Lost? Ask the M&R Host for directions!
BMW just did the "Drive to find a cure" (for breast cancer) event out here, I got to drive a 330 (and 325, and X5, and 540, and 530, and 740, and Z3) for 10 miles each. What a blast! Check out BMWUSA.com for when they'll be in your neighborhood.
It seems this website is quite different from the last time I was here. Previously, if I wanted to read reviews from the posters here, I would simply go to Nissan (for example) and then click on REVIEWS and it would take me to all of the postings for that specific car and model.
How do I access this page?
Heeeeeelp!!!
Did you access the Nissan(or whatever make/model) from the home page? Click on New or Used, choose the make, then model. At the top of the info page for that model, click on Reviews. At the top of the page under the title "Overview", click on "Consumer Ratings & Comments".
Hope this helps!
KarenS
Senior Host
Owner's Clubs
How could they perform any type of diagnostic test if the engine was "locked up". Where else can I go to get the engine replaced, if necessary? or do I want to have this current engine rebuilt?? It is a 5-speed, V-6, 2.5L. It has about 57000 miles on it, excellent maintenance history and no prior problems. Now what???
MMAKHER--this is a very odd story that doesn't make sense to me as presented. What it sounds like is either a) you stopped driving the car when it started making horrible noises and was ready to seize up or b) you just shut down a normally operating engine and it seized up by itself?
Possibly this is a mis-diagnosis, in that the starter motor has jammed in the flywheel, and this will keep the engine from turning and of course the starter from operating. I suggest you have the starter removed and then test for a seized engine. This is a proper diagnosis.
CONTOUR6--if you don't see this subject in the list of our discussion here, start a new discussion on the Villager intake studs and see if someone has had any luck tracking down some sort of "hidden warranty" on this.
Mr. Shiftright
no strange noises since and no problems. i am sure someone, somewhere else, has done this before...any advice? i am under warranty...should i take it into the service department on monday and admit what a retard i am?
You're probably fine. If it didn't break, you're lucky.
And who is giving you this kind of advice? Shifting a car into neutral is dangerous...it's tough on brakes and you have no power for maneuvers.
Consider that you got a shocking but not drastic lesson in not listening to well-meaning people who don't know too much about cars.
Gee, I wish you were Bay Area on west here I could hook you up.
If it's just straightforward work, a VW specialist would feel pretty comfortable with your car, except for the Quattro system perhaps.
Jon
http://www.attorneygeneral.gov/ppd/bcp/car/usedcar.cfm
I'll tell you one thing though Jon...if the car was repaired well, you may never be able to tell. Mostly its the bad jobs you can spot.
Also, you can pay a small fee to www.carfaxonline.com, and submit the VIN #, and they will tell you if the car was ever totalled (but they can't tell if it just had a fender bender).
First thing I look for is overspray...where paint appears on tires, rubber seals, door locks, etc. And a small magnet is a great tool for detecting plastic bondo...but keep in mind of course than many bumpers and rocker panels these days are not metal!
Any reccycling costs should be built into the cost of your doing business.
Theoretically, only those customers whose cars have committed some toxic waste spill are charged, but you know, I wonder.
Next thing we'll be seeing this on our Repair Orders:
Gas: $22.45
Water: $10.25
Electricity: $5.55
I'd scream my bloody head off about that if I were you.
For the life of me, I can't see this option. Where is it?
tneal--most door panels come off like this (but please check with Ford).
You first take off the armrest (two screws hidden in bottom). They you need to remove the door handle (often there is a hidden screw behind a plastic piece that you pry out, behind the handle), Then you pull the panel's little plastic snaps off (there are a number of them around the entire perimeter of the panel, and you gently pull on the panel until they "pop" out. The snaps remain attached tot he panel. Then you LIFT the panel toward the top of the door.
Then you will see a plastic sheet that you have to peel off, and you're in. When you are done, be SURE to tape the plastic sheet back on. Very important little item!
If you don't feel the topic was adequately addressed, feel free to create a new topic, or better yet, find an existing topic that is active. You're always more likely to get a response by posting in a more general topic... the more specific the title (year, make, model, problem), the less likely you will be to get an answer as it will appear to be only of interest to those who own or have own an 87 Chevy Nova. Alternatively, you can create a topic with a more general title.
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Sure, maybe buying at the same dealer you service at might get you a small favor now and then, but I don't think it has as much impact as how you and the dealer treat each other as people.
As for dealers taking cars out of inventory to send elsewhere--if you are trying to pry a very popular car with popular options out of another dealer, so that he'll send it to your dealer, this may not work. You could be getting stalled on either end, who knows? Some dealers play games.
Second, yesterday the blower in my HVAC system stopped working. I found the HVAC HI 30 amp fuse blown. I replaced it, and now have high blower speed ONLY. I checked the other HVAC related fuses and can't find one blown. All blower speeds went out at once. Any ideas? And do you think these two problems could be related?
I would greatly appreciate any help you could give. THANKS!!!
Mr Shiftright
Anyway, I don't see any reason why you can't read to the other side, no. Maybe even cut a mark there with a sharp edge of a file.
want to come on like I'm tring to sell amsoil
on these posts.My question is:Alot of users are
using the amsoil by-pass filter,on the newer cars
there is only one place to mount the filter,I
was thinking of starting a post to help people with similar cars compare and get info on where to
mount these filters ,amsoil does not provide this
info to my knowlege.what do you think?
So I would say this is not a good idea in Town Hall. Possibly other types of auto message boards that do not prohibit solicitation would be a good way to get the word out on your products.
Here's what I suggest. Go back to your topic and cut and paste your opening comments, and then click on the Roving Host's link to "BMW Problems" and then paste in your comments there.
That should get you all the responses you need and then we don't have two topics going on the same subject.
best,
MrShiftright
If you don't find what you're looking for there, type in Accord in the board search box on the left and you'll get a list of a bunch of topics on the Honda Accord.
kirstie_h
Roving Host
Edmunds.com
Review your vehicle
Any idea as to what I can do to repair the problem or should I take the car in to the shop ?
Thanks for your comments.
Cenzo 1
My question is this: is there a simple steering rod adjustment that can be done to return the steering wheel to its normal straight-ahead position? Or does (as my dealer told me) an alignment need to be performed? I tend to believe the former, since the mechanic did this once, but I want to be better informed, since I am no expert on rack-and-pinion steering system adjustments.
Thanks in advance.
BURRSR--you should be able to "center" the steering wheel on this car, yes, either under the car or up top. You might start a new topic called "Wheel Alignment" and then post your question there. In that way, you'll get your question answered hopefully and then others can also post alignment questions.
thanks,
Thanks for all you do!
