no interstate near the dealer.
Any special maneuvers I should do?
S
Suggest you drive it over some bumps, dips, and test pavement Drive it on a road where you can get the speed to at least 55 and then try out the brakes. Make sure you don't feel any vibrations when you apply the brakes as some others have reported in this forum. Also make sure that the car tracks straight. If you feel any vibrations, hear any strange noises, smell anything burning, or the car pulls or drifts to one side or another. ask to try another LX. Check out the telescoping and tilt steering wheel to make sure you can get the wheel in a position that's right for you. Same thing with the power driver's seat adjustment and the manual lumbar support lever. Also try out the front and rear passenger seats to see if your passengers will be comfortable. Suggest you carefully examine the interior and exterior to make sure that your new car doesn't have any marks, dents, chips, scratches, etc. Check the wheel well to make sure you have a space saver tire. If you want the doors to lock automatically when you shift into drive or upon obtaining a certain speed, then have the dealer program this feature before you take delivery.
No, it falls under the comprehensive coverage.
It depends on what each stupid Insurance co decides and calls it!
If one hits a sidewalk curve they call it collision!
I used to think collision is only when you hit another vehicle!
They generally call it Comprehensive if: Stolen/fire/broken glass...
Who cares what they call it anyway...
The point was: Hyundai warranty does not cover PAINT DAMAGE due to chips!
Now it just runs very smooth, and much more comfortable than previous 17" - Off course a little less feeling with the road, but with my drivinghabits - i'm absolutely satisfied. (Just still have some jumping/wobble feeling at 60-80 km/h which is not tyre related)
Its not for shipping per se, but for protection against the elements after purchase.
Buy the 17's and try them.
If you find they are a bit noisy or ride a little rough, go to your dealer and ask to trade. If nothing else, he should put you in touch with another customer that wants the 17's. Should be easy, the 17's are more in demand, as many people favor appearance over ride.
No substitutions - No choice - No trade, I was told!
Not necessarily... it doesn't mean all the cars will have the same things wrong with all of them... If I remember correctly yours sat on the lot for months and that explain partially the bad rotors, and the door buzz has to do with wiring probably!
Your car was probably one of the first ones made... IMO, it is always prudent to wait a while before buying a new product, until they fix what needs fixing.
I think you posted before never get the first Production run... Let me tell you I saved big bucks and have the top Sonata with all available options, for about the same price as I was willing to spend on a base GLS. Of course I did see an LX today with a GPS and a $30,000 asking price, too much!
Yes that Door buzz does probably has to do with wiring. I bet most buzzes do. Hyundai could secure interior wires better, but I'm sure nothing has changed on the production line, aside from those 3 recalls. And the Dealer needed to order my replacement Door handles.I just would like to know why I need to replace them, no one knew? :confuse:
There's a small piece of metal that sticks out from the break pad, that, when the pad gets worn down, will touch the rotor, and make a squealing noise. (Sometimes that metal is inside the break pad and will make more of a grinding noise)
Most any mechanic should be able to look at them and tell you if that's the case.
Hope this helps.
- Jason
Justin
