How do the 4 cyl MZ6 owners feel on this board? Also, any chance of a 5 spd A/T on the 2005 models (4 cyl)?
And overall, how does the 6i compare to the Accord 4 cyl for those who have driven both?
Rich would know more about the 5-speed automatic availability in the 6i next year. I believe he has posted that the 6s will be available with a 6-speed automatic for 05.
If you plan on doing a lot of mountain driving, or carrying a full load, you might want to think about getting a 6s, or the Accord V-6. Both are great cars.
I would rather order the cheap stereo (as long as it came with the steering wheel controls) and replace it with a good after-market system.
Does anyone agree? Suggestions?
As an extension of the question above on the Bose Stereo system in the 6, is it really that bad for the masses or only for people who know that the Sydney Opera House is Sydney?
ramon: I am no audiophile, so to me the Bose unit and stock units both sound fine. It may be a little more difficult to swap out the stereo unit in the MZ6 than it is in some other cars because of the way the console is constructed. I believe that discussion happened here about a year ago, so you may want to do a search and see if that information turns up.
These were the Appalachians and not the Rockies. The 6i MT is adequately powered for those mountains with that load. It never really pooped, I never felt compelled to drop it into 4th, although I did so once or twice, and in cruise control at 70-75 on W. VA interstates it never faltered. I suspect that with more luggage and four or five adults it might have pooped out more.
I wouldn't recommend the 6i automatic for mountain driving with heavy loads. The 6i MT can get more HP to the wheels than the auto. From 0-60 on the flat it's almost as fast as the 6s auto. So it depends on *which* 6i you're talking about, the weight of your load and the size of the mountains.
Whichever model you settle on, whether it's the 4 or 6, a manual would be better if you are willing to drive one.
The load was 2 adults weighing about 320 lbs plus 80 lbs. of luggage. The 2.3 MT was fine in the Appalachians with that load. With just a driver alone in the car you're super good for the eastern mountains.
Another thought: Mazda will be dropping the gears on the 4 MT if you wait for the '05 models. This should make the 2.3 feel more mountain-capable, although at the cost of 1 MPG.
The only test I've seen of the 6i MTX was in Car and Driver, and according to their numbers, the 6i MTX is a couple ticks quicker than any of the numbers I've seen for the 6s auto.
Like I've said before, the 6i MTX is just as quick as the last generation Accord and Camry V6 automatic models, and I don't think too many people were calling those cars underpowered or sluggish.
BTW, I don't regularly drive the car to the mountains, especially since we now have a Tahoe (yeah, one of these behemoths,
Right now, I have a Nissan Altima 2.5S rental car, and while impressed by the engine, I'm not too enthused by the rest of the car, and that's another story.
I don't plan on buying a 6 cyl because of gas consumption and price premium which I can't justify on a second car, although it'd be nice.
Finally, while I drove stick shift for years, I don't plan on going back to it as it's too much of a pain when you're stuck in traffic, which of course happens quite regularly out here.
I'll try out both cars when I'm ready, and will wait for the 2005 models anyhow.
6s Auto - 7.65
6i Manual - 8.15
I got these times from:
http://www.car-videos.com/performance/
So far, the only 0-60 time I've seen from a reputable source for the 6i MT is 7.9, but I've seen quite a few 0-60 times for the 6s auto and they are around 8.2 seconds.
The problem is that there may be no tests on both vehicles from the *same* reputable source.
That would ensure comparability and lead to a firm conclusion. It was *Car & Driver* that coaxed a 7.9 out of a 6i MT, but I don't think they've ever tested a 6s--either manual or auto. The general consensus is that a 6i MT can hold its own with a 6s AT--and I've even repeated the mantra a few posts up--but there is, after all, a difference of 60 HP between these engines. It's a little hard to believe that a 6s AT loses so much between the flywheel and the wheels that it has to struggle to beat a 160 HP vehicle, albeit with a manual. It may very well be true, but the data isn't completely solid.
Not that it matters to me, a 6i MT owner. Gas mileague is great. I use it as a daily driver, and the only thing I cared about was whether it could merge briskly onto a freeway. That it does. On an on-ramp you can scream up to 70MPH in third gear--or even 4th if you keep up the revs--right quick. I'm a flatlander, so performance in the mountains is not a concern for me, but I was pleased, as I said, with how well the 6iMT did in the eastern mountains with 2 adults and 80 or 90 lbs of luggage in the trunk.
You'll never be the quickest kid on the block with a 6i--or even a 6s for that matter. Mazda is not putting out HP/Torque monsters like Nissan these days. But the output is good enough, comparable, as you said, to the last generation of Camry and Accord V6s. And Mazdas, I might add. My last car, which my wife now drives around town, is a '99 626 ES with a 170 HP 2.5 liter V6 engine. It runs (best) on premium gas and is geared lower, so there's a different feel to the way it drives, but I don't feel that I've gone from a V6 HP/Torque monster to a 4 cylinder dog. Quite the reverse.
Car and Driver did test a 6s manual. They got 6.8 in it's first test. Then they got a long term car. That did 6.4 when they first got it and 6.9 after 40,000 miles. they think it may have dropped due to tire wear.
some guys on another Mazda 6 message board are getting around 7.5-7.6 on a stock 6s auto after really getting the hang of the manual feature. That's using a G-Tech Pro to measure those times.
I realize that. I was responding to your comment about the 6i MTX being almost as fast as a 6s auto. The numbers that we DO have don't show that to be true, but you're right, the numbers that we have aren't from the same source on the same day......so I don't think you can make the comment about the 6i MTX being almost as fast as the 6s auto....because there isn't a comparison test between the two.
"but there is, after all, a difference of 60 HP between these engines."
That difference narrows considerably when you hook both cars up to a dyno. The 6i MTX puts almost as much hp to the wheels as the 6s auto, but it's lighter.
Thanks in advance.
The long term 6s report is in the June 2004 issue of C&D.
fowler3
My question is this, what is the difference betweent the Grand Touring and the Sport model?
Do they both include the Sport Pkg or what? I am not particularly crazy about the Sport pkg.
I am starting school next month (Freshmen in College) and I will be able to afford another new car by the end of next year.
Thanks in advance for any information that you can provide.
Hybrid Vehicles Chat Room
Immediately following at 6-7pm PT/9-10pm ET, we keep the chat party going with the Mazda Mania chat.
Mazda Mania Chat Room
The Town Hall chats are a great place to take these message board topics LIVE. Hope to see you there this week!
PF Flyer
Does this car stays straight and stable in a windy day when driving on the freeway? Or does it "swing" and "dance" on a freeway during the windy day? Thanks A lot for answering my question.
Given the price of replacements I'm just curious as to how they are wearing.
http://www.autoweek.com/cat_content.mv?port_code=autoweek&cat- _code=carnews&loc_code=index&content_code=07383418
But, the new Maximas don't get anywhere near the same mileage we get with our older cars. I'm guessing increased horsepower plus more safety equipment that adds weight are mainly responsible.
I wish the Mazda V-6 put out the same kind of torque as the Maxima's but that aside it's not a bad powerplant. If your commute is primarily on the highway, your fuel mileage may not be as bad as you fear.
I've got a MZ6 wagon on order since May 12th, but my salesperson is telling me that its build date was delayed and it will now arrive as a 2005. Of course I was counting on the $1500 rebate, which it may not have. Is this plausible? Is it possible to confirm this? He wants to locate another car with "nearly the same options" instead, but I'm not sure I should give up on the order yet. He is less than forthcoming with exact details, so I could use some outside help. Thanks
Post the specifics of what your looking for...I will look in your area and see whats out there.
5MT
SAB/SAC
Moonroof
Bose
Sport Package
But, without leather
Blue and Silver were my color choices, but options were more important
My salesman says that there is one packaged this way coming in to Medina, OH, but when I checked the Mazda inventory search, it showed one with the options I wanted PLUS leather.
I need the car before our baby arrives at the first of September. Will the 2005s be on sale in August? Since the option we wanted most, the SAB/SAC, will be standard, I can save some money by passing on the moonroof and Bose which I can't do now.
"...a 276-hp, 265-lb-ft Mazda 6 scheduled for a mid-2005 world debut. "
I'm showing that my first 2005's will be built in Aug...to expect delivery in Aug, might be cutting it really close. Also, the incentives may not be so generous that early.
I wish I had better news for you.
Rich
Both are '04 Pebble Ash wagons with black cloth interiors. Options are BOSE, Sport Pkg, SAB/SAC pkg, and moonroof. Both are also MTX.
One is at Moon Township Mazda which is out by our airport (closer to Ohio) and the other one is north of the city at Baglier Mazda.
I found them on the Mazdausa.com inventory search which means they most likely are still there. However, there's a chance that they are either still on their way or even have already been sold.
Hope that helps!
