Volvo Maintenance and Repair
Please share any problems and solutions you've experienced with your Volvo!
KarenS
Owner's Clubs
KarenS
Owner's Clubs
/J
Best of luck1
/J
Scott
KarenS
Owner's Clubs
In 1997 European automakers started recommending 18,000-Miles + between oil change intervals and that was after over a decade of 9,000-Miles between oil change intervals.
European automakers must still have better engineered engine technology...or
HOW ABOUT THIS FROM: - Mr. Mike McMillan of General Motors "Extending Drain Intervals is an important issue for us. We definitely want to be the leader in Extended Drain Intervals."
I Think You Will Be Interested In This Mobil 1 Secret
Mr. Pryor of Mobil made the following statement about the benefits of it's introduction of Mobil 1 Tri-Synthetic Motor Oil (1996) in a Mobil Publication.
"It's a highly advanced low-phosphorus synthetic that works well with engine catalyst systems to further reduce emissions. It also provides greater protection against engine wear."
Then he goes on to say "In fact, this technology will play a big role in a global trend among engine manufacturers, especially in Europe (WHY NOT in US???$$$$$), to extend oil change intervals to 45,000 kilometers (27,900 miles) and beyond. He adds that new low viscosity versions, such as 0w-20 and 0w-30 are formulated to provide better fuel economy as well as greater engine protection."
As usual Mobil BEHIND THE TIMES and NOT Telling US consumers the whole TRUTH...
If you listen around, you'll hear experts cited in the oil industry - Have you never heard any of these? "Synthetics are too expensive. They'll never sell." "Synthetics are a fad." "Oil should be changed every three thousand miles, even if it's synthetic."
I suppose it does me little good to quote experts who think otherwise...
Recent tests at Mobil have even demonstrated synthetic motor oils with a three year ( 25,000 mile) life span.
HOWEVER since 1995 The Col's made in USA Advanced QUALITY-FIRST Formulated Extended Drain Interval Synthetic Motor Oil is Volvo Approved...
I don't know anything about this model car, but it would seem odd that there are 2 relays. I mean, what would be the point? What else would need power accept the pump? Unless the injectors have their own relay.
Pretty easy, though. Pull a spark plug and crank it. Is it getting fuel? (the fuel will come shooting out of the hole) If so, then fuel delivery is not your problem.
Maint foreman said he checked three other S80s and two of them had the increased travel and one did not. I asked how pedal travel coould change with installation of new pads and brake bleed and master cyl. replacement. They haven't a clue.
The brakes still work GREAT, but the pedal travels about 20% further to perform same functions as before the service. Anybody seen or heard of this "feature"?
This is a completely wild guess and I've never had the problem for more than a few seconds after changing brakes, but who knows. Usually have to "pump the brakes up" to get the pedal back.
Otherwise, yes it would be a good idea to check to see if you are getting spark.
thanks and best wishes for a happy and healthy 2002
I live in NY where the temp outside is in the teens and low 20's.
Any advice?
Over the last 2 years I have replaced headlights on both sides and both beams twice. Rear break lights and rear turn signals three times each.
The transmission issue I have read in other posting about freezing up and unable to move for about three to four minutes is common for me in cold weather(glad I live in Virginia where it really does not get very cold!).
An engine mount broke at 80,000 miles. I replaced the drive chain or belt at 100,000 miles. First time for the dealership.
My big concern is the amount of oil I am going through! I have used mobil one synthetic oil from day one and progressively have seen the amount of oil I am adding to top off after the long driving sales trips leap to about a quart of oil at every 1000 miles! I change my oil religiously at 5000 miles and carry a trunk full of filters because the shop that changes the oil had difficulty getting them.
Back to the oil usage issue. I make jack rabbit starts and hard stops. My driving involves mostly long cruises two to three hours at a time of 60 MPH without a stop. The only evidence I can detect of where the oil is going is the emissions I see at night in the rear view mirror reflected from the lights of the cars behind me. And this is only present when I floor the accelerator in moving one of my jack rabbit starts or getting around some one in a hurry, ie. from about 50 to 65 I'll really 'floor it' and when I peak at the rear view I can see the smoke trail I just left behind. No oil in the drive or leaks of any kind. No smoky emissions in the initial morning start ups.
At this rate I am going through a lot of oil to top off before beginning trips. Gas mileage is about the same as when I purchased the car about 24 miles per gallon. The oil issue is a real concern in my long term plans to make this a 'long term' keeper. Any one have any ideas of what is going on? the dealer told me some oil 'burning' is normal but he is concerned about the amount I have been using lately. He offers no solution.
Any ideas?
dabaer
I believe the standard schpeel is that your Volvo will go through a quart of oil per 1000 miles. I've heard this from a number of sources, although I'm skeptical about this. I've had that kind of consumption twice with my 854t, and generally go thru a quart every 2-3000 miles.
happy motoring,
javadoc
i guess the 100,ooo per quart is life with a volvo
dabaer
oh I am in sales and drive to DC from charlottesville, Va two to three times per week plus other destination sin the state of VA so I get a lot of 'butt time'
I also recall reading some where either here or on another Forum that there is a solution to a downhill overrun when in cruise. I have that condition, but the Volvo(Canada)dealer service rep.said that it was normal. Does any one have a definitive answer to these two items.
Paul
1. I can feel vibrations in the steering wheel and even in the throttle at speeds above 50mph - The dealer has always claimed that my wheels are out of balance and I have had these rebalanced thrice in 36000 miles at $40 a pop. The wheel balancing seems to mitigate the problem somewhat, but not entirely - which leads me to believe that there are other problems. I also find it hard to believe that anyone would design a car that is so sensitive to wheel balance. The dealer could any problems with the suspension. Any thoughts?
2. The wind noise is awful at speeds over 40mph. It seems to be roof related (may the rooof rack). Has anyone had this problem and if so has removing the roof rack solved it?
Wind noise: Most likely being generated by the roof rack cross members. A couple of solutions for this: a) remove the cross members if you don't need them; b) instal a Thule or Yakima fairing or mini splitters on the front cross member and the noise should basically be "gone with the wind." I use a Yakima fairing on the rack on my 850 (a Yakima rack) and removing the fairing generates alot of noise from the cross members.
Best of luck!
/javadoc
Scott
Our topic for Wednesday, March 13: Stump the Technicians!
Join us with your maintenance & repair questions this Wednesday from 5-7pm PT/8-10pm ET. Some of our contributors from the Maintenance & Repair board will be waiting to hear your problems, and making Herculean efforts to solve them.
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
It doesnt change in pitch as the car goes faster and stepping on the break doesnt make it go away. Its constant and always there.
Anyone have any ideas or have experienced similar problems.
Thanks for any help.
On the flip side, when it comes to getting experienced opinions and specific Volvo "help", perhaps posting your question at this *as well as* one of those other sites might get you a few more answers. Then, naturally, you can come back here and "share" what you find with all of us if you learn something. Good luck finding your answers...
A soon-to-be-owner of a Volvo S60...
My wife owns a 1996 960 sedan with about 105K miles. She recently had some extensive emissions work done on it by a shop that purports to work on nothing but Volvos. Less than a week later (and all of a sudden), the car began spewing gray exhaust in large quantities and running very roughly, i.e., like it was firing only on a couple of cylinders. She took it back to the same shop and now they're telling her that she has major fuel injection problems. I'm not very mechanically inclined at all, but this seems very coincidental to me. Does anyone know if working on the emissions system probably would have entailed messing with the fuel injection system? Does this situation strike anyone else as being suspicious? Any thoughts or suggestions would be greatly appreciated.
dcmoore
My first question is how long ago was it you got the CEL? If it was a temporary trigger and has since gone away, it may reset itself after 2 weeks or so. Other than that, I would suggest you search brickboard.com to see if you can find any answers.
/javadoc
BUT, good link nonetheless.
anyone have any information on this?
Not sure how comfortable you feel with a manual boost adjuster. I'm still not convinced to trust it on my daily driver, although plenty of people use them without problems. It just makes me nervous. If I was to go that route, I'd probably opt for a much more expensive electronic boost controller.
My suggestion is to first get a boost guage on your car so you can monitor the turbo pressure when doing these mods.
If you really want to have the car be fast, just go with an ipd ecu and a good quality 3" exhaust. ipd's is really expensive for any of their cars, so a good shop can bend you one (mandrel bends only) for about half the price. The ipd chip and a good exhaust should have you pushing close to that 300hp mark... reliably too.
Anything else you do will only wring a few ponies unless you spend some serious money.
/java
Hmmm... I don't even see an exhaust on ipd for your '01 T5 wagon. They just list an '01 wagon without mention of turbo.
Well, like java said, you can go to a quality shop and have them make one up for you.
Let us know how the modding goes for ya.
But another problem is that occasionally, the alarm will go off when my husband or I open the door with a key instead of the remote control. There doesn't seem to be any pattern that we can figure out. For example, today I opened the door on the passenger side with my key and the alarm went off within a second or two after that. I'm beginning to think that it only happens after the car "locks itself", but I can't verify yet.
So, does any know the secret formulas about when the alarm is supposed to go off? Thanks for any advice!
The Subaru dealer "certified" it? Does that come with an extended warranty? I would think not. In which case, its not really certified. A Volvo dealer puts a 7 yr/74K mile warranty on their certified cars. But, regardless, you're still getting a really good deal.
