Quick Links
See Official Rules for eligibility and other requirements.
MODERATOR --Need help with anything? Click on my name!
Share Your Vehicle Reviews Here
I'm looking for a wiring diagram of a 2001 echo tailight wiring, the area were to tap in a trailer wiring harness, i know about the plug in one's, but my trailer has separate turn and brake ( like the car), need color code for wires at the tailight connector in the trunk behind the drivers side trunk liner panel.
If anyone has this info? it would be greatly appreicated.
Thanks Tyler ( 2001 echo 4d sedan )
I just pray its not the tranny!
Thanks all....
My mileage is about 165,000.
Now it goes well again.
Cheers
Stan
Lately, especially starting up in cold weather, the chirping has been joined by a hideous squeal. The squeal is terrible during the first 30 seconds of use in the morning (it's bad when turning the steering wheel) and then abruptly stops.
I've narrowed the chirping noise down to the AC clutch when it's engaged, but the squealing has me baffled. I've had the belts checked out twice in the last year and have been told they're OK.
Would a faulty clutch cause the squealing? Is it as simple as tightening the serp belt?
Any help would be greatly appreciated!
Stan
I ran the car cold today -- after it sat for five hours in the 32-degree cold -- and drove it home without any heat and the fan off ... no squeal, not even on turns.
I'm going to let it sit overnight and fire it up again in the cold of the morning without the heater. If there's no squeal, then I'm thinking it's that clutch.
Any thoughts?
