Mazda6 Sedan
15960626465342
  • dsm6dsm6 Member Posts: 813
    That doesn't surprise me. Ford can occasionally make a good product.
    Remember when the SHO switched from a 3.0L V6 to a 3.4L V8, gaining displacement, cylinder count, power, and torque, and ended up worse for it?
  • newcar31newcar31 Member Posts: 3,711
    Yeah, I remember when the SHO switched to the V8. I worked at the Ford dealer back then. The V8 sounded really, really cool. I think the main reason why it ended up worse is because it was in a heavier re-designed car and it was only available with an automatic.
  • coasterbobcoasterbob Member Posts: 32
    has anyone test driven the 6? I have just started researching it.....the brochure and some reviews sound great!
  • maltbmaltb Member Posts: 3,572
    Like they're talking about for the MS version.
    For North America it's not likely to see a MS edition of the 4cyl. In sticking with our gluttonous tastes a 6cyl MS6 is much more likely.
    Actually if you think the 4 cyl is fine on the Pro, the 6 with the 4 cyl actually has a better power to weight ratio than the Pro has. The weight difference is only about 350 lbs, of course the 6 cyl 6 adds two hundred pounds to that difference, so it needs some extra power.
    Speedometers are much more accurate than 10%, closer to 2 to 3%. They are generally calibrated high so they consistantly read faster than you are going.
    Let me put it another way: The power to weight ratio is fine on the Protege, considering that it is a $15K or less automobile. The 4cyl Mazda6 may have a better power-to-weight ratio than the Protege ES, but the 6 cyl Mazda6 is better than both of em---obviously. After riding in the 6 cyl version, I'll gladly trade a little bit of handling balance for some silky smooth V6 power. This V6 really sings....
  • bluong1bluong1 Member Posts: 1,927
    fine. but power doesn't compensate for the handling characteristics.
    Have you ever try to compute the engine rpm at certain given cruising speed and compare with what you observe? I did it on my Protege5, and there is about 7% of difference. In addition, if the speedometer is over read, then it will make things ever worse. That means the tachometer is about 9-10% off. That's a lot of inaccuracy.
    Bruno
  • jampedrojampedro Member Posts: 38
    Thanx for the sketch confirming it's inside the console apparently at the bottom of the lower section. At that point, mine has small holes in the center of the molded plastic bottom where I might install one. But I still can't tell where the cord opening is from the sketch and I haven't found any on mine, but I'll look closer after work. A picture would be a real help.
    I suppose I could install any aftermarket cigarette lighter connected to the same circuit as the normal cig. lighter. Anyone foresee any problem with that?
  • brucec35brucec35 Member Posts: 246
    How? Little things like SALES TAX and dealer tag/title/doc fees.
    I checked at CarsDirect.com. The MSRP for what I assume will be a typically loaded car, with V6, Auto, leather, comfort pkg, bose upgrade, cassette player, 6 disc cd changer, moonroof, side airbags, and not even including some of the smaller options is $25,615. Add in sales tax of $1793 and you have $27,408. And this is WITHOUT the sport package, since I prefer a car w/o the plastic cladding and over-the-top spoiler. Add in $1500 for even modestly good 17" wheels/tires and the total comes to $28,908 (or $18,000 plus even if you go with the sport package). Dem's the facts. Even dropping the CD changer and cassette player it's still over $18,000 for one like I want. The reason I factor in sales tax, etc, is that if I buy my other choice, a nice used luxury car, from a private seller, I don't have to pay tax at all.
    Knock off a thousand or so in a few months if demand is soft, or more if the car is a bomb, but if that's the case then I suppose resale value will be even worse. But you are still looking at a car that's within a few thousand of cars in the next class up. I like the 6, but the similar performing Saab 9-3 just appeals to me more.
    As for the Saab's size, I haven't sat in one, but I checked the stats and it's within an inch of the BMW 5 series in most interior dimensions, and has more headroom. I thought our two 5's were plenty spacious enough, since we don't have kids.
    Finally, I read here that the Saab got 5+ for safety, the Mazda 3+ in a recent comparison test. That's another plus. I have yet to test drive either, so that may well be the deciding factor of course.
  • chikoochikoo Member Posts: 3,008
    Mazda and Honda make good front wheel drive cars like the 6 and Accord because they give very poor low end torque which results in very negligible torque steer. Once the car is moving one does not sense any torque steer since the car is already in motion. Right? :)
    I'm confused...
    Are you comparing new and used cars and then new and new cars? In all this confusion, even I lost count. And I don't feel lucky today.
    And what safety figures are out on the Mazda6?
  • groovypippingroovypippin Member Posts: 264
    I'm confused. Are Saabs tax free where you live? If a Saab retails for several thousand more than a Mazda6, won't you end paying even more sales tax onthe more expensive vehicle?
    Isn't everything relative?
  • meesrmeesr Member Posts: 20
    ... then I'm moving there.
    ... is getting a new Mazda 6 from Mazda corporate in one week. Will post stuff.
    Oh, and he gets it FREE. Sick, huh?
  • pcballa706pcballa706 Member Posts: 19
    how much faster will the 0-60 be in a 6cyl than in a 4cyl?
  • allen53flallen53fl Member Posts: 41
    I finally got to see a 6 (at the Miami Beach Auto Show). It was on a high turn table w/the front doors open. Couldn't really get a good look at it though. Don't flame me, but I really wasn't "impressed" with its looks, (it looked kinda smallish up there). Maybe after a test drive, I could change my mind....Really disappointed that Mazda did not have the wagon, hatch or RX8 there. Had a couple of P5's, which felt very comfortable to sit in, much better than some of the vehicles listed below.
    Some other very quick impressions:
    Audi A4 - liked a lot, but felt cramped in drivers seat, (right leg crammed at console).
    Saab 9-3 - Liked a lot, but also felt cramped inside, too many small buttons on dash, (was too busy). Nice looking car though.
    M45 - disliked it a lot, esp for a 40-45k car. 340 hp isn't everything.
    Corolla - Surprised by its very excellent fit and finish and how comfortable the drivers seat was.
    Passat - Surprised how firm the seats were, too firm I think. Dash kinda bland. Smaller on the inside than I thought it would be.
    BMW Z4 - Really wanted to like this one, couldn't fit in very well. 2000S is much more comfortable.
    Accord - Have tried to let the looks grow on me. Nope, not yet. Hated the dash. Like the coupe (exterior) much better, (same ugly dash though).
    What REALLY tripped my trigger was the G35 Coupe. I kept coming back to it several times. What a beautiful car! Inside and out! Yeah, but it cost around 35k, so unless the stock market corrects its very wicked ways soon, I won't be getting it (or anything else for that matter!!!) for a loooong time). Oh well, it's still nice to dream.
    Got a laugh about the parking in a previous post, (needed 2 feet). Ha! While in Toronto this summer, I saw a small car squeezing into a spot with about 2 INCHES to spare front & rear (I'm not kidding!). And yes, they got it in!. I had to stand and watch this adventure!
    P.S.Thanks for all the great posts....
  • tomcat630tomcat630 Member Posts: 854
    In Illinois we have to pay sales tax on private party used car sales, they get it when we register for plates/titles. There is a minimum amount so one can't say "I paid a dollar".
    The Saab 9-3 will be sharing platform with the 2004 Chevy Malibu, hardly a "luxury" car, just a "different" one with the key hole in the console. And, it was featured in 'Seinfeld', I.E. a car for "image is all" yuppies.
    Also, nobody in thier right mind will pay MSRP for a 6 unless they can't wait till supplies build up. Altimas go for discounts now, just wait.
  • yugoboyyugoboy Member Posts: 161
    Has an absolutely smashing review of the new 6, i think the only negative they had about it was it's bodykit, and paint job(subjective of course)! I cant wait for a comparo against the camry and boring accord, i think the 6 will trounce the competition.
    And what's with edmunds review: "Tight rear-seat accommodations" and then when you read the car and driver review it praises how spacious the backseat is!!!
    Starting to lose my faith in edmunds when it come's to review's, alot of inaccurate info and typo's, totally unacceptable!!!
  • johnclineiijohnclineii Member Posts: 2,287
    With all due respect, what does Car and Driver cost you? (Even if you read it at the library, that subscription was paid for...on the web? How many ads did you see?)
    As to the printed version, in addition to what you pay, what is it filled with? Did you know most magazines get well over 2/3 of their revenue from ads? Do you think there is any possibility that what a car magazine writes could be influenced by the desire to sell ads?
    What does Edmunds cost you? And what annoyances do you have to put up with to use Edmunds? What incentive does Edmunds have to change its opinions to fit what the companies would like to hear?
    Finally, is it very nice to eat a host's steak dinner then sit at the table and complain about the quality of the steak that the host has worked hard to provide you and charged you exactly nothing for eating? Even compare it to the quality of dinners bought and paid for elsewhere?
    Just wondering...
    I think I will wait and try the backseat out for myself, as well as the V6 vs. 4, etc.
  • diploiddiploid Member Posts: 2,286
    Spacious...maybe for kids.
    It's the C&D people who are inaccurate and inconsistent. They have the Focus on their 10Best list for a couple of years now, and in the latest comparison test, it didn't even place second.
  • mazdafunmazdafun Member Posts: 2,329
    Again, the rapidly-descending rear window clips the backs of taller occupants' heads.
    That's why I'm more interested in the wagon or hatch (in addition to the utility of their cargo doors)...I do have a few tall friends after all.
    That's probably why they didn't bring over the adjustable headrests in the rear...trying to discourage any taller passengers from sitting in the rear seat (oh, and visibility, maybe).
    They didn't have and 6s at the dealership I visited last night (shipment delayed...Mazdausa shows they have 5 in their inventory...probably en route). I did get a brochure. They must've used early prototypes for the pictures because I noticed a lot of mismatched body panels and doors and other little things like missing rubber bumpers under the corners of the trunk lid (one on the right but missing on the left) and stuff like that. Oh well, picky me.
  • ickes_mobileickes_mobile Member Posts: 675
    Car and Driver had the interior volume of the Mazda6 as one cubic foot smaller than the Accord front and rear. I've seen other reports that the interior volume in the Mazda6 is 96 cubic feet and the Accord is 102 cubic feet. Differences may be due to sunroofs. Car and Driver's artical said that the back seat in the Mazda6 was smaller than Camry and Accord, but adequate for two people. Will just have to wait and sit...
  • doying5doying5 Member Posts: 83
    Me and my 200 lbs have been in the back seat of the Mazda6 on some rather intense test drives. For those who question the room..."Sit in it Potsy"
  • stretchsjestretchsje Member Posts: 700
    Speaking of roominess... I posted this on another forum, but I'll pose the same question here, where there's a larger American viewer-base :-)
    OK, practicality and roominess aside, how's does the 6's driving mannors differ from smaller sporty cars such as the Celica, RSX, and the Protege? I currently drive an old Celica and really enjoy the small-car charactoristics, but am planning on getting a 6. Am I in for heavyweight shock?
    I realize a midsized car, especially in America, is perpetually an oxymoron with performance, and that's why the 6 is so appealing--it breaks the typical mold of sacrificing zoom for room. The 6 can be the best among its midsized rivals, but since cargo space isn't very high on my priority list, I am going to cross-shop it with smaller cars, such as an RSX. I still haven't driven either, only my old Celica and an '02 Protege, both of which I like.
    I realize everyone here loves the car, but I don't have the constraint of needing a midsize. I'm sure the "total package" of the 6 will have me sold (after all, hardly anything on the car that isn't impressive), but once I have to live with my new car, am I going to miss the days of driving a smaller, lighter, and less refined car?
    I should clarify that the 6 is already at the top of my price list. An Audi TT is out of the question, as is an RX-8 or Nissan Z. Believe me, the RX-8 looks like a dream car of mine. I need to hold four people (uncomfortably) on occassion, and still want a semi-useful trunk, which leaves out the Miata and MR2. The RSX fits these criteria perfectly, but just doesn't seem exciting. The 6 does, though, and the huge space in the 6 is like a bonus. If I can buy used to save $$$, then all the better.
    But, regardless of this, I'm trying to focus exclusively on the fun-to-drive quotient- will I get the same thrill in a bigger car than what I'm used to? If the 6 drives like a small car, then the cargo space is a bonus. On the other hand, if the 6, sporty as it may be, still isn't as tossable as my old little car, I'll feel like I'm carrying around excess baggage.
    I began thinking of this after seeing the US's bumpers grow- extending the length of the car another 2-3 inches for no reason, and it already has a very large turning radius.
  • dinu01dinu01 Member Posts: 2,586
    I think the 6 will be THE car in the midsize segment to get, for driving enthusiasts. As far as being tossable, the PRO does that job very well. The six will be a little less agile (larger car), but should have better power, especially in the V6 trim.
    Personally, if saving money and having fun is at the top of your list...stick to a PRO ES w/GT package (sunroof, alloys, A/C, spoiler).
    I'm more or less in the same boat as you: next November (2003) I will NEED to buy a 2nd car. I have an 01 PRO ES and love it. My budget is $10.000-11.000 CDN. I can get a 3 yr old PRO with all the goodies mentionned above (GT package here in Canada), a 1995 Maxima SE, 95 Accord, 98 Civic Coupe... but that means trading sportiness for luxury/space, things I don't care about.
    So PRO is it for me.
    Dinu
    I feel much like you do in the affinity for smaller cars. The 6 obviously has 300+ more pounds to throw around so it will never feel like a Miata or Protege through the slaloms, but it does have an amazingly solid and sure footed feel.
    From what I have seen/heard the RX-8 would be ideal. My 6'6" friend said he can actually sit in the back (uncomfortably). Pretty amazing for a guy who can't drive a Miata with the top up.
    Me to, I love the agility of small cars. Have you considered the Mazda Protege Speed?
    Give us a comparable for the rear seat in the Mazda6. How does it compare to, say, a '98-02 Accord, Passat, or Maxima?
  • capitanocapitano Member Posts: 509
    at my local dealer seems odd. They are showing 23 6i's inbound and only one with the manual transmission. They show 9 6s's inbound with 3 of them equipped with manual transmissions.
    Seems like the 6i manual that several posters are interested in might be harder to come by than the 6s 5speed.
    The one 6i manual has 5 SP - LEA - SR - COM - PREM PKG (taking that as leather, sunroof, comfort package and premium package) with a price of $22,520.
    Of the 6s 5spds, two are strippers: base plus wheel locks @ $21,650. The third is LEATHER - SR - LOX(wheel locks) - COMF PKG and goes for $23,430.
    The only one with a sport package is one of the automatics.
    There is only one of the 32 cars has side air bags and that is a 6i auto that also has the premium package, TCS and ABS and comes in at $21,580.
    The most expensive model is a 6s auto with LEA - SR - COMF PK - BOSE for $24,965.
    They have 6 stripper 6i autos that for $19,900.
    I almost bought a Protege, but that Mazdaspeed Pro is far too "racer" to get my interest, plus seems pricey.
    Really, the next Protege ES will probably be a perfect car for me, with the new Mazda 2.3l engine, but I can't wait that long.
    To the one saying car mags are all ads. What do you see on the left side of Edmunds Town Hall? Links to PeopleFirst.com, TireRack, and Carfax. Edmund's cetainly isn't "Ad free", like Consumer R.
    "Do you think there is any possibility that what a car magazine writes could be influenced by the desire to sell ads?" Car and Driver has bashed many a car from companies that support them. GM is one example.
    Looks like lots of nitpicking on the 6, probably from worried Brand X owners. "Oh no, my car isn't perfect", what will my frineds think?"
    has had his interest peaked in a Mazda6...
    "The 6 obviously has 300+ more pounds to throw around so it will never feel like a Miata or Protege through the slaloms"
    Is it that obvious? Anyone drive their Pro to the dealership to test drive a 6? Which was more fun?
    With the 6's more sophisticated suspension, I'd hope it could handle at least as well, yet be more comfortable to ride in. I'm even more curious how the handling of the 6 stacks up to an RSX or Celica, the latter which I drive now. Better, worse, or just different? I fear missing my little car, but think the total package of the 6 is too good to pass up.
    Well, yeah, the 6 is midsize and Pro is compact.
    The Pro goes away in 2 years in favor of the '3'.
  • arugalaarugala Member Posts: 5
    I'm very interested in the new Mazda 6 (particularly the hatch). However, there are a couple of things that I find less than ideal. The recent Edmunds review put the 0 - 60 time at about 8 seconds with the V-6. That's not bad, but not too great either for this type of car. The new Accord V-6 puts out 240 hp and yet still delivers 30 mpg on the highway (the Mazda is rated for 27). I think the Honda is supposed to be a full second faster to 60 mph. Also, there are some specific features that I definitely want. They include adjustable rear seat head restraints, stability control, and the nav system. If Mazda is going to omit those from the U.S. version, I'll be less likely to buy the car. (Partly just based on principle - why should we have to accept less?)
    Do people really want it?
    I talked to a product planner who is dealing with that issue and he says it's all about prestige, not about usefulness. I think it's good in rentals or for people who spend their days on sales calls, but otherwise does it have any appeal to the masses?
    Edit: I'm asking in the context of cost justification.
    want nav. The only car I would take it on would be a mini, but just to get the speedo back where it belongs.
    I think the nav system are an affectation. YMMV.
    I don't even find them that useful on trips. Usually, I'll have my route either mapped out beforehand or I'll have someone playing navigator.
    For everyday driving, it's not necessary at all.
    Then again, most SUVs are for image only.
    I wouldn't waste my money or the space inside my car for a NAV system. Besides, it puts even more buttons on the dash, which seem to cover the consoles of current BMWs like a rash. Just give me the extra storage cubby.
    If I wanted a NAV system, it'd be more of a temporary item (i.e. GPS receiver hooked up to a laptop or one of the stand-alone units). I can then take it out when I don't need it, and can transfer it between vehicles or take it hiking. Plus, they're easier to update in the comfort of a house.
    arugala: 8 secs 0-60. If it was you wouldn't complain, right? I really don;t see the fixation of so many with 0-60 times. Most cars todays put up good #s, so relax people. There's more to a car than 0-60 and HP figures.
    NAV: For maximum $100 CDN ($62 US), I'd take it. More than that it's just a waste. As someone pointed out earlier it's all about "prestige" (aka: "snobiness" on wheels).
    Dinu
  • azstanazstan Member Posts: 74
    If Mazda is going to "bally-hoo" NAV, then why the hell don't they include it as an option NOW? Honda has done the same thing with their NAV option.
    I simply do not understand the fixation with things like HP numbers and 0-60 times.
    The Miata has limited horsepower and poor 0-60 times. Always has. Thing is, the car is an absolute blast to drive. Doesn't that matter to anyone?
    The Cadillac Deville has more horsepower than a Mazda6. Maybe I should get one of those instead.
    What matters to me is what a car "feels" like. That's why I love my Protege5. It only has 130 HP! God, why do it I like it so much? I must be a fool.
    let them get the basic options working and selling. Then once their confidence builds up, so will the options.
  • vocusvocus Member Posts: 7,777
    The NAV, I think, is more useful to rentals, etc. like someone already said. However, the adjustable rear headrests and stability control are very worthwhile options that should have been included already, especially on car debuting in 2003.
    if you are a fool, so do I.
    I love the P5 deadly. I couldn't be careless about hp, or 0-60, or 1/4 mile numbers. I can average 100 mph on the Hwy for hours. Passing is performed with ease, and the car is RESPONSIVE. That's all matter for me.
    Right on bro! PRO ES over here.
    Dinu
    The lack of rear headrests in the NA Mazda6 is a shame. In So Cal, I can live without stability control but in a more adverse climate, I'd definitely want it.
    http://www.mazda.ca
    Click on the 6. They have a really cool screensaver and info on the 6, all in good old Canadian specs of course - for those imperially-challenged metric folks (or something like that).
    Dinu
    Have your speakers on when entering the mini sites.
    Dinu
  • ashutoshsmashutoshsm Member Posts: 1,007
    Edmunds was able to improve the 0-60 times by 0.7 seconds (ie. to 7.3 seconds) by holding in the brake before launching. Not recommended on an auto transmission car, but its how the Accord's 7.0 was likely measured. And there again is my beef with Edmunds Mazda 6 review - so why not list 7.3 in the table, because that's the only thing people in a hurry will look at, and won't read the whole review! And rear quarters cramped - by what standards, really. They're within a smidgen of all competitiors' dimensions, and seat quality and bench depth is better (more thigh support) And yes, I've sat in one & I think its at least as comfy as other midsize cars, and more so than smaller ones like the VW Passat!
    So there!
    Now, laucnh your own automatic the same way at your own risk, unless you can afford transmission rebuilds every year or two ;)
