does anyone know if the software has been updated for the 2004 model? the 2003 i believe is 3-1/31 (look under the "Set" screen and see what the numbers are at the top)
Anyone else here have seen this? What was your experience? Is it critical enough that I dring it to a dealer right away, as the manual says?
Thanks in advance!
Eduardo
Los Angeles, CA
My 2000 RR had a similar indication after running it through a carwash, interior fan kicked on high and would not go off and the indicator you mentioned came on. Long story short, I guess a relay had gotten wet and h/c system reacted as it did, because it eventually (2 days later) cleared the fault and shut the fan off.
Eduardo
Los Angeles, CA
Source: Edmunds.com SUVs newsletter
In doing comparisons with the RR's competitors, other than the Mercedes G-Class (not interested), the RR's price is significantly higher?
For those of you RR owners, have you found it to be worth the money?
If you could do it all over again, would you have purchased your RR?
Also, I noticed mine running rough at idle with the brake applied but it smoothes out nicely as soon as I take my foot off the brake. Any Ideas?
The steering wheel squeak is also in a service bulletin.... but maybe the cold weather is making some of the plastic in the column support area brittle.
RR or Cayenne... I think both have excellent attributes...but over the long term I think the RR has a more compliant ride. All the reviews of the Toureg and Cayenne point to the harsh ride as being a negative. After that I think it boils down to which one "looks" better for you...the razor redged RR or the guppy face Cayenne (no bias here!)
Keep the updates coming from current owners please!
BTW, does the navigation system use DVD or CD-ROM for 2004?? Can you order a RR withOUT navigation??
Cayenne or Range Rover - I'm a Porsche fan as well, this will be an interesting choice. Another SUV I like a lot is the VW Touareg, it's interior design, material quality, fit and finish isn't too far off the Range Rover's at all, it's very nearly equal.
Steering Column Cowl Rub
No: 76/22/03/NAS
Ref:
Issue: 1
Date: 12/05/03
AFFECTED VEHICLE RANGE:
New Range Rover (LM) All
SITUATION:
STEERING COLUMN COWL CONTACTS THE STEERING WHEEL
The column cover may have been incorrectly installed during a repair procedure permitting contact with the steering wheel and causing a rubbing noise. The information in the current RAVE Workshop Manual is incomplete and does not indicate all required steps.
RESOLUTION:
REPOSITION THE COWL FOR CORRECT CLEARANCE
Should a customer express concern regarding the above, follow the rectification procedure outlined in
this bulletin.
I have a 2003 and a 2004 RR, and I had maybe one or two small issues with the 2003 and none with the 2004. Aside from improvements to the radio and nav software, there are no other noticeable differences. If you get a late 2003 or a 2004 I think you'll be OK.
You might want to check out the upgraded luxury package ($5000) on the 2004... the seats are awesome, and there is leather on the doors and upper dashboard.
I subscribed to a RR technical service bulletin update, and there have been very few new items since October of last year.
Many Thanks
The RR is a full size SUV, the Cayenne more or less is midsize. The Cayenne is more of a sport oriented SUV, still has touches of luxury but the suspension is harsher than the RR (which can be described as smooth, slightly bouncy). Granted the RR isn't a bad handling vehicle, just the Cayenne is better. The RR has nice throttle response for its size, but still not anywhere close to the Cayenne S (talking 8.9-9.0sec to 60 vs. around 7.1-7.2sec for the Cayenne).
Now the subjective part, I think the RR is an infinitely better looking vehicle. Has a more classic, stately, and prestigious appearance to it. The RR is also more exclusive. With the introduction of the Cayenne V6 (bases at $43k), the Cayenne is destined to become a very common vehicle....just like the X5. Granted, the Cayenne Turbo has a slightly more unique look to it(different hood and bumper, red calipers, rear valence) but overall to most peoples eyes they all look the same. So it takes minimum $43k to get into a Cayenne and still takes $72k to get into a RR.
As far as the interiors are concerned, I like both the Cayenne and RR...but some things about the Cayenne's gut just strike me as a tad low rent.
Both vehicles Nav systems are not the easiest and are CD based.
So I would say.....If you're looking for more of a luxury ship with classic charm take a hard look at the RR. On the other hand, if you want a little sport in your SUV (steering wheel mounted shift buttons) and welcome the slightly smaller overall size take a look at the Cayenne.
Dandman: If we were to believe you then Pamela should be the first choice for marriage. While we are behind the AAA truck, the mechanic is sleeping with Pamela. LOL! How funny the elegance is!
Also, any way to make the NAV screen default to off on start up?
Has anyone hard wired a V1 using the power in the overhead light module? Is it easy to remove the light console to tap into a switched lead?
Sorry I don't have a solution to offer to your questions.
Kind Regards
I would weigh in on the Cayenne v. RR issue in favor of the RR. I drove a Cayenne S twice and found it not to be comfortable for a SUV type vehicle. Sure it is faster off the line than the RR, but you give up a lot in features and more importantly, space, for both driver and passengers, and cargo.
If I want to corner and accelerate fast (relative to SUVs, not supercars) I drive the Porsche C4S. If I need the space, the RR wins out.
Anyone hardwire a radar detector using the overhead light console? I am looking for detail on the panel removal.
If the 05 Nav is new (dvd based), hopefully it can be retrofitted at a somewhat reasonable cost. I should say though, the Jag Nav system isn't so intuitive either with that touch screen (still fussy). Its a tad easier to use than the RRs but not by a large margin. The main advantage to the switch will be that its DVD based (makes things a little more convenient for those that travel all over the place).
It cannot be tightened to make it seal better, and please DO NOT pour that "stop leak" stuff into your engine... it causes many more problems than it "might" solve.
My Rover (same V8) looked as if it had the same leak... they looked a little harder (dye in the oil and fluorescing investigation) and found it was my failing cork valve cover gasket. Those are simple and fast to replace, and the oil seeping down the back of the block looks just like a leak at the main.
My question: how much is a "very small" leak? Do you get a drop overnight? 5 drops?
I personally would not have it changed unless it was leaking badly. A teaspoon of oil overnight would bother me a lot. Otherwise I'd live with it and avoid problems "down the road" as you suggest. A piece of cardboard beneath the drip will keep the garage clean.
Besides, this way you'll be missing out on one of the most valuable of all Rover diagnostics: "when it stops leaking, it's empty".
Seriously, this sounds like a very minor leak (hopefully) and I wouldn't pay 3-4 days labor to fix it.
Best regards,
-Bob
If your RR is already out of warranty, then I agree with nanug, if it's a tiny leak, you should wait to see if it gets worse.
-Tom
Y'know if it's under warranty, I'd think pretty hard about having this fixed. Especially if they'll put in writing that anything getting disturbed by THIS repair remains covered after warranty expiration. You might also ask them to gauge the main bearings and such as it's apart just to make sure all is well in the engine room. It seems a little premature for a rear main leak with ... what did you say, 20k miles? Maybe they can "mike" the crank to ensure roundness and stuff too. Or it could have just been a bad seal. I've seen plenty of those.
Rovers are easy enough to work on, and simple enough, that any time I had the chance for warranty work I'd have them dig in a little. They went ahead and did many items from the TSB list for free, and upgraded quite a lot of my truck. The trucks aren't complex enough that I worried about fixing one thing, but breaking two others.
In your message, you stated that you noticed improvements to the nav system from 03 to 04. Can you ellaborate?
Anyone else experience this?
I bought the Infinity 3002cf 3-1/2" at Circuit City for $59 and found that it fits the holes fine but it's slightly thick on the back and front. So I'm returning it tomorrow.
So (1) anyone know how to "properly" remove the speaker covers? And (2) what's a good compatible speaker replacement?
Thanks in advance!
Eduardo
Los Angeles, CA
