Visitor Agreement.
Your concerns are well-founded - the vehicle will probably ride much more stiffly and be much less capable in slipperly conditions. But it will probably handle more crisply and have a sportier feel. And big wheels are very "cool" these days.
All depends on what you want out of your Pilot. Personally, if I wanted a pavement-only sport SUV, I wouldn't screw around with bigger wheels on the Pilot, I'd get something else like an X5.
- Mark
Pilot EX-L w/DVD
Odyssey EX-L w/DVD
Odyssey Touring w/DVD
Sienna XLE w/DVD and w/AWD?
Situation:
1. One child with another on the way.
2. Yearly trip to Mammoth for skiing in December.
3. Yearly trip to Mammoth for camping in July with the need to tow a 3,000 lbs tent trailer.
4. Up to 3 other family members to haul during trips #2 and #3 above.
Well, which vehicle is the best fit given the situations above. I am also thinking about the Sequoia and 4Runner, but the Sequoia's mpg stinks and 4Runner's 3rd row seat is kinda of tight. My co-worker mentioned the MDX, but it seems overpriced.
The sequoia is a good option for the towing. Nissan has 2 new offerings, the Pathfinder and the Armada, you should check out those as well as a tahoe.
Another good option is the V8 4Runner, although it is smaller inside than the Pilot.
- Mark
rent a suburban twice a year, or pay your other family members a franklin to drive themselves.
hint: many people go from a 2 door to a 4 door to avoid the hassle of having to seat/get kids out of row behind the door. why would you want to put the carseat kids in the 3rd row?
the 3rd row in an suv is probably safer than in a minivan, in most cases, beause it is higher off the ground. just my 2 cents.
Edited from 45 pounds to 4500 pounds . Ooopps my typo
We say 4500 for boats: link
If I was regularly towing a 4000 lb boat, I'd be looking for a different vehicle.
- Mark
I would advise against towing such a heavy load at speeds sufficient for aerodynamics to make much of a difference! :-)
markjenn, I don't think the Pathfinder is a good option for most people with young children. While I think it is very cool and forward in style, it is smaller inside than the Pilot. Maybe it's just that I was so used to the Pilot, but the Pathfinder just felt odd and I preferred the handling of the Pilot, too.
BUT! Now we own an 05 Ody, and it wins hands down for ease with the kids. Easier loading, more space, and more options and toys.
Thanks for the info. I will officially remove the Pilot from consideration.
Randy
Its the only thing that will meet you tough demands.
My "fix" certainly made the seat better (for me), but I would also prefer something more comfortable. Honda uses thin metal bars in pockets on the underside of the seat material to define the tucked portion of the seat bottom. Those bars are pulled down with hog rings to some hemp cord that is embedded in the seat foam. Those darn metal rods can be felt if you push down on the seat. I could feel them when seated also. I removed the seat covering and then removed those bars. I ended up covering the bars with a high density foam material (I think I ended up using strips of copper pipe insulation cut into long 1/2" wide strips). I then removed very small sections so that the hog rings could be reattached). I am in the process of having a contact in the automotive industry make an entirely new foam seat bottom of different density. I am still working on the details on the whole "bar and tucking" situation. In the end, I think one would be best to just use a nice covered pad and sit on that. I think the seat removal and process of wrapping those rods is more trouble that it was worth.
With 7 people in the MDX/Pilot there will be limited space for cargo...unless you add a roof box carrier or load up the trailer with tons of stuff.
You probably should be OK for a once a year trip. You just need to be aware of how much you are loading up...for example when we go to Nantucket and I am worried about going over the 1000 lb. cargo limit of my truck and my mom cannot understand why I am upset that she wants to bring 50 lbs of potatoes in a huge lobster pot on top of all the other items(to save money at the store). Which of course we never eat all of anyway. This is usually when I have already figured out that we are at 1400 lbs people and cargo.
I think the pilot can "handle" that much load, but it really isn't a tow vehicle. You run the risk of shortening the life of the transmission, brakes, etc. You are very close to the limits if not over...I suggest taking a second car and you are all set.
I do not know how much experience you have towing but you never want to be at the absolute limits of your tow vehicle. The safety of your family is more important than the savings over the Sequoia.
Your actual trailer weight will be considerably more than the dry weight as indicated by another post.
Max towing specs based on 4 people in the vehicle according to Honda.
I don't think a pilot is the right choice. Have you checked out the Nissan Pathfinder It might price a little less than the Sequoia.
With the kind of weight you are considering you need a tow vehicle with a heavier duty braking system especially if your tent trailer does not have its own braking system.
Avoiding an accident is all about experience, vehicle control and braking. A heavier tow vehicle will have more control over your tent trailer.
The transmission is nothing short of frustrating when towing since you cannot manually put it in 4th gear. You will need to stop approximately every 170 miles to fill up which makes for a longer trip on a long haul.
Tow ratings are certainly useful, but there are really two key differentiators between a vehicle that works well towing and one that does it barely: weight and body-on-frame vs. unibody. To get more weight, you need to go up a size to a Sequoia, Expedition, Tahoe class of vehicle which you may not want to do. But you can get body-on-frame rather than unibody by going with the 4Runner or Pathfinder.
The Pilot is a great vehicle and will handle occasional towing fine, but it is based on the Odyssey unibody platform - it is most definitely a car-based SUV rather than a truck-based SUV. If there is any significant towing planned (weight, distance, frequency), there simply are better choices. I don't think you'd give up any significant reliability going with the 4Runner or Pathfinder. You would give up a little comfort and on-road smoothness, but that's the price you pay for a truck-based SUV.
- Mark
Wonder if the Chevy Astro/GMC safari would work. Real chassis.. 5000lbs towing capacity, awd, 1500lbs payload...lots of space inside
But its a GM....
2005 is the last year of those modesl
I had planned to buy the Element liking its versatility but was surprised by the low mileage as compared to the Pilot. According to Consumer Reports magazine tests there is only about 1 mpg difference between the Element and the Pilot for highway and city driving. The Pilot is much bigger so if I am going to get bad mileage I might as well go with the larger vehicle.
Can anyone give me advice regarding the pros and cons of the Element vs. the Pilot and even the CRV. The CRV is my last choice as it is small. There is only my husband and I so far in our family but I want enough space to lug mtn bikes, camping equipment and large items.
- Brenda Silver
Nova Scotia
There is no perfect vehicle. For me - The highlander is too small, the Sequoia too truck like; the Ody has too many problems right now. I could get better mileage with something else but when I weigh my need for room (Pilot) and my need for quality (Honda I hope) then I realize that I will just have to live with less mileage than I want. Back in the early 70s a lot of people traded their gas guzzlers for Pintos and Vegas and quickly found out that a family of four couldn't survive with that as a primary vehicle and long trips were a pain, literally. You have to go with what best fits your needs and that's the problem, separating needs from emotions and wants.
What has impressed me with the Pilot is the low number of issues or problems. Do wish the beige dash plastic looked better.
uhhh... doesn't matter what honda claims when the NHTSA gives it 5 stars on all front and side crash tests.
And I'm not sure why you are comparing your FWD 3400 lb. V6 sedan's mileage to that of an AWD 4400 lb. SUV. Heck, when I put it that way, I think the LS only getting a few extra MPG is downright sad and a testament to the Pilot's efficiency.
I have 3 kids and mixed feelings on airbags. Some designs are better than others. In general airbags and kids don't mix well. One reason kids are in the back seat is because of airbags.
--jay
You probably would gain reliability going with the 4Runner. And you could double the tow rating by going with the V8.
- Mark
"Head injury, although measured, is not currently included in the star rating."
-from NHTSA website regarding side impact star ratings
Again, you are right on the mileage, I had not considered the difference in vehicles, if the Impala wighed another 1000 pounds I would probably be worse than the Pilot. (Not to mention replacing the rotors front AND REAR more often currently every 30 - 35K)
Nowadays, with so many minivans and SUV's on the road, many side-impacts are focused higher on the vehicles. EuroNCAP began adding a "pole test," which while not as relevant, demonstrated that a 5-star-NHTSA vehicle could do poorly. The new IIHS test, which uses a barrier more similar to the size of an SUV, demonstrates that a number of 5-star NHTSA vehicles don't fare well when hit by a larger object. Having some kind of head protection airbag is a key.
Honda is definitely behind the curve here. Eventually the Pilot will have side curtains, though.
As far as children and side curtain airbags, there are two areas of thought:
- The side curtains deploy downward and along the side, with nowhere near the force of front airbags. There has been no demonstrated injury risk to occupants who may be out-of-position from side curtain airbags.
Volvo actually goes one step further -- when the side curtain inflates downward, it actually "slows down" at around the midpoint of the window. Still fast enough to inflate quickly enough to provide head protection, but with a little less force in the end.
- The effectiveness of side curtain airbags in protecting children is debatable. Most of the cushioning of those bags is aimed where an adult's head normally is. Some bags have little or no effective cushioning near the bottom. They look like they might, but the edge of the bag is often for structuring the bag. Thus, many smaller children won't be high enough to get protection.
This will vary dramatically based on the height of the child, and the type of car seat they sit in. As well as the vehicle's airbag design.
Hopefully I will never have to test them in any of my vehicles.
you might consider aftermarket rotors on the Impala. My Volvo has the same issue (as do many vehicles these days - usually higher-end manufacturers from what I've read), but after a couple of sets of OEM rotors, I went aftermarket and they are not wearing out nearly as fast as the OEM ones.
- Mark
