"The car has a bad oil cooler, which is located below the lower intake manifold.. It is leaking oil externally, and it is also allowing coolant to mix in with the engine oil.
The cost to replace the oil cooler will be approximately $900"
i also am curious as to if ne one is having there oil pressure drop below normal but not showing any other major problems i brought it in to get looked at and they said it was internal and that it would cost about 5000 dollars to get fixed but i had them wait so i picked it up and it was fine than and has been for bout 2months and now for the last to days it has been mildly doing it again, has any one else had similar problems or know what it is.
I'm speaking french from Quebec but I can write a little bit in english.
I can see that everyone have the same problem as far as I read on the forum. This is my story with my Cadillac Catera 98.
--- The begining ---
I bought my Catera at 98 000 KM. I dont how is the conversion from "km" to "miles". The second day I bought it, the pressure oil gage drop down and a noisy sound like a long "beeeeeeep" goes on. I go back to the dealer and he says " The pressure oil gage must be changed". The cost for this repair is 300$ CDN. The probleme is resolved after that. The third day after I purshase this car, the entire cluster light goes down, I lost all the dash light. Again, I go back to the dealer and he says " this is the light control command" tha one at the left of the steering. Yhe cost for this repair is 200$ CDN. After only two weeks, the car won't start after a one hour ride. I wait 2 hour and the car startup again. The dealer says " this is the crank sensor" 400$ the fix it. The problem is resolved.
--- THE HEADACHE BEGIN ---
After I repair all the problem I just said. I have no problem for 2 month ago. But after the two month "free" problem, the headache begin.... The horn goes down: 225$ to fix it (just the piece) I repair the part myself. The motor wipper cost 400$ to fix (dealer charge included). The oil cooler below the intake cost 1200$ CDN to fix it. Valve cooler 300$ CDN. Gasket kit because my car smell oil very bad cost 400$ + dealer charge. fog light problem cost 300$ each side because the water goes in. Beam light goes down for the same problem (water in). The heat seat driver down.
AND YOU KNOW WHAT ?????????
After 2 years The cluster dash light goes down for the second time !! The crank sensor goes down again !!!!
And the spark plus wire cost 600$ for all 6 cylinder !!
And lot of computer reset to stop the "engine light" cost 35$ each time is go on !!! Last month, the engine begin to overheat and is to much for me !!!!!!
HOOOO !! I forgot the LINK KIT is broken at 140 000 KM. It cost to me 2500$ CDN to repair.
I sell that car for 4500$ "as is".
If you can repair this car yourself is "OK" but if you have no skill in mechanic... sell that car as soon as you can !
You can reply this message, I will check each day and i can help you out !
Bye,
Etienne form canada, Quebec, Montreal.
My dad will try to fix it. Is this a difficult place to get in? How much would cost to get this oil cooler? Do I need a full kit or just a specific part?
Thanks. I will sell it after we fix.
mexdeb
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/67854-98-cat- era-crankshaft-position-sensor-replacement.html
Someone worte about car not starting and then after cutting it off it w/n start. My 2000 catera was doing that also. Found out it was the crank sensor i ordered the part at $50.00 and mechanic put it o for $125.00. ewww...got away cheap that time becaue my mechanic wanted $200.00 for the part alone.
Hope someone can use this information.
Always maintain the peace within you...
Sharron
I am experiencing the same problem as one of the other guys. My ABS, TCS lights come on simultaniously, & the speedometer goes dead. Do you have any idea what this can be? Also, my left & right turn signals don't work, they just make the relay give off a strange electrical noise. Any solutions will be appreciated!
Thanks have a great day.
RAB
My 2000 was doing the same thing. Would cut off suddenly and wouldnot start back up for 15/25 min. It was the crank sensor. If anyone want to speak with my mechanic who is very good with cateras please contact me @ svm0608@sbcglobal.net.
HOPE THIS HELPS
Crank Sensor you say, not the fuse. I mean this is completely dead it will do nothing, I drove yesterday for a good hour and nothing came on I was sick. What will cost about? Is your guy in northern NJ?
C
First of all Cateras are not that hard to work on. Many GM technicians have probles with it b/c they are used to GM this is not a GM it is basically an Opel which is German.
Let me tell you guys a few of the problems these cars have
Battery Draw---Check the rear defroster relay (they stick)
Oil Leaks---Valve Covers and Head Gaskets
Coolant Leaks---Water control valve, Head gasket, oil cooler cover
Problems with Oil Pressure----Pressure sensor or the actual guage(it can be replaced seperate of the whole cluster)
Coolant Light stays on---replace the jug it has a sensor (or sometimes you can beat on it and it will go out)
No start---crank sensor (only replaced on fuel pump in 6 years on a catera)
Rough Running---Pull spark plug boot check for leaking valve covers. Also the ignition coils would go bad on these.
Cant get vehicle out of park---Needs the Shifter assembly.
Have not seen a whole lot of transmission issues.
Noise from front of Engine----most likely timing belt related.
I have replaced a lot of A/C control panels.
I have replaced a few a/c door actuators for air not blowing out of proper position.
I have replaced quite a few brake light switches.
I have replaced few wheels speed sensors
I have replaced quite a few o2 sensors.
I have seen a few Air Injection faults.
As I said these cars are German with some GM infulence. Thing is Saab uses the same engine as the 3.0 catera and had not had half the problems the catera has. These car are not hard to fix, can be tricky to diagnose.
I have a 1998 Cadillac Catera. It stalled out on my way to work turning left monday. I took it into a shop they let me know my coolant was leaking and replaced my water control valve. It is still stalling out for me. When sitting for about 15-30 minutes I can start it up and it will run for a minimal amount of time then just stall. Does this sound like a crank sensor to you, or do you have any ideas? Thank you.
Caddywoes2
Caddywoes2
I did replace the coolant jug also was told they cant just get a new sensor and it was the sensor. I do have oil leaks and may have had battery draw that was a mystery . Could have been the rear defroster relay, Thats good to know, will watch for that. Thanks for your info.
or something.Eventually it starts.The other day coming off
the nj parkway it just stalled out loosing power and slowly
shuting down. The light that denotes transmition problem came on?Could this be a relay chip?
