Visitor Agreement.
Opatience- I take it you approve of Bat Auto Tech. Right? ;-) Just curious what you think of alldata? Thanks for your comments
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
Alldata, again, I am biased, but for a person's money, it is the best investment by far. Especially for TSB and tech info. Everything is updated continually, with info from the manufacturer.
I did find out that NHTSA will send info to folks, but the charge for the research time. Which could be as little as $1.00 or as much as $10.00 and postage.
Right now, Alldata is having a special on one year subscriptions for $19.95/year. Add other vehicles, for $14.95/year.
I use Alldata, a pro edition and the DIY subscription has the same info as my Pro edition.
One problem they have run into is that Honda has forced them to pull their info from the DIY subscriptions. Honda doesn't want the Do-It-Yourselfer to have the info to fix their cars.
I have noticed that Chiltons has come out with a repair manual CD and is talking about an on-line setup. We are going to be checking them out to see how well they compare. Chilton's track record for info hasn't been that great, so we'll see how they do.
Revka, you are absolutely correct about walking into the dealer blind. The more folks are educated on their vehicles, the better chance they stand of having their vehicle repaired without too much incident. I see too often where someone goe in for a problem and they are told this or that part needs replacing. They never ask why or even what the part is. Having no idea, they say yes. Then are thrown when the cost of the part is high. Not saying a person needs to know everything about their vehicle, but the basics wouldn't hurt. And as has been said, there are great resources, like Edmunds (LOL!), on the internet to learn.
Try this...if you can't get it into a gear, shut off the engine and see if it goes in easier. If it doesn, it probably is the clutch. If not, it could be a shifter adjustment or just a worn out gearbox.
I agree with Mr Shiftright, most likely, either there is a problem with the clutch master cylinder or slave cylinder or the clutch disk is bad.
Revka
Do you know if people can get more Honda Tsb info through the nhtsa?
Yes, Honda is required to provide Recall and TSB info to NHTSA. They'd like not to, but since they are a govt entity, Honda has little choice.
You mention that alldata updates frequently. Do you know how often that is?
AS near as I have been able to figure out, it is about a 2 week basis. It may be more frequent than that, but I have only been able to verify 2 week intervals from my checking on it.
One of the reasons I was asking about them was because they appear to be missing a TSB for my vehicle that I've seen in Edmunds' Maintenance Guide. I sent them an email about it, hoping to get more details, but haven't heard back as of yet. I hope to soon.
If they don't get back to you soon, let me know. Will need to know what info you need, year, make, model and when you sent them the e-mail. I'll either get you the info or make sure somone contacts you and I will find out a contact that can be posted. I give them enough grief as it is, a little more won't hurt. LOL!
If I can be of any more help, you know where to find me. LOL!
Revka
Hope to hear from you before Feb 22 via the Talk to the Press discussion or at jfallon@edmunds.com with your thoughts and contact information. Thanks for your participation.
Revka
Hatchbacks & Station Wagons Boards
Also, are yo sure you aren't hearing the brakes holding the car against a too fast idle speed?
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
How does the center diff attach to the T case and both driveshafts?
Whats the difference between a locking center diff and locking t case? Is one better than the other?
This is a crosspost from the "separating fact and fiction" board.
We have a 1995 Saturn SL-1. It had a security system that would disallow the car from starting unless you pressed a special button first. We always found this security system to be annoying.
We took the car in for regular maintenance to a new mechanic. As part of the work order, we requested that the security system be removed. We picked the car up from the mechanic on Friday and did not drive it again until Monday.
On Monday, my wife noticed the battery light was on. By Thursday, the car was dead. We arranged AAA to tow it back to the mechanic. Miles driven from Friday to Thursday: 87.
The mechanic examined it and has concluded that the alternator is shot. Their technician disavows any responsibility for the problem, although on my end it seems entirely too coincidental that a mere few days after they remove a security system that was tied into the electrical system of the car, the alternator is completely dead.
I could definitely use some help separating fact from fiction here. Is there anything we can do to prove that the mechanic was at fault? Or are we supposed to accept their explanation that it's just a coincidence?
If the alternator light wasn't on on Friday, I'd have to say the benefit of the doubt goess with the mechanic. Accidentally "frying" the alternator by mis-connecting wires is usually an instantaneous form of death so the charge light would have been on as you left the shop.
If your side of the story would be that you didn't notice the red light on on Friday, that's a bit weak for "proving" anything, so no go there.
I think you are out of luck.
Technical Questions
Also, if you get no response in a few days, then use the "browse by Vehicle" feature to the left of this page to find forums related to your specific vehicle.
thank you and good luck solving your problems!
MrShiftright
Allison
Disconnect the battery cables first, negative (black ground) then positive (hot red) and move them out of the way...disconnect the bracket holding in the battery and lift the battery out slowly and carefully...take it to the auto parts store to match it up with the one they sell you (it is such a time waster to buy the batt, bring it home, and find out the terminals are reversed or something else is wrong)...
Reverse procedure...clean battery cables with a wire brush (battery wire brushes can be bought at the auto parts store for under $5), install positive first then negative...drive away and repeat in 3-5 years...
Buy the batt with the most CCA (cold cranking amps) that you can afford...
Happy motoring...
You need to check your owner's manual as well. Some cars have codes for the radio that are lost if the battery is disconnected and some cars (like my Outback) sound their alarm when you hook up a battery. So it's good to know how to turn the alarm off before you hook up a battery.
It was only a few years ago, but I think Goodyear was selling bias-ply tires with guaranteed mileage of 12K...wasn't that about 2-3 years ago???...
my wife owned a small mitzu hatchback. i can't remember the model exactly. battery died when we left the lights on. decided we'd replace it since it was much more than 4 yrs old. following replacement, car idled rough. everytime going to a stop sign or light, engine would die. called a firestone mechanic and asked if i could bring it in. he asks over the phone "does it have fuel injection"? i say matter of fact it does. he says "it lost it's idle parameters when the battery was disconnected. start it in the parking lot, let it idle for 30 minutes and it will be fine".
sure enough, problem fixed. thank you mr. firestone mechanic!
flash forward to today...it appears to me that at least some vehicles like my honda accord and honda odyssey have something called an "idle learn" procedure which you evidently are supposed to perform when the battery is disconnected to install a radio or something.
therefore - i suggest you investigate further if the vehicle idles poorly, or cuts out at stop lights following the replacement. probably most vehicles re-learn parameters on their own to some extent, or do just fine with the power-up defaults from the factory - but there may be extra tweaks to improve upon the defaults.
I remember when cassette tapes came out, what a novelty they were. No more reel to reel. LOL!!
Most of the newer vehicles have security radios and if the battery is run dead or disconnected, you have to have the security code to enable the radio again.
I can tell you, it is a royal pain in the [you know what].
If you don't have the security code, then you will probably have to pull the radio out and get the numbers on the radio and go to the dealer to get the security codes, usually at a pretty nice price.
There were quite a few vehicles that had to have relearn procedures done on them to make them run right. This is why I always stress the need for a quality repair manual for the vehicle. There is only one I recommend. ; )
One other thing this subject brings up...............
There are many, many, many [see "bunches"] of problems that are corrected in PCM program updates [reflashing].
If you are having a "driveability" problem with your vehicle, ask the dealer if there is a updated reflash for the PCM. It can't hurt to ask them to look and see.
I have seen vehicles that have gone in for a problem and come to find out, there were 9 software updates for various problems.
That would be equivelant to not upgrading Internet Explorer 9 versions and wondering why it didn't work so well with some pages [driveablity issue].
now then, one (and there are a number) of the downsides to the reflash phenomenon is that the customer doesn't have a convenient means to know what rev his/her ECM or TCM happen to be nor what the issues are with a particular rev, and what gets fixed between revs. seems like they should provide a means via a USB interface or even 9-pin RS-232 to hook your car up to a general purpose computer (MAC or PC) and get all the revision information when you start the car for example, or take it from OFF to ACC, so at least you know how far behind in revisions you are. I'm aware of the OBD-II interfaces, but the protocol and interface is something an end consumer would have to pay at least $100 for. There should also be a web-site where the details of the revisions is provided. just my opinion.
"Ok, if I take my tranny in for a reflash, the optimal shift duration data will get changed and the tranny will take a while to adjust. If I disconnect the battery to cause the tranny to relearn, aggressive or mild driving will just affect the time it takes for the tranny to figure out the optimal shift duration, based on throttle and rpm stuff."
We were focusing on the tranny there, but does the PCM really adapt to the driver or does it take the driver's inputs and use those to reach a software ideal?
This was the link to the other thread if you have interest.
You've opened a lovely can of worms, Bob. :-)
Any more, they are trying to make it so that the average DIYer won't be able to do much with out a scanner, DVOM and good information.
Unfortunately, half of the people don't read their owner's manual until it is too late.
Used to be all you had to be concerned about was the presets on the radio.
Now, there is a different procedure for different vehicles.
Welcome to the world of computers. LOL!
Looks like you covered it pretty well.
Here is a scenario...............
Dad has a 2004 GMC Sierra, the truck's PCM has adapted to his driving style and he drives down the road and it shifts nice and smooth and at the points where he is used to.
Jr wants to borrow Dad's truck to go out on a date and in to town that night.
Dad tells him not to hot rod his trucks, but Jr thinks to himself, "Dad will never know."
Dad will know, because when Dad jumps in his truck the next morning, on the first shift, the transmission sends him back in his seat. Dad's wondering what happened to his truck, so he heads to the shop to have them take a look at it. The shop is 20 miles away, so when Dad gets there, it is shifting fine and the good ol' driveability that he is used to is back.
Now, why is this?
The newer vehicles are constantly monitoring and changing the driveability of the vehicle to "fit" [for lack of a better word] the operator.
On some of the newer GM vehicles, that adaptive time is about 10 minutes of drive time.
The computer will take an average of the parameters and modify them to the "best" [according to the program] parameters to allow for a smooth shift and performance.
The computer will even back the throttle off if the pedal is suddenly mashed to the floor and the computer sees no movement between the front and rear wheel sensors.
I think for the most part, it uses the driver's inputs to reach a software ideal.
It must remain with in the emissions parameters, so it will modify the conditions or habits of the driver with in reason.
Hope this helps, more than confuses.
Heavy trucks have that already. When you turn the key on, on newer HD trucks [kenworth and such] that have digital dashes, the revision number of the software is listed just below the odometer.
The problem with the reflashing is that it takes a $3000 scanner and a download [or disk] from the manufacturer, which they also charge for.
02 Honda Accord
You should have received a card that lists your audio system's code number and serial number. It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this Owner's Manual. If you should happen to lose the card, you must obtain the code number from your Honda dealer. To do this, you will need the system's serial number. [means removing the radio]
I'm lost on the 03 vanilla.
What is it?
I think somewhere this thread jumped from 101 to a 300 level course.
Sorry about that.
and thanks for the valuable information. i guess i should pull my respective owner's manuals and see if the battery replacement proceedure mentions anything about the idle learn proceedure. this is something i remember reading in the instructions downloaded from the H & A Accessories website when i contemplated installing keyless entry in the '03 LX.
i'm pretty cheap.
Good call buddy.
I forgot about that.
This is a memory saver.
It uses a 9V battery and prevents losing the memory of the radio and alarms, as Alcan said.
Odd coincidence...I bought my 2004 Crown Vic 8/1/04, with a manufacture date of 08/03, meaning it sat on the dealer's lot for a year...
I then bought my 2004 Ram 1500 in 11/26/04, with a manufacture date of 11/03, also sat on the lot for a year prior to my purchase...
Sitting on the lot, in the summer heat (GA and TN), I wonder if I will really get 3-4 years out of a stock battery...
When replaced, tho, be sure I will purchase a 5 year batt with sufficient CCA's to run Miami for a week...but I may not have a radio...
The dead battery was the OEM one, so it lasted ~7 years. It was an Anchorage car for the first 5 years of its life, but it still lasted almost 2 years in the Boise heat. Pretty amazing. I did six years in TN heat, and I don't miss the humidity.
