Visitor Agreement.
Sounds like you are describing a heavily "coked" car--by cleaning out the carbon you have only cured the symptom, not the cause. If indeed that engine carbonized so much as to cause sticking rings or a leaking valve, then there's something wrong with that engine or its management systems. That was my point---not that carbonization doesn't happen but that when it does, it's because of a defect, not because it's something modern engines are 'subject to' as a rule.
These are normally on high mileage cars and the problem rarely comes back.
..they (marine engines) operate at a higher rpm range. Aren't most marine engines tuned for low end torque, and thus cruising rpm ranges are kept fairly low compared to automotive car engines?
The fuel today contains alcohol and no lubricant. How much alcohol, and what chemical type? Did fuel previously have lubricants that have since been reduced or removed?
Everything in the upper cylinder area is hot and dry. Then why doesn't it sieze due to this apparent lack of lubrication? Do the engineers not calculate the operating temperatures for all parts of the engine, including the combustion area to select the proper alloys to use? Sure, it may be hot, but it is designed to be, in order to combust the fuel properly. Should the fact that the engines continue to operate for years and years with the maintenace specified in the manual not be enough to conclude that the combustion chamber is not overly hot or dry?
It is a great place for carbon to form and stick. Why? There is great emphasis on achieving proper flame front propagation as well as ensuring a fairly uniform temperature so that there are not undue hot or cold spots that may decrease efficiency.
I would be interested in any information that would educate me in this regard.
"For every 100 hours of operation on a marine engine, that would be equivalent to 10,000 miles on a land based vehicle's engine."
And your point is? After all, even after 200,000 miles a modern automobile engine should have precious little (as in virtually non-existent) evidence of carbon deposits.
"Even with the new technology, (direct fuel injection), on two cycle outboards, carbon formation from the fuel, (not the oil), is a BIG maintenance problem."
I have a problem with that statement as well. Assuming a modern fuel injected engine is properly leaned (regardless of its stroke count), there will be virtually zero carbon deposits left behind from the fuel. My guess is that if there is carbon, it is from the burned oil, not the fuel. Then again, maybe 2-Stroke engines cannot be leaned past stoichiometric, I doubt that but since I have not studied the 2-Stroke leaning process I must consider it as a very distant possibility.
"You will see the results of operational problems faster on a marine engine, because they work harder and they operate at a higher RPM."
Hmmm, it seems to me that piston airplane engines work even harder pound for pound and cubic inch for cubic inch, and yet they accumulate virtually no carbon deposits after thousands of hours, regardless of the fuel type. All of this of course assumes that the operator of said engine leaned properly.
"The modern fuel today is causing engine damage through the formation of carbon in the upper cylinder area."
Sorry, not buying. Since the advent of properly controlled fuel injection systems, I have never heard of, read about or seen any evidence of upper cylinder carbon, except of course from you. Do you have any scientific research to back up what you are saying?
"The fuel today contains alcohol and no lubricant."
Are we to infer from that statement that you think that fuel used to contain lubricant? Preposterous! To the best of my knowledge, fuel has not contained any lubricative properties since at least the mid to late 1920s.
"Everything in the upper cylinder area is "hot and dry". It is a great place for carbon to form and stick."
Another highly suspect comment. It is supposed to be dry (forgetting for the moment the water vapor that is a by-product of combustion). The reason that carbon doesn't stick to everything is that there shouldn't be any left behind after combustion, once again, assuming a properly leaned engine.
Best Regards,
Shipo
Other than once with my last 1990 Taurus, which was experiencing a rough idle once it got in the upper 70K mile range, did I ever use any fuel additive, or need any, and this was an injector cleaner, not any decarburization stuff. The additive did seem to do it's job and then I went back to just using plain old gas from the lowest priced station I could find, like I have for all my driving life.
In 40 years of driving I have yet to experience a carboned up engine, in a climate that sees all kinds of weather. All this bolony about requiring upper engine lubricants and devices to eliminate carbon deposits is pure bunk with modern engines.
More likely, in my estimation, is if you add any kind of lubricant to gas, you would be more likely to have carbon buildup, as those lubricants can never burn as cleanly as straight lighter gasolene.
Additionally, the 10% ethanol used in many modern fuels actually would burn even cleaner than regular gas. Ever see ethanol burn? No smoke at all!(Smoke is unburned carbon particles by the way.)
Marine, (inboard and I/O), engines operate between 175 and 190 degrees. These are automobile and truck engines, that have been converted for marine use. Most cruise at about 3,200 RPM, which pushes the average 27' cruiser at about 20 mph. These engines still have the automotive cam in the block, which is why they have "valve overlap", and water intake problems, which is another issue. Lead was the lubricant in the old fuel formula. A land based vehicle at 2,000 rpm will do about 60 mph.
...Lead was the lubricant used in the old fuel formula..."
Ummm, sorry, you got it wrong again. A fact it is not, an "Old Wives Tail", yes, an "Urban Legend", yes. A fact? No. Lead is not now nor had it ever been a gasoline borne lubricant for internal combustion engines. This falls into the category of something that has been repeated so often that folks "think" that it's so.
Best Regards,
Shipo
Dude, you have consistently proven to be quite a source of entertainment for this topic (and apparently several others as well), and for that we all owe you a tip of our hats, however, as a source of information regarding intermittent combustion piston engines, you have proven to be a source of misinformation on an almost epic scale. Maybe that's your plan; to offer information that is so blatantly wrong that folks have no choice but to disregard it and then do their own research in an effort to get it right. If that's the case, then thanks, you've been a great help.
Regarding Tetraethyl Lead (TEL), it was discovered to be an effective Anti-Knock agent in automotive gasoline by a certain Mr. Thomas Midgely (the same guy who gave us Freon as a coolant) who worked for Charles Kettering, then the head of General Motors. This happened shortly after WWI, and by the early to mid 1920s TEL was well on its way to becoming a standard ingredient in both aviation and automotive grade gasolines.
The reason that TEL is so important is that it served to delay the organization of the flame front just a little, allowing the fuel to burn in a controlled manner instead of simply exploding. Think of it this way, conventional gasoline of the era went "BANG" when the spark plug sparked, and that was hard on pistons, valves and gaskets and everything connect to them. With the addition of TEL, the fuel went more like "WOOSH" when the spark plug sparked, and that was MUCH easier on the various internal engine components. It had NOTHING to do with lubrication of the valve seat/valve face interface.
To take it a step further, unless a remedial scavenger was added to the witches brew called gasoline, the lead simply hung around and made a general mess of the combustion chamber, the spark plugs, the exhaust system and the rings. The scavenging agents that were finally settled upon were bromide salts, which by the way are not only not a lubricating agent, they are actually abrasive, so much so that the aviation community has been trying to eliminate them from aviation grade gasoline for at least 60 years!
Please, for your own sake, take the advice you so smugly offered to vcheng and "Search the net on the subject!"
Kind soul that I am, I will actually give you a bit of a start.
For two references discussing why Mr. Midgely developed TEL application in the first place (please note, any mention of the lubricating qualities of lead is consciously absent from both dialogs):
http://www.1903to2003.gov/essay/Evolution_of_Technology/piston_en- - gines/Tech23.htm
http://www.uh.edu/engines/epi684.htm
The three following links regarding issues with leaded aviation fuels were published by the NACA (precursor to NASA) back in the 1940s, and once again, please note that striving to replace the lost lubricity of lead is noticeably absent from these dialogs. What is present however is documentation showing the effort to find an octane enhancer/anti-knock agent to replace TEL has been going on for at least 60 years.
http://naca.larc.nasa.gov/reports/1945/naca-wr-e-181/naca-wr-e-18- - 1.pdf
http://naca.larc.nasa.gov/reports/1946/naca-wr-e-183/naca-wr-e-18- - 3.pdf
http://naca.larc.nasa.gov/reports/1949/naca-rm-9d13/naca-rm-9d13.- - pdf
There are many scientific studies regarding the effects of lead on the burning properties of gasoline. Said studies are well documented and readily accessible, however, literally every reference that I have ever seen, heard or read that supports your claims have been simply anecdotal or hearsay. To the best of my knowledge, there has NEVER been any scientific evidence to support the "Lubricity Theory" as I am going to call it. In fact, if you have a reference to valid scientific evidence to support your Lubricity Theory, I would love to see it. If you can provide such, I will humbly retract everything I have written about you being misinformed and gladly eat a huge helping of crow. ;-)
I await your response.
Best Regards,
Shipo
Thatkeeps the reading lower than the effective water temperature in the jackets. I notice that this reading flucuates with the type of driving environment at the time.
http://www.epa.gov/seahome/leadenv/src/leadg.htm
http://www.asbcc.com/mboard/messages/495.html
Site 1) http://www.faqs.org/qa/qa-13239.html -- A message board/FAQ site that lets just any Tom, Dick or Sally offer their opinions. Yeah, I think that I'm going to believe a poster named "IDbuffalo" over the NACA.
Site 2) http://www.epa.gov/seahome/leadenv/src/leadg.htm -- Hmmm, from the EPA, that looked like it might have had a little promise. It even starts out looking good for your case as well with an opening sentence of, "Leaded gasoline was first used in the 1920's as a lubricant." Unfortunately it offers no reference to supporting science, and given the overwhelming evidence to the contrary, it becomes an irrelevant source of information. My guess is that the writer for the EPA just parroted the "Lubricity Theory" Old Wives Tail without even checking to see if it was true.
Site 3) http://www.asbcc.com/mboard/messages/495.html -- Yikes, another message board, and this one doesn't even work. Now there’s a resource that I can really sink my teeth into.
In the end, I'm afraid that you are going to have to try a little harder than this last effort to prove your point.
Best Regards,
Shipo
Most modern cars can run at 220-230 degrees with no problem I'm told.
Also keep in mind that car engine temperatures vary a lot more than boat engines. You don't find too many boats in bumper to bumper traffic, and usually ambient temps are cooler on the water. Last of all, you have heat exchangers on boats, which offer a constant supply of cool water.
shipo is the one who has his facts right. Time to back off I would think.
To be a lubricant for one metal against another a material doesn't have to be an oil. He said that the material left after burning is lead. And he said that additives put in every few tanks of fuel will serve to keep the valve lubed.
to all: Why not just let the topic drop. I've read enough rudeness for one day.
2.) Valve deposits are more fuel related, and much harder since today's engines are built to tighter tolerances, and the valves are exposed to less oil through the valve guides, and there is a lack of a lubricant in the modern fuel.
3.) Intake valve deposits affect the flow characteristics of the air / fuel mixture robbing the engine of power.
4.) Intake valve deposits also absorb fuel on "start-up", until they become saturated. As a result, these deposits can cause a lean condition during warm up. Short trips contribute to this type of deposit formation. Short trips also contribute to the formation of "sludge" in the crankcase!
5.) Here are a list of some operational symptoms which are caused by poor fuel distribution and / or by faulty fuel injectors:
a.) Hard Starting
b.) Poor Fuel Economy
c.) Rough Idle
d.) Engine runs fine when cold, and
terrible when warm
e.) Engine will start just fine when cold,
and not when warm
f.) Getting a fuel smell inside the vehicle
g.) Loss of power on acceleration
h.) Fuel leaking from injector seals or
the injector
6.) Fuel injectors should be kept clean, on an on-going basis, with a gasoline additive that is introduced into the tank at the time of "fill up"! To keep the engine running efficiently, the injectors should be replaced every 100,000 miles, as a regular maintenance item. They should be replaced because the internal parts start to weaken and malfunction, and as a result, the fuel injector will not open and close properly. Most fuel injectors can remain in operation for a long period of time, by cleaning them on an "on-going basis", but eventually, the constant movement of the internal parts causes the fuel injector to just wear out. (Remember, there is no lubrication in the fuel).
7.) Using a high quality fuel will always help to keep the injectors clean, which will make the injectors perform better and last longer overtime
8.) Fuel injectors suffer from deposits that can build up around the injector nozzle. Deposits can also build up inside the injector and reduce the amount of fuel being delivered.
9.) When the fuel delivery decreases, the injector pulse width will increase, creating additional heat in the injector.
10.) Classic symptoms of dirty injectors:
a.) Lean misfire
b.) Rough idle
c.) Hesitation
d.) Stumbling on light acceleration
e.) Loss of power
f.) Higher Hydrocarbons
g.) Higher Carbon Monoxide
11.) It doesn't take much of a restriction in an injector to "lean out" the fuel mixture. Only an 8 -to - 10% restriction in a single fuel injector can be enough to cause a misfire, (and related engine damage).
12.) The shape and orifice size of the nozzle determines:
a.) How much fuel flows through the injector
b.) The shape of the spray pattern. Injector deposits play a roll in the spray patterns over time.
If fuel deposits accumulate in the nozzle area, it can restrict fuel delivery, and break up the spray pattern causing a lean fuel condition, (and related engine damage).
13.) Deposits come from the fuel itself. The formation of these deposits is a normal consequence of engine operation. Detergents are added to the fuel by gasoline refiners to help keep the injectors clean. The build up of deposits can quickly outpace the cleaning efforts of the added fuel detergents, ---(if the vehicle is used primarily for short trip driving). Injector clogging also can be accelerated by the type of fuel used. (Not all fuels have the same quality of additive packages).
14.) On the other side of the fuel system, we have the electric fuel pump.
Pumps fail because:
a.) The pumps run constantly
b.) After many years of service, they can experience wear in the: ----armature, brushes, bushings, and commutator
c.) Pump vanes, rollers and gears can also wear causing a gradual loss of pressure and flow.
d.) Fuel pumps rely on fuel passing through it for lubrication and cooling. Remember, there is alcohol in the fuel, and no lubricant.
e.) Fuel starvation, (low fuel level in the tank), can be another factor that accelerates wear.
I disagree, it would be more like 4,000 miles.
Products such as "carbon guard" and "sea foam" are used in both 2 and 4 cycle engines to remove this carbon and keep it from forming on the pistons, valves and rings. Even with the new technology, (direct fuel injection), on two cycle outboards, carbon formation from the fuel, (not the oil), is a BIG maintenance problem.
I won't even address this one, as all the marine engines I work on will never see those additives.
Most of the gas marine engines I work on will never see more than 3,500 rpms. Far less than any automotive engine. Diesels rarely see above 2,500 rpms. So that comment is not accurate.
The same land based engine might take three times the mileage to develop the same problem.
Acutally, it is the other way around, unless you are refering to electrical, then marine sees more problems.
The modern fuel today is causing engine damage through the formation of carbon in the upper cylinder area. The fuel today contains alcohol and no lubricant.
Only in California. Not in every state and as far as the lubricant, only diesel fuel has that problem and even that is addressed by the manufacturers.
Rarely do any of the marine inboard engiens run above 180 degrees.
WRONG, not even close. The heads and most blocks are different, even though automotive heads will fit, the coolant passages on the marine engines are different.
Wrong again. First, there are no LH rotation automotive cams made, they are all marine. While automotive cams will work, there are specific marine cams made and used.
On a long flat stretch with OD. Put it on a hill and that changes.
Look at it realistically and those rpms go up.
Lead was the lubricant up until the mid 80s when leaded fuel was done away with.
And I've never used any kind of an additive either.
the only injector problems I've had have been on diesel cars (common problem) and very very old cars, where the injectors actually start to rust internally.
I dose my cars with a strong, mean and nasty fuel additive about once a year, that seems to do the trick.
If car engines suddenly gave all the trouble and required all the maintenance of marine engines, most owners would revolt. Marine conditions are much more severe, corrosive and laborious for the engine. Push a barrel through air and then through water and you'll see.
I did, however, walk out into our shop where two long term technicians were working. I asked them..." How often do we replace injectors on a Honda?"
One guy..." Never" The other tech..." Well...almost never but very rarely...I can't remember when I last changed any injectors".
I don't know, maybe other makes have a higher failure rate?
So, I guess maybe I haven't been so "lucky" after all!
I just wonder why you take such preventative care of your cars when you dump them before 100,000 miles? Hell, an abused Honda that rarely gets an oil change will go farther than that!
Whatever floats your boat
Best Regards,
Shipo
I also own a 44' fishing boat with twin Perkins 6 cylinders that turn about 2000 rpsm.
This boat is a work boat, not a pleasurecraft.
The last boat is a 20' Searay with a 351 windsor and a Mercruiser outdrive. I does run int the 3500 rpm range, but mainly because it was designed to go fast.
And yes, I have used Seafoam.
I live in an area where the toughest boats in the world are run (Pacific Ocean at the Columbia River) and used to work on my step dad's fishing vessels in the toughest waters in the world (Bristol Bay).
Believe what you want to believe. Doesn't hurt my feelings. But remember, before you make personal attacks, read the rules of this forum again.
Have fun.
[quote from EvergreenAmerica website]creates a permanent Crystal Lattice Structure on all metal surfaces - 85% the hardness of a diamond - virtually eliminating friction and wear in fluid systems. [end quote]
This is just like the additive manufacturers who claimed that Teflon in their product sticks to the cylinder lining. Not possible. Teflon requires a special primer to adhere to anything.
Anytime someone makes the comments, crystal, ballbearing or teflon in an additive, I wonder how much harm it is doing, instead of good.
Crystals are not smooth, are not a lubricant and have no lubricating properties, so I am not sure how that would prevent wear.
Then I looked up that patent on the USPTO web site, and Shock of all shocks, it's not assigned to the government, it's assigned to an individual. An individual who by the way happens to live in Argonne, IL. Hmmm, is it possible that it was developed by an employee of ANL, who used government labs to test his personal project? Could be.
I then checked the ANL web site and could find no reference to "Motor Silk" or "Boron CLS" or anything else even remotely connected with this stuff. Hmmm again. This stuff is starting to sound like Snake Oil. Gee, what a surprise.
Think about it this way. If this stuff was the REAL DEAL, and if I were marketing it, given the bad reputation in the market for additives in general, I would have a down loadable PDF of EVERY test plastered all over the splash page of my web site. Did they do that? Nope. They just followed the time honored tradition of other products of their ilk (Motor Honey, MMO, Royal Purple, etc...) of posting wonderful sounding claims, and even referenced (apparently) non existent tests (or presented them in a light that is essentially a lie).
In the end, unless someone can come up with a few scientific studies of the long term efficacy of Motor Silk, I hereby dub it "Snake Oil".
Best Regards,
Shipo
Best Regards,
Shipo
What more evidence does one need? Just send four easy payments of 29.99 and start contributing to our national security by reducing dependence on foreign oil, and help save the caribou in Alaska too!
I prefer to drop cans of Marvel Mystery Oil, and let them wonder what hit 'em :-D
MotorSilk... It sure took that itch away from me!
Well I'll be a darned, someone has finally come up with a good use for MMO. ;-)
Best Regards,
Shipo
just like the finest products, "As Seen On TV!" these here computer golliwog gizmos are kinda like TVs, aren't they?
next we can sell geniune Honduran "(prestigious watch brand here)"-like inspired products by email.................
that takes care of THAT, and I could use the $500 LOL
MotorSilk... put a tsunami in your tank! (tm)
I remember they sold a auto transmission sealer like none other. As a demonstration they had a wheel cylinder cup in a bottle of it. After a couple of hours, the seal would swell to twice it's normal size.
And they sold the BEST radiator sealer. It looked like honey with brass filings in it. It would stop the leak without fail. It also had a nasty tendency to plug up your heater core.
Someone mentioned they may still be in business?
