Plugs have a tendancy to leak more than they should and they may be fine today and develop a leak at a later date.
Recommend you replace that tire.
-Dave
I actually keep a plug repair kit (consists of a couple tools, rubber cement, and the hemp plugs) in my cars along with a small compressor, and that is my first alternative to dealing with flats.
The only time there is an issue with a plug is when you have a lot of them in a tire (for whatever reason). It can throw off the wheel balance, and you will need to get the wheel rebalanced. But that's the worst I have heard about.
If you absolutely think you need a new tire, you can get it shaved to match the tread depth of the other three. But I would not do this unless the plug repairs were marginal for some reason (or maybe if you had more than four plugs in a common area of the tire).
Craig
Thanks, Luke
Steve
Enjoy!
Ralph
Do a search on this and similar threads for head gasket related terms -- there has been much discussion on the issue lately.
Below is the text of the initial notice sent out to dealers regarding the coolant conditioner fix -- note the extended coverage on the gaskets to 8 years/100K miles.
--K9Leader
WWP-99 Service Campaign - Cooling System Conditioner
Subaru has determined that certain 1999 through 2002 model year 2.5L equipped Subaru vehicles may experience an external coolant leak from the cylinder head gaskets. This is the result of normal relative thermal expansion and contraction variations of engine parts. As a precautionary measure, SOA is recommending that a special conditioner be added to the engine cooling system to prevent leaks from occurring or to correct existing leaks.
Only early Phase II 2.5 liter engines are affected by this campaign. Phase I 2.5 liter engines (some 1999 model year and prior years) are not affected. Countermeasures applied to the manufacturing process for those 2002 and later VINS not affected by this campaign have eliminated the need for this campaign to be performed on those vehicles.
In the future, it will be necessary to add Genuine Subaru Cooling System Conditioner to the SUBARU vehicle cooling system whenever the engine coolant is replaced. The updated recommended service procedure as well as intervals for coolant replacement will be added to all applicable service manuals. As a reminder, we will include an update page in the owner notification letters that should be added to the Owner’s Manual and Warranty and Maintenance Booklet. We ask you to keep in mind that replacement of fluids (including Subaru Cooling System Conditioner) during inspection and maintenance services are not covered under warranty.
If the vehicle owner has this Service Program repair performed promptly, Subaru will extend coverage under the Subaru Limited Warranty on the vehicle for cylinder head gasket external coolant leaks to a period of 8 years or 100,000 miles, whichever occurs first. Warranty coverage begins on the date the vehicle was delivered to the first retail purchaser. If the vehicle was used as a demonstrator or company vehicle before being sold at retail, warranty coverage begins on the date the vehicle was first placed in such service. As a further condition for this extended warranty coverage to apply, the vehicle owner must have Genuine Subaru Cooling System Conditioner added to the vehicle at any subsequent cooling system services at the interval specified in the Warranty and Maintenance Booklet under the heading “Schedule of Inspection and Maintenance Services”.
Dealers will automatically be sent an initial quantity of Genuine Subaru Cooling System Conditioner. Dealer bulletins and affected VIN lists will be mailed to dealers in early February 2004. Owner notification letters are scheduled for mailing in stages
Greg
I've had luck with plugs on flats. My wife has one now that I actually installed myself, and it's holding the PSI.
Try the coolant conditioner first, they're pretty confident it'll help in most cases. Just keep an eye on the temp gauge and stop immediately if it gets hot, you don't want the alloy block/heads to overheat.
-juice
Greg
-juice
Rosemary
-juice
Thanks again,
Rosemary
Mike k
P.S the weather was 60 on Sunday so the outback got the full OCD treatment .
-juice
Just realized our LLBean (delivered 2/1/01) has experienced 4 winters already! Time flies!! The "frozen" brake pedal only happened once (this past winter) when it was single digits [F] during the day. It happened backing out of my parking space at work after sitting all day - I just drifted back an extra car length before the pedal seemed to finally "melt". Luckily, I had turned the steering wheel enough backing up so I didn't back in to anyone/anything. Weird feeling not being able to stop... I got ready to pull the emergency brake by instinct (used to drive stick shift VWs).
I finally had the brake fluid changed for the first time [power flush] 2 weeks ago at 54K miles. Subie mechanic said there was no visible water in the line and it looked like it should at 54K. He checked the master cyl. (for the recall issue) and said everything was OK. Not sure why it would have been frozen at start up - if it was even "frozen"...
Now that I think of it, how was I able to put the car in reverse without depressing the brake pedal? Don't remember if I did and then it froze while backing up... I'll hopefully never experience it again...
Ralph
It might have been that the brake pistons seized up, you can lube them with a purpose built grease but they usually only do that when you're changing brake pads.
-juice
I posted a message late last week (#2743) about buying a 1999 Legacy SUS & concerns over the HG issue.
Well - we decided to buy the car. We should get it next week, or at the latest around the 17th.
This is a 30th Anniversary SUS Limited. It has the factory "custom" wheels - where the area between the 5 "spokes" is painted or anodized gold.
To my question: are the areas that are NOT painted gold simply polished, are they clear coated over the base metal, or are they painted with color then clear coated, or anodized? I'm asking because the wheels need reconditioned. The gold areas look good & the "spokes" are OK, but the rim area on all 4 wheels has that white oxidation all over them - probably a result of using the wheel weights that clamp onto the wheel, as opposed to those that stick onto the inside.
I'd like to do the reconditioning myself. I'm not concerned with having them look 100% original - I'll have to decide whether to polish or paint - & knowing what there is to contend with would be a help.
Professional re-finish was quoted at $140 each.
I have taken to cleaning the rims with aluminum polish and a tiny brass bristle brush - I didn't think I could destroy them any more than they already were.
Not perfect, but certainly passable from a couple feet away.
There is an automotive catalog which has polishing and buffing kits for rims, if you are really inclined.
Good Luck! Rob M.
remove the two LARGE phillips screws (don't touch those teeny ones) that
hold the cupholder assy in. Pull out the cupholder. Pull out the ashtray
all the way (push down on the spring loaded "lid" and it comes all the way
out) and look in the now vacant hole for two phillips screws fairly close to
the rear edge (vehicle's rear) of the "roof" of the vacant hole. They're
impossible to access with a normal screwdriver - I used a bicycle multi tool
but you can also use a phillips bit and a pair of pliers to complete the
half turn it takes to loosen them enough to remove by hand.
Now pull out on the top edge of the trim piece that surrounds the radio
until it resists further leaning. All you need is for the top edge to come
out about 3 inches - DON'T try pulling this out all the way, meaning don't
try pulling up on it to pull it's bottom edge out of the slot. Leave the
bottom edge pinned between the front edge of the center console and the
center of the dash. I pulled this trim piece out when putting a stereo in
my nearly identical '97 last week and it was a pain to put back.
Now point both center vents all the way down, providing a ledge at their
bottom edges to grip the trim piece with several fingers and pull back and
down at a 45 degree angle, wiggling it side to side to help free it. It
takes a surprising amount of force, but then two plastic clips at the
vertical centerline of the vents on each edge will pop out of the dash
opening. They're not fragile at all, but just don't break the trim piece
that defines the bottom of the vents - spread the load with several fingers.
Once it's free, there's a wiring harness to the emergency flasher switch to
disconnect - I think the catch is on the top surface of the white connector.
Now you've got 4 phillips screws holding the HVAC unit in place. Remove
them, then lift it like the hood of a car and see two small silver phillips
screws. Remove these (key here is don't drop these into the dash) and you
can now wiggle the part they held onto the back of the HVAC unit away about
a half inch. These screws hold the cable mechanism that moves the water
valve. Now put the HVAC unit back down (again like a car hood) so it's
close to its normal position and you'll see you've opened up a half inch gap
into which you look. At the bottom you'll see a white 'wire tape' that's
the wiring connector and the thing that limits you from pulling the gap
wider. On the rearward face of the slot you've opened up, you'll see the
back of a circuit board and on it are 3 green plastic discs about a quarter
inch in diameter. These are the light bulbs. Use a small standard blade
screwdriver to hook a crevice on the edge and rotate the uppermost one
counter clockwise about 1/16th of a turn. That's all it takes to remove
them as they're kind of a 'push and turn' install. Once you've pulled this
easy one, it will help you get the harder two that are down deep in the slot
you've created. Note that the one by the fan switch is longer - the other
two are identical. Once they were loosened, I used a pair of needlenose
pliers to reach down and gently remove them from their holes. Kind of like
that old game of "Operation".
This whole thing should take you no more than 20 minutes. Now slap the new
ones in, remembering the long one goes by the fan switch and button it back
up. The bulbs again take just the slightest rotation to lock them back in
place. A penlight helps you see the holes they go in have notches in and
position them with the needlenose.
Of course, there is always the option of buying a set of custom wheels & using the factory rims for winter. But prices seem, in general, to start at about $100 each & go up from there. I don't want to have to spend that kind of money.
Thanks for your input Rob!
Kevin
Juice: Appreciate the link to the used parts dealer. LOL -- have you EVER had good luck trying to get specific info on car parts (phone or email) from a "recycling yard".
The mirror issue will be resolved. I am prowling supermarket lots with my ruler and a note pad, making notes on model years, mounts, mirror types, placement, colors, plastic composition, etc. I shall gladly share my treasure trove of advice on this important issue when I have firm intelligence (like actually replacing one on my '98 OBW).
Gee -- am I the ONLY one on this forum with a damaged outside door mirror? Hmmmmm.
The problem is that water, salt, etc has gotten under the clear coat on the silver / natural part of the rim. I'll bet the gold portion looks flawless. I have found that once the clear coat starts peeling, it doesn't stop.
Paint might not adhere to the clear coat unless prepped properly, Guaranteed, it will continue to lift off along with the new paint. The clear coat that is left on the rim is tough. I don't think that wet sanding or scotch pad will take it off - this could be accomplished with a buffing wheel on an electric drill with polishing grit. Course to remove the clear coat and debris, and fine to polish.
I have let the clear coat peel, and have a routine of cleaning the rims every time I wash the car. Brass brush to knock off the peeling clearcoat. Aluminum rim polish to get rid of the black, then a light coat of spray wax to keep dirt from bonding. Not perfect, but passable.
Stripping, masking and painting would be a chore. Given the time, I might attempt this over the summer.
Enjoy your new car! Rob M.
Craig
Craig - I thought about having them dome professionally. However, looking at what it would cost per wheel, I can buy custom wheels for just a little more. For instance, The Tire Rack (www.tirerack.com) has a painted, 5 "open" spoke 15" x 6.5" rim for the car at $105 each. If I were going to spend close to $100 a rim for reconditioning, I'd rather buy new ones & keep the factory rims for winter. In fact, I might just have to do that anyway, if my attempt at reconditioning doesn't work out well!
Thanks again for the tips - I do appreciate them!
-mike
If you do go aftermarket, Rotas are a good low-cost choice. Most sets sell for $575-650.
Keep an eye on the weight. If the new wheels are significantly heavier than the old ones, you will notice the effect.
Craig
-mike
I am kind of frustrated with my Outback and needed to see about how others opionion. It is a 2001 Ltd with 45,000 miles on it. I brought it into the dealership today for an oil change and some funky thing going on with my security system. It was locking and unlocking on its own. They think they have tracked down the cause with corroded wires. If that does not work, I will have to pay for a new harness (??) that holds the system in place. Odd that I would have to pay for that. I have the 100k service warranty.
Also, my front rotors need to be fixed and I have almost nothing left of my rear brakes. I would figure with all of my highway driving that 45k would not be long enough for the rear brakes to be shot. They are replacing them tomorrow. (Luckily I have a loaner)
I am over paranoid about this car falling apart??
Is the alarm aftermarket or Subaru unit?
-mike
Are you having the rotors turned (resurfaced)? That's fairly typical for Outbacks but usually fixes the problem. I assume you complained about a vibration when braking, right??
Craig
Steve
What dealer in NH gives a loaner?
Cheers!
Paul
Bob
Robert, Exeter Subaru in NH gives you a loaner car if you purchase the car from them. I commute from the Seacoast to Nashua, NH so it is very convenient for my 60 mile commute.
The part about the security system is odd. If it ends up costing you out of pocket to fix, I probably would just ask them to unplug the security system unless you really feel you need it. If they unplug the security system, you should still have keyless entry. Something to keep in mind if the cost of repair seems excessive.
Craig
Were the rotors warped? If so, see if Subaru will replace them under warranty. Quite a few people have had this problem (myself included). As for 45K befroe needing brakes- that's good in my opinion. I had mine done (front & rear) at 30K.
Mark
I don't see why the security system is not covered if they actually installed it at 19,000 miles? I don't need it where I live, but I travel quite a bit; especially to Boston and NY and park at airports so I would really like to keep it.
-mike
That's the technical answer. I would call 800-SUBARU3 and ask for a little help. A Subaru Gold warranty customer should expect to be treated well, at least ask how they can help.
-juice
