link
Is it possible? Thanks.
Have a 2004 Odyssey with DVD Player, but have been unsuccessful (to-date) getting home-burned DVD's to play in it.
I've only tried DVD+RW's... has anyone had success with DVD-R, DVD+R, or DVD-RW discs?
Thanks in advance!
Does anyone have a system in their Sienna that has a in-dash DVD installed? I'd like to know where it was placed since there isn't a good location in the center dash area. I've been told to use the top glove box in from of the passenger seat. Would work but it would take most of the box with not much to spare for other items if any.
I've used DVD X-Copy (fast, but has compatibility problems) and DVD Shrink/DVD Decrypter (slower if you modify the quality settings, but less compatibility problems).
I haven't found a player yet that can't handle my Phillips DVD+R's (sliver color), that I've made using the DVD Shrink and DVD Decrypter software combo (both are free off the 'net and work together to rip and burn).
I strip off all the encoding stuff, so I think that helps (I make the discs region free, and strip off all the useless junk they put on commercial DVD's, like I add back in the ability to jump to the main menu without having to watch the previews and warning screens, etc). I use the copies on airplanes for my daughter so we don't lose or wreck the originals. We travel a lot.
I hope that helps.
-R
+R with bitsetting to DVD-ROM
doesn't play:
+R without bitsetting
+RW
don't know about -RW
We're getting a 9" Sony integrated overhead system installed in our Touring on Wednesday. I'll report after it's done.
The 7.8" screen fits into the factory overhead console with very little effort. I have the rear seat audio and no functionality was lost by installing this kit.
I opted to install the AD212 DVD in the top passenger glove box. the 3/4 DIN size DVD is fairly small and fits nicely into this area. Of course there was some cutting involved for the wiring.
I used a Sound Gate auxiliary input interface for the Sienna instead of using these FM modulators being sold with many systems. I didn't want to loose any more sound quality than I had to.
The factory JBL system works great with this player/screen combo and all of the functionality you find in the manual has worked with no issues.
I have only spent a few hours testing the basics of my install and have not found the limitations I had expected to find with an after market DVD system.
I do recommend checking this option if you're considering an aftermarket system.
I spent just at $1000 total for this package. Now I have a little left over for something else to add. Except it might go towards the home theater this time!
Dano
I hope this helps others who are looking for an aftermarket system.
1) is the player in-dash or somwehwere else?
2) can you control the audio thru car audio system? Is it thru FM modulator or is it wired?
3) Screen size?
4) Total cost of unit?
5) Cost of installation?
6) Model #s
7) Does it have a TV tuner with antenna? If so, how well does it work?
8) Does it decrease head space by much?
sorry for so many questions.
Got an EX-L yesterday without RES.
can you also email me answers directly to
joonkim@rocketmail.com
thanks so much.
That tends to defeat the purpose of a message forum - which is to share information and experience. Stick around and enjoy the ambience! :-)
The Touring addition has a moonroof, which complicates installation of overhead systems. The installer has originaly put it too far back and had to redo the installation. The final installation is good: the system's edge is right behind the rear edge of the moonroof opening.
Overall, we're very happy with this system. One big plus is that you can completely turn around the monitor to face the driver or front passenger. You'd want to do it when the movie is starting and you have to make selections from the menues.
Does the screen on yours vibrate and shake? Mine does.
Does your headliner seem to have a lot more 'give' to it, not quite sagging but it seems the system is not attached to anything - but the headliner.
Is all this correct?
I do not have the moonroof - so I assumed the install would go more smoothly, but for the moment, I am not a happy owner.
I am wondering if Sony under engineered this product.
I may have to go back to CC to see the Panasonic - and the Panasonic screen also turns.
But (as usual), now, if DVD player is on, AM radio does not work. That means no Mr. Tony on my local sports radio network. So....I guess I shall have to go back - AGAIN!
Are these things that tough to install?
1.) I heard that the Odysseys have a very limited area to mount these units. One miscalculation and you are screwing through the roof! How do you find the place to mount it? I do not have a moonroof. Just lights and vents.
2.)Are there any power/audio cables already routed from the factory that could be used?
3.)Best place/method on running audio/power cable to unit through headliner.
Thanks! Any comments/help appreciated!
2. i dont have an odyssey so dont know. Chk out www.pie.net for accessories. I bought a connector for my sienna which enables me to control the audio through the factory speakers. This is not FM modulation but if all else fails FM modulation might be a quick way to get audio.
3. it was run along the floor and brought up throught the B pillar to the roof.
We want to put in this same DVD system. I've heard it shakes quite a bit. Is this true for you? Does it play +/- R DVD's?
If anyone is from the Sacramento, CA area, please any advice would help. We would really like to find a good installer who can do a clean job.
I'd really like comments on Vizualogic quality, please.
We're thinking of their headrest replacement system for our new 05 Avalon. No1 has info on this car yet, closest we can come is an 05 Lexus rx330. I'm gonna have to find a Lexus dealer and see if they will let me try swapping an Avalon headrest for a Lexus for 30 seconds or so.
MikeS.
The service manager at Lexus had 1 of his guys pull the headrest out of an 05 RX330 and it plugged right into my 05 Avvy, the color even matched up perfectly.
I called my audio store had them order me one. Should be here in a couple days and then the kid will again have a DVD player to keep her amused. 3 yr olds get bored pretty quick
Why the heck are you put in that position to do this?
I have just purchased a 2005 Cad. STS, which has the DVD/NAV system in the dash. I can play DVD's from park, but cannot play them while driving. Has anyone figured out how to turn this "safety" feature off?
We just bought a new 2005 Dodge Caravn SE yesterday and are excited to buy and install a DVD system. After visiting Best Buy yesterday, we were told that we needed to first let the technicians see our vehicle to make sure they could install a system "because it is so new". Now, while looking at systems online, we are finding that some will not fit. We have the very base model, no sunroof, etc. Has anyone else encountered this problem? Can anyone make a recommendation? Thanks so much.
I used to use DVD Xcopy, but had a lot of compatibility problems. So that's why I searched for any found the above software solutions.
In fact if the kids are happy I'd say you're a *lot* safer driving peacefully.
-juice
My wife contacted Chrysler directly with the VIN, but they were no help. They referred us to the dealer.
Don't need the screen or headphones. I have everything except an idea and the hardware.
