DVD/Entertainment Systems
I would like to know if anyone figured out how can we play a DVD Movie 2000 Acura 3.5 RL?
Think, for navigation map, Acura uses DVD-ROM. Normal movies are also DVD-ROM. So, what is the difference between DVD-ROM movie that we can rent from Blockbuster and the DVD-ROM that has the Navigation map?
So, there must be a way, where we can figure out how to play movie DVD in place of navigation DVD?
Wouldn't this be awesome? I mean we'll have on board entertainment system for free?
NOw, I know some of you think who is in the hell is going to watch movie while driving? Right, no one in right mind should. IT IS A SAFETY HAZARD.
But, think of the advantages, think of taking your girlfriend or wife or domestic partner taking them to a ocean shore, top of the mountain, or somewhere where you can just part your Acura and watch movie?
I hope someone can figure this out and let me know, I am doing my best to try to figure it out.
So far, I looked at the format of NAVI DVD-ROM and it had different FOLDERS then normal Movie DVD-ROM.
I have DVD-writer at home, and if I just know what the writing method is then I can copy movies from regular MOVIE DVD's to BLANK one's so I can watch them on my vacaton trip or fishing trip or hiking trip.
P.S. Please respond your comments / questions to following e-mail:
Atlanta_Giglo@OneBox.com
I have a 2002 suburban z71. It has an in dash cd player/am/fm "head". In the floor console there is a cassette player. The cassette is controlable via the head unit (just switching to the appropriate source). In the rear there are headphone jacks for rear passenger audio control. The rear passengers can select any source and set their own volume independently.
OK, here is what I want to do. Replace the cassette with a DVD player. Add headrest style displays for rear passenger viewing. I want all the audio to be handled by the existing system. What I figure is that this will give me the simplest system with the most integration into existing controls.
Seems all I would need would be the displays for the rear (No speakers, tuners or any other fancyness) a DIN DVD player (Play, eject, fast forward, rewind, etc) and some wiring / expertise to hook it all up.
One possible problem could be the existing cassette looks smaller than DIN. Any suggestions?
TIA!!!
I just installed exactly what you're looking for. It WAS simple...just open up the checkbook.
In our 2001 Suburban we installed an Alpine TME-M750A monitor in each front headrest, a Panasonic in-dash DVD player (CX-DV700U) in the opening where the cassette player was installed, an Alpine VCR under the captain's chair behind the driver and an Alpine wireless headphone system. Audio from the DVD player is available either through the headphones or through the factory AM/FM head unit via an RF modulator (tune the radio to 88.7 and pick up the DVD audio).
Audio from the VCR is through headphones only since the installer didn't recommend running two audio sources into the RF modulator. The Alpine headphones and monitors can receive signals from two sources so one person can be watching/listening to DVD while the other watches/listens to the VCR. The driver can even listen to a CD or AM/FM through the factory system at the same time.
The Panasonic DVD player was mounted behind the cassette opening, rather than in it since we didn't want to do any cutting of the console. The cassette opening is big enough to allow access to the DVD slot and the eject button. There are no other controls or display on the front of the DVD player.
Total price was around $3,600, including tax and installation, with the Alpine monitors being the most expensive part of the system.
Only modification to the Suburban was cutting into the headrests to mount the monitors. The transmitter for the wireless headphones was mounted on the left side of the cabin near where the OnStar antenna is mounted.
We just returned from a 3,000 mile trip and boy did it make a difference in keeping everyone happy.
Let me know if you have any questions.
Bob
I like what you did with the DVD player mounting, seem like it is the way to go.
I was out at CES and I found a company that makes a plug in harness that will replace the proprietary connection from the old cassette to the head unit with one that could then be used to connect the DVD audio. They aren't shipping it yet but I have the contact info and will be following up soon. I still have questions about if it will work or not, I don't want to interfere with the OnStar either.
If you would, please post the name of the company you mentioned. I'm also interested in a direct connection to the GM head unit. While the FM modulator works OK, I'm sure a direct connection would sound better. Only problem I see is that I'd have to figure out how to switch two external units through the head unit (DVD and VCR).
Bob
I definately would recommend an in car dvd player for anyone taking trips with kids.
http://www.thewgalchannel.com/news/1609879/detail.html
odie
If you plan on adding a front dash type monitor then most have a safety switch that prevents the screen from being viewed ( the exception is when using a Navigation Unit). So you would need to install a by-pass swithch to allow viewing while driving (for the passanger side). There are also DVD changers that allow you to control the movies by way of a remote, while the changer is in the back/trunk.
If you can be a little more spacific on they locations and types of screens and format of player/s you plan to use I can be a little more detailed, instead of being so general.
Many stores carry portable units that you can take from vehicle to vehicle. Another Idea is the protable DVD players that are half the side of a Notebook. If you have an armrest just velcro it to it and it will stay there. Pull it off when done or parking (so you can hide it from prying eyes) and it takes a second to reinstall. Both of the latter can be had for under $500 if only one function is planned for it.
We considered and looked at a portable DVD player and thought about the velcro attachment, but, the volume is not that great on a portable player. Your reply is greatly appreciated. If you would prefer "talking" via email, contact me at: dmr01@earthlink.net . Thanks a lot!
One thing on the portables is that you can get the FM modulator to hook up to them to play the sound through the Cars stereo system.
The Bypass switch is very easy, but you will need to know the wiring of the vehicle. By using a switch usually a DPST which you hook up to the motorized screen and one of the parking brake wires (depending on vidio screen unit and parking brake wiring) With the indash screens, they have a safety circuit that prevents you from viewing while driving. They allow you to view only when the parking brake is engaged. With the switch (as in my setup) I first start the car, then I depress the brake pedal. With the brake pedal depressed I hit the switch (in my case I used a momentary push button switch, but some have used momentary toggle switches). I release the button and release the brake. The screen will function until I turn the motor off with the key. If I get stopped I turn the motor off. If the officer askes about the screen I can start the car and the screen will not work (in my case Navigation will always work but not movies or vidios) so I can tell the officer it is only for Navigation. The switch can be used say if you are driving down a road and you want to use it. Simply put the brakes on lightly (just enough to have the brake lights go on) and hit the switch the screen will be avalable. So you do not have to be stopped to turn it on. I can go in to more detail on the wireing once you have the screen.
Hope this helps.
I have been haveing a lot of email problems (companies quiting service without notice) so this site is better for me.
Plus we all get to learn.
Steve, this site is great for us all, and I was not trying to take anything away from anyone! Sorry if it appeared that way!
1. Panasonic $2100
2. Kenwood $2300 (has a touch screen)
3. Pioneer $1999
Not sure of the model numbers...do you need those? All 3 have the screen hidden and it ejects out when ready to view. Looking to ground it so we the children and passenger may watch while traveling. They can install it as quick as Monday, Nov. 18! Thanks again for your time!
Can you give more detail what you mean?
1. when installing, do not connect the wire to the emergency brake, just ground it to part of the frame/metal....or nut and bolt..
forgive me, i am not a mechanic--not sure if this is a ground wire--but, it is the wire that connects to the emergency brake (and i am assuming when the brake is engaged, then there is a ground)
2. if it is already installed, then, cut the wire to the emergency brake and ground it to part of the frame/metal--or nut and bolt
HOPE THIS HELPS! Am sure other readers could input and describe better than I!!
Odie
Now the 03 accord had the NAVI coming out, would it be possible to modify it and play DVD on it as well?
We bought a $99.99 product called "Suspension Theater" to hold the player in cars.
It has the following features:
1. Suspends the portable DVD player at the ideal viewing height and is easy to install.
2. Transforms easily into a carrying case with reinforced rubber handle and padded no-slip shoulder strap.
3. Installs in minutes and adapts to virtually any vehicle.
4. Requires no permanent installation.
Product available at BestBuy.com (not available in BestBuy retail stores) Click here for Suspension Theater
I recently bought our family's first SUV and am considering entertainment options for when our kids (now 2 and 5) get older. One of my main concerns (besides saving money) was the ability to just replace if the system dies in five years rather than paying a gazillion dollars to get the dealer to fix an integrated system.
While surfing, I found Vizualogic system where rear passengers' screens are on the backs of the front seat headrests and (if desired) the front passenger's is on the visor.
What seems to be really cool is that the view is more straightforward than in the roof (ceiling?) mounted systems.
My issue is, no one seems to have purchased this. It may be one of those "seems too good to be true" things. Or it may be a legitimately good system that could work for us (once we can pony up the money).
Does anyone have any experience with this company/system?
Does anyone have any experience with both (or a floor mounted console one)?
I was looking at post # 33 by ocuihs regarding the "Suspension Theater," and thought that might be a good alternative to a built in unit, but I am concerned about the limited sound of such units.
For those who use the portable units instead of a built-in, do you find the sound sufficient?
ocuihs - Do just use the portable units sound?
The last thing I WANT to hear from the portable DVD player is the sound from the 598th playing of "The Little Mermaid"
When my kid watches movies from the back seat it's ALWAYS with headphones on so I can have an actual conversation with my wife.
That works great for us. I wouldn't want a permanently installed DVD player. When we're in hotel rooms or planes, the portable machine lets her watch whatever kids movie she wants to watch.
Actually I suspect the next technology will be individual video on demand, just like they have in some new airplanes. I just flew on a LAN Chile flight in which the coach section had individual video on demand units in each of the seat backs. You could select any of a dozen movies off the touch screen, or select a whole range of video games. I assume that these systems run off a big hard drive in the plane rather than DVD. I bet we'll see the same thing in cars in a few years.
And thus, if I ran the sound through the car system, it would also be easier to adjust the volume, as opposed to reaching back and finding the control on a portable unit.
I also agree with you on the Hard Drive idea. We have one at home that we use to tape TV shows, etc... and it works great. Only problem is that it won't let us tape DVD's due to copy protection. But if we could dub a selection of shows to a hard drive, and then take it with us on the road for the kids.....wow, that would be cool.
The bigger problem is that they have no attention span at that age. So 5 minutes after you carefully get everything set up and playing, the headphones are all tangled up laying on the floor and she wants to do something else.
The portable DVD players have about the same sound as a laptop. It's fine but isn't going to be really loud or high quality. But for kids that young it doesn't really matter. If you have a relatively quiet car and have the windows rolled up it should be adequate.
I don't know how you would wire it through your car's speakers unless your car stereo system has a separate amp. The typical car stereo tuner doesn't have any spare jacks for a line-in, or any way to select to some other input device. Seems like it would be more trouble than it's worth.
I think your promotion of "your brother's RX customized" and "310 Motoring" looks like spamming the message boards. Please refrain.
Steve
http://www.salient-designs.com/
http://www.kvh.com/tracvision/a5/index.asp
"Troopers say he was watching a movie on a DVD player installed in his dashboard when the crash occurred."
I thought about it but wasn't sure if it would mess up the leather heated seats. Has anyone done this yet in their Tahoe? I am so glad I found this site for help.
