Fuel and Oil Additives
                    I didn't see a thread about fuel and oil additives (you know that huge shelf at the wal-mart with like 200 brands claiming to clean and stop leaks).  Anyhow, to introduce myself, I have a 1994 Chevrolet Z71 extended cab with the 5.7 liter engine.  I am experiencing some hesitation starting off in the 0 to 1000 RPM range and I was just wondering if anyone had any particular experience with some of the fuel injection cleaners like STP and the like.
Anyhow you are all welcome to post any pros and cons that you may have had with all those aftermarket additives.
Keep is rubber side down!!!
Swoosh Man
Swoosh Man
Is good quality gas enough?
The oil companies also say nothing more is needed.
Some of those same companies also sell gasoline additives.
Those pictures of cleaned up engines seem too good to be true.
FTC sued companies for oil additives not living up to representations.
Didn't sue any Gasoline Additive companies. Most made both oil and Gas Additives.
Fuel injection repairs are expensive.
Additives are cheap.
I personally use them. I also do a 3 stage fuel injector cleaner every 15,000 miles. I had a car that needed premium until I got the big treatment. Now it uses regular.
I like them.
I think most off the shelf additives are harmless and just duplicate (if that) additives already in your fuel.
A friend told me that this gasoline gets its high octane rating from nitro-methane. Is that true?
If a couple of gallons of this gasoline happen to get into my Chevy, will it clean the intake valves or will it damage the engine? It costs $3.50 a gallon. It sounds expensive, but it's alot less than $6.00 for a bottle of Techron concentrate, if it works.
What is a 3 stage fuel injector cleaner and how does it work?
Mr. Shifty,
Who sells the industrial grade additives? Which brand do you use?
1. A cleaner is put into the oil.
2. A large bottle is added to the fuel injection system through the vacuum hose while the engine is running.
3. Another bottle is placed in the gas tank.
Stage 2 is obviously some serious stuff. The workers use gloves safety glasses, and a fume mask when they put it in the bottle. As it runs into the vacuum hose it really stinks while it is cleaning out the carbon. I did 2 this year. One was bad and the bottle was almost gone before the carbon smell went away. The other smelled much better about half way through.
On the car that was bad, I had to use premium gas for a smooth ride, even though I get a tuneup yearly. After the treatment it has been running great on regular.
http://www.allstates.com/injector.html
I'll have to check the label...I buy it from my friend who runs a Porsche repair shop and he usually dumps it in for me because I don't even want to be near it (he doesn't either, but he's careful). But I had a bad injector acting up on my Benz diesel and it fixed the problem completely in about 25 miles.
Chevron Techron is good but over-use of this stuff can foul your engine oil. Chevron recommends this stuff be used a couple weeks before your next oil change just to be safe.
I've had great results with Redline SI-1. I gave a third of a bottle to my buddy whose throttle-body-injected 1981 VW Rabbit was getting a miserable 24mpg and in one tankful, he was back over 30mpg. Zoinks!
Just beware of all the glitzy junk out there. Putting mediocre cleaners or cheap alcohols in a flashy bottle and charging $5-10 seems to be a fad these days. Don't buy into it!
I also like to use a little isopropyl alcohol now and then to keep my fuel system moisture free. Just be sure to avoid anything with "methanol" in it. That stuff is so corrosive, it shouldn't even be on the shelves anymore!
--- Bror Jace
The higher the octane, the more resistant it is to early detonation. There is no more energy in higher octane gas. You won't get any more power from racing fuel than whatever your car manual says to use. In any event, always go with the lowest octane gas you can use that doesn't ping your engine.
The motor is making a soft whining noise, and I believe that someone who is good with motors can help me out; there are two small springs which I think I have replaced wrongly, inside two trough-like silver pieces that are on one side of the motor. The motor is whining slowly until I join the motor (plus supporting antennae) to the side supports, and it stops dead. I know that if I put back the small pieces of the motor back, I will avoid going to the dealer, this time for a $700 tab! Help, anyone?
To get to the discussion list page, click on the hot link "Maintenance and Repair" at the top of this page. Then look for the tab that says "Add Discussion"
Mr.Shiftright
Repair and Maintenance Message Board
Any ideas?
Is the time to start using fuel injector cleaners now when there are evidently no problems or do you wait until problems develop?
How often should you use fuel injector cleaners? Do these type of products have a "best used by" shelf life or are they good until the end of time?
I am looking at the concentrated fuel injector cleaner made by STP. It costs about five dollars per bottle normally, but I belong to a warehouse club and can get it in bulk (ie four bottles in a package) for about $2.50 a bottle.
i started using valvoline synpower in my '99 mazda protege at 10000km, but then later on switched to chevron complete fuel system cleaner (with techron concentrate) ...no particular reason for the switch, except that chevron is a more reputable brand and i know people who swear by it.
whichever brand u end up using, just make sure u use it a tank prior to your oil change, as these things have a tendency to dilute the motor oil and deplete its additives. i just rec'd an email from chevron, confirming this fact.
on the flip side, many auto manufacturers categorically state that fuel additives should NOT be used as they are not necessary (gasoline in north america contain additives to keep the fuel system clean).
moreover, if the fuel system cleaner contains methanol (i know PROLONG does), it could mess up your cars fuel system. so thats one thing you want to be careful about.
the reason i continue to use chevron is to insure against the odd bad tank of gas all of us get once in a while ...its much cheaper insurance compared to fuel injector repair bills.
I'm in favor of the mechanic's decarbonization procedure every 15,000 miles as well.
The fuel injector cleaner I am thinking about using is STP Super Concentrated Fuel Injector Cleaner. Normally it is about $5.00 a bottle. The Wholesale Club sells it in a four pack for less than $8.00.
Is this a good fuel injector cleaner? If I buy the four pack, will the last bottle still be good when I need to use it? I estimate that it might be about a year before I use the fourth bottle.
It amazes me sometimes how people who do absolutely nothing to their cars, don't even know if the oil level is okay but have 150,000 miles on them and are running fine. Wish I knew if I was wasting money or not?
Had an old Nova which was gunked up terribly by my mother in law and nursed it back to running good by putting a bit of Marvel Mystery Oil in at every fill up. Not sure whether the Marvel actually did any good or I was just knocking the cob-webs out. She only drove about 300 miles a year. About the time I got the engine cleaned out the transmission went on me, so what do I know?
I wonder if the worry is that there is something in Techron that is corrosive to some seals or metals that BMW uses in the fuel system. I sure hope not, as Chevron with Techron has been my gas of choice since 1998 in my 328i. So far, so good anyhow.
Might ask your service advisor exactly what the concern ins next time. I'd be curious to know..
The recommendation goes that the best way to use Techron is to add it to your fuel tank about 2 weeks before your next oil change. They are concerned that the Techron additive will leak past the rings and contaminate the crankcase oil. After two weeks of driving, they figure you will have completely gone through that tank of 'spiked' fuel, changed your oil to get rid of any possible contamination and you're all set.
So, what happens if this stuff gets into the motor oil?
Perhaps it attacks the anti-wear compounds in oil? Perhaps it breaks down the oil itself? I honestly have no idea.
--- Bror Jace
Anyway, I have used an additicve in every tankful of a few cars (Amsoil PI) and also Techron in several more and I have never seen any indication of a problem with my oil analysis. I never did it before changing the oil either.
Thanks for using our product. A small amount of the product can pass by the
rings of an engine, diluting the oil, however that will be of no serious
concern. It is little different from the fuel and blow-by products which
also can effect the oil, in the same manner.
Perhaps it would be possible to use Techron on the same cycle as your oil
changes. An oil change each 5,000 km and a bottle of Techron at the same
time.
> -----Original Message-----
> Sent: Sunday, August 19, 2001 8:51 PM
> To: lubetek@chevron.com
> Subject: Techron Fuel System and Motor Oil
> Importance: High
> Hi
> I regularly use Chevron Complete Fuel System Cleaner (with Techron
> Concentrate) every 5,000kms in my 1999 Mazda Protege LX.
> Since Chevron does not have a presence where I live (Toronto, Canada), I
> use your product to keep my fuel system clean
> I came across some discussions in a Bulletin Board which stated that Fuel
> system Cleaners should be used only prior to an oil change, since they
> have an adverse effect on the additives contained in Motor Oil. An article
> specifically stated that "Even Chevron recommends using the fuel system
> cleaner prior to an oil change, since they deplete the additives in motor
> oil".
> Is this true, since I use the Techron Fuel System Cleaner based on mileage
> accumulated, and totally independent of when I get my oil changed.
> Thanks very much for your help !
according to chevron, usage of the concentrated techron cleaner is an insurance for people who occassionally get that bad tank of gas once in a while.
IMO this mainly applies to people who:
a) do not regularly fillup with chevron, or
b) do a lot of long distance road trips, passing through areas where chevron does not have a presence (north of kentucky for example).
under normal circumstances the limited dosage of techron contained in their gasoline does not cause any harm to motor oil, but its just because the dosage of techron in their fuel system cleaner is 10 times more powerful, thats where this problem of oil additive dilution becomes an issue.
another good product i've heard a lot of about is Redline's Fuel System Cleaner (SI-1 / SI-2). BMW recommends it and even has a part number specifically for it in their parts catalogue.
this is the response i rec'd from Redline regarding the same question that I'd put forward to chevron.
>Some fuel system cleaners can only be used >occasionally and will
>build up damaging concentrations in the oil. This >>is not the case
>with the Red Line SI-1 or SI-2 Complete Fuel >System Cleaner, they can
>be used continuously and this is the most >effective use of the
>product.
>What is the recommended frequency of using Redline's Fuel System Cleaner?
>I would use it continuously, about 1.5 ounces to >10 gallons of fuel
>after the initial full bottle.
For the past year I have had intermittent rough running on my 88 Dodge Aires. Did a Tuneup, replaced spark plug wires, rotor, coil, alternator and belt, alternator tensioner pully, and at least 2 vacuum hoses. All in response to this rough running. It would skip driving even at constant speeds. It would also die when stopping, or starting again at lights. There were times when I floored the gas and it wouldn't accelerate very fast.
My Mazda mechanic recommended a true decarbonization. I took it in yesterday. They hooked it up on a machine that ran a special fluid that connected to the fuel line. It ran for over an hour and cost about $130.00. Nothing went into the tank or oil. When I drove the car I immediately noticed the increase in power. No missing so far.
Bottom line, Gas alone doesn't always keep the fuel injectors clean.
of late, i've been adding a bottle of chevron techron concentrate before each oil change.
i dont know whether its doing any good, but it hasnt done any harm either
Most of the rest of the OTC stuff is junk.
http://www.heffsauto.com/product/3mpromo.htm
http://www.thetoolwarehouse.net/shop/product2650.html
Maybe use some Chevron Techron, but the highly concentrated fuel-rail type 3m stuff undoubtedly works a heck of alot better for removing deposits from injectors and backs of intake valves
Yesterday I noticed that the coolant is now diiirty. When I bought the car a few weeks ago the liquid was clean and clear. Did they do something not right?
