Volvo Maintenance and Repair
However, its overall reliability is well below the par. We have piled up $4K repairs bill after the warranty expired. The AC went first, oil leak, ABS modules followed, etc. The AC job costed us $1.4K alone. The engine check lights went on numerous times and it can be handled by the dealer only.
Recently, engine check light came on and was told it needs a job on emission systems ($500); and oil leakage from differential (according to the dealer)---another $500. The problems keep come on and on. It makes me wonder if it is worthy to keep footing the repair tap. The car has had 81,000 miles and I like to keep it for as long long it feasible ( it is in excellent condition and being kept in the garage). By reading the board message, the oil leakage my possible come from the return oil line from the Turbo. If the leak is from differntial, then transmissison fluid should present. Am I correct?
We have Lexus ES 330 and are happy with it. I only need another small sedan or SUV to replace it. The repairing bill is skyhight with Volvo Dealership; the equivalent AC joob will be around $700. Certainly, the quality of Volvo XC is far less than desirable. Any suggestion as to my dilema will be appreciated. I do enjoy the roominess and manuverability of this XC.
2. If I let the CEL on, the XC still functions all right. I wonder if it can past emission test! The dealer guessed it may be caused by a loose wire, leaky canister or a bad valve. The estimate is not cheap--$500.
Appreciated any suggestion!
Also, I replaced a headlight bulb for this car and it still doesn't work. I checked to see if the socket is live and it is not. I suspect a fuse somewhere, but the ones in the car are fine. Any ideas?
JohnG
Replacement depends on the driving and maintenance habits of the owner.
You obviously drive much lighter than I do.
I am concerned that this problem could be indicative of a more serious issue, for example a failing water pump.
Possibly the coolant level sensor is going bad, which I can financially deal with.
Any theories as to why the coolant level sensor would be behaving this way would be appreciated.
-Dave D.
I am concerned that the indicator could signal a worse problem, such as a failing water pump.
If the sensor is going bad I can deal with that $.
Theories appreciated.
-Dave D.
Has this affected quality in a positive or negative way? Will Volvo's go 200-300K miles?
$700 would be for the whole job. And that is a bit of a high estimate, to boot. That might be dealer price for the job with tax. But find an independent volvo mechanic and you'll save a bundle over the life of the car.
Personally, I would not buy the previous generation S40. I believe its more Mitsubishi than Volvo.
You can probably do a search on this board for "maintenance cost". I've commented on this topic many times. Short of it is, I find it no more expensive than any other car I have owned or currently own, UNLESS you always go to the dealer.
Yes, my Volvo has been the best car I've ever owned and I plan on running it into the ground. Its now at 106K miles and I plan on driving it for a long time to come.
I replaced the timing belt myself, so I'm not sure what a dealer would charge. I did find it to be a much easier job than on the Subaru we had, so it shouldn't be more expensive than most cars with a timing belt.
Ford has pretty much let Volvo be Volvo. I think they are benefiting in being able to share development costs on things like the new S40/Mazda3/Focus platform, but Volvo does still have a hand in it and, for now, everything else on the car (engine, tranny, interior, etc) is purely Volvo.
It's encouraging to hear that Ford is letting Volvo be Volvo; platform sharing doesn't bother me. I asked this because a lot of people have said that the Jag X-Type is really a glorified Ford Contour............Volvo is definitely on my list of possibilities if VW does a crash & burn in the US. I do notice , though, that Consumer Reports "recommends" the S60, but gives the S80 & XC90(I think that's the name...) SUV "Worse than Average." Reasons? I'm used to that, though, owning VW's.
I can probably sum it up my volvo ownership best by saying this: I've NEVER owned more than one vehicle from the same manufacturer .... but now that I own a Volvo, I would more than likely buy another one to replace my S70 when and if it finally dies. My only complaint is the depreciation that they face. But, like you, I would definitely NOT buy a new one, so its not as big of an issue as it could be.
Does anyone know what this means?
What happens is the circuit board develops cracks in it over time, so the circuit lines break contact at random intervals. As time goes on, the intervals will get closer together and the light will stay on longer until, eventually, its ALWAYS on.
check out this article:
http://www.volvospeed.com/Repair/abstrax.php
oh, and here is the gentleman who fixed mine:
http://home.earthlink.net/~vicrocha/
Also, my car is at 52K and I have not once changed the brake pads. I hope my car isn't damaged in anyway, but I'm checking a brake inspection this week. Would it be better to get the work done by the dealer or Midas??
The charger might not help for a couple of reasons. Is it a REAL charger? Or something like a float/trickle charger? In any case, it is possible that the battery has a dead or shorted cell, in which case nothing you do to it will fix it, so you'll need to replace with a new one.
My mechanic gave me a long history of the development of Volvo's recommendation. Bottom line, the original maintenance schedule (1976) called for changing ever 50K. When Volvo changed the engine type in 1992, the factory replaced belts after 20K at no charge, then recommended changes every 40K, pretty much because the newer four valve types would incur massive internal damage if the belt were to break or get out of sync. From 1994 to 1998, Volvo increased the interval to 70K (with no chagne in engine design), and after 1998 increased to 105K (with no change in design).
My guy thinks the lengthened intervals were a marketing response to reduce maintenance costs.
Anyone have any thoughts on this?
Well, admittedly, I haven't been searching for any such problems, but I have not come across a rash of broken timing belts, so I wouldn't think its a problem.
And I could be completely wrong about this, but doesn't the difference in intervals between the 98s and the 99+ (actually, there switch was made in mid '98, so there are some '98s that the 105k interval applies on) correlate with the switch from mechanical to hydraulic tensioners? And, along with that, the size of the timing belt is different, too. So I assume the change in interval is directly related to these differences.
I have no idea on those earlier years he speaks of.
No motor co is going to risk a rash of belt failures just to lower maintenance costs.
By all means look at the belt, if it is cracked or has a number of teeth missing, change it. Otherwise a 50k belt replacement is a waste of money.
I'm about to sell my 1996 850 GLT, but the ABS light is on. Is it worth paying the $130 to ship it to the person in So.CA to get it refurbished? Or do I take my chances and try to sell it like it is?
Also, I've been told that the AC condensor unit in my car needs to be replaced -- at $550, plus labor. Is there an alternative?
And, YES, I believe in making all repairs before selling a car. There is no way a potential buyer can trust what you are telling them is the truth. And I always think "well, if you know what's wrong and you know what it costs, why didn't you do it??" IF it were me buying the car, the ABS light wouldn't bother me because I know the deal, but that light is going to scare just about everyone else off the car. For the AC, I think most would deduct at least $1K from the price for what could possibly be a dead compressor, for all they know.
Spend the $130 on the ABS, definitely. Hopefully you can remove and replace yourself. For the AC, if it really is just the condenser (maybe a 2nd opinion is in order?), then buy the $179 part and the labor should be about another $180, in my opinion (2 hours), plus the coolant ... so $450 would be the TOTAL repair bill (which makes me think that $550 you were quoted includes everything). So you've spent less than $600 and you will EASILY see an extra $1K on the selling side after doing these repairs.
It has just jeasterday become more serios. Stopped any cranking (just the consol click-buzz of relays), and not till 3 am this morning would its start.
Got it home and since 9 been repeating the same issue (its now 2PM).
Gonna hit the starter motor now incase its the bendix.
About a month ago I came out of the supermarket, fired up the old mule and noticed the check engine light came on. Engine was running fine, so I went on my way. After about a quarter mile the light went out. This happens now everytime I start up the car. Doesn't matter wheter I turn it off and on with 5 seconds or 5 days in between. My mechanic is stumped. Before I drop the cash on a visit to the area Volvo expert can someone maybe give me some help?
John :confuse:
sounds like its slipping.
How many miles?
Ask them to service the transmission (flush and fill) and see what happens.
First ?: Can a good drive line shop replace this bearing?
2nd?: Since vibration started, tranny shifts with a 'BANG'. Is this caused by bad bearing?
I refuse to go to the dealer and pay $100 every time I want to change settings. I know where the appropriate screw is in the 850 platform but can not find any references to the current platform.
Thanks in advance.
