Honda Odyssey 1999 - 2004
14647495152137
  • pat84pat84 Member Posts: 817
    I have the factory cross bars on my EX. I also use a Sears Turtle Top when I go on vacation. The tool to adjust the factory rack cross bars is a Torx star bit. I already had it in my tool box. I would recommend you get a set of Torx bits.
    The way Honda designed their factory rack adjustments makes Daimler Chrysler engineers look like geniuses. Of course they also came up with a POS tranny.
  • cavillercaviller Member Posts: 331
    I'd provide the direct link to save space, but it's from another forum and would be a violation of Edmund's TOS. SO, here it is:
    The topic comes up now and then, so here's a list of features on the 2001 EX which are not on the 2001 LX. Honda charges an additional US$2500 for the EX. I put an * by those that have Honda OEM or identical replacement versions which can be purchased for the LX:
    Power Sliding Doors, Automatic Climate Control (LX has dual-zone manual heat/AC), Power Driver's seat (LX has 6-way manual driver's seat), Upgraded fabric, Heat-rejecting/reflecting tinted glass (LX has standard tinted glass), Steering wheel audio controls, Auto-off headlights, Homelink remote system, Driver's seat and 2nd row seat-back pockets, Body color trim and mirrors (LX has black trim&mirrors), NAVI (optional), Dash mounted tweeters, Storage tray under Passenger seat*, Cargo Net*, Security System with Remote Keyless Entry*, Alloy wheels*, CD player* (LX has cassette), Roof Rails*, Michelin Symmetry tires* (LX has Firestones), Grab Handles behind 2nd row seats, Center storage box light.
    Also, there are some features on Canadian models not available in the US including a larger wiper fluid tank and low fluid indicator, heated outside mirrors, Daytime Running Lights, and gauges with metric calibration. US buyers of Canadian-spec Odysseys should be aware that there is no Honda warranty, usually only an aftermarket dealer-supplied warranty. Otherwise, these vehicles are essentially identical, and built in the same plant on the same assembly line.
    The EX is about 40 lbs. heavier (69 lbs. with NAVI). The EX is also 1.2" taller due to the roof rack. Clearly, weight and aerodynamics favor the LX in a quarter-mile run:-). Note, this list applies to 2001 models. Earlier models may vary. I believe pre-2001 LX models did not include floormats or traction control, while pre-2001 EX models did not include the security system, for example. Some links with more complete lists of features:
    http://www.honda2001.com/models/odyssey/features.html
    http://english.honda.ca/models/odyssey_features.asp
    Also, I posted a review of my preferences for going with the LX:
    http://www.epinions.com/content_7063506564/tk_~CB001.1.25
    To each their own!
  • rogerberkowitzrogerberkowitz Member Posts: 31
    We opted for the Honda crossbars since they were roughly the same price as Thule or Yakima, and look better when they are left of the van unused. Probably would have gotten more utility out of the aftermarket bars though. For carrying cargo, I bought a Thule Mountaineer (I think it's about 16 cubic feet). We've used it primarily on camping trips to hold the bulky items like the tent, sleeping bags, etc. The heavy stuff stays inside the Ody.
    The latest issue of Consumer Reports looked at various cargo boxes. The Sears is referred to as a luggage box, while there are various categories of Thules, Yakimas and others.
  • nathan7nathan7 Member Posts: 4
    I have an '01 Odyssey EX, and want to tow 3 ATVs on an open trailer, not too far, and and probably no more than 2500lbs. I was going to get a Tru-cool transmission cooler ($53 for the Class II at www.accessconnect.com/oilcoolers.htm ), to go with a Hidden Hitch, because it's so much less than the Honda cooler, which is still $170 on the web. It's also a very different design. 2 questions:
    1) Does anyone know if Honda's (tiny-looking) trans cooler is really better, or worse, then a 3rd party one?
    2) Do I affect my warranty by letting a non-Honda shop install a non-Honda transmission cooler? (I doubt Honda dealer would install a non-Honda unit.)
    Thanks, Nathan
  • hj_houdinihj_houdini Member Posts: 4
    I have a Y2K dark emerald pearl Odyssey EX with 14k miles. The van just got through it's first Wisconsin winter. I've finally been able to hand wash it again and have noticed many small "pock" marks on the lower half of the doors beneath the rub strip. It's almost like dirt embedded in the paint, but some of the spots show the appearance of rust beginning to form.
    I'm wondering if I got a bad paint job or if it's just a result of winter driving. I've never seen this on any other cars I've owned. And I'm pretty religious about regularly washing it to keep the dirt and salt off.
    I haven't taken it back to the dealer yet. I'll probably first take it to a professional detail shop to see what they can do. I'm also considering getting some Zaino clay to see what that would do.
    Has anyone else seen this problem or have some additional advice?
    Thanks in advance.
  • cebrencebren Member Posts: 7
    Neither of my Accessory Power Sockets are working. Can someone please tell me the location of the fuse that controls them? I find no mention of the fuse for these sockets on pages 311-316 of my owner's manual. It lists four separate fuse boxes with each fuse numbered, but no mention of which is for the acc. power sockets.
    Also, what happened to the bookmark accessing feature of this site? I can't seem to locate the many bookmarked items I had saved. Thanks.
    If you marked a message, it should be listed under Message Center (listed under "Bookmarks" there) when you click that button. It they aren't there, then you can file a bug report using the Online Support button and get some "real" help.
    Steve
    LOL "What we've got here, is a failure to communicate," Steve. The entire format of this site apparently has changed since I bookmarked about 50 postings last year. None of them are listed under the topics you mentioned. As I recall, there was a separate Bookmark tab but it seems to have disappeared.
    Well, we did a big switch to new software back around December. I guess that's when we dumped your old bookmarks. fwiw, I use "Read Subscriptions" to keep track of discussions I want to read and the "Mark" button to bookmark specific messages. Hope this helps.
    Steve
    Well I took my van to a detail shop and found out my problem. It's actually brake dust that is embedded in the clear coat. So the van is not rusting, just the flakes of metal from the brakes. Sounds like this is a very common problem on vehicles since they went away from asbestos brakes. The Ody has such open wheels that it allows even more dust to get out.
    So for $170 the detail shop will completely clean, clay, and add a paint protector. They also suggested installing dust covers. Several high end cars like BMWs and Lincolns already come with dust covers. For $130 I can get a set installed on all the wheels. Essentially they press fit on the inside of the wheel. This way the dust can't get out. And they're vented to help cool the brakes.
    Has anyone else installed dust covers? How do they look?
  • drew_drew_ Member Posts: 3,382
    BMWs do not come with brake dust covers, and neither do Mercedes-Benzs. In fact, they strongly recommend against installing those and may even void your warranty if you do since they really restrict the airflow to the brakes (despite what they may tell you about venting), and can warp the rotors. If the solution was so easy, all of the manufacturers would be including dust covers already. When designing the design of the wheels, manufacturers take into account the aerodynamics and air flow. The more air the cooler the brakes and the better the performance since there little or no brake fade.
    Drew
  • dmathews3dmathews3 Member Posts: 1,739
    You do realize that they only work when the key is on. I don't have access to my van right now but I found them when I accidently blew the fuse to them myself. It's in the fuse box on the passenger side as I remember.
    Thanks for your posts. I noticed the same thing on my 99 DEP EX at the end of this winter (Twin Cities MN). After a couple of months of weekly washings, I havent noticed if the blemishes are still there or not.
  • PeejPeej Member Posts: 1
    I recently purchased the Odyssey EX ( 3 weeks ago) and so far thru 2 full tanks of gas I have not come anywhere close the estimated gas mileage. I have only beeb getting about 15mpg highway at best. Has anyone else experienced this, and if so, is there anything that can be done about it? Otherwise I love the vehicle..........
  • richcolorichcolo Member Posts: 81
    15 MPG? Wow! That would be disheartening. We live in a very small town, so nearly every trip is at least 20 miles, to a nearby "city". We have almost always achieved at least 20 MPG. The all time lowest was about 17 MPG, but that involved hauling a full load of people, quite a bit of stop and go traffic, and more than an hour of idling while parked with the A/C going. On the highway I have gotten as high as 28 MPG, but only once. Typically we're getting 20 - 21 MPG on Colorado's oxygenated gas in the winter, and 21 - 23 MPG on "real" gas in the summer, and 25 or a little better on trips.
    I think that you have a problem if you are only getting 15 on the highway. I have read posts mentioning numbers as low as 14 MPG, which I did not find alarming because the authors indicated it was for city driving and short trips, but 15 MPG on the highway, I would definitely discuss it with the service writer at the dealer.
  • rockycowrockycow Member Posts: 114
    Thanks for your posts regarding roof rack and carriers - really helped
    rocky cow
    Once again: Neither of my Accessory Power Sockets are working. Can someone please tell me the location of the fuse that controls them? I find no mention of the fuse for these sockets on pages 311-316 of my owner's manual. It lists four separate fuse boxes with each fuse numbered, but no mention of which is for the acc. power sockets.
    And yes, I did turn on the ignition switch...they still don't work. There are five fuse boxes and about 55 fuses...I hate to pull each one to find out which is burned out.
    I guess you didn't look very hard. As I said before, it's on the passenger side. I found it in the book in my 01 EX. I just went out there and looked in the back of the book in the index, under fuses and went to the page they said and over about 3 pages it is broke down in 3 sections. Under the hood, drivers side, and passenger side. On the display for passengers side #9 is Acc. Power which is THE ACCESSORY POWER SOCKET! It's a 15amp. and if I remember (which is hard with 2 cars and a motorhome) to keep track of I think there are some spare fuses included, look at the 3 displays and they should tell you.
    So what did you buy?
  • rictomrictom Member Posts: 89
    My LX started out low-- 16-17 or so for the first few tankfulls/couple hundred miles. It really wil get better. Now I average 19-20 in the city. Really haven't taken it on long freeway/highway trips to see if that mileage is better.
    If you get 500 miles or so and still no improvement it would be time to talk to the dealer, assuming you're not trying to break any quarter mile records!
  • ian2ian2 Member Posts: 168
    Our '01 EX got 24mpg on a 500km trip when it was reading 500km on the odometer. I was carring quite a bit of cargo and doing 120km/h most of the way. I can't wait to see the mileage once the car is broken in.
    In city driving, try not to stomp on the gas too much. It will take quite a bit of gas to get a 4300lbs vehicle up to speed rapidly.
    The info on Consumers reports helped my wife decide that she didn't want a roof carrier. So I have to return the crossbars. She promised to pack "light" since 2kids and 5 adults are heading to Mexico from Colorado.
    rockycow
    Wrong; it is not that one. But thanks anyway, dmathews3. Two dealers I called couldn't figure it out either.
  • tedc2tedc2 Member Posts: 1
    I also needed a transmission cooler. after looking at the after market I decided because of warranty and Hondas good reputation C would go with their cooler. this was a good choice! Fit perfectly, instructions were clear. I called hondapartsforyou.com. the girl was helpful, price was reasonable (especially compared to the local dealer) and shipping was free. I understand that if a problem occurs and you have an after market cooler you are not under warranty
  • odyfanodyfan Member Posts: 40
    cebren,
    The fuse you are looking for is on driver side under dash fuse box. It is the 4th red color fuse from the bottom of the box with 7.5A label on it.
    I found it when I was installing my Donnelly mirror.
    Happy driving!
    Looks like they use more than one, if I figure you out it is the ACC relay. I didn't open it as it is tucked up befind everything and must be fun to get at.
  • bg18947bg18947 Member Posts: 184
    1999-2000 Service Manual, page 22-133
    Driver's Under-Dash Fuse/Relay Box - No. 8 (7.5A)WHT/BLK wire from Ignition Switch goes to this use-box location, exits out as YEL/BLK to Passenger fuse box that follows.
    Passenger's Under-Dash Fuse/Relay Box - No.9 (15A)
    YEL wire from Under-Hood Fuse/Relay Box, exits out as WHT/RED wire to Audio Unit/Front Accessory Power Socket/Rear Accessory Power Socket
  • anbthomasanbthomas Member Posts: 3
    I just got on the waiting list for the 2002 Odyssey. I picked the Havisu Blue and like the color. However, I'm a little concerned about the fern interior. Anyone have an opinion on the fern interior and how fern leather might look (be honest)
  • ocuihsocuihs Member Posts: 138
    FYI...Honda released 2.04 May 2001 at $152
    https://esales1.alpine-usa.com/dos/honda/cover_areas_honda.htm
  • ksemehksemeh Member Posts: 3
    Hi anbthomas,
    I havn't seen the color chart yet. Does it really look like a Blue and Green color mix as the name "Havasu" says. I suppose it is a light color. I wish someone post the color chart of 2002 Odyssey.
  • billg7billg7 Member Posts: 342
    The Fern Interior is basically a medium grey color, with a pattern. It has some green in it but that green is hard to see.
    It looks fine to me. I have seen cars with grey leather interior also.
    The Fern interior was in the 2000's and 2001's and I didn't see any complaints on this board. It hides dirt and stains well. You should be able to look at dealers lots and see some cars with that interior to be able to judge for your self
    In my opinion, it's much more blue than green. It's definitely metallic. The closest match that we could find is the Sailfin Blue Pearl on the Toyota Camry. It's probably a little darker. It's really hard to tell from the small square.
    Another change, we did purchase a Thule "excursion 667" got it installed and ready to go on Honda cross bars. The excursion will fit the small round, small square or larger cross bar like the Honda. We head out tomorrow for Mexico on a 4K trip. Let you know how I liked it upon return.
    rockycow
  • minimanminiman Member Posts: 85
    Speaking from experience (I am on my 2nd Odyssey, the first one was yellow and tasted sour), in both vans city MPG 15-17 with most trips 3 to 10 miles, many traffic lights, hills. (We put on under 10k miles per year, so little distance, lots of lights.) Just when I am loosing the faith, we take a highway trip and get 24-25 mpg w/ the van full of gear and people (plus I have a heavy foot). When we really do mixed driving, we can see 20 mpg.
    My V6 sedan (other car) gets 25-26 hwy, filled it up today after city driving, 16.8 mpg.
    That's the physics of traffic and stoplights. Overall, I do not think I can complain about the Honda's mileage. It's a large, and not very aerodymanic vehicle and it's actually great that highway mileage is as good as it is. Many small sedans do only marginally better and accomodate fewer bodies and only 1/100th the gear.
  • gpalmgpalm Member Posts: 7
    Can anybody point me to the post # that references a dealer with a highly competitive Honda Extended Warranty offering.
    When the Odyssey forum first started you could search the entire thread. With this not possible, your help would be appreciated.
    Also, if you can post a URL on a good comparison of Honda Extended Warranty offerings, it would be a great help.
    GP
  • jimblockjimblock Member Posts: 62
    I just bought HondaCare for my 2000 Odyssey EX Navi which is 21 months old and had 19,500 miles on it. I bought the 7year/75000 mi/$0 deductable warranty because we don't drive enough miles to get much beyond 75000 in 7 years.
    Based on my readings on the forum, I checked with 2 on-line sources, and the sent e-mail to the 2 Honda dealers closest to me for their best prices. The best price I found online was $705. One of the local dealers responded to my e-mail within a HALF HOUR by calling. He agreed to meet the $705 price (he said that was only about $100 over his cost). Only downside was that I did have to pay sales tax to a local dealer, but I preferred that to dealing with a dealer out of state.
    The low price I found was from Gregallen Vagnini at Union Park Honda Inc. (Wilmington, Delaware) 302-573-5222 e-mail: <GJV1152@Aol.com>
    The other source I checked (they post prices for all HondaCare variarions) is: http://www.hondawarranty.net/
    As I said, one of my local Lond Island dealers met Gregallen's price so I bought HondaCare from him. The other dealer didn't respond for more than a week and then suggested I call his business manager.
    Here is an excerpt of a previous post about an experience with Gregallen:
    HondaCare Bargin by richcolo  Mar 09, 2001 (10:34 pm)
    As I promised a couple hundred posts ago, he is my experience in dealing with Gregallen Vagnini from Union Park Honda in Wilmington, DE. I e-mailed him at gjv1152@aol.com and asked for a quote for my 1999 EX w/ 32,500 miles, for a 6yr/100,000 miles/$0 deductible HondaCare Warranty. He responded in less than 5 minutes (!) with a quote of $795, and a list of information I would need to e-mail or call him with. I sent the info and he mailed a package to me postmarked the very same day. Unfortunately the application in the package had been filled in with 7yr/100K/$0 for $925--a good price if that's the coverage you want, but it didn't fit for me. I called and left a voicemail for Gregallen, his message indicated that it was his day off. He returned my call and apologized for his mistake the next morning, and got the right application in the mail. I've filled out the application and returned it (with payment) to him. I now expect to receive my receipt from him, and will receive package from Honda with my information in about 45 days. Until then I have a carbon of the application and the contract, and an 800 number at Honda if I need it. I'm a happy camper. BTW, I had checked with my local Honda dealer, and he offered the same warranty to me at $1195, then backed down to $1100 because I bought the ody there, they've done all the service and warranty work, and have botched up getting it done when promised a few times, and because my 3 year old plays with his every week in play group and our wives are friends. When I called to ask if he would like to match $795 he told me "that's a money looser, I'm not in business to loose money, where did you hear this price?" I told him and he asked "Where do you think your going to get it worked on?" I said "At ANY Honda dealer... that's what YOU told me earlier" He very quickly said, "That's right. Be sure you are agreeing to exactly the same thing you asked me about." I reviewed the documents carefully, I'm getting what I want, and I doubt that Union Park is paying just so I'll be a happy customer, I just don't think they are making very much per warranty. I think they are hoping that they will sell many HondaCare contracts at a small markup, while the local guy is worried that he'll not get his markup on the few that he sells if I tell the other folks in town that he sold it to me for less. Well when I tell those folks that Gregallen sold it to me, he (the local) won't even get the small markup from them, will he?
    Sorry to be so long, but I hoped to dispel a myth or two... The price does not seem to increase just because you've exceeded 12,000 or 18,000 miles, or because your van is more than 1 year old. Previous posters have reported increases related to those items, I suspect they had spoken to dealers looking for an "angle" to increase profit. If I turn out to be wrong, and my deal falls apart or increases in price I'll report back for a big helping of crow.
    The Honda Warranty doesn't go up with mileage or age. Why it goes up is lets say you bought it on 10-01-98 and was offered warranty for $700. Now today it is almost 3 years old and the price is now $900. It isn't because van is almost 3 years old, it's because almost 3 years have passed and the price has went up for everybody, no matter how old van is. That is why the myth got started.
  • mburnett70mburnett70 Member Posts: 1
    I'd be interested in knowing how far all of you have taken your Odysseys. Please also tell me about your driving conditions (start/stop or longer commutes/high mileage).
    Mike
  • chip29chip29 Member Posts: 2
    The closest I can describe the color is to look at the previous model Odyssey. There was a light metallic blue used that I'm told by one of the Honda people will closely match the Havasu blue.
    The Redrock Pearl is definitely more red than burgundy. A shame since the MDX burgundy is dark and rich looking. The Evergreen Pearl is lighter than the Emerald Pearl ('99 - '01).
    Colors aside does anyone know when to expect '02's? My guess is early Sept. as that is when the '01's came out. We're first on the list at the dealer and I hope we see the many rumored upgrades. Leather and DVD entertainment are confirmed but HP increase and "mild" refreshening of exterior are not.
  • azmom1azmom1 Member Posts: 6
    I am curious as to what kind of arrangement you made with the dealer re 2002 models with no delivery date, no price set--I put a deposit on a 2001 ex, but may want to wait. I think I have a reasonable deal with this dealership and am a little afraid of starting the whole process over. I don't want leather, just side air bags, maybe a less boring color, and a car one year less depreciated. Are you planning on paying MSRP/above/below? Will your dealer be adding on their "package" of price stuff? Or is the arrangement just that you get first refusal on the 2002 when it arrives? I tried calling the dealership for general info about the 2002 and they know even less than is on this board. I appreciate everyone's comments about the 2002. Thanks
  • vicnkimvicnkim Member Posts: 1
    Help Please!!!!! OHIO PLANT VS. Canadian PLANT. We recently purchased a 2001 Odyssey
    up here in Alaska and it states on the door panel that is was manufactured in Canada. Is this a problem?? The internet only talks about the OHIO plant. so first I need info about how the Canadian Plant operates and who they send their Odyssey's to in the USA? When we questioned the sales representative he stated that "The Canadian Plant makes Odyssey's for both the Canadian market and the American market...
    IS this True???? if this is true my 2nd question is how do I find out I have a Honda Odyssey that is made for the American market?
  • newtohondasnewtohondas Member Posts: 3
    We have a 2000 Odyssey LX purchased in Virginia. It was supposedly made in Canada.
    On an unrelated topic, our 1 year old van has never been waxed. Any thoughts on when it should receive its first, and how often?
    All Odysseys are made in Canada. The ones made for the Canadian and outside the U.S. market are somewhat different. The instrument panel is in metric,and they have heated mirrors on the outside and a few other things, that is covered in a previous post on this board.
    If you live in the U.S. you do not get a factory warranty if you buy an Odyssey made for sale outside the U.S. If the dealer were to sell you one of these, he would have to tell you in writing and have you sign that you understood what you were buying. He would also then supply his own nonfactory warranty. Otherwise you could take it back to the dealer and get all your money back.
  • mschafermschafer Member Posts: 317
    I have 98,000 on my 99EX. About 90-95% highway driving.
    I must have a lemon, since I've not experienced the myriad woes with sliding doors, tires, tranny clunks, A/C clunks, pulling to the right or left, etc, ad infinitum.
    The vehicle has *never* visited the dealer for service. I changed the oil + filter at 1,000 miles and every 5,000 miles thereafter. I changed the air filter and A/C filter at 30k, 60k and 90k miles and changed the ATF at 45k and 90k. I did the front brake pads at about 60,000 miles. The original Firestone Affinity tires went almost 65,000 miles before I replaced them. I rotate at 5k, 10k and every 10k thereafter.
    I did have the CEL & TCS lights come on starting at about 70,000 miles; and found a shade tree mechanic type home brew solution to the problem that does now have a TSB to fix it; but I doubt seriously if I'll get any dealer to do it gratis at 98,000 miles.
    It will have to go in for the timing belt change at 105,000 miles, so that will be it's first dealer visit. I wish Honda would get with the times, and eliminate this ridiculous requirement for their engines; but I guess their dealer service departments need to have something to do.
    Hope this answers your question.
    You're about a year late on your first wax job.
    Thanks for the extended warranty information.
    I lived in Canada for a period of 6 months (wink wink nod nod). While there I purchased a 1999 EX at Canadian list - still, this was below US invoice (as published then). To execute the deal I needed a Canadian DL. I was able to get back both GST and PST (another words all Canadian tax). When I registered in US I paid state sales tax (NY). With NAFTA, there are no duties. The only other two considerations were NHTSA (US safety standards) and EPA standards. For Canadian built cars, both of these were not issues for bringing in the 1999 Odyssey (and still are not issues for any Canadian built cars). Paper work was needed, but no big deal. Crossing the border is a non-event - just make sure to get documentation that shows you brought it in (some form from customs).
    The bad news -- as stated in this forum, Honda US is a real pain in the back side. Even when presented with proof of living in Canada and new US residency, they would not transfer warranty. I did not push because we: A) Had no problems in Warranty and B) Are close to original dealer in Canada.
    From my understanding, the Canadian Odyssey is the car I would have gotten in the US (in 1999) except for heated mirrors and driving lights (come standard on Canadian version).
    The mileage - at 57,000KM <35,000+ miles> (yes - we left all the gauges the way they were - no big deal looking at the inner ring of the speedometer) we have had no issues and would buy again.
    One transient issue is a pretty serious "THUMP" when put into reverse. This only happens once a month and is not repeatable (atleat not to me). Tried the "park on slight incline and put into gear" routine --- no luck. And hence the reason for the extended warranty - (with sliding doors, etc) I don't want to be on the hook if the transmission issue comes home to roost.
    Also, my appologies for long post - some info may be of use.
  • lexsarlexsar Member Posts: 14
    I have a '00 Ody EX with 26K miles on it. I have always noticed a noise from the brakes (front disc) that sounds like the brake pads re-seating themselves. If I have been going forward, they make this re-seating noise the first time I apply the brakes going in reverse. Conversely, if I have been in reverse, the noise occurs the first time I apply the brakes going forward. Dealer says they don't hear anything. Anyone have a similar experience with the front disc brake pads?
  • auburn63auburn63 Member Posts: 1,162
    This is considered normal by Honda but there is something you can do or have done. If you take the front pads out and spray disc brake quiet bettween the shims and on the outside of the shims, then reassembly you will see that the problem goes away for a long time.
  • twinmommatwinmomma Member Posts: 6
    Hello. I've been reading this forum from the beginning and only have about 1K left to read! Hopefully I am fairly safe in assuming this question has not been posted before. I am a current Honda civic owner and am bound and determined to own an Ody in a month or two. (Anyone in the market for an '87 Civic? Just kidding I am not advertising!) What I want to know is does the Ody have a time belt or chain? My FIL says stay away from belts, stay only w/ chains because belts break too often. I am auto illiterate, admittedly, and it cost me big time. Apparently the belt in our Civic had never been changed (we've owned for almost 3 years) and finally wore out at 128K while I was on the hwy going 70. Yes, I can hear the groans... my engine needed a triple bypass, er valve job...$900. How often do those need to be maintained? Is it true, should I stay away from belts and stick w/ chains? It is definitely not the determining factor in vehicle choice: safety, reliability, room, features are. How can I find out this info on the Ody? I called a dealership, they did not know. Thanks for your help.
    The Ody has a timing *belt*. Under normal driving conditions it should be changed at 105,000 miles. Under severe conditions, sooner.
    If the dealership did not know whether or not it has a belt, that would be one dealer service department that I would avoid like the plague.
