Mazda6 Sedan
1112113115117118342
  • ashutoshsmashutoshsm Member Posts: 1,007
    ... both of which use the same Duratec engine, is that the latter has engine management and electronics designed by Ford. Which is NOT the case in the Mazda.
    Whew! On to the next subject of discussion, and lets beat it into the ground as well, eh?
  • kenokakenoka Member Posts: 218
    I really can't believe how much discussion there has been on the use of the Duratec engine. It seems to come up every time we think the issue's dead. Maybe we should rename the engine "Freddy Krueger". Obviously Ford's brand value is in the gutter about now. They are really going to have to do some serious work on this in order to turn themselves around.
    As for the engine itself, I have done my own research and have satisfied myself that this is a fine block for Mazda to use. It has been rated as a top ten engine by Ward's, and was designed with the help of both Cosworth and Porsche. When Porsche delivered the prototype it had 250hp output. I think emissions work and some cost cutting dropped that output to present levels. Mazda has put different heads, timing chain, variable valve timing, etc. in order to both increase power output and smooth out the NVH issues with this engine. NVH is probably one of the few viable complaints about previous Duratecs.
  • mazdafunmazdafun Member Posts: 2,329
    Also, I think it'll be a little bit shorter (less rear overhang), at least according to the specs for the Japan and Euro versions.
  • mike1770mike1770 Member Posts: 20
    Wow, that's the first picture I've seen of the HB, and it looks great! It really does seem to have better lines than the sedan. I'm enjoying my 6s, but I too wish the HB had been available from the start -- I definitely would have considered it.
  • marchharemarchhare Member Posts: 44
    So, I wrote a few weeks ago how my check engine light came on. Nothing seemed wrong with my car, so they cleared the light and I went on my way. Two days ago (Wed) the light came back on (really annoying because the closest Mazda dealer to me is more than 20 miles away) so I took it back in.
    They kept it overnight last night (giving me a rental) and the mechanic said he was on the phone with Mazda engineers all this morning trying to figure out what was wrong.
    As it turns out (according to him), there's nothing wrong with the car, but there's some bug in the computer software that neither the Mazda nor Ford engineers can pinpoint right now. So, I'm to pick up my car today and periodically bring it in to clear the light and make sure nothing else is hiding behind the error message.
    The mechanic suggested that in the future they might have to replace the whole computer if they can't figure out what this programming error is (although I don't see how that might fix it, but whatever works).
    Nothing directly life-threatening (although ignoring the "check engine" light could hide other, more serious, problems), but annoying. So, maybe we'll be looking at the first recal for the 6 (and hopefully the only one) sometime related to this problem.
  • audia8qaudia8q Member Posts: 3,138
    90% of the time a check engine light comes on because the gas cap was not screwed on correctly.
    hopefully your dealer will figure out your problem and get you going. So far we have not had any communication from Mazda concerning an issue like yours. which is good, hopefully its an isolated case.
  • mileagemileage Member Posts: 9
    Is it possible to program the door locks to lock automatically when you start driving?
  • jmessjmess Member Posts: 677
  • gee35coupegee35coupe Member Posts: 3,387
    One place the MPV hasn't passed the Odyssey is sales volume. By a LONG WAY.
    http://autosite.com/editoria/asmr/svvan.asp
    And a total of 15 MPV reviews vs. 27 Odyssey reviews is kind of a small sample don't ya think.
  • maltbmaltb Member Posts: 3,572
    Choe,
    Both the I4 and the V6 are manufactured by Ford in the US. So by default, neither engine is suitable to your needs. Enjoy your day.
  • mazda6smazda6s Member Posts: 1,901
    Rich-
    Can you tell me the current build combos available if the base requirement is 6i, MT, cloth interior, ABS/TCS pkg, and SAB/SAC pkg.
    According to the mazdausa site, you can only get this combo if you take the Premium pkg.
  • jjpeterjjpeter Member Posts: 230
    Malt said - " Both the I4 and the V6 are manufactured by Ford in the US."
    I looked at the sticker of both the 6i and 6s at a local dealer the other day, and the I4 says its built in Mexico and the V6 says built in US. Transmissions built in Japan.
  • ruskiruski Member Posts: 1,566
    the Pontiac Grand Prix GTP's supercharged engine is not simply a 3.8L V6 with a supercharger bolted onto it. It is somewhat different. People can't just by a non-supercharged Grand Prix GT and easily bolt on the supercharger.
    The non-supercharged one is known as L36
    The supercharged version is L67
    You are correct JJ, I should have stated North America.
    Check this about bolting on a supercharger
    http://www.thrashercharged.com/tech_htm/faq.shtm#16
  • dbamacdbamac Member Posts: 6
    Choe - I'm not certain what you thought you read in my post, but I was not supporting what you were stating. Furthermore I don't necessarily agree that the MC engine is smoother and give a "cleaner" (cleaner?...I assume you mean stronger) pull. Yes, the MC engine is a smooth engine, but it is slow to rev for such a small displacement engine which can make it feel rather lethargic at times...I have never gotten the feeling that all 210 of those ponies are actually in the stable.
    I get the feeling you are not an overly technical person by some of the statements you are making. Others here might want to consider that before responding in the future.
    I do want point out that Gary (Mazda6) is correct in pointing out that a Miller Cycle engine has a different combustion cycle than, say, a Honda engine (an Otto Cycle engine). The very nature of that combustion cycle (leaving the intake valves open during combustion) is part of the reason Mazda is abandoning the concept. MC engines To clean up the MC engine, they probably have to close those valves...then it woudln't be a MC engine.
    Can that be the educated end to the MC engine in the 6 discussion?
  • toneetouchtoneetouch Member Posts: 60
    hello all. i'm a long time reader, first time writer.
    mazdafun wrote that there is less rear overhang with the 6 hatch. does anyone know what other interior and exterior differences exist between the 6 hatch and sedan?
    i can't figure out exactly why, but i also think the hatch is better looking than the sedan, and am looking forward to it being available in the US.
    thanks,
    antonio
    Yes, I know there are differences, like the compression ratio must be lower to allow the addition of the blower. But, L36 and L67 are closer to each other than the Mazda 2.3 Miller-cycle is to the 2.5L V6, NO?
    how the engine in my Millennia worked. It usually went like this:
    "Yeah, the Lysholm compressor holds the gas/air charge in the combustion chamber since the intake valve doesn't close during combustion.
    "It has a supercharger."
    "Oh...cool!"
  • breldbreld Member Posts: 6,918
    I live in Denver but will be making a quick "on a whim" trip to Detroit tonight to visit the NAIAS tomorrow. The best part - my rental car while I'm there should be a Mazda6! I might have to take the long way to the hotel!
    I've driven a Passat for the past two years, and chose it primarily for the availability of the V6 and manual transmission (the only other good choice at the time was a Maxima). I really enjoy the Passat, but do long for something a bit sportier, so the M6 is obviously on my mind. With the availability of the hatch version later this year, I will strongly consider making the change.
    With great previous experiences with a Civic, Prelude and Integra, I love Hondas, but the unavailability of a V6 sedan with a manual tranny has kept me away from Hondas/Acuras for several years now. I think it's fantastic that Mazda (and Nissan) chose not to ignore this admittedly small segment. Now if only the TSX would become available with the Accord's V6.
    Anyhow, I'm looking forward to spending a little "quality time" with the 6 at the show tomorrow.
    2024 Audi Q8 e-tron - 2017 911 C4S - 2025 BRZ - 2023 A6 Allroad - 2024 Genesis GV60 - 2019 Cayman
  • mazdamarlamazdamarla Member Posts: 350
    Okay. I want the Auto transmission. But what is this other thing where it lets you shift it as though it were a manual even tho it's the automatic?? And there's no clutch pedal, so how do you "shift" it??
    What is it, what is its purpose, and when would you use it?
    My husband had a stick-shift Nissan truck. One of my friends will drive nothing BUT a manual transmission car. I, on the other, have anbsolutely NO DESIRE WHATSOEVER to drive a stick. But what is this function for on the 6??
    "And there's no clutch pedal, so do you "shift" it manually??"
    Yes, you can if you want to.
    "What is it, what is its purpose, and when would you use it?"
    It's for shifting manually, if and when you want to.
    HINT: You can ignore it if you like.
    then why would you not have just GOTTEN a manual transmission to begin with (and saved some money in the process)?
    the manual tranny versions have the simpliest option combos.
    you can get the abs/tcs and side airbags with the premium package. Nothing else is required.
    otherwise you need to take premium, sport, comfort and leather to get your options.
    For those who are ordering a mazda6 this month...tomorrow is the last day of allocation this month. Which means if your order isnt transmitted to mazda from your dealer by tomorrow they wont look at the order for a month.
  • altersysaltersys Member Posts: 56
    Argh. The difference is there's no clutch pedal to press. You just hit up or down and the automatic transmission shifts when you tell it to. The only difference between this mode and full automatic is that in full auto the transmission decides when to shift for you. In manumatic mode, you decide... but selecting a gear is still easier than in a true manual because you don't have to press a clutch, release the gas, shift, then press the gas and release the clutch again. See the difference?
    That said, true car lovers generally agree that manumatics really aren't as "fun" as a true manual, and are really just novelty items. They don't really improve performance over standars autos- they just give you something else to futz with.
    Anyone want to comment on my post a page back, please?
    -Alt
    Thanks for the answer. If I can get a 6i-MT with abs/tcs and sab/sac and premium package, that will do it for me. I'd consider the 6s-MT, but they don't allow the equivalent, which would be the 6s-MT with just the sab/sac package as the only option.
  • blueguydotcomblueguydotcom Member Posts: 6,249
    Novelty? Yeah that was Porsche's idea when they slipped the Tiptronic in their 911 a decade ago. Yep, BMW and Infiniti's manumatics are novelty items.
    There actually is a slight advantage to a manumatic over a straight auto. Can it compare to a manual? In 2003...no. But some are darn close.
    The big difference isn't in straightline acceleration (most 5 speed autos will hold 2nd through 60 when you're pushing hard) but for passing and handling. An automatic when passing doesn't know exactly how much power you want when you're cruising at 60 and you slam your foot down. With a manumatic you're simply dropping the car into 3rd and launch instantly. There's no "gear-hunting" involved.
    Likewise on corners it's best (imo) to have the tach in the sweet spot, engine pulling with full torque so you can launch outa the corner. With a manual this is cake. On an automatic it's near impossible to control and with a manumatic you can mostly do it. I'd rather have some measure of control over the engine then zero like you get with an automatic.
    Come flying into a corner at 75, downshift into 4th and you can decelerate some and keep the torque up as you sweep through - never touching the brakes - and explode out of the turn. You can do this with a manual and a manumatic. With and automatic you must touch the brakes and wait for the car's computer to decide if and when to downshift. No thanks.
  • choe13choe13 Member Posts: 348
    thanx thats what i needed to know, why mazda did not further venture with the MC. I said can someone tell me a reason why they would not use the MC instaed of the bad named duratec considering everything that would be right for the use of the MC. And you just gave it to me. No need to add that i'm technically unsure about everything i talk about, becuae only with this issue i wasn't.
    ...based on the UK specs, the hatch and sedan are the same length and have the same wheelbase which seems to indicate the same overhangs.
    I would presume the same will hold true for the US versions.
    For more info see: http://sycomax.mazda6.co.uk/uploadpool/documents_UK/PDFBrochure/Mazda6_UK_0502.pdf
    Click down to page 8-9
    robr2,
    thanks for the link. according to the pdf's diagram, it appears the only difference in exterior dimensions would be a longer and higher (more horizontal) rear window, and shorter 'trunk deck' (i don't know the correct term, sorry) for the hatchback than the sedan. it looks good, though.
    it also looks like the hatch has a wider and lower opening at the base than the trunk on the sedan.
    anyone have any more info?
    i wish december wasn't so far away....
  • yugoboyyugoboy Member Posts: 161
    Forget the hatch, bring over real practicality and performance!!!!
    http://www.avtoin.com/zeneva2002/slike/Mazda%206%20SW.jpg
    2004 is so very far away!!!!
    Is it the Miller Cycle engine that keeps valves open during burn?
    I thought that it was the rotary Wankel engine in RX-7 doing that
  • jampedrojampedro Member Posts: 38
    My Japanese made 6 locks the doors automatically when the ignition is turned on.
    Also has rear headrests and folding side mirrors, but (dammit) no aux. power port.
    About half the time I'm driving my 4 speed automatic 6 I change gears into any gear I want by moving the shifter through the D, S, L positions and using the hold button. Is the result any different than a manumatic?
    BTW, I only do this in my 6 because it's so much fun to drive. Hardly ever did it in my slushy 98 Camry which has been relegated to my wife.
    i can't agree with you there, yugoboy. the hatch has great storage room with the flat folding rear-seats, a more muscular looking rear, easier loading with wider and lower rear access, equally great perfomance (i think), and a cool looking rear wiper. all without the family hauler look of the wagon.
    why anyone would get the sedan is beyond me...
  • johnclineiijohnclineii Member Posts: 2,287
    Why would anyone get the sedan? Because they CAN.
    Today.
    Sigh.
    good point.... though u got to understand some like that sedan look since it makes it look "fit". But i'm with you on this. The Hatch which is not even a true hatch look, more like a is300 look, looks great, while also providing additinal generous space and also helping the handling/steering dynamics even further. And most upscale cars are being built on this platform , but they classify it as a sedan still.
    Mazda has stated the hatch is how the mazda 6 was suppose born naturally. I can't wait to get get my hands on it, on grey silver.
    I wouldn't suggest it but someone more knowledgeable may be able to give you concrete reasons why one may want to avoid that with a garden variety 4 speed. The 5 speed manumatic is designed to have the selectable gearing.
    Audia8q, yeah, that's what they told me the first time (about the gas cap). But I actually did read the manual and stuff before I drove it much and knew about that problem. I'd made sure to screw it in for a few clicks everytime I got gas. This last time I had taken the car in on Tuesday and then the light came on the next day and I hadn't even got gas.
    The mechanic told me that it had something to do with the "evap test" and that it didn't think it was running it when it was, or something like that. He told me that he had called some "Mazda engineers" (don't know who that would be, but maybe he has a phone number) they they had told him it was a software problem.
    A couple of times they mentioned that and as I was leaving they told me they'd send me a letter when Mazda had a fix for it and I could bring in the car to have the software changed.
    So, I really doubt it was the gas cap problem. And they were certain it was software thing. The car's running fine, so I'm inclined to think they're right. I guess I'll just have to wait and see (and drive it all the way out there once a month to have the light turned off).
  • markjennmarkjenn Member Posts: 1,142
    I think Mazda may have shot itself in the foot on this staggered release of the sedan followed by the hatch/wagon. Granted, the buzz in groups like this is not representative of the general car-buying population, but there are an incredible number of people (myself included) who have postponed any car decision to see what happens with the hatch and wagons.
    If Mazda wants to truly be the Japanese BMW, theyv'e got to stop thinking like the Accord and the Camry are the targets. The Accord is virtually an unhittable target; it is so refined, so well done (styling notwithstanding) that anyone who is cross-comparing these two cars will have great difficulty in choosing the 6 - the Honda just objectively stacks up to be a little better mainstream sedan as the car tests are showing, and with the reliability and resale, you just can't go wrong.
    Mazda has got to go after the BMW crowd, and that means differentiation, with stuff like manual transmissions across the board, wagons, hatches, coupes, wide availability of options without excessive bundling into packages, AWD, an extra measure of technical sophistication here/there - in short they have to get out of the commodity car market where they're slugging it out with the Accord and Camry and get into niche market where they appear to offer everything a niche Euro car offers but with much better value and reliability.
    Maybe that's their plan with the hatch and wagon - I think BMW stages the release of a new model with the sedan appearing first simply because it is too complicated to try and introduce all the models simultaneously.
    I think there are a LOT of folks out there who think BMWs are fantastic cars, but just don't want to pay a premium to own a fussy machine - they want a blue-collar BMW. Make it happen Mazda!
    - Mark
    and put Sirius in it, too, please! :)
  • voochvooch Member Posts: 92
    The manumatic is a novelty item. The simple fact that the automatic part of the manumatic system is going to primarily used makes the manual part a "novelty" item. Its a trinket, a toy, something extra to play with. But I'm sure you will tell me you use it the majority of the time... OR that race car or sports car drivers use it 100% of the time, which has no bearing here since the M6 is no racer. I doubt anyone that has it uses it on a regular basis (just a guess because if they did, why would they not get a manual? just doesn't make sense). I've only driven manuals so I'm speaking from that point of view. If there was an automatic switch on my manual transmission, I would consider it a novelty item as well because it would be something I would rarely ever use and would just look neato as a button or whatever.
    The compass on my rearview mirror is a novelty item. I rarely use it. Although the manumatic may be a bit more functional.
    Its just as much a novelty item on a Porsche or what have you than a M6. Especially on a Porsche! Heck, a sports car is a novelty item itself. Why would anyone get a automatic SPORTS CAR anyway? Gag.
    good points. but let me counteract some of your arguments. First mazda is basically dipping its feet with the mazda 6 sedan. The north american market has been turned off from what should be a very usefull hatchback design(i blame saab). In addition to their stratgey, they want to introduce another version of this car(same car though essentially) to keep it fresh as long as possible(look at jetta, pt cruiser) without reinventing it year after year(bankruptcy).
    Though it does "try" rather than succeed against the accord and camry, it does certainly satisfy that 15 percent of people who are exactly looking for a car like this, so mazda won't be rich, but they will stay in the game(maybe only way to stay in the game).
    As well regarding the matter of introducing every single type of version of a model at once, hatch, sedan, couple, AWD option, that would just put mazda into bankruptcy since they are still in critical care from their own company bankruptcy or bound to bankruptcy not so long ago(ford to the rescue). In addition to this, i'll will tell you why they don't build coupe sedans. Mazdas owners and head markerters hate the 2 door coupe transforming of a natural 4 door sedan, because as i have read about the company history, they like to keep it logical and practical. They believe sedans are suppose to be 4 doors, and in reality thats what they should be, not a 2 door real sports car pretender(ironically though every mazda car is a sports car at heart). While also true sports cars should have only two main door, which they have built with the rx8 and miatas. I personally like this choice of designing strategy, because after the smoke clears, it does make sense. What can i say, i'm a mazda kind of guy, through thick and thin.
  • fowler3fowler3 Member Posts: 1,919
    **Maybe that's their plan with the hatch and wagon - I think BMW stages the release of a new model with the sedan appearing first simply because it is too complicated to try and introduce all the models simultaneously.**
    You are right about that. Number of production lines running in the beginning; programming the robots to assemble alternate models at the outset would be a nightmare. Better to get the crews trained and assemble one good model for introduction, get the manufacturing bugs worked out, THEN introduce the next versions. Also, if sales of the first model are slow that tells them how to allocate the next ones.
    In other words -- one model at a time gives them better feedback from buyers.
    fowler3
    Mazda offered a 626 5-door sedan which didn't do well. Mini-vans were coming on the market and they took care of the socker mom buyers better. In Europe, the 2-door and 5-door hatchbacks became very popular, and still are, for their utility, because they had I-4 engines and lower taxes than V6 models. More people could afford them.
    The 6 series is a World car, so if the hatchback is a flop here, again, they still have Europe, Asia and Oceana to sell them in.
    Many American buyers don't like the hatchback version because of more road noise from the rear wheels/tires and less structure* between them and the rear bumper. Same for small wagons. Mini-vans are longer, taller, and the wheels are lower which reduces road noise in the cabin.
    * I'm not talking fun-to-drive and handling here, I'm talking about peoples' fear of fire in the cabin, however unrealistic today. Many of these same buyers would like the hatchback, but...they defer and opt for the sedan. Also, many buyers are pro-sedan because of the BMW 3 and C-class MB, a "sport sedan" has four doors and is not a utility wagon. Rent a small truck if you need to carry an old office chair to GoodWill. ;)
    fowler3
  • igotamiataigotamiata Member Posts: 14
    I'm looking at buying a Mazda 6 and was quoted a price today with the S Plan discount. When I told the salesman I wasn't a Ford or Mazda employee, he said "It doesn't matter. Just find someone who works for them and get their four digit pin number. It never gets checked out."
    Is this common practice? Is it illegal in any way?
    Thanks for any help.
  • edmund2460edmund2460 Member Posts: 293
    Any comments anyone on why the 6s comes out just short of the Camry XLE in this comparison in the metrics for handling and braking. I'm not referring to the subjective section where the reviewers but the skidpad and braking measurements. I regarded the Camry as built more for comfort and ride than handling and here it is besting the 6s whose brake system was optimized to the nth degree. Are R&T's measurements at variance with other reviewers? Also, I wonder if anyone sees any difference in the door design on the 6. I read the Mazda engineers dxtensive efforts to design a door that shuts effortlessly. I did not find anything remarkable about the doors, when I was in the showroom.
  • rodlcwrodlcw Member Posts: 45
    The eyeglass holder seems to "hangup" when pressing to open, and I have to then pull it down.
    Opens just a crack and not all all the way.
    The manumatic is now sticking and slowly moving back to normal position mainly when upshifting by tapping lever. It moves and shifts gear, but then the lever just slowly goes back to center position.
    I still haven't got an answer regarding the heated seats, if they are only suppose to heat for 2-3 minutes then shut off.
    i'm not a car genius but i'll tell you my opinion about your inquiries. I think the reason why the Camry v6 beat the 6s in regards of handling(skipad) and braking are these. First i will have to admit no matter how great mazdas handling and steering is below extra legal speeds, it does suffer on the skipad at a faster speed because of its wide radius steering ratio(this steering design is excellent in below legal speeds, helps lane changing and turns with composure, but also tends to feel like it gives up easier during high speed turning, since it requires the drivers additional effort to hold on). As for the braking, the camrys v6 might be better in end result, but during the process of the stopping, it doesn't feel as good as the 6s. So with these statements proving the lack of results one might think mazda 6s should top, in a tradeoff it does give the driver more of a control(sometimes not a positive thing, but mostly desired).
    As for your inquiry about the extra effort made doors, to me it does have a very good "thunk" sound once closed, compared to some other cars. With that, to me when a door makes that solid sound, it makes a reflective point that the other parts of the car is solidly built.Though for someone else its harder to appreciate it.
    You all make good points about Mazda's strategy. I'll close by saying:
    1. I have no idea why hatchbacks aren't more popular. I think they got a bad rap right about the time when SUVs started appearing and people either wanted a formal sedan or they wanted the cool new SUV. But the anti-SUV backlash is strong, very strong at the moment. There is just absolutely no way that the market can support, what is it now, maybe 50 different SUV models with some mfgs having six or eight. To me it is Greenspan's "irrational exuberance" and with any nudge whatsoever (e.g., any hint of oil shortages), will send the SUV market into the tank. And perhaps that the only non-pocket-rocket hatchback that was around was the quirky Saab.
    2. Yep, maybe Mazda is following the "prudent" and conservative course. But they should still err on the side of bold because if they don't turn the corner pretty soon, they're going to be history. Nissan was bold three years ago and look how they've been transformed. If they had tried the long/slow approach, they'd be history now.
    - Mark
