i saw this
24211355 for the part number, sound right? then trans fluid again too?
lastly, last time i used synthetic, what do you guys recomend? that stuff was $$$ and i don't know if its worth it
i love you!!!!!
(not really, but you get the point!)
also, so i alow enough time, how long do you think? what kind of $$?
thanks again
I've had that problem for some time on mine and it finally got so bad - power steering abruptly cutting out and back in again while driving - that I had to take it in. New Steering rack. It wasn't as bad as I thought ($$). The independent shop that did it charged me $900 for a new rack, power steering hose installed and alignment.
Good to know it's not as bad a job to get to as I had been told. Of course, I'm sure if I ever do have to replace it, the car shops will still try to tell me how horrible it is and milk me for all thay can.
I went to the local cadillac dealership, the parts are going to be $65, plus $32 for a new filter/gasket, then i need to pick up some fluid. all in all, probably $115 or so, no nearly as bad as i thought
question though, the parts screen said "valve kit for 1-2, 2-3 (also fits 3-4)" so it sounds like there giving me 2, when there's 3 in there. Im 99.99% sure, the bad one is the 3-4, because of what i said earlier where when i restarted it it would only go goofy when it tried to go into 4th. is there anyway to tell by looking at them? no idea what they even look like, parts comming tomorrow at 7am. or do i just have to guess and do the 2-3, 3-4? what do you guys recommend? (which ones did you do...)
any input would be helpful
Henri
now its always in 2nd, even when i restart it. only way to drive i speed up quickly to 60 or so then coast down to 40, and keep doing it! not fun...eating gas like a motha too.
good thing they get the part tomorrow
for upshifts, at 10%, 25%, 50% it does delay shifts across the board (as we know) for 100% throttle, upshifts stay the same with or without.
same for downshifts, no difference at all
not sure if anyone cares, but i thought id share
i only have a 3.5 - 4 hour window to do it by myself. can someone who's done it, give a little write up of what to do after i take off the pan? that way i know what im getting into, so it might go a little quicker. does stuff have to be removed fist? any tips on mistakes to avoid?
didn't wanna go in blind! got my service manual, but it doesn't help to much here
I'm suspecting the HVAC programmer, a control box located on the firewall under the glovebox behind the PCM module. Has anyone had a similar problem?
Does anyone have a Classic they are parting out?
mrdubya, we're pulling for you on changing out those tranny solenoids in your limited time window!
the solenoid is clearly broken, so i take all of it out, open up the casing that houses it (if you've done it you should know what im talking about. first thing that happens is 3 more little steel balls fall out. i know which half they came from, but staring and staring for a hour there seems to be NO possible place these could have come from. finally i give up, put it all together, fill with fluid etc etc. and start it
jerks into reverse, jerks into drive as i go through the gears. thinking maybe it has to adjust i go for a drive, still only second gear. (this is why i think maybe the computer has to be reset?) driving around a little it no longer jerks into reverse, but still drive.
anyone have some input?? merry christmas.....
and on top of it, its 15 past when im supposed to be at work, i call in and there pissed saying get a cab, blah blah then there like we will send someone to get you. im like, you don't get it, im covered in trans fluid got a huge mess and have to find some sort of alternate transportation for the future.
yeah, im a little upset
if reseting the computer doesn't help, then i won't try to fix it again, instead beg the parents for money to fix my car....:(
but does it take 8 hours to completly reset the computer? i obviously want to try this first.
I feel for you. Wish I could help with advice, but I haven't been there yet.
Everyone,
Within the next couple of weeks I plan to have the trans fluid and screens replaced; my '97 has 106,000 miles on it. The DIC shows transmission oil life at 100%. Has anyone seen anything less than 100%? I know there are differences of opinion as to whether or not to change fluid.
Since the cost of shift solenoids is not high, I'm thinking of replacing them as preventive maintenance at the same time the trans is opened to replace the screens.
Mike asked about using synthetic trans fluid; I haven't see any replies. I'm planning to use Mobil 1 synthetic unless I find a good reason not to.
well i guess i'll find out tomorrow if she's okay or not.
the part on my solenoid that failed was, its hard to explain but, its like a metal box with a plastic plunger sticking out, this goes into the valve assembly (or whatever it is, i don't know) the plastic part conncected to the metal "box" broke at its neck.
sense these are so comononly broken, why don't they have a metal core or somthing??? good question
i guess the way it works in 1st one of them is "on", in 2nd neither is on, in 3rd the other is on, and 4th both are on (by on, i think they push in on the valve stuff inside) so everytime you upshift/downshift they move, thats alot of action for a tiny little part
im not exactly sure how it all works, but taking it apart gives you a little understanding, not sure how else to explain it.
i kinda think somthing else broke to cause this to break, when i opened it up, there already was a tiny steel ball (not a broken metal piece, but a machined ball) and i don't really think those other 3 balls that fell out were supposed to be there, there was NOWHERE they could have came from
anyone who's cracked the thing open ever notice any ball bearings? i noticed 1 that was in a area that these couldn't have come out of, and that one only had a slit smaller than the ball so i could see it, most likely so it could stay lubed
Henri
not sure of a screen, it did come with a tube screen that went inbetween the solenoids that i replaced, but that in no way interferes or protects the solenoids. but it also came with a little bar, and a bolt. no idea what that was for, probably what your talking about though. i only replaced what i took off, so obviously it didn't harm anything not putting it on, but thats probably what its for
Greg
For a long time - several months, maybe a year - every now and then the steering would be hard to turn for an instant, but so occasionally that I didn't worry about it. Also had a slow but regular power steering leak, having to fill up the reservoir every couple of months.
In the last two months, the leak got about twice as fast, but the power steering started cutting out more often, especially when I'd just begin to turn it (parking lot or heading into that curve at 50MPH) and then cut back in abruptly after about 2 seconds. Almost like a switch was being turned on and off. After nearly leaving the road twice I decided it needed to be fixed.
The shop said that some internal seals in the rack were giving way under pressure. Also was leaking fluid from each end.
Rack replaced, problem solved.
let me know what the shop says, right now my cars warming up after being "reset", wishfull thinking, but maybe the gears will work.
if it doesn't work, i kinda got lucky, my step mom bought a 2004 cavileer, and they where just about to get rid of her old, 93 ssei which i may end up using for a little while
--Robert
Greg
D E A L E R S H I P
no the computer didn't work, i don't get it either, i put the solenoids in too, and i was so frustrated with the steel balls i gave up, i know i shouldn't have, but i did. btw, top half or bottom for the balls?
thanks henry, never thought of that!! no ____ (word censoring is so sensitve here!) i have a appointment on friday to bring it in. if i wasn't a broke college kid i would have brought it there to begin with. YES i know it will end up costing me more, but its a chance i took and lost, its not the end of the world.
let me know what happens gisom
A man gots to know his limitations. <---( Not directed at you )
Henri
thats the only reason i did it, its not way up there or anything
now there going to be calling me back, 12 hours! ha! not sure what to think, maybe it was a honest mistake, they havn't opened it up yet they want to make sure ill pay up before they do any work (understandable)
Greg
i hope it doesn't get to expensive! my poor baby
they were saying $340 to put the check va
lves in, new gaskets etc. they put it all together, no luck, they'll have it over the weekend i guess.
the sad thing is its a cadillac dealership! they've had 1 car transmission for like 10 years, except the catera. the transmission specialist should know how to fix it.
the ssei is junk, but that things got some torque. spins the tires on dry pavement like nothing. im not abusing it or anything, its most likely going to the junk yard after im done with it anyway. its got decent top end, not quit as much as the aurora, but the car doesn't rev very high, so it shifts to soon. but it gets squirly when you punch it from 10 or so. the torque steer sucks real bad. when the aurora takes off at that speed it doesn't have any torque steer, most likely because of the perfectly equal half shafts that the 4t60hd doesn't have.
Greg
Greg
tell more, if you can
ive got the L shaped bar still, i should stop by the dealer tommorrow since they havn't figured out whats going on?
