Visitor Agreement.
Did you figure out what was wrong with your Echo? Mine is doing the same stalling business. Its completely random - maybe once a week, after the first stop I come to when the car is still cold it feels almost like it loses power for a few seconds, then it's usually fine for the rest of the day.
It might be something as simple as your tire rubbing on a piece of plastic (like the mudflap maybe?) inside the wheel well. It could be brought about by the suspension compressing in a turn one way versus the other until now something's come loose enough that it rubs even in a straight line. It would only be unloaded by turning to the left when the suspension rises enough to keep the tire from touching.
As bad as it sounds, it's probably not apparently obvious, it doesn't hurt the tire much, it just sounds really loud. Kniesl's (sp?) advice is good though too. If you look and can't see anything touching, check out the CV joints in the front. Sound can travel in a car and you may hear it coming from one place even though it's happening somewhere else.
The difference in the amount of light at night is noticeable. Not bad for $10 and 15 minutes. :-)
I'm looking for a wiring diagram of a 2001 echo tailight wiring, the area were to tap in a trailer wiring harness, i know about the plug in one's, but my trailer has separate turn and brake ( like the car), need color code for wires at the tailight connector in the trunk behind the drivers side trunk liner panel.
If anyone has this info? it would be greatly appreicated.
Thanks Tyler ( 2001 echo 4d sedan )
I just pray its not the tranny!
Thanks all....
My mileage is about 165,000.
Now it goes well again.
Cheers
Stan
Lately, especially starting up in cold weather, the chirping has been joined by a hideous squeal. The squeal is terrible during the first 30 seconds of use in the morning (it's bad when turning the steering wheel) and then abruptly stops.
I've narrowed the chirping noise down to the AC clutch when it's engaged, but the squealing has me baffled. I've had the belts checked out twice in the last year and have been told they're OK.
Would a faulty clutch cause the squealing? Is it as simple as tightening the serp belt?
Any help would be greatly appreciated!
Stan
I ran the car cold today -- after it sat for five hours in the 32-degree cold -- and drove it home without any heat and the fan off ... no squeal, not even on turns.
I'm going to let it sit overnight and fire it up again in the cold of the morning without the heater. If there's no squeal, then I'm thinking it's that clutch.
Any thoughts?
thx,
I used to have and 87 Celica and after about 12 years or so the windows started leaking in heavy rain. All I could do was hope for some sunny days and let the car sit with the windows open to dry out and even then when it got humid it never really did.
I think part of the issue is modern cars seal up pretty tight, so if there's a weather or temperature change outside, they still have the old conditions inside. If it's warm and humid and a front comes through and cools down the temp outside, your car will stay warm and humid until you equalize.
I've actually started parking my Echo in the garage with the windows cracked. This allows the car to stabilize a bit since our garage will change temp with the outside.
So are there any 2003 Echo maintanence manuals out there I can buy that will assist me in doing this work, and perhaps other types of minor maintanence work also?
thanks,
drummer
Platinum plugs have a very serious drawback. If you leave them in for 100,000 miles (thats how long the wifes Camry service manaul says they are good for) when you go to take them out they can be corroded in there! You cant get them out without stripping the threads! Not so good after all are they? I take them out of the Camry every two years and clean the carbon off the threads and re instal them. So whats the advantage? Regular plugs you can get for 99 cents each. What are those platinum plugs $8 each? Thats $32 for 100k miles while regular plugs would cost about $12 over the same lenth of time. And if you want to get lazy and just leave them in there you might have a problem. BIG problem!
