Lexus SC 430
INTERIOR: i see mixed opinions on these boards. a leather cleaner and conditioner. someone suggested an all in one type. as a female, i was raised knowing fully well that shampoos that had conditioner included were very bogus, and am thinking its very similar to interior leather cleaner with conditioner built in. can anyone suggest a good leather care for the Ecru color?
There are a lot of good leather products out there. I use HIDEFOOD, which is a rich cream. Some people don't like it because it takes time to work into the leather and being organic it can spoil over time. But it looks great if you follow directions and plan to spend an hour doing up the whole car. This product might be hard to find but you can always get it at a Jaguar dealer. I bet the Lexus dealer sells it too, come to think of it.
The ZAINO people (Church of Zaino) are over in our "Maintenance and Repair" Board, which you can find by using our drop down window to the left, where it says "Select a Board".
thanks for your help Leo-K
You can rotate the tires and the pressure sensor will continue to work.
There is a pressure sensor and transmitter in each rim. The receiver reads the pressure as transmitted from the wheel regardless of which position it is in.
I hope you understand my explanation. So just go ahead and rotate the tires and everything will work properly.
The only real problem comes in when you install new tires. Whoever does the installation has to know how to install the tires and retain the integrity of the pressure sensors.
Ron
Leo-K
The Volvo convertible is a nice car, but when I look at a red SC430 photo on eBay, it is just not the same.
And, as everyone has said, repairing complex modern cars out of warranty is not a pleasant prospect, so you have to hedge against this by paying way under 'book' value.
Basically you have to "steal' this car to make it work for you I think.
Peter Egan had an excellent article in Road & Track several months ago where he said he may never own a car newer than 1975 because he never got comfortable with the complicated electrical systems in modern cars. Some of these newer cars might not be worth fixing in the future if they have a major electrical failure even if the drivetrain and body are perfect.
I only have 10,000 mls on them lots of tread.
Also there are two kinds of plugs solid rubber and the stringy kind which one is better?
Thank you very much Leo-K
I appreciate it very much. Leo-K
On the issue of a high milage SC430 I'm not so sure that it wouldn't be such a bad deal at the right price since in 2-3 years of use the top mechanism and other parts probably wouldn't have had more use than in a lower milage vehicle.
I dont know what dealer you use, but the service at Jaguar in Carlisle, PA generally sucks. My cars have sat there for more than a week several times waiting for parts, and one salesman acted like he was doing me a personal favor giving me his crappy Taurus as a loaner because the car wasnt ready after they had called saying it was ready. Quite different compared to Rahal Lexus in the same area, which has excellent service.
I'm not a fan of pretty much all of Jaguars current line up other than the XK which is amazingly still a gorgeous and fresh looking car despite the fact that it dates back to '97 (and its underpinnings date back 35 years). I've heard good things about the new XJ sedan, but havent gotten a chance for a test drive yet. The one thing that does dissapoint me is that interior materials quality and finish in Jaguars has gone WAY down since the Ford take over. The X-type feels cheap, and the first generation S-type was simply an embarrasment. The XK is a little better, but it pales compared to a '96 XJS, which had leather and wood that could qualify for Aston Martin duty.
Jag is in the red again this year, and Ford has closed the historic Conventry plant in an effort to make the company profitable, so I believe that means Jags will not be built in England anymore. I hope Ford does not do to them what GM has done to Saab, which doesnt have a single Swedish bone left in its body.
Thank you in advance!
1. Overall, wouldn't new non run flats still ride better and be less noisy than say the new Dunlop run flats?
2. In looking at Tire Rack's ratings, the Goodyear Eagle F1 GS-D3 and the Michelin Pilot Sport PS2 are the top rated tires for best ride and low noise, which are the most important qualities I am looking for. (I think these are non run flats and may be Y rated, which would be plenty safe for my driving) Anyone have any comments or experience with these tires?
Any other comments would be welcome. Seems tires are the hottest topic and all the experience shared here is great. I love my SC, I just want a better ride and less road noise. Thanks.
This is an annoying problem I have also experienced by accident. Below the volume controls on the steering column is another switch. I am not sure but I believe it is labeled "Set". You pull this button towards you and hold it to "set" the audio volume at current listening volume. If this is accidentally depressed at a high volume, it will default to that ear piercing, speaker busting volume every time you accidentally brush up against it. You need to reset it by holding it at a lower volume. That should solve the problem. Good luck....you won't need ear plugs any longer
Kevin
He said they're a hard ride
Another dealer said most take them off.
Today's dealer disagreed with that though.
Ken
For 05 the SC has reduced spring rates(softer ride) and shocks. This has improved the ride somewhat. Other than those changes the car is the same.
As for myself, I plan to go to Michelin RFT's. I have heard good things about them especially about the ride. I would like to go to a normal tire, but like you I don't want to run around without a spare and sacrifice anymore trunk space.
Ron
200-days supply languishing on dealer lots.
Caddy will offer no new discounts/incentives at this time. They do not want to tarnish the Flagship's image.
DrFill
One dealer in Boston area was recently offering '05 XLR at $4800 off MSRP. That's a start.
While the exterior of the SC isn't (IMHO) its strong suit, the interior (esp. in Saddle) is just gorgeous (but NOT in ecru!).
Shifting back on topic, I thought the SC430 would get a facelift this year and a entry-level 6-cylinder model of some sort? Dr Fill?
M
M
Dealer helplessly changed whole Mark Levinson system once and amplifier twice, - didn't do any good.
Hey, let me know if anyone has same problem or better yet solution to it. Thanks for your time in advance.
Anyhow, the tires were fine on dry, smooth roads, but anything else and you're fighting to control the car, especially on grooved surfaces.
Researched and talked to lots of people over the past 6 months. Finally settled on Pirelli PZero Nero's (non-runflats) purchased from Larry at TireRack. They drop-shipped to my Lexus dealer for $50. and the dealer put them on for $150(need a special machine). In Colorado, I need a tire that performs in the wet and won't run and hide if there's a little snow on the ground. I now have that.
Among the many positives from this switch:
1)Better handling (yes, a sidewall with a little give to it will out perform most runflats; 2)No more jaw-jarring from going over bumps; 3)No more tramlining(at least it wouldn't when I tried to make it do so); 4)Smoother, quieter, more predictable ride); 5) Estimated life of 22-35K miles instead of 10-15K miles; 6) Don't have to be discarded if they go flat (which is what most Lexus dealers will do with your runflats - I asked)
The only negative - I now have 2 cans of "runflat", a small (6") inexpensive portable air compressor and a tire patch kit in my trunk. I also have AAA and a cellphone if I run into something unusual.
The BEST PART??? You can almost buy 2 of these Pirellis for every 1 of the runflats!!! Yes, that's right - I paid $600. plus $50 shipping for all 4 tires!!
Do your dental work, kidneys and nerves a favor - ditch your runflats as soon as you can and put some real performance tires on your SC! (This is probably the best auto improvement I've made in 20 years - the car as now a REAL pleasure to drive as I don't have to search for open, smooth patches of road all the time)
Incidentally, these Pirellis are not slouches in the performance department - led Tirerack's ULTRA HIGH PERFORMANCE ALL-SEASON customer survey. You can pay more (michelin, et al), but at least for my application, there is not a better tire available at ANY price!!
Hope this helps those of you still on the fence and getting beaten up by your runflats!! (and NO, I have no connection whatsoever to Pirelli or Tirerack)
Fplanner2000
Do you
