Toyota Echo Maintenance and Repair
11314151618
    squealing means that the belt is slipping--so either it's the wrong belt or they didn't adjust it using the right tools.
    As for the ticking noise, that's not really specific enough to pin anything down. You need to have a mechanic ride with you, or drive the car. Ticking and rumbling are such different phenomena that it's hard to make sense of it.
  • kneisl1kneisl1 Member Posts: 1,694
    It could also be the bearings in the alternator water pump or even the ac are bad. If you can remove the belts and spin those pulleys by hand you might find bad bearings.
    That happened to my sons ECHO and it was bad alternator bearings.
    Good luck and tell us what happens!
    Well that's a very good observation! It's possible that an alternator or AC compressor is dragging so badly due to bad bearings (hence the noise) that it could be causing the belt to slip as well. The two problems (slippage, noise) might be connected. Worth looking into.
  • pohhoppohhop Member Posts: 1
    Hi
    my friend as an 2004 1.4 echo.
    starting up on idle is sounds likes it's missing, put a few rev on runs smooth. On idle, is sounds like a valves though it's an automatic adjuster loosing pressure, at the exhaust it's chuffing like the mixture is out, not a constant hum.
    He also complains that sometime when he puts the A/c on it stalls the engine. I've never been there when it's done this.
    1. Are they auto tappet adjusters?
    2. how do you adjust the air mixture?
    3. could it be an injector?
    any other ideas. please.
    thanks.
    yes the valves are adjustable on that car. It wouldn't be expensive to CHECK the clearances but it's a bit of labor (over 6 hours) to shim each valve. Your friend should get a quote for this job.
    Possible idle roughness could be a defective Idle Air Control valve (IAC), or just a vacuum leak somewhere.
    If gas mileage has dropped a lot, there could also be an EGR system problem to cause this rough idle.
    Unplug the injectors one at a time with the engine running. If the engine doesnt run any different, that injector is BAD. If it runs good the injector is GOOD. Do each one one at a time until you have tested them all.
    Let us know what you find out and Good Luck!
    Please disregard the previous two posts by me. Its hot here and I wasnt thinking too good.
    Start the engine. It is running unevenly right? One at a time, unplug the injectors. If after unplugging one of them, the engine runs WORSE, you just unplugged a GOOD injector. Keep going until you unplug an injector and it doesnt run any different. It still runs unevenly just as it has been. You should have three injectors which make the engine run WORSE when you unplug them and one when it doesnt run any different.
    THATS the bad one.
    If one is bad.
  • polo79polo79 Member Posts: 1
    Hi all, I have a 2000 2dr echo with a manual sun roof, the problem is that the handle to open and close the sun roof isn't working. Has anyone had this problem before?
  • hannahrene23hannahrene23 Member Posts: 1
    I have at 2003 Toyota Echo. It keeps not starting. Sometimes it will start, sometimes it won't. When I turn the key, nothing happens. All the lights come on, the air comes on, but it doesn't click or act like it wants to start. Sometimes if I switch the car into Drive while it is off and then back into Park it will turn on, sometimes it won't. The battery, starter, and ignition switch and fuses have all been checked and they are all fine. I did some research and I'm thinking it might be the Neutral Safety Switch, but could it be anything else?
    I had a VW FOX that did this. The probelm was the relay for the fuel pump. It worked intermittently, causing the very same problem you mention. I will ask elsewhere if this could happen to the ECHO and get back to you.
    neutral safety switch is a definite possibility, given your symptoms or a misaligned gearshift mechanism.
    Echo was not available with a factory sunroof, so I have not had the problem you describe. However, you could try visiting a place that installs aftermarket sunroofs and see if they have any suggestions for you.
    had replacement of brake pads done at Wheel Works before?
    No not me.
    Next to oil change a very DIY thing.
    who has my Echo now had the front brake pads replaced there yesterday. I hope it turns out OK. He saw a $99 coupon, but of course the coupon fails to include the turning of the rotors for another $79. Deceptive advertising practices, it seems to me.
    Those front brake pads made it to 177K miles before needing replacement - they had never been done prior to that. One of the benefits of a stick shift (and a driving pattern that includes a lot of highway miles). :-)
    edited September 2012
    Awesome nippononly!
    Couldnt have done it better myself! 177k WOW!
    Turning rotors unnecessary however. ESPECIALLY they way you drive.
    Keep an eye on that guy who now drives YOUR ECHO!
    I sure will. :-)
    The reality is he will probably need to drive that thing at least another two years, so he will probably drive it past the 200K mark. If so, I will stick a note in here. ;-)
  • mykimyki Member Posts: 2
    Hi I just want to know How much i can sell my toyota echo hatchback 2004
    brand new front brake , manual transmission, 3 doors, 136000 kl ::
  • Kirstie_HKirstie_H Administrator Posts: 11,257
    Please visit our Real World Trade-In Values discussion. Be sure to provide information about the condition of the vehicle and where you are located.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • echofanechofan Member Posts: 20
    Seems like most of the Echos out there are 10 or more years old. Mine is an '02 with 105k, and the only things replaced so far are spark plugs and one belt.
    I'd be interested to hear from people with higher mileage, about what they've had to replace, and when. Water pump? Alternator or starter? CV joints? Stuff like that.
    Anybody had to adjust valve clearance? At about 80k, a couple of my exhaust valves were within about 2 thousandths of the minimum so I'm wondering if I'll need to mess with that soon.
    Love this car, and would like to keep it as long as possible!
  • jmrbkjmrbk Member Posts: 18
    I don't remember all the details (when, how many miles) on what I've replaced, but I have a 2002 sedan, purchased new on 12/12/01. I presently have just shy of 114,000 miles. I had to replace the alternator about a year ago and have replaced the battery twice. I had to replace the struts twice early on in the life of the car. Once it was covered by the warranty but I think the second time I had to pay for it.
    All in all it's been a great car for me and I do love it. I am starting to become tempted to get something new though, but not having car payments for the last 6-7 years sure has been nice!
    Thanks for the info. Just to clarify my earlier post, I bought the car in August '10 with 68k miles, so there may have been other parts changed before that (pretty sure the brake pads are not original, for example).
    edited October 2012
    When I replaced my '02 this year, it had about 170K miles. I had never repaired anything.
    It was on its third battery by then though, also the third set of tires, third set of spark plugs. I had never had to replace brake pads or the clutch. I gave the car to a friend, who did have to replace the front brake pads a couple of months ago, at about 175K.
    Apart from that, ummm?? I replaced the drive belts once. Fluids and air filters certainly came and went a bunch of times over the years. I never checked the valve clearance, and it was never a problem that I didn't. Never did the water pump, alternator, starter, or CV joints - those were all original when my friend took it.
    If you want a car that will run forever with the absolute minimum of attention, I think you have found it with the Echo!
    My sons 2000 has ~ 180k on it. New belts. New brakes (once) Air filters, oil changes. No valve adjustments. Couple of CELs. New MAF fixed that MAF common to fail. Current CEL. Dont know what it is.
    Nothing else. Son and GF have driven to Seattle and back from NJ the past two summers.
    I bought the car for them five or six years ago for $3000 with 117k miles.
    brand new front brake ,rotor ,pads, JUNE 2012
    oil service + inspection,
    replace drivebelt
    replace front exhaust gasket
    136k
    Ya it's a very good car still have the original battery and no problem in winter
    no big repare on this car
    love toyota
    they are good
    Thanks for the replies. Have been making 500 mi round trips for work every other week. Sometimes wondered if I oughta just go ahead and replace a few things, to reduce the chance of having to fix something in a parking lot far from home.
    But I think I'm about convinced that my odds are pretty good for now, so I'll just keep driving! Of course, I do the basics, like oil and filters, and I did change the transmission fluid & screen last year. But the only thing that has broken so far is a couple of cracked hubcaps. I can live with that!
    Replacing perfectly good parts on a vehicle just because you are paranoid isnt going to save you from inconvience its just going to cost you $$$$.
    Now, if you could accurately determine whats going to fail youd be on to something. ; )
  • untrapableuntrapable Member Posts: 4
    Hello.I have a 2001 ECHO sedan 5 speed.145,000 kilometers.The clutch all of a sudden has become very lite in feel,like it's losing pressure.Seems to drive okay.No lights on.
    Any idea's?I also have the engine shake sometime's at idle.Motor mounts?And intermitten squeling or chirping also.When clutch is engaged it goes away,but when clutch is released it comes back.
    I just bought the car 2500 bucks ,safety e-tested,no claimed accidents.original miliage on engine.
    Please help. I heard the clutch is lite in the ECHO but it seemed tighter when i first got it.
    thank you Bryan in Ontario Canada
    Squealing when the clutch is released (in neutral) sounds like a pilot bearing going bad. When you replace the clutch that can be replaced at the same time for the price of the part.
    If you meant squealing when the clutch is released in gear and the car begins to move, that would be different.
    As for increasing lightness of the clutch, you will know when it is not properly releasing any more because the gears will begin to grind as you engage them with the stick shift.
    A lot of what you describe could be attributed to a failing clutch.
    Yes the squeling disapears in neutral when clutch is lightly engaged.When going through the gears it seems fine.No grinds or anything in any gears.I don't wanna increase the lightness of my clutch.
    I meant that its to light of a feel.Its like a drum pedal for a set of drums.I mean thats pretty light feel.
    It seemed the clutch was tighter when first getting the car,so thats indicating a problem to me.
    But maybe the car wasnt driven much before I got it.Sittin on the lot.
    Any other input would be great thanks.:)
    As long as the clutch doesnt slip under acceleration its 95% allright.
    As long s the gears shift quietly ditto.
    I think you are fine!
  • dfree1dfree1 Member Posts: 5
    Great little commuter car. I drive about 95 miles round trip total each day and still get about 40 MPG going 70-75 on a car with 220,000 miles.
    I did a full exhaust due to aftermarket cat converter (bad at 140K) not matching OEM muffler (go figure, I got to due the muffler also). The replacement Bosal muffler had a bad seam that I thought was the connection to the cat so went to the shop. Went to Menike and they showed me the bad seam for free and I drove to AZ and they ordered a replacement. I reinstalled the replacement and still could not get the joint to seal so I went to Menike again and had them cut and weld. 80K later I got a engine code showing possible cat failure. Up and downstream O2's replaced with previous cat. Got a new cat via warranty replacement. Installed and codes cleared, I could see evidence of seam failure on the cat by the residue.
    New platinum plugs about a year back.
    Oil change every 3 - 5 K.
    Air filter, engine and cabin, once a year.
    Brakes front about every other year (bought a spare set of rotors for a half-hour driveway break swap), Rear first time just a couple of months back.
    Clutch still nice and tight.
    Dave
    How many miles between front brake pad changes? It sounds to me like you are replacing them very frequently. Which means you are using the brakes too much.
    Im afraid you will have an accident driving like that.
    That's a lot of miles - hope mine gets that far without too much trouble. I'd be thrilled to own a car for that long, where the worst thing that ever happened is exhaust system problems.
    Jay
    Owning an ECHO is a huge thrill, certainly!
    Maybe the biggest in the industry and not just for longevity.
  • classicsplayerclassicsplayer Member Posts: 3
    I recently bought an 01' Echo with 132000 miles on it and am finding expensive problems.
    Rear Shocks
    Motor Mounts
    Rear Brakes including rotors.
    rear speakers
    Hope that I don't find too many more problems
    What did you pay for it?
    ECHOs have drums on the rear.
    Hows the gas mileage?
    Aside from the speakers, those sound like normal wear items for a high mileage car. Not the car's fault really--more about poor maintenance. Brakes can be done at 50K, shocks at 80K, motor mounts at 100K.
  • aries65aries65 Member Posts: 7
    I have a 2001 Echo with about 114,000 miles on it (yeah, I don't have that long of a commute!). I'm going to be needing to change out the shocks/struts in the rear due to a lot of squeaking going on. Has anyone gotten this done recently on their Echo - and how much did you pay for it?
    Also, my front speakers have a loose connection somewhere since sometimes they'll come on. I'm only getting sound in the back. Is this a quick and easy fix - or will I have to pay some big money to get this fixed?
    TIA!
    If you have a garage and a few tools you can do it yourself for only the cost of the shocks.
    The hardest part is accessing the top bolts located under the Rear deck. You will need a good long extension for your socket wrench.
    I did mine in under an hour.
    I do not recall the cost but under eighty for two shocks and bellows from AZ or AA.
    Dave
    Appreciate the response. I'm not very handy at all. I'll have to pay a garage to do it.
    So, if anyone knows a ball-park figure or maybe just had it done themselves, I'm just curious as to how much this is going to set me back.
  • albusdalbusd Member Posts: 8
    This isn't going to help you figure out how much a shop would charge for your rear shocks, but I am curious how you figured out that they needed changing? I have a 2000 Echo 4-door with about 140k on the clock and have never even thought about changing out suspension components. Is it a really obvious squeaking or has the ride quality become terrible or something?
    And about the speakers, my echo has an aftermarket stereo system/cd player and has the same problem you describe, where going over a bump might cause the front speakers to come for a few seconds and then they go dead again, so I'd be interested in knowing if you find the culprit. For now, given the spartan nature of the Echo, I'm just glad it even has a radio!
    Always glad to hear from other Echo owners out there!
    When I go over a bump, or when I take heavy bags of groceries out of the trunk, I can hear a groaning/squeaking noise coming from the back end. So I'm not sure if it's new shocks I need - if they even have them, or replacing the back struts.
    I've pushed down on the back end to see if it "bounces" - but it doesn't do that.
    Maybe I don't need something changed out? Or maybe I do?
    I've already had the front struts replaced (and bushings), changed out the steering fluid, changed out the front brakes, have had tires replaced, and a tune-up done.
    I was mistaken on the mileage. I've actually only got 104,000 on the car!
    I think with the stereo it may be a loose wire somewhere. I'll be checking out some local auto stereo shops this weekend. I really miss not having that "surround sound" in the car. It's a "treat" when I sometimes I get a day of it when the front speakers decide to pop on! LOL
    My echo is at about 230k miles and I did the rear shocks about 3k miles back. I know the shocks were weak and you could see where the hydraulic fluid was leaking on the side of the shock body.
    After removing the shocks I could compress and extend them by hand. The new ones took more pressure and it was tougher to compress them.
    I am planing on replacing the stock radio and was just looking on line for a replacement. I got the Echo used with about 30k miles on it back in 04 and the previous owner must have damaged the tape player. I had no idea until recently after trying to use a converter with a smartphone to listen to podcasts.
    I had the radio out for some reason a few years back and I recall it has a single large connector.
    You probably need to reseat the connector. As a first check. If it is still glitching you probably need to check for a loose connection at the speakers.
    Dave
    I stopped in at a mechanic today. They took my car out for a test drive, bounced the car on the back, and put it up on the lift to check out everything. He said my struts and shocks are fine! He sprayed some lube on the bushings all under the car and told me to have a nice day - no more squeak and no charge!
    As for the stereo, one of the guys there said it would be best to take it to the Toyota dealership since they have all the schematics for the wiring and all - and would be able to figure out where the loose connections were. So I may have to bite the bullet with that.
    But at least I found a really nice mechanic to go to. They'll be getting my business in the future.
  • cselwitzcselwitz Member Posts: 1
    I have a 2001 Echo, 200k miles. I have had it since it was new. Last week I started it and found gas spraying around inside the hood. The culprit is a hose up against the firewall just under the hood. The hose is rubber exterior, appears to be metal inside. The end nearest the firewall had a squeeze mechanism to release it, the other end has a metal bell shape to is where it connects to a small tube going into the engine. I can't figure out how to release that end of the hose to remove it, nor can I find any reference to what the hose is online to purchase a new one. This is the most accessible and seamingly inexpensive repair I can imagine and it woudl be very frustrating to have to tow the car to a repair shop to complete it
    Anyone have any experience with this?
    No but I will look in my service manual tonite and get back to you.
    Does the hose go to the fuel rail the injectors are on?
    If worst comes to worst tow it to the mechanic. Its too good a car to lose!
    If it was me I would drive it spraying and all to the mechanic if it wasnt too far away. Maybe at night to avoid traffic and delays....
  • ktealkteal Member Posts: 1
    Hi, I'm new here and was hoping someone could help me out. My echos headlights are out of alignment and I was hoping to take care of this myself but have so far been unsuccessful.
    After taking a look at the car and the service manual I am still at a loss. The plastic nobs that were supposed to adjust the headlights seem to have fallen off. I can sort of adjust the lights by pushing or pulling the bit of nob I can grab with pliers, but there has to be a better way that won't be messed up by a bumpy road.
    Anyone know how I can still adjust the headlights without buying a new assembly? or where I can purchase some replacement adjustment nobs?
    My factory service manual for the 2000-2002 models says something like the horizontal direction cannot be adjusted, and you adjust the vertical direction with an adjusting "bolt". It doesn't mention knobs?
    At least one other website says that there is no adjustment since they are set at the factory.
    You could always add a sandbag or two to the trunk to make them point higher... sorry I know that ain't much help.
  • cahtawkcahtawk Member Posts: 1
    I too have a Toyota Echo (4-door sedan). I went to a gas station (Snyders Exxon in Carnegie PA) where they replaced the sensor, the engine line went on 5 minutes after driving it away from there, and when I returned it to them they persisted in claiming that my gas cap wasn't on tight enough. Long story short, I went back to get my car inspected and they are now claiming I need a catalytic converter. Which is hilarious considering they made this claim with the previous car I had. Whatever you do, don't go to anyone but a Toyota Repair place. And don't ever go to a gas sta/repair place unless you just want your tires rotated or an oil change. And check your oil after they change it out because they might forget to put some back in after draining your car.
    They charged me $60 for the so-called "inspection" and left it as not passed and got belligerent with me when I tried to explain to them that the engine light has been on because of their not correcting a bad installation of this particular part.
    Go to a Toyota repair place before a minor repair becomes a deliberate misinformation campaign conducted by mechanics that can't ably work on today's cars.
