I'm having the same issue you described with my 95 AWD Legacy. Only the front wheels are spinning on ice. Tested it in 1 and 2 (not just Drive) and checked for the 2WD fuse. I even put a fuse in to make sure that the 2WD switch was functioning. It lights up 2WD with a fuse in place. But when I take it out - still no AWD.
Did you ever come to a conclusion regarding your problem?
Thanks in advance!
I am no expert on piston slap...hard to give an idea on brake replacement either as this depends on the kind of driving you do. Some people drive "hard" and wear out brakes very quickly.
I would ask if the timing belt has been replaced...as this is due around the 100,000 km. mark (I think).
The price seems to be OK if the car is clean and well serviced...can you get the history from the dealer?
Doug
I have to wonder what is going on at the factory with these clamps/hoses. Perhaps the supplier of one or the other was changed and either the hose got skinnier or the clamp tension got looser. I hope all the clamps on this car don't start leaking! :sick:
As far as getting the correct ATF level to keep this brand new transmission happy ...I need to start a new thread for that.
will it harm the transmission or just overflow out the dipstick tube harmlessly?
And does anyone know how to obtain the OEM fluid? I asked at my dealer and was told that they use it out of 50 gallon drums and it's not for sale to customers. He said to just use Dextron II, but I don't want to use second best, nor do I want to mix non OEM with OEM fluid.
Vinnie
If your dealer doesn't stock it try a different dealer.
-mike
Oh, and this is from the owner's manual:
Use one of the following types of automatic transmission fluid:
Genuine Subaru Automatic Transmission Fluid Type-HP
IDEMITSU ATF HP
Castrol Transmax J
Pennzoil ATF-J*
* Available only in the USA (except Alaska and Hawaii)
5-speed Auto - only use fluids specified above.
For 4-speed Auto Trans:
"If the recommended automatic transmission fluid is unavailable, Dexron III may be temporarily used. If the Dexron III is used continuously there will be a noticeable increase in the vibration and noise from the automatic transmission."
-mike
Mike, I wonder that as well. The older transmissions called for Dexron III. I have a feeling, though, that the Subaru OEM type HP is actually "IDEMITSU ATF HP."
-mike
-mike
They're good. Mazda switched to those when the MPV went to a 5 speed auto and reliability improved on the trannies.
-juice
So, I think you are safe.
My son's 96 Lumina has had piston slap its whole life (105,000 miles), so I don't think it's a serious problem).
Keep am eye on the head gaskets. Subarus have some history of head gasket problems. Yours may have been solved... but I would inspect the heads every few months. Also, check for oil in the radiator, or coolant in the oil (milky appearance). If steam comes out of the tailpipe after the engine is fully warm could also be a sign of a head gasket with an internal leak.
The price sounds a little high for a 2000 MY Legacy. But you should be able to get another 60,000 kilometers of reliable service from it, so you decide if it's worth it.
Jim W
I've got the old one out so that's not an issue. I can only find one supplier, Metra, that makes something close, and they don't seem to have one guaranteed to fit my model. Thanks in advance.
-Rob
There was a ground that had been hooked up, but it was corroded. Once it was cleaned up, the subaru started right up.
Thank you WXESX for replying. We had no ideal of what was going on.
I do have one more question, the car is running fine, but sounds like a belt is sqeaking a little. Once you put your foot on the clutch it goes away. Any ideas?
Mitzi
-mike
Can anyone help. Thanks
http://www.frostfighter.com/
TKS, John
I'll guess its frozen right at the nozzle. The tank and the lines have larger quatities of fluid in them and are probably OK. The nozzles sometimes gets water on and in them from the melting snow and ice.
Most blue washer fluid should be good down to at least -20. It didn't freeze in mine the past week and we had -18 in Minneapolis. However one nozzle froze. I held my thumb on it for about 20 seconds and thawed the ice of the top of the hole. It worked fine after that.
Subaru does need to use a stonger pump too. At 65 mph the fluid hardly makes it to my windshield, because of the wind.
Have you disconnected the lines from the reservoir end and blown through the line while still attached to the nozzles? I agree that it does sound like a pump problem - I find it very rare when both front nozzles will freeze simultaneously. Sometimes at less than -20F temperatures I will see one nozzle stop and the other perhaps spray erratically, but usually it is just erratic spray from one and the other works fine.
Grab your keyless fob, and hit unlock/lock for a few cycles. That should stop it.
-juice
Does it only happen when the steering wheel is fully turned one way or the other?
If Yes, then it could be the tires are too big and are rubbing when fully turned.
It could also be a CV-Joint problem although I doubt that as the trans should overpower that.
Could be a torque converter problem, but you don't mention any other slippage which would indicate a shifting or transmission problem.
-mike
You don't notice locked diffs driving in a straight line because all the wheels are traveling at very close to the same speed.
I'm not positive I'm right or anything, but from your description it sounds like a limited slip differential thats locked when it shouldn't be.
The LSD can't lock really as they are viscous coupled LSDs and wouldn't really be any tighter than they are set at. A broken diffy though could be acting like a locked diffy if they blew up the diffy.
-mike
So, I replaced the cat myself and never got around to resolving the Evap issue. Meanwhile, whenever I fill my car up with gas, I have to push the accelerator a bit to get the car to turn over. This only happens when I fill up, and I never overfill.
Most recently, my car began to randomly lose power; almost as if there was a governor not letting it go above 60. It will lurch and sometimes pop (a misfire), but it quickly goes away.
I went in and retrieved the latest batch of codes. In addition to the two original codes, i now have:
P0302 Cylinder 2 Misfire
P0304 Cylinder 4 Misfire
P0171 System Too Lean
P0130 O2 Sensor Circuit malfunction (bank 1, sensor 1)
I did some research and it sounded like the ERG valve could cause the problems. However, it seems like the 2000 Legacy does not have an ERG valve. Someone also suggested that I try cleaning the Mass Air Flow Sensor.
I replaced my plugs and wires last spring. So if anyone has any help, I could sure use it. Also, why did the Cat code not clear out if I replaced it?
Bill
-Mike
any thoughts? i have it a shop now. thanks.
http://townhall-talk.edmunds.com/direct/view/.f117262/0
it prompted me to check up on my most recent oil change. With the person doing the change not first knowing how to get my hood open, to actually cutting my hatch latch to the oil filter, I am wondering if the probability of him doing the same exact thing is fairly high.
I checked my oil first, and it is dark, and over full. Getting nervous, I checked the front diffy oil, (couldnt locate it initially with our sleet and ice), and see the level between low and full, but my car is on a downward slope. This oil is lighter.
I had the change a month ago, and have since driven 1013 miles. If the same mistake was taken, would the damage already have reared its head? Is it safe enough to drive to the place? Am I correct in assuming that the only way to add more oil to it is through that small opening where the dipstick lie?
-mike
